--- ray/src/util/cmatrix.c 2014/07/08 16:39:41 2.7 +++ ray/src/util/cmatrix.c 2015/07/22 04:23:27 2.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: cmatrix.c,v 2.7 2014/07/08 16:39:41 greg Exp $"; +static const char RCSid[] = "$Id: cmatrix.c,v 2.11 2015/07/22 04:23:27 greg Exp $"; #endif /* * Color matrix routines. @@ -11,11 +11,12 @@ static const char RCSid[] = "$Id: cmatrix.c,v 2.7 2014 #include "standard.h" #include "cmatrix.h" #include "platform.h" +#include "rtprocess.h" #include "resolu.h" const char *cm_fmt_id[] = { - "unknown", "ascii", "float", "double", - COLRFMT, CIEFMT + "unknown", "ascii", COLRFMT, CIEFMT, + "float", "double" }; const int cm_elem_size[] = { @@ -143,17 +144,23 @@ cm_getheader(int *dt, int *nr, int *nc, FILE *fp) return(NULL); } -/* Allocate and load a matrix from the given file (or stdin if NULL) */ +/* Allocate and load a matrix from the given input (or stdin if NULL) */ CMATRIX * -cm_load(const char *fname, int nrows, int ncols, int dtype) +cm_load(const char *inspec, int nrows, int ncols, int dtype) { FILE *fp = stdin; CMATRIX *cm; - if (fname == NULL) - fname = ""; - else if ((fp = fopen(fname, "r")) == NULL) { - sprintf(errmsg, "cannot open file '%s'", fname); + if (inspec == NULL) + inspec = ""; + else if (inspec[0] == '!') { + fp = popen(inspec+1, "r"); + if (fp == NULL) { + sprintf(errmsg, "cannot start command '%s'", inspec); + error(SYSTEM, errmsg); + } + } else if ((fp = fopen(inspec, "r")) == NULL) { + sprintf(errmsg, "cannot open file '%s'", inspec); error(SYSTEM, errmsg); } #ifdef getc_unlocked @@ -178,7 +185,7 @@ cm_load(const char *fname, int nrows, int ncols, int d } if (nrows <= 0) { /* don't know length? */ int guessrows = 147; /* usually big enough */ - if ((dtype != DTascii) & (fp != stdin)) { + if ((dtype != DTascii) & (fp != stdin) & (inspec[0] != '!')) { long startpos = ftell(fp); if (fseek(fp, 0L, SEEK_END) == 0) { long endpos = ftell(fp); @@ -188,14 +195,14 @@ cm_load(const char *fname, int nrows, int ncols, int d if ((endpos - startpos) % (ncols*elemsiz)) { sprintf(errmsg, "improper length for binary file '%s'", - fname); + inspec); error(USER, errmsg); } guessrows = (endpos - startpos)/(ncols*elemsiz); if (fseek(fp, startpos, SEEK_SET) < 0) { sprintf(errmsg, "fseek() error on file '%s'", - fname); + inspec); error(SYSTEM, errmsg); } nrows = guessrows; /* we're confident */ @@ -225,8 +232,8 @@ cm_load(const char *fname, int nrows, int ncols, int d while ((c = getc(fp)) != EOF) if (!isspace(c)) { sprintf(errmsg, - "unexpected data at end of ascii file %s", - fname); + "unexpected data at end of ascii input '%s'", + inspec); error(WARNING, errmsg); break; } @@ -280,20 +287,26 @@ cm_load(const char *fname, int nrows, int ncols, int d } if (fgetc(fp) != EOF) { sprintf(errmsg, - "unexpected data at end of binary file %s", - fname); + "unexpected data at end of binary input '%s'", + inspec); error(WARNING, errmsg); } } - if (fp != stdin) - fclose(fp); + if (fp != stdin) { + if (inspec[0] != '!') + fclose(fp); + else if (pclose(fp)) { + sprintf(errmsg, "error running command '%s'", inspec); + error(WARNING, errmsg); + } + } #ifdef getc_unlocked else funlockfile(fp); #endif return(cm); EOFerror: - sprintf(errmsg, "unexpected EOF reading %s", fname); + sprintf(errmsg, "unexpected EOF reading %s", inspec); error(USER, errmsg); not_handled: error(INTERNAL, "unhandled data size or length in cm_load()"); @@ -387,9 +400,9 @@ cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2) for (i = 0; i < cm1->ncols; i++) { const COLORV *cp1 = cm_lval(cm1,dr,i); const COLORV *cp2 = cm_lval(cm2,i,dc); - res[0] += cp1[0] * cp2[0]; - res[1] += cp1[1] * cp2[1]; - res[2] += cp1[2] * cp2[2]; + res[0] += (double)cp1[0] * (double)cp2[0]; + res[1] += (double)cp1[1] * (double)cp2[1]; + res[2] += (double)cp1[2] * (double)cp2[2]; } copycolor(dp, res); }
