--- ray/src/util/cmatrix.c 2019/08/14 18:20:02 2.22 +++ ray/src/util/cmatrix.c 2019/10/23 17:00:14 2.23 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: cmatrix.c,v 2.22 2019/08/14 18:20:02 greg Exp $"; +static const char RCSid[] = "$Id: cmatrix.c,v 2.23 2019/10/23 17:00:14 greg Exp $"; #endif /* * Color matrix routines. @@ -155,6 +155,32 @@ cm_getheader(int *dt, int *nr, int *nc, int *swp, FILE return(NULL); } +/* Allocate and load image data into matrix */ +static CMATRIX * +cm_load_rgbe(FILE *fp, int nrows, int ncols) +{ + CMATRIX *cm; + COLORV *mp; + /* header already loaded */ + if ((nrows <= 0) | (ncols <= 0) && !fscnresolu(&ncols, &nrows, fp)) { + error(USER, "bad picture resolution string"); + return(NULL); + } + cm = cm_alloc(nrows, ncols); + if (!cm) + return(NULL); + mp = cm->cmem; + while (nrows--) { + if (freadscan((COLOR *)mp, ncols, fp) < 0) { + error(USER, "error reading color picture as matrix"); + cm_free(cm); + return(NULL); + } + mp += 3*ncols; + } /* caller closes stream */ + return(cm); +} + /* Allocate and load a matrix from the given input (or stdin if NULL) */ CMATRIX * cm_load(const char *inspec, int nrows, int ncols, int dtype) @@ -193,6 +219,10 @@ cm_load(const char *inspec, int nrows, int ncols, int case DTfloat: case DTdouble: break; + case DTrgbe: + case DTxyze: + cm = cm_load_rgbe(fp, nrows, ncols); + goto cleanup; default: error(USER, "unexpected data type in cm_load()"); } @@ -312,6 +342,7 @@ cm_load(const char *inspec, int nrows, int ncols, int else if (dtype == DTdouble) swap64((char *)cm->cmem, 3*cm->nrows*cm->ncols); } +cleanup: if (fp != stdin) { if (inspec[0] != '!') fclose(fp); @@ -328,6 +359,7 @@ cm_load(const char *inspec, int nrows, int ncols, int EOFerror: sprintf(errmsg, "unexpected EOF reading %s", inspec); error(USER, errmsg); + return(NULL); not_handled: error(INTERNAL, "unhandled data size or length in cm_load()"); return(NULL); /* gratis return */
