root/radiance/ray/src/util/cmatrix.c
Revision: 2.15
Committed: Wed Feb 17 23:26:06 2016 UTC (9 years, 2 months ago) by greg
Changes since 2.14: +6 -5 lines
Made realloc() calls less aggressive to avoid memory errors
2 static const char RCSid[] = "$Id: cmatrix.c,v 2.14 2016/02/02 18:02:32 greg Exp $";
5 * Color matrix routines.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "standard.h"
12 #include "cmatrix.h"
13 #include "platform.h"
14 #include "paths.h"
15 #include "resolu.h"
16
17 const char *cm_fmt_id[] = {
18 "unknown", "ascii", COLRFMT, CIEFMT,
19 "float", "double"
20 };
21
22 const int cm_elem_size[] = {
23 0, 0, 3*sizeof(float), 3*sizeof(double), 4, 4
24 };
25
26 /* Allocate a color coefficient matrix */
27 CMATRIX *
28 cm_alloc(int nrows, int ncols)
29 {
30 CMATRIX *cm;
31
32 if ((nrows <= 0) | (ncols <= 0))
33 error(USER, "attempt to create empty matrix");
34 cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
35 sizeof(COLOR)*(nrows*ncols - 1));
36 if (cm == NULL)
37 error(SYSTEM, "out of memory in cm_alloc()");
38 cm->nrows = nrows;
39 cm->ncols = ncols;
40 return(cm);
41 }
42
43 static void
44 adjacent_ra_sizes(size_t bounds[2], size_t target)
45 {
46 bounds[0] = 0; bounds[1] = 2048;
47 while (bounds[1] < target) {
48 bounds[0] = bounds[1];
49 bounds[1] += bounds[1]>>1;
50 }
51 }
52
53 /* Resize color coefficient matrix */
54 CMATRIX *
55 cm_resize(CMATRIX *cm, int nrows)
56 {
57 size_t old_size, new_size, ra_bounds[2];
58
59 if (nrows == cm->nrows)
60 return(cm);
61 if (nrows <= 0) {
62 cm_free(cm);
63 return(NULL);
64 }
65 old_size = sizeof(CMATRIX) + sizeof(COLOR)*(cm->nrows*cm->ncols - 1);
66 adjacent_ra_sizes(ra_bounds, old_size);
67 new_size = sizeof(CMATRIX) + sizeof(COLOR)*(nrows*cm->ncols - 1);
68 if (nrows < cm->nrows ? new_size <= ra_bounds[0] :
69 new_size > ra_bounds[1]) {
70 adjacent_ra_sizes(ra_bounds, new_size);
71 cm = (CMATRIX *)realloc(cm, ra_bounds[1]);
72 if (cm == NULL)
73 error(SYSTEM, "out of memory in cm_resize()");
74 }
75 cm->nrows = nrows;
76 return(cm);
77 }
78
79 typedef struct {
80 int dtype; /* data type */
81 int nrows, ncols; /* matrix size */
82 char *err; /* error message */
83 } CMINFO; /* header info record */
84
85 static int
86 get_cminfo(char *s, void *p)
87 {
88 CMINFO *ip = (CMINFO *)p;
89 char fmt[32];
90 int i;
91
92 if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) {
93 ip->err = "unexpected # components (must be 3)";
94 return(-1);
95 }
96 if (!strncmp(s, "NROWS=", 6)) {
97 ip->nrows = atoi(s+6);
98 return(0);
99 }
100 if (!strncmp(s, "NCOLS=", 6)) {
101 ip->ncols = atoi(s+6);
102 return(0);
103 }
104 if (!formatval(fmt, s))
105 return(0);
106 for (i = 1; i < DTend; i++)
107 if (!strcmp(fmt, cm_fmt_id[i]))
108 ip->dtype = i;
109 return(0);
110 }
111
112 /* Load header to obtain/check data type and number of columns */
113 char *
114 cm_getheader(int *dt, int *nr, int *nc, FILE *fp)
115 {
116 CMINFO cmi;
117 /* read header */
118 cmi.dtype = DTfromHeader;
119 cmi.nrows = cmi.ncols = 0;
120 cmi.err = "unexpected EOF in header";
121 if (getheader(fp, get_cminfo, &cmi) < 0)
122 return(cmi.err);
123 if (dt != NULL) { /* get/check data type? */
124 if (cmi.dtype == DTfromHeader) {
125 if (*dt == DTfromHeader)
126 return("missing/unknown data format in header");
127 } else if (*dt == DTfromHeader)
128 *dt = cmi.dtype;
129 else if (*dt != cmi.dtype)
130 return("unexpected data format in header");
131 }
132 if (nr != NULL) { /* get/check #rows? */
133 if (*nr <= 0)
134 *nr = cmi.nrows;
135 else if ((cmi.nrows > 0) & (*nr != cmi.nrows))
136 return("unexpected row count in header");
137 }
138 if (nc != NULL) { /* get/check #columns? */
139 if (*nc <= 0)
140 *nc = cmi.ncols;
141 else if ((cmi.ncols > 0) & (*nc != cmi.ncols))
142 return("unexpected column count in header");
143 }
144 return(NULL);
145 }
146
147 /* Allocate and load a matrix from the given input (or stdin if NULL) */
148 CMATRIX *
149 cm_load(const char *inspec, int nrows, int ncols, int dtype)
150 {
151 const int ROWINC = 2048;
152 FILE *fp = stdin;
153 CMATRIX *cm;
154
155 if (inspec == NULL)
156 inspec = "<stdin>";
157 else if (inspec[0] == '!') {
158 fp = popen(inspec+1, "r");
159 if (fp == NULL) {
160 sprintf(errmsg, "cannot start command '%s'", inspec);
161 error(SYSTEM, errmsg);
162 }
163 } else if ((fp = fopen(inspec, "r")) == NULL) {
164 sprintf(errmsg, "cannot open file '%s'", inspec);
165 error(SYSTEM, errmsg);
166 }
167 #ifdef getc_unlocked
168 flockfile(fp);
169 #endif
170 if (dtype != DTascii)
171 SET_FILE_BINARY(fp); /* doesn't really work */
172 if (!dtype | !ncols) { /* expecting header? */
173 char *err = cm_getheader(&dtype, &nrows, &ncols, fp);
174 if (err != NULL)
175 error(USER, err);
176 if (ncols <= 0)
177 error(USER, "unspecified number of columns");
178 }
179 switch (dtype) {
180 case DTascii:
181 case DTfloat:
182 case DTdouble:
183 break;
184 default:
185 error(USER, "unexpected data type in cm_load()");
186 }
187 if (nrows <= 0) { /* don't know length? */
188 int guessrows = 147; /* usually big enough */
189 if ((dtype != DTascii) & (fp != stdin) & (inspec[0] != '!')) {
190 long startpos = ftell(fp);
191 if (fseek(fp, 0L, SEEK_END) == 0) {
192 long endpos = ftell(fp);
193 long elemsiz = 3*(dtype==DTfloat ?
194 sizeof(float) : sizeof(double));
195
196 if ((endpos - startpos) % (ncols*elemsiz)) {
197 sprintf(errmsg,
198 "improper length for binary file '%s'",
199 inspec);
200 error(USER, errmsg);
201 }
202 guessrows = (endpos - startpos)/(ncols*elemsiz);
203 if (fseek(fp, startpos, SEEK_SET) < 0) {
204 sprintf(errmsg,
205 "fseek() error on file '%s'",
206 inspec);
207 error(SYSTEM, errmsg);
208 }
209 nrows = guessrows; /* we're confident */
210 }
211 }
212 cm = cm_alloc(guessrows, ncols);
213 } else
214 cm = cm_alloc(nrows, ncols);
215 if (cm == NULL) /* XXX never happens */
216 return(NULL);
217 if (dtype == DTascii) { /* read text file */
218 int maxrow = (nrows > 0 ? nrows : 32000);
219 int r, c;
220 for (r = 0; r < maxrow; r++) {
221 if (r >= cm->nrows) /* need more space? */
222 cm = cm_resize(cm, cm->nrows+ROWINC);
223 for (c = 0; c < ncols; c++) {
224 COLORV *cv = cm_lval(cm,r,c);
225 if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) {
226 if ((nrows <= 0) & (r > 0) & !c) {
227 cm = cm_resize(cm, maxrow=r);
228 break;
229 } else
230 goto EOFerror;
231 }
232 }
233 }
234 while ((c = getc(fp)) != EOF)
235 if (!isspace(c)) {
236 sprintf(errmsg,
237 "unexpected data at end of ascii input '%s'",
238 inspec);
239 error(WARNING, errmsg);
240 break;
241 }
242 } else { /* read binary file */
243 if (sizeof(COLOR) == cm_elem_size[dtype]) {
244 int nread = 0;
245 do { /* read all we can */
246 nread += fread(cm->cmem + 3*nread,
247 sizeof(COLOR),
248 cm->nrows*cm->ncols - nread,
249 fp);
250 if (nrows <= 0) { /* unknown length */
251 if (nread == cm->nrows*cm->ncols)
252 /* need more space? */
253 cm = cm_resize(cm, cm->nrows+ROWINC);
254 else if (nread && !(nread % cm->ncols))
255 /* seem to be done */
256 cm = cm_resize(cm, nread/cm->ncols);
257 else /* ended mid-row */
258 goto EOFerror;
259 } else if (nread < cm->nrows*cm->ncols)
260 goto EOFerror;
261 } while (nread < cm->nrows*cm->ncols);
262
263 } else if (dtype == DTdouble) {
264 double dc[3]; /* load from double */
265 COLORV *cvp = cm->cmem;
266 int n = nrows*ncols;
267
268 if (n <= 0)
269 goto not_handled;
270 while (n--) {
271 if (fread(dc, sizeof(double), 3, fp) != 3)
272 goto EOFerror;
273 copycolor(cvp, dc);
274 cvp += 3;
275 }
276 } else /* dtype == DTfloat */ {
277 float fc[3]; /* load from float */
278 COLORV *cvp = cm->cmem;
279 int n = nrows*ncols;
280
281 if (n <= 0)
282 goto not_handled;
283 while (n--) {
284 if (fread(fc, sizeof(float), 3, fp) != 3)
285 goto EOFerror;
286 copycolor(cvp, fc);
287 cvp += 3;
288 }
289 }
290 if (fgetc(fp) != EOF) {
291 sprintf(errmsg,
292 "unexpected data at end of binary input '%s'",
293 inspec);
294 error(WARNING, errmsg);
295 }
296 }
297 if (fp != stdin) {
298 if (inspec[0] != '!')
299 fclose(fp);
300 else if (pclose(fp)) {
301 sprintf(errmsg, "error running command '%s'", inspec);
302 error(WARNING, errmsg);
303 }
304 }
305 #ifdef getc_unlocked
306 else
307 funlockfile(fp);
308 #endif
309 return(cm);
310 EOFerror:
311 sprintf(errmsg, "unexpected EOF reading %s", inspec);
312 error(USER, errmsg);
313 not_handled:
314 error(INTERNAL, "unhandled data size or length in cm_load()");
315 return(NULL); /* gratis return */
316 }
317
318 /* Extract a column vector from a matrix */
319 CMATRIX *
320 cm_column(const CMATRIX *cm, int c)
321 {
322 CMATRIX *cvr;
323 int dr;
324
325 if ((c < 0) | (c >= cm->ncols))
326 error(INTERNAL, "column requested outside matrix");
327 cvr = cm_alloc(cm->nrows, 1);
328 if (cvr == NULL)
329 return(NULL);
330 for (dr = 0; dr < cm->nrows; dr++) {
331 const COLORV *sp = cm_lval(cm,dr,c);
332 COLORV *dp = cv_lval(cvr,dr);
333 dp[0] = sp[0];
334 dp[1] = sp[1];
335 dp[2] = sp[2];
336 }
337 return(cvr);
338 }
339
340 /* Scale a matrix by a single value */
341 CMATRIX *
342 cm_scale(const CMATRIX *cm1, const COLOR sca)
343 {
344 CMATRIX *cmr;
345 int dr, dc;
346
347 cmr = cm_alloc(cm1->nrows, cm1->ncols);
348 if (cmr == NULL)
349 return(NULL);
350 for (dr = 0; dr < cmr->nrows; dr++)
351 for (dc = 0; dc < cmr->ncols; dc++) {
352 const COLORV *sp = cm_lval(cm1,dr,dc);
353 COLORV *dp = cm_lval(cmr,dr,dc);
354 dp[0] = sp[0] * sca[0];
355 dp[1] = sp[1] * sca[1];
356 dp[2] = sp[2] * sca[2];
357 }
358 return(cmr);
359 }
360
361 /* Multiply two matrices (or a matrix and a vector) and allocate the result */
362 CMATRIX *
363 cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
364 {
365 char *rowcheck=NULL, *colcheck=NULL;
366 CMATRIX *cmr;
367 int dr, dc, i;
368
369 if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
370 error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
371 cmr = cm_alloc(cm1->nrows, cm2->ncols);
372 if (cmr == NULL)
373 return(NULL);
374 /* optimization: check for zero rows & cols */
375 if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
376 static const COLOR czero;
377 rowcheck = (char *)calloc(cmr->nrows, 1);
378 for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
379 for (dc = cm1->ncols; dc--; )
380 if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
381 rowcheck[dr] = 1;
382 break;
383 }
384 colcheck = (char *)calloc(cmr->ncols, 1);
385 for (dc = cm2->ncols*(colcheck != NULL); dc--; )
386 for (dr = cm2->nrows; dr--; )
387 if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
388 colcheck[dc] = 1;
389 break;
390 }
391 }
392 for (dr = 0; dr < cmr->nrows; dr++)
393 for (dc = 0; dc < cmr->ncols; dc++) {
394 COLORV *dp = cm_lval(cmr,dr,dc);
395 double res[3];
396 dp[0] = dp[1] = dp[2] = 0;
397 if (rowcheck != NULL && !rowcheck[dr])
398 continue;
399 if (colcheck != NULL && !colcheck[dc])
400 continue;
401 res[0] = res[1] = res[2] = 0;
402 for (i = 0; i < cm1->ncols; i++) {
403 const COLORV *cp1 = cm_lval(cm1,dr,i);
404 const COLORV *cp2 = cm_lval(cm2,i,dc);
405 res[0] += cp1[0] * cp2[0];
406 res[1] += cp1[1] * cp2[1];
407 res[2] += cp1[2] * cp2[2];
408 }
409 copycolor(dp, res);
410 }
411 if (rowcheck != NULL) free(rowcheck);
412 if (colcheck != NULL) free(colcheck);
413 return(cmr);
414 }
415
416 /* write out matrix to file (precede by resolution string if picture) */
417 int
418 cm_write(const CMATRIX *cm, int dtype, FILE *fp)
419 {
420 static const char tabEOL[2] = {'\t','\n'};
421 const COLORV *mp = cm->cmem;
422 int r, c;
423
424 switch (dtype) {
425 case DTascii:
426 for (r = 0; r < cm->nrows; r++)
427 for (c = 0; c < cm->ncols; c++, mp += 3)
428 fprintf(fp, "%.6e %.6e %.6e%c",
429 mp[0], mp[1], mp[2],
430 tabEOL[c >= cm->ncols-1]);
431 break;
432 case DTfloat:
433 case DTdouble:
434 if (sizeof(COLOR) == cm_elem_size[dtype]) {
435 r = cm->ncols*cm->nrows;
436 while (r > 0) {
437 c = fwrite(mp, sizeof(COLOR), r, fp);
438 if (c <= 0)
439 return(0);
440 mp += 3*c;
441 r -= c;
442 }
443 } else if (dtype == DTdouble) {
444 double dc[3];
445 r = cm->ncols*cm->nrows;
446 while (r--) {
447 copycolor(dc, mp);
448 if (fwrite(dc, sizeof(double), 3, fp) != 3)
449 return(0);
450 mp += 3;
451 }
452 } else /* dtype == DTfloat */ {
453 float fc[3];
454 r = cm->ncols*cm->nrows;
455 while (r--) {
456 copycolor(fc, mp);
457 if (fwrite(fc, sizeof(float), 3, fp) != 3)
458 return(0);
459 mp += 3;
460 }
461 }
462 break;
463 case DTrgbe:
464 case DTxyze:
465 fprtresolu(cm->ncols, cm->nrows, fp);
466 for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols)
467 if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0)
468 return(0);
469 break;
470 default:
471 fputs("Unsupported data type in cm_write()!\n", stderr);
472 return(0);
473 }
474 return(fflush(fp) == 0);
475 }
