root/Development/ray/src/util/cmatrix.c
Revision: 2.41
Committed: Sat Apr 19 17:12:59 2025 UTC (8 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.40: +1 -12 lines
refactor: Isolated RMATRIX<->CMATRIX conversion routines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.41 static const char RCSid[] = "$Id: cmatrix.c,v 2.40 2025/03/22 01:27:22 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Color matrix routines.
6     *
7     * G. Ward
8     */
9
10     #include <ctype.h>
11 schorsch 2.16 #include "platform.h"
12 greg 2.1 #include "standard.h"
13     #include "cmatrix.h"
14     #include "platform.h"
15 greg 2.14 #include "paths.h"
16 greg 2.2 #include "resolu.h"
17
18 greg 2.1 /* Allocate a color coefficient matrix */
19     CMATRIX *
20     cm_alloc(int nrows, int ncols)
21     {
22     CMATRIX *cm;
23
24     if ((nrows <= 0) | (ncols <= 0))
25     error(USER, "attempt to create empty matrix");
26     cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
27 greg 2.29 sizeof(COLOR)*((size_t)nrows*ncols - 1));
28 greg 2.21 if (!cm)
29 greg 2.1 error(SYSTEM, "out of memory in cm_alloc()");
30     cm->nrows = nrows;
31     cm->ncols = ncols;
32     return(cm);
33     }
34
35 greg 2.6 static void
36     adjacent_ra_sizes(size_t bounds[2], size_t target)
37     {
38     bounds[0] = 0; bounds[1] = 2048;
39     while (bounds[1] < target) {
40     bounds[0] = bounds[1];
41     bounds[1] += bounds[1]>>1;
42     }
43     }
44
45 greg 2.1 /* Resize color coefficient matrix */
46     CMATRIX *
47     cm_resize(CMATRIX *cm, int nrows)
48     {
49 greg 2.6 size_t old_size, new_size, ra_bounds[2];
50
51 greg 2.21 if (!cm)
52     return(NULL);
53 greg 2.1 if (nrows == cm->nrows)
54     return(cm);
55     if (nrows <= 0) {
56     cm_free(cm);
57     return(NULL);
58     }
59 greg 2.30 old_size = sizeof(CMATRIX) + sizeof(COLOR)*((size_t)cm->nrows*cm->ncols - 1);
60 greg 2.6 adjacent_ra_sizes(ra_bounds, old_size);
61 greg 2.30 new_size = sizeof(CMATRIX) + sizeof(COLOR)*((size_t)nrows*cm->ncols - 1);
62 greg 2.6 if (nrows < cm->nrows ? new_size <= ra_bounds[0] :
63     new_size > ra_bounds[1]) {
64     adjacent_ra_sizes(ra_bounds, new_size);
65     cm = (CMATRIX *)realloc(cm, ra_bounds[1]);
66 greg 2.21 if (!cm)
67 greg 2.6 error(SYSTEM, "out of memory in cm_resize()");
68     }
69 greg 2.1 cm->nrows = nrows;
70     return(cm);
71     }
72
73 greg 2.5 typedef struct {
74     int dtype; /* data type */
75 greg 2.22 int need2swap; /* need byte swap? */
76 greg 2.5 int nrows, ncols; /* matrix size */
77 greg 2.25 COLOR expos; /* exposure value */
78 greg 2.5 char *err; /* error message */
79     } CMINFO; /* header info record */
80
81 greg 2.1 static int
82 greg 2.5 get_cminfo(char *s, void *p)
83 greg 2.1 {
84 greg 2.5 CMINFO *ip = (CMINFO *)p;
85 greg 2.20 char fmt[MAXFMTLEN];
86 greg 2.2 int i;
87 greg 2.5
88 greg 2.40 if (isncomp(s) && ncompval(s) != 3) {
89 greg 2.5 ip->err = "unexpected # components (must be 3)";
90     return(-1);
91     }
92     if (!strncmp(s, "NROWS=", 6)) {
93     ip->nrows = atoi(s+6);
94     return(0);
95     }
96     if (!strncmp(s, "NCOLS=", 6)) {
97     ip->ncols = atoi(s+6);
98     return(0);
99     }
100 greg 2.22 if ((i = isbigendian(s)) >= 0) {
101     ip->need2swap = (nativebigendian() != i);
102     return(0);
103     }
104 greg 2.25 if (isexpos(s)) {
105     double d = exposval(s);
106     scalecolor(ip->expos, d);
107     return(0);
108     }
109     if (iscolcor(s)) {
110     COLOR ctmp;
111     colcorval(ctmp, s);
112     multcolor(ip->expos, ctmp);
113     return(0);
114     }
115 greg 2.2 if (!formatval(fmt, s))
116     return(0);
117     for (i = 1; i < DTend; i++)
118     if (!strcmp(fmt, cm_fmt_id[i]))
119 greg 2.5 ip->dtype = i;
120 greg 2.1 return(0);
121     }
122
123 greg 2.5 /* Load header to obtain/check data type and number of columns */
124     char *
125 greg 2.25 cm_getheader(int *dt, int *nr, int *nc, int *swp, COLOR scale, FILE *fp)
126 greg 2.1 {
127 greg 2.5 CMINFO cmi;
128     /* read header */
129     cmi.dtype = DTfromHeader;
130 greg 2.22 cmi.need2swap = 0;
131 greg 2.25 cmi.expos[0] = cmi.expos[1] = cmi.expos[2] = 1.f;
132 greg 2.5 cmi.nrows = cmi.ncols = 0;
133     cmi.err = "unexpected EOF in header";
134 greg 2.7 if (getheader(fp, get_cminfo, &cmi) < 0)
135 greg 2.5 return(cmi.err);
136 greg 2.21 if (dt) { /* get/check data type? */
137 greg 2.5 if (cmi.dtype == DTfromHeader) {
138     if (*dt == DTfromHeader)
139     return("missing/unknown data format in header");
140     } else if (*dt == DTfromHeader)
141     *dt = cmi.dtype;
142     else if (*dt != cmi.dtype)
143     return("unexpected data format in header");
144     }
145 greg 2.21 if (nr) { /* get/check #rows? */
146 greg 2.5 if (*nr <= 0)
147     *nr = cmi.nrows;
148     else if ((cmi.nrows > 0) & (*nr != cmi.nrows))
149     return("unexpected row count in header");
150     }
151 greg 2.21 if (nc) { /* get/check #columns? */
152 greg 2.5 if (*nc <= 0)
153     *nc = cmi.ncols;
154     else if ((cmi.ncols > 0) & (*nc != cmi.ncols))
155     return("unexpected column count in header");
156     }
157 greg 2.22 if (swp) /* get/check swap? */
158     *swp = cmi.need2swap;
159 greg 2.25 if (scale) { /* transfer exposure comp. */
160     scale[0] = 1.f/cmi.expos[0];
161     scale[1] = 1.f/cmi.expos[1];
162     scale[2] = 1.f/cmi.expos[2];
163     }
164 greg 2.5 return(NULL);
165 greg 2.1 }
166
167 greg 2.23 /* Allocate and load image data into matrix */
168     static CMATRIX *
169 greg 2.37 cm_load_rgbe(FILE *fp, int nrows, int ncols)
170 greg 2.23 {
171     CMATRIX *cm;
172     COLORV *mp;
173     /* header already loaded */
174     cm = cm_alloc(nrows, ncols);
175     if (!cm)
176     return(NULL);
177     mp = cm->cmem;
178     while (nrows--) {
179     if (freadscan((COLOR *)mp, ncols, fp) < 0) {
180     error(USER, "error reading color picture as matrix");
181     cm_free(cm);
182     return(NULL);
183     }
184 greg 2.37 mp += 3*ncols;
185 greg 2.23 } /* caller closes stream */
186     return(cm);
187     }
188
189 greg 2.9 /* Allocate and load a matrix from the given input (or stdin if NULL) */
190 greg 2.1 CMATRIX *
191 greg 2.9 cm_load(const char *inspec, int nrows, int ncols, int dtype)
192 greg 2.1 {
193 greg 2.15 const int ROWINC = 2048;
194 greg 2.36 int dimsOK = (dtype == DTascii) | (nrows > 0) && ncols;
195 greg 2.22 int swap = 0;
196 greg 2.32 FILE *fp;
197 greg 2.25 COLOR scale;
198 greg 2.15 CMATRIX *cm;
199 greg 2.1
200 greg 2.33 if (!inspec)
201     inspec = stdin_name;
202     else if (!*inspec)
203 greg 2.32 return(NULL);
204 greg 2.33 if (inspec == stdin_name) { /* reading from stdin? */
205 greg 2.32 fp = stdin;
206 greg 2.33 } else if (inspec[0] == '!') {
207 greg 2.9 fp = popen(inspec+1, "r");
208 greg 2.21 if (!fp) {
209 greg 2.9 sprintf(errmsg, "cannot start command '%s'", inspec);
210     error(SYSTEM, errmsg);
211     }
212 greg 2.21 } else if (!(fp = fopen(inspec, "r"))) {
213 greg 2.9 sprintf(errmsg, "cannot open file '%s'", inspec);
214 greg 2.1 error(SYSTEM, errmsg);
215     }
216     #ifdef getc_unlocked
217     flockfile(fp);
218     #endif
219     if (dtype != DTascii)
220     SET_FILE_BINARY(fp); /* doesn't really work */
221 greg 2.36 if (!dtype | !dimsOK) { /* expecting header? */
222 greg 2.25 char *err = cm_getheader(&dtype, &nrows, &ncols, &swap, scale, fp);
223 greg 2.21 if (err)
224 greg 2.5 error(USER, err);
225 greg 2.36 dimsOK = ncols > 0 && ( nrows > 0 ||
226     (dtype != DTrgbe) & (dtype != DTxyze) );
227 greg 2.5 }
228 greg 2.36 if (!dimsOK && !fscnresolu(&ncols, &nrows, fp))
229 greg 2.34 error(USER, "unspecified matrix size");
230 greg 2.1 switch (dtype) {
231     case DTascii:
232     case DTfloat:
233     case DTdouble:
234     break;
235 greg 2.23 case DTrgbe:
236     case DTxyze:
237 greg 2.37 cm = cm_load_rgbe(fp, nrows, ncols);
238 greg 2.23 goto cleanup;
239 greg 2.1 default:
240     error(USER, "unexpected data type in cm_load()");
241     }
242     if (nrows <= 0) { /* don't know length? */
243     int guessrows = 147; /* usually big enough */
244 greg 2.27 if (cm_elem_size[dtype] && (fp != stdin) & (inspec[0] != '!')) {
245 greg 2.1 long startpos = ftell(fp);
246     if (fseek(fp, 0L, SEEK_END) == 0) {
247 greg 2.27 long rowsiz = (long)ncols*cm_elem_size[dtype];
248 greg 2.1 long endpos = ftell(fp);
249
250 greg 2.27 if ((endpos - startpos) % rowsiz) {
251 greg 2.1 sprintf(errmsg,
252     "improper length for binary file '%s'",
253 greg 2.9 inspec);
254 greg 2.1 error(USER, errmsg);
255     }
256 greg 2.27 guessrows = (endpos - startpos)/rowsiz;
257 greg 2.1 if (fseek(fp, startpos, SEEK_SET) < 0) {
258     sprintf(errmsg,
259     "fseek() error on file '%s'",
260 greg 2.9 inspec);
261 greg 2.1 error(SYSTEM, errmsg);
262     }
263     nrows = guessrows; /* we're confident */
264     }
265     }
266     cm = cm_alloc(guessrows, ncols);
267     } else
268     cm = cm_alloc(nrows, ncols);
269 greg 2.21 if (!cm) /* XXX never happens */
270 greg 2.1 return(NULL);
271     if (dtype == DTascii) { /* read text file */
272     int maxrow = (nrows > 0 ? nrows : 32000);
273     int r, c;
274     for (r = 0; r < maxrow; r++) {
275     if (r >= cm->nrows) /* need more space? */
276 greg 2.15 cm = cm_resize(cm, cm->nrows+ROWINC);
277 greg 2.1 for (c = 0; c < ncols; c++) {
278     COLORV *cv = cm_lval(cm,r,c);
279 greg 2.13 if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) {
280 greg 2.1 if ((nrows <= 0) & (r > 0) & !c) {
281     cm = cm_resize(cm, maxrow=r);
282     break;
283     } else
284     goto EOFerror;
285 greg 2.13 }
286 greg 2.1 }
287     }
288     while ((c = getc(fp)) != EOF)
289     if (!isspace(c)) {
290     sprintf(errmsg,
291 greg 2.9 "unexpected data at end of ascii input '%s'",
292     inspec);
293 greg 2.1 error(WARNING, errmsg);
294     break;
295     }
296     } else { /* read binary file */
297 greg 2.2 if (sizeof(COLOR) == cm_elem_size[dtype]) {
298 greg 2.31 size_t nread = 0;
299 greg 2.1 do { /* read all we can */
300 greg 2.17 nread += getbinary(cm->cmem + 3*nread,
301 greg 2.4 sizeof(COLOR),
302 greg 2.31 (size_t)cm->nrows*cm->ncols - nread,
303 greg 2.1 fp);
304     if (nrows <= 0) { /* unknown length */
305 greg 2.31 if (nread == (size_t)cm->nrows*cm->ncols)
306 greg 2.1 /* need more space? */
307 greg 2.15 cm = cm_resize(cm, cm->nrows+ROWINC);
308 greg 2.1 else if (nread && !(nread % cm->ncols))
309     /* seem to be done */
310     cm = cm_resize(cm, nread/cm->ncols);
311     else /* ended mid-row */
312     goto EOFerror;
313 greg 2.31 } else if (nread < (size_t)cm->nrows*cm->ncols)
314 greg 2.1 goto EOFerror;
315 greg 2.31 } while (nread < (size_t)cm->nrows*cm->ncols);
316 greg 2.1
317 greg 2.26 if (swap) {
318     if (sizeof(COLORV) == 4)
319     swap32((char *)cm->cmem,
320 greg 2.31 3*(size_t)cm->nrows*cm->ncols);
321 greg 2.26 else /* sizeof(COLORV) == 8 */
322     swap64((char *)cm->cmem,
323 greg 2.31 3*(size_t)cm->nrows*cm->ncols);
324 greg 2.26 }
325 greg 2.1 } else if (dtype == DTdouble) {
326     double dc[3]; /* load from double */
327     COLORV *cvp = cm->cmem;
328 greg 2.31 size_t n = (size_t)nrows*ncols;
329 greg 2.1
330     if (n <= 0)
331     goto not_handled;
332     while (n--) {
333 greg 2.17 if (getbinary(dc, sizeof(double), 3, fp) != 3)
334 greg 2.1 goto EOFerror;
335 greg 2.26 if (swap) swap64((char *)dc, 3);
336 greg 2.1 copycolor(cvp, dc);
337     cvp += 3;
338     }
339     } else /* dtype == DTfloat */ {
340     float fc[3]; /* load from float */
341     COLORV *cvp = cm->cmem;
342 greg 2.31 size_t n = (size_t)nrows*ncols;
343 greg 2.1
344     if (n <= 0)
345     goto not_handled;
346     while (n--) {
347 greg 2.17 if (getbinary(fc, sizeof(float), 3, fp) != 3)
348 greg 2.1 goto EOFerror;
349 greg 2.26 if (swap) swap32((char *)fc, 3);
350 greg 2.1 copycolor(cvp, fc);
351     cvp += 3;
352     }
353     }
354     if (fgetc(fp) != EOF) {
355     sprintf(errmsg,
356 greg 2.9 "unexpected data at end of binary input '%s'",
357     inspec);
358 greg 2.1 error(WARNING, errmsg);
359     }
360     }
361 greg 2.23 cleanup:
362 greg 2.9 if (fp != stdin) {
363     if (inspec[0] != '!')
364     fclose(fp);
365     else if (pclose(fp)) {
366     sprintf(errmsg, "error running command '%s'", inspec);
367     error(WARNING, errmsg);
368     }
369     }
370 greg 2.1 #ifdef getc_unlocked
371     else
372     funlockfile(fp);
373     #endif
374 greg 2.37 if ((scale[0] < .99) | (scale[0] > 1.01) |
375     (scale[1] < .99) | (scale[1] > 1.01) |
376     (scale[2] < .99) | (scale[2] > 1.01)) {
377     size_t n = (size_t)ncols*nrows;
378     COLORV *mp = cm->cmem;
379     while (n--) { /* apply exposure scaling */
380     *mp++ *= scale[0];
381     *mp++ *= scale[1];
382     *mp++ *= scale[2];
383     }
384     }
385 greg 2.1 return(cm);
386     EOFerror:
387 greg 2.9 sprintf(errmsg, "unexpected EOF reading %s", inspec);
388 greg 2.1 error(USER, errmsg);
389 greg 2.23 return(NULL);
390 greg 2.1 not_handled:
391     error(INTERNAL, "unhandled data size or length in cm_load()");
392     return(NULL); /* gratis return */
393     }
394
395     /* Extract a column vector from a matrix */
396     CMATRIX *
397     cm_column(const CMATRIX *cm, int c)
398     {
399     CMATRIX *cvr;
400     int dr;
401
402 greg 2.21 if (!cm)
403     return(NULL);
404 greg 2.1 if ((c < 0) | (c >= cm->ncols))
405     error(INTERNAL, "column requested outside matrix");
406     cvr = cm_alloc(cm->nrows, 1);
407 greg 2.21 if (!cvr)
408 greg 2.1 return(NULL);
409     for (dr = 0; dr < cm->nrows; dr++) {
410     const COLORV *sp = cm_lval(cm,dr,c);
411     COLORV *dp = cv_lval(cvr,dr);
412     dp[0] = sp[0];
413     dp[1] = sp[1];
414     dp[2] = sp[2];
415     }
416     return(cvr);
417     }
418
419     /* Multiply two matrices (or a matrix and a vector) and allocate the result */
420     CMATRIX *
421     cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
422     {
423     char *rowcheck=NULL, *colcheck=NULL;
424     CMATRIX *cmr;
425     int dr, dc, i;
426
427 greg 2.21 if (!cm1 | !cm2)
428     return(NULL);
429 greg 2.1 if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
430     error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
431     cmr = cm_alloc(cm1->nrows, cm2->ncols);
432 greg 2.21 if (!cmr)
433 greg 2.1 return(NULL);
434     /* optimization: check for zero rows & cols */
435     if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
436     static const COLOR czero;
437     rowcheck = (char *)calloc(cmr->nrows, 1);
438     for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
439     for (dc = cm1->ncols; dc--; )
440     if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
441     rowcheck[dr] = 1;
442     break;
443     }
444     colcheck = (char *)calloc(cmr->ncols, 1);
445     for (dc = cm2->ncols*(colcheck != NULL); dc--; )
446     for (dr = cm2->nrows; dr--; )
447     if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
448     colcheck[dc] = 1;
449     break;
450     }
451     }
452     for (dr = 0; dr < cmr->nrows; dr++)
453     for (dc = 0; dc < cmr->ncols; dc++) {
454     COLORV *dp = cm_lval(cmr,dr,dc);
455 greg 2.4 double res[3];
456 greg 2.1 dp[0] = dp[1] = dp[2] = 0;
457 greg 2.21 if (rowcheck && !rowcheck[dr])
458 greg 2.1 continue;
459 greg 2.21 if (colcheck && !colcheck[dc])
460 greg 2.1 continue;
461 greg 2.4 res[0] = res[1] = res[2] = 0;
462 greg 2.1 for (i = 0; i < cm1->ncols; i++) {
463     const COLORV *cp1 = cm_lval(cm1,dr,i);
464     const COLORV *cp2 = cm_lval(cm2,i,dc);
465 greg 2.18 res[0] += (double)cp1[0] * cp2[0];
466     res[1] += (double)cp1[1] * cp2[1];
467     res[2] += (double)cp1[2] * cp2[2];
468 greg 2.1 }
469 greg 2.4 copycolor(dp, res);
470 greg 2.1 }
471 greg 2.21 if (rowcheck) free(rowcheck);
472     if (colcheck) free(colcheck);
473 greg 2.1 return(cmr);
474     }
475
476 greg 2.2 /* write out matrix to file (precede by resolution string if picture) */
477     int
478     cm_write(const CMATRIX *cm, int dtype, FILE *fp)
479 greg 2.1 {
480 greg 2.3 static const char tabEOL[2] = {'\t','\n'};
481 greg 2.21 const COLORV *mp;
482 greg 2.3 int r, c;
483 greg 2.30 size_t n, rv;
484 greg 2.2
485 greg 2.21 if (!cm)
486     return(0);
487 greg 2.39 #ifdef getc_unlocked
488     flockfile(fp);
489     #endif
490 greg 2.21 mp = cm->cmem;
491 greg 2.2 switch (dtype) {
492     case DTascii:
493 greg 2.3 for (r = 0; r < cm->nrows; r++)
494 greg 2.2 for (c = 0; c < cm->ncols; c++, mp += 3)
495 greg 2.3 fprintf(fp, "%.6e %.6e %.6e%c",
496     mp[0], mp[1], mp[2],
497     tabEOL[c >= cm->ncols-1]);
498 greg 2.2 break;
499     case DTfloat:
500     case DTdouble:
501     if (sizeof(COLOR) == cm_elem_size[dtype]) {
502 greg 2.30 n = (size_t)cm->ncols*cm->nrows;
503     while (n > 0) {
504     rv = fwrite(mp, sizeof(COLOR), n, fp);
505     if (rv <= 0)
506 greg 2.2 return(0);
507 greg 2.30 mp += 3*rv;
508     n -= rv;
509 greg 2.2 }
510     } else if (dtype == DTdouble) {
511     double dc[3];
512 greg 2.30 n = (size_t)cm->ncols*cm->nrows;
513     while (n--) {
514 greg 2.2 copycolor(dc, mp);
515 greg 2.17 if (putbinary(dc, sizeof(double), 3, fp) != 3)
516 greg 2.2 return(0);
517     mp += 3;
518     }
519     } else /* dtype == DTfloat */ {
520     float fc[3];
521 greg 2.30 n = (size_t)cm->ncols*cm->nrows;
522     while (n--) {
523 greg 2.2 copycolor(fc, mp);
524 greg 2.17 if (putbinary(fc, sizeof(float), 3, fp) != 3)
525 greg 2.2 return(0);
526     mp += 3;
527     }
528     }
529     break;
530     case DTrgbe:
531     case DTxyze:
532     fprtresolu(cm->ncols, cm->nrows, fp);
533     for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols)
534     if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0)
535     return(0);
536     break;
537     default:
538     fputs("Unsupported data type in cm_write()!\n", stderr);
539     return(0);
540 greg 2.1 }
541 greg 2.39 #ifdef getc_unlocked
542     funlockfile(fp);
543     #endif
544 greg 2.2 return(fflush(fp) == 0);
545 greg 2.1 }
