root/radiance/ray/src/util/cmatrix.c
Revision: 2.30
Committed: Fri Jan 15 17:22:23 2021 UTC (3 years, 3 months ago) by greg
Changes since 2.29: +14 -13 lines
fix: fixed a few other bugs related to 64-bit addressing
2 static const char RCSid[] = "$Id: cmatrix.c,v 2.29 2021/01/15 02:46:28 greg Exp $";
5 * Color matrix routines.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "platform.h"
12 #include "standard.h"
13 #include "cmatrix.h"
14 #include "platform.h"
15 #include "paths.h"
16 #include "resolu.h"
17
18 const char *cm_fmt_id[] = {
19 "unknown", COLRFMT, CIEFMT,
20 "float", "ascii", "double"
21 };
22
23 const int cm_elem_size[] = {
24 0, 4, 4, 3*sizeof(float), 0, 3*sizeof(double)
25 };
26
27 /* Allocate a color coefficient matrix */
28 CMATRIX *
29 cm_alloc(int nrows, int ncols)
30 {
31 CMATRIX *cm;
32
33 if ((nrows <= 0) | (ncols <= 0))
34 error(USER, "attempt to create empty matrix");
35 cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
36 sizeof(COLOR)*((size_t)nrows*ncols - 1));
37 if (!cm)
38 error(SYSTEM, "out of memory in cm_alloc()");
39 cm->nrows = nrows;
40 cm->ncols = ncols;
41 return(cm);
42 }
43
44 static void
45 adjacent_ra_sizes(size_t bounds[2], size_t target)
46 {
47 bounds[0] = 0; bounds[1] = 2048;
48 while (bounds[1] < target) {
49 bounds[0] = bounds[1];
50 bounds[1] += bounds[1]>>1;
51 }
52 }
53
54 /* Resize color coefficient matrix */
55 CMATRIX *
56 cm_resize(CMATRIX *cm, int nrows)
57 {
58 size_t old_size, new_size, ra_bounds[2];
59
60 if (!cm)
61 return(NULL);
62 if (nrows == cm->nrows)
63 return(cm);
64 if (nrows <= 0) {
65 cm_free(cm);
66 return(NULL);
67 }
68 old_size = sizeof(CMATRIX) + sizeof(COLOR)*((size_t)cm->nrows*cm->ncols - 1);
69 adjacent_ra_sizes(ra_bounds, old_size);
70 new_size = sizeof(CMATRIX) + sizeof(COLOR)*((size_t)nrows*cm->ncols - 1);
71 if (nrows < cm->nrows ? new_size <= ra_bounds[0] :
72 new_size > ra_bounds[1]) {
73 adjacent_ra_sizes(ra_bounds, new_size);
74 cm = (CMATRIX *)realloc(cm, ra_bounds[1]);
75 if (!cm)
76 error(SYSTEM, "out of memory in cm_resize()");
77 }
78 cm->nrows = nrows;
79 return(cm);
80 }
81
82 typedef struct {
83 int dtype; /* data type */
84 int need2swap; /* need byte swap? */
85 int nrows, ncols; /* matrix size */
86 COLOR expos; /* exposure value */
87 char *err; /* error message */
88 } CMINFO; /* header info record */
89
90 static int
91 get_cminfo(char *s, void *p)
92 {
93 CMINFO *ip = (CMINFO *)p;
94 char fmt[MAXFMTLEN];
95 int i;
96
97 if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) {
98 ip->err = "unexpected # components (must be 3)";
99 return(-1);
100 }
101 if (!strncmp(s, "NROWS=", 6)) {
102 ip->nrows = atoi(s+6);
103 return(0);
104 }
105 if (!strncmp(s, "NCOLS=", 6)) {
106 ip->ncols = atoi(s+6);
107 return(0);
108 }
109 if ((i = isbigendian(s)) >= 0) {
110 ip->need2swap = (nativebigendian() != i);
111 return(0);
112 }
113 if (isexpos(s)) {
114 double d = exposval(s);
115 scalecolor(ip->expos, d);
116 return(0);
117 }
118 if (iscolcor(s)) {
119 COLOR ctmp;
120 colcorval(ctmp, s);
121 multcolor(ip->expos, ctmp);
122 return(0);
123 }
124 if (!formatval(fmt, s))
125 return(0);
126 for (i = 1; i < DTend; i++)
127 if (!strcmp(fmt, cm_fmt_id[i]))
128 ip->dtype = i;
129 return(0);
130 }
131
132 /* Load header to obtain/check data type and number of columns */
133 char *
134 cm_getheader(int *dt, int *nr, int *nc, int *swp, COLOR scale, FILE *fp)
135 {
136 CMINFO cmi;
137 /* read header */
138 cmi.dtype = DTfromHeader;
139 cmi.need2swap = 0;
140 cmi.expos[0] = cmi.expos[1] = cmi.expos[2] = 1.f;
141 cmi.nrows = cmi.ncols = 0;
142 cmi.err = "unexpected EOF in header";
143 if (getheader(fp, get_cminfo, &cmi) < 0)
144 return(cmi.err);
145 if (dt) { /* get/check data type? */
146 if (cmi.dtype == DTfromHeader) {
147 if (*dt == DTfromHeader)
148 return("missing/unknown data format in header");
149 } else if (*dt == DTfromHeader)
150 *dt = cmi.dtype;
151 else if (*dt != cmi.dtype)
152 return("unexpected data format in header");
153 }
154 if (nr) { /* get/check #rows? */
155 if (*nr <= 0)
156 *nr = cmi.nrows;
157 else if ((cmi.nrows > 0) & (*nr != cmi.nrows))
158 return("unexpected row count in header");
159 }
160 if (nc) { /* get/check #columns? */
161 if (*nc <= 0)
162 *nc = cmi.ncols;
163 else if ((cmi.ncols > 0) & (*nc != cmi.ncols))
164 return("unexpected column count in header");
165 }
166 if (swp) /* get/check swap? */
167 *swp = cmi.need2swap;
168 if (scale) { /* transfer exposure comp. */
169 scale[0] = 1.f/cmi.expos[0];
170 scale[1] = 1.f/cmi.expos[1];
171 scale[2] = 1.f/cmi.expos[2];
172 }
173 return(NULL);
174 }
175
176 /* Allocate and load image data into matrix */
177 static CMATRIX *
178 cm_load_rgbe(FILE *fp, int nrows, int ncols, COLOR scale)
179 {
180 int doscale;
181 CMATRIX *cm;
182 COLORV *mp;
183 /* header already loaded */
184 cm = cm_alloc(nrows, ncols);
185 if (!cm)
186 return(NULL);
187 doscale = (scale[0] < .99) | (scale[0] > 1.01) |
188 (scale[1] < .99) | (scale[1] > 1.01) |
189 (scale[2] < .99) | (scale[2] > 1.01) ;
190 mp = cm->cmem;
191 while (nrows--) {
192 if (freadscan((COLOR *)mp, ncols, fp) < 0) {
193 error(USER, "error reading color picture as matrix");
194 cm_free(cm);
195 return(NULL);
196 }
197 if (doscale) {
198 int i = ncols;
199 while (i--) {
200 *mp++ *= scale[0];
201 *mp++ *= scale[1];
202 *mp++ *= scale[2];
203 }
204 } else
205 mp += 3*ncols;
206 } /* caller closes stream */
207 return(cm);
208 }
209
210 /* Allocate and load a matrix from the given input (or stdin if NULL) */
211 CMATRIX *
212 cm_load(const char *inspec, int nrows, int ncols, int dtype)
213 {
214 const int ROWINC = 2048;
215 FILE *fp = stdin;
216 int swap = 0;
217 COLOR scale;
218 CMATRIX *cm;
219
220 if (!inspec)
221 inspec = "<stdin>";
222 else if (inspec[0] == '!') {
223 fp = popen(inspec+1, "r");
224 if (!fp) {
225 sprintf(errmsg, "cannot start command '%s'", inspec);
226 error(SYSTEM, errmsg);
227 }
228 } else if (!(fp = fopen(inspec, "r"))) {
229 sprintf(errmsg, "cannot open file '%s'", inspec);
230 error(SYSTEM, errmsg);
231 }
232 #ifdef getc_unlocked
233 flockfile(fp);
234 #endif
235 if (dtype != DTascii)
236 SET_FILE_BINARY(fp); /* doesn't really work */
237 if (!dtype | !ncols) { /* expecting header? */
238 char *err = cm_getheader(&dtype, &nrows, &ncols, &swap, scale, fp);
239 if (err)
240 error(USER, err);
241 }
242 if (ncols <= 0 && !fscnresolu(&ncols, &nrows, fp))
243 error(USER, "unspecified number of columns");
244 switch (dtype) {
245 case DTascii:
246 case DTfloat:
247 case DTdouble:
248 break;
249 case DTrgbe:
250 case DTxyze:
251 cm = cm_load_rgbe(fp, nrows, ncols, scale);
252 goto cleanup;
253 default:
254 error(USER, "unexpected data type in cm_load()");
255 }
256 if (nrows <= 0) { /* don't know length? */
257 int guessrows = 147; /* usually big enough */
258 if (cm_elem_size[dtype] && (fp != stdin) & (inspec[0] != '!')) {
259 long startpos = ftell(fp);
260 if (fseek(fp, 0L, SEEK_END) == 0) {
261 long rowsiz = (long)ncols*cm_elem_size[dtype];
262 long endpos = ftell(fp);
263
264 if ((endpos - startpos) % rowsiz) {
265 sprintf(errmsg,
266 "improper length for binary file '%s'",
267 inspec);
268 error(USER, errmsg);
269 }
270 guessrows = (endpos - startpos)/rowsiz;
271 if (fseek(fp, startpos, SEEK_SET) < 0) {
272 sprintf(errmsg,
273 "fseek() error on file '%s'",
274 inspec);
275 error(SYSTEM, errmsg);
276 }
277 nrows = guessrows; /* we're confident */
278 }
279 }
280 cm = cm_alloc(guessrows, ncols);
281 } else
282 cm = cm_alloc(nrows, ncols);
283 if (!cm) /* XXX never happens */
284 return(NULL);
285 if (dtype == DTascii) { /* read text file */
286 int maxrow = (nrows > 0 ? nrows : 32000);
287 int r, c;
288 for (r = 0; r < maxrow; r++) {
289 if (r >= cm->nrows) /* need more space? */
290 cm = cm_resize(cm, cm->nrows+ROWINC);
291 for (c = 0; c < ncols; c++) {
292 COLORV *cv = cm_lval(cm,r,c);
293 if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) {
294 if ((nrows <= 0) & (r > 0) & !c) {
295 cm = cm_resize(cm, maxrow=r);
296 break;
297 } else
298 goto EOFerror;
299 }
300 }
301 }
302 while ((c = getc(fp)) != EOF)
303 if (!isspace(c)) {
304 sprintf(errmsg,
305 "unexpected data at end of ascii input '%s'",
306 inspec);
307 error(WARNING, errmsg);
308 break;
309 }
310 } else { /* read binary file */
311 if (sizeof(COLOR) == cm_elem_size[dtype]) {
312 int nread = 0;
313 do { /* read all we can */
314 nread += getbinary(cm->cmem + 3*nread,
315 sizeof(COLOR),
316 cm->nrows*cm->ncols - nread,
317 fp);
318 if (nrows <= 0) { /* unknown length */
319 if (nread == cm->nrows*cm->ncols)
320 /* need more space? */
321 cm = cm_resize(cm, cm->nrows+ROWINC);
322 else if (nread && !(nread % cm->ncols))
323 /* seem to be done */
324 cm = cm_resize(cm, nread/cm->ncols);
325 else /* ended mid-row */
326 goto EOFerror;
327 } else if (nread < cm->nrows*cm->ncols)
328 goto EOFerror;
329 } while (nread < cm->nrows*cm->ncols);
330
331 if (swap) {
332 if (sizeof(COLORV) == 4)
333 swap32((char *)cm->cmem,
334 3*cm->nrows*cm->ncols);
335 else /* sizeof(COLORV) == 8 */
336 swap64((char *)cm->cmem,
337 3*cm->nrows*cm->ncols);
338 }
339 } else if (dtype == DTdouble) {
340 double dc[3]; /* load from double */
341 COLORV *cvp = cm->cmem;
342 int n = nrows*ncols;
343
344 if (n <= 0)
345 goto not_handled;
346 while (n--) {
347 if (getbinary(dc, sizeof(double), 3, fp) != 3)
348 goto EOFerror;
349 if (swap) swap64((char *)dc, 3);
350 copycolor(cvp, dc);
351 cvp += 3;
352 }
353 } else /* dtype == DTfloat */ {
354 float fc[3]; /* load from float */
355 COLORV *cvp = cm->cmem;
356 int n = nrows*ncols;
357
358 if (n <= 0)
359 goto not_handled;
360 while (n--) {
361 if (getbinary(fc, sizeof(float), 3, fp) != 3)
362 goto EOFerror;
363 if (swap) swap32((char *)fc, 3);
364 copycolor(cvp, fc);
365 cvp += 3;
366 }
367 }
368 if (fgetc(fp) != EOF) {
369 sprintf(errmsg,
370 "unexpected data at end of binary input '%s'",
371 inspec);
372 error(WARNING, errmsg);
373 }
374 }
375 cleanup:
376 if (fp != stdin) {
377 if (inspec[0] != '!')
378 fclose(fp);
379 else if (pclose(fp)) {
380 sprintf(errmsg, "error running command '%s'", inspec);
381 error(WARNING, errmsg);
382 }
383 }
384 #ifdef getc_unlocked
385 else
386 funlockfile(fp);
387 #endif
388 return(cm);
389 EOFerror:
390 sprintf(errmsg, "unexpected EOF reading %s", inspec);
391 error(USER, errmsg);
392 return(NULL);
393 not_handled:
394 error(INTERNAL, "unhandled data size or length in cm_load()");
395 return(NULL); /* gratis return */
396 }
397
398 /* Extract a column vector from a matrix */
399 CMATRIX *
400 cm_column(const CMATRIX *cm, int c)
401 {
402 CMATRIX *cvr;
403 int dr;
404
405 if (!cm)
406 return(NULL);
407 if ((c < 0) | (c >= cm->ncols))
408 error(INTERNAL, "column requested outside matrix");
409 cvr = cm_alloc(cm->nrows, 1);
410 if (!cvr)
411 return(NULL);
412 for (dr = 0; dr < cm->nrows; dr++) {
413 const COLORV *sp = cm_lval(cm,dr,c);
414 COLORV *dp = cv_lval(cvr,dr);
415 dp[0] = sp[0];
416 dp[1] = sp[1];
417 dp[2] = sp[2];
418 }
419 return(cvr);
420 }
421
422 /* Multiply two matrices (or a matrix and a vector) and allocate the result */
423 CMATRIX *
424 cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
425 {
426 char *rowcheck=NULL, *colcheck=NULL;
427 CMATRIX *cmr;
428 int dr, dc, i;
429
430 if (!cm1 | !cm2)
431 return(NULL);
432 if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
433 error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
434 cmr = cm_alloc(cm1->nrows, cm2->ncols);
435 if (!cmr)
436 return(NULL);
437 /* optimization: check for zero rows & cols */
438 if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
439 static const COLOR czero;
440 rowcheck = (char *)calloc(cmr->nrows, 1);
441 for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
442 for (dc = cm1->ncols; dc--; )
443 if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
444 rowcheck[dr] = 1;
445 break;
446 }
447 colcheck = (char *)calloc(cmr->ncols, 1);
448 for (dc = cm2->ncols*(colcheck != NULL); dc--; )
449 for (dr = cm2->nrows; dr--; )
450 if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
451 colcheck[dc] = 1;
452 break;
453 }
454 }
455 for (dr = 0; dr < cmr->nrows; dr++)
456 for (dc = 0; dc < cmr->ncols; dc++) {
457 COLORV *dp = cm_lval(cmr,dr,dc);
458 double res[3];
459 dp[0] = dp[1] = dp[2] = 0;
460 if (rowcheck && !rowcheck[dr])
461 continue;
462 if (colcheck && !colcheck[dc])
463 continue;
464 res[0] = res[1] = res[2] = 0;
465 for (i = 0; i < cm1->ncols; i++) {
466 const COLORV *cp1 = cm_lval(cm1,dr,i);
467 const COLORV *cp2 = cm_lval(cm2,i,dc);
468 res[0] += (double)cp1[0] * cp2[0];
469 res[1] += (double)cp1[1] * cp2[1];
470 res[2] += (double)cp1[2] * cp2[2];
471 }
472 copycolor(dp, res);
473 }
474 if (rowcheck) free(rowcheck);
475 if (colcheck) free(colcheck);
476 return(cmr);
477 }
478
479 /* write out matrix to file (precede by resolution string if picture) */
480 int
481 cm_write(const CMATRIX *cm, int dtype, FILE *fp)
482 {
483 static const char tabEOL[2] = {'\t','\n'};
484 const COLORV *mp;
485 int r, c;
486 size_t n, rv;
487
488 if (!cm)
489 return(0);
490 mp = cm->cmem;
491 switch (dtype) {
492 case DTascii:
493 for (r = 0; r < cm->nrows; r++)
494 for (c = 0; c < cm->ncols; c++, mp += 3)
495 fprintf(fp, "%.6e %.6e %.6e%c",
496 mp[0], mp[1], mp[2],
497 tabEOL[c >= cm->ncols-1]);
498 break;
499 case DTfloat:
500 case DTdouble:
501 if (sizeof(COLOR) == cm_elem_size[dtype]) {
502 n = (size_t)cm->ncols*cm->nrows;
503 while (n > 0) {
504 rv = fwrite(mp, sizeof(COLOR), n, fp);
505 if (rv <= 0)
506 return(0);
507 mp += 3*rv;
508 n -= rv;
509 }
510 } else if (dtype == DTdouble) {
511 double dc[3];
512 n = (size_t)cm->ncols*cm->nrows;
513 while (n--) {
514 copycolor(dc, mp);
515 if (putbinary(dc, sizeof(double), 3, fp) != 3)
516 return(0);
517 mp += 3;
518 }
519 } else /* dtype == DTfloat */ {
520 float fc[3];
521 n = (size_t)cm->ncols*cm->nrows;
522 while (n--) {
523 copycolor(fc, mp);
524 if (putbinary(fc, sizeof(float), 3, fp) != 3)
525 return(0);
526 mp += 3;
527 }
528 }
529 break;
530 case DTrgbe:
531 case DTxyze:
532 fprtresolu(cm->ncols, cm->nrows, fp);
533 for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols)
534 if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0)
535 return(0);
536 break;
537 default:
538 fputs("Unsupported data type in cm_write()!\n", stderr);
539 return(0);
540 }
541 return(fflush(fp) == 0);
542 }
