--- ray/src/util/cmatrix.c 2019/08/14 18:20:02 2.22 +++ ray/src/util/cmatrix.c 2020/03/26 02:48:31 2.26 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: cmatrix.c,v 2.22 2019/08/14 18:20:02 greg Exp $"; +static const char RCSid[] = "$Id: cmatrix.c,v 2.26 2020/03/26 02:48:31 greg Exp $"; #endif /* * Color matrix routines. @@ -16,12 +16,12 @@ static const char RCSid[] = "$Id: cmatrix.c,v 2.22 201 #include "resolu.h" const char *cm_fmt_id[] = { - "unknown", "ascii", COLRFMT, CIEFMT, - "float", "double" + "unknown", COLRFMT, CIEFMT, + "float", "ascii", "double" }; const int cm_elem_size[] = { - 0, 0, 4, 4, 3*sizeof(float), 3*sizeof(double) + 0, 4, 4, 3*sizeof(float), 0, 3*sizeof(double) }; /* Allocate a color coefficient matrix */ @@ -83,6 +83,7 @@ typedef struct { int dtype; /* data type */ int need2swap; /* need byte swap? */ int nrows, ncols; /* matrix size */ + COLOR expos; /* exposure value */ char *err; /* error message */ } CMINFO; /* header info record */ @@ -109,6 +110,17 @@ get_cminfo(char *s, void *p) ip->need2swap = (nativebigendian() != i); return(0); } + if (isexpos(s)) { + double d = exposval(s); + scalecolor(ip->expos, d); + return(0); + } + if (iscolcor(s)) { + COLOR ctmp; + colcorval(ctmp, s); + multcolor(ip->expos, ctmp); + return(0); + } if (!formatval(fmt, s)) return(0); for (i = 1; i < DTend; i++) @@ -119,12 +131,13 @@ get_cminfo(char *s, void *p) /* Load header to obtain/check data type and number of columns */ char * -cm_getheader(int *dt, int *nr, int *nc, int *swp, FILE *fp) +cm_getheader(int *dt, int *nr, int *nc, int *swp, COLOR scale, FILE *fp) { CMINFO cmi; /* read header */ cmi.dtype = DTfromHeader; cmi.need2swap = 0; + cmi.expos[0] = cmi.expos[1] = cmi.expos[2] = 1.f; cmi.nrows = cmi.ncols = 0; cmi.err = "unexpected EOF in header"; if (getheader(fp, get_cminfo, &cmi) < 0) @@ -152,9 +165,52 @@ cm_getheader(int *dt, int *nr, int *nc, int *swp, FILE } if (swp) /* get/check swap? */ *swp = cmi.need2swap; + if (scale) { /* transfer exposure comp. */ + scale[0] = 1.f/cmi.expos[0]; + scale[1] = 1.f/cmi.expos[1]; + scale[2] = 1.f/cmi.expos[2]; + } return(NULL); } +/* Allocate and load image data into matrix */ +static CMATRIX * +cm_load_rgbe(FILE *fp, int nrows, int ncols, COLOR scale) +{ + int doscale; + CMATRIX *cm; + COLORV *mp; + /* header already loaded */ + if ((nrows <= 0) | (ncols <= 0) && !fscnresolu(&ncols, &nrows, fp)) { + error(USER, "bad picture resolution string"); + return(NULL); + } + cm = cm_alloc(nrows, ncols); + if (!cm) + return(NULL); + doscale = (scale[0] < .99) | (scale[0] > 1.01) | + (scale[1] < .99) | (scale[1] > 1.01) | + (scale[2] < .99) | (scale[2] > 1.01) ; + mp = cm->cmem; + while (nrows--) { + if (freadscan((COLOR *)mp, ncols, fp) < 0) { + error(USER, "error reading color picture as matrix"); + cm_free(cm); + return(NULL); + } + if (doscale) { + int i = ncols; + while (i--) { + *mp++ *= scale[0]; + *mp++ *= scale[1]; + *mp++ *= scale[2]; + } + } else + mp += 3*ncols; + } /* caller closes stream */ + return(cm); +} + /* Allocate and load a matrix from the given input (or stdin if NULL) */ CMATRIX * cm_load(const char *inspec, int nrows, int ncols, int dtype) @@ -162,6 +218,7 @@ cm_load(const char *inspec, int nrows, int ncols, int const int ROWINC = 2048; FILE *fp = stdin; int swap = 0; + COLOR scale; CMATRIX *cm; if (!inspec) @@ -182,7 +239,7 @@ cm_load(const char *inspec, int nrows, int ncols, int if (dtype != DTascii) SET_FILE_BINARY(fp); /* doesn't really work */ if (!dtype | !ncols) { /* expecting header? */ - char *err = cm_getheader(&dtype, &nrows, &ncols, &swap, fp); + char *err = cm_getheader(&dtype, &nrows, &ncols, &swap, scale, fp); if (err) error(USER, err); if (ncols <= 0) @@ -193,6 +250,10 @@ cm_load(const char *inspec, int nrows, int ncols, int case DTfloat: case DTdouble: break; + case DTrgbe: + case DTxyze: + cm = cm_load_rgbe(fp, nrows, ncols, scale); + goto cleanup; default: error(USER, "unexpected data type in cm_load()"); } @@ -272,6 +333,14 @@ cm_load(const char *inspec, int nrows, int ncols, int goto EOFerror; } while (nread < cm->nrows*cm->ncols); + if (swap) { + if (sizeof(COLORV) == 4) + swap32((char *)cm->cmem, + 3*cm->nrows*cm->ncols); + else /* sizeof(COLORV) == 8 */ + swap64((char *)cm->cmem, + 3*cm->nrows*cm->ncols); + } } else if (dtype == DTdouble) { double dc[3]; /* load from double */ COLORV *cvp = cm->cmem; @@ -282,6 +351,7 @@ cm_load(const char *inspec, int nrows, int ncols, int while (n--) { if (getbinary(dc, sizeof(double), 3, fp) != 3) goto EOFerror; + if (swap) swap64((char *)dc, 3); copycolor(cvp, dc); cvp += 3; } @@ -295,6 +365,7 @@ cm_load(const char *inspec, int nrows, int ncols, int while (n--) { if (getbinary(fc, sizeof(float), 3, fp) != 3) goto EOFerror; + if (swap) swap32((char *)fc, 3); copycolor(cvp, fc); cvp += 3; } @@ -306,12 +377,7 @@ cm_load(const char *inspec, int nrows, int ncols, int error(WARNING, errmsg); } } - if (swap) { - if (dtype == DTfloat) - swap32((char *)cm->cmem, 3*cm->nrows*cm->ncols); - else if (dtype == DTdouble) - swap64((char *)cm->cmem, 3*cm->nrows*cm->ncols); - } +cleanup: if (fp != stdin) { if (inspec[0] != '!') fclose(fp); @@ -328,6 +394,7 @@ cm_load(const char *inspec, int nrows, int ncols, int EOFerror: sprintf(errmsg, "unexpected EOF reading %s", inspec); error(USER, errmsg); + return(NULL); not_handled: error(INTERNAL, "unhandled data size or length in cm_load()"); return(NULL); /* gratis return */
