| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: cmatrix.c,v 2.26 2020/03/26 02:48:31 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Color matrix routines.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#include <ctype.h>
| 11 |
#include "platform.h"
| 12 |
#include "standard.h"
| 13 |
#include "cmatrix.h"
| 14 |
| 15 |
#include "paths.h"
| 16 |
#include "resolu.h"
| 17 |
| 18 |
const char *cm_fmt_id[] = {
| 19 |
"unknown", COLRFMT, CIEFMT,
| 20 |
"float", "ascii", "double"
| 21 |
| 22 |
| 23 |
const int cm_elem_size[] = {
| 24 |
0, 4, 4, 3*sizeof(float), 0, 3*sizeof(double)
| 25 |
| 26 |
| 27 |
/* Allocate a color coefficient matrix */
| 28 |
CMATRIX *
| 29 |
cm_alloc(int nrows, int ncols)
| 30 |
| 31 |
CMATRIX *cm;
| 32 |
| 33 |
if ((nrows <= 0) | (ncols <= 0))
| 34 |
error(USER, "attempt to create empty matrix");
| 35 |
cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
| 36 |
sizeof(COLOR)*(nrows*ncols - 1));
| 37 |
if (!cm)
| 38 |
error(SYSTEM, "out of memory in cm_alloc()");
| 39 |
cm->nrows = nrows;
| 40 |
cm->ncols = ncols;
| 41 |
return(cm);
| 42 |
| 43 |
| 44 |
static void
| 45 |
adjacent_ra_sizes(size_t bounds[2], size_t target)
| 46 |
| 47 |
bounds[0] = 0; bounds[1] = 2048;
| 48 |
while (bounds[1] < target) {
| 49 |
bounds[0] = bounds[1];
| 50 |
bounds[1] += bounds[1]>>1;
| 51 |
| 52 |
| 53 |
| 54 |
/* Resize color coefficient matrix */
| 55 |
CMATRIX *
| 56 |
cm_resize(CMATRIX *cm, int nrows)
| 57 |
| 58 |
size_t old_size, new_size, ra_bounds[2];
| 59 |
| 60 |
if (!cm)
| 61 |
return(NULL);
| 62 |
if (nrows == cm->nrows)
| 63 |
return(cm);
| 64 |
if (nrows <= 0) {
| 65 |
cm_free(cm);
| 66 |
return(NULL);
| 67 |
| 68 |
old_size = sizeof(CMATRIX) + sizeof(COLOR)*(cm->nrows*cm->ncols - 1);
| 69 |
adjacent_ra_sizes(ra_bounds, old_size);
| 70 |
new_size = sizeof(CMATRIX) + sizeof(COLOR)*(nrows*cm->ncols - 1);
| 71 |
if (nrows < cm->nrows ? new_size <= ra_bounds[0] :
| 72 |
new_size > ra_bounds[1]) {
| 73 |
adjacent_ra_sizes(ra_bounds, new_size);
| 74 |
cm = (CMATRIX *)realloc(cm, ra_bounds[1]);
| 75 |
if (!cm)
| 76 |
error(SYSTEM, "out of memory in cm_resize()");
| 77 |
| 78 |
cm->nrows = nrows;
| 79 |
return(cm);
| 80 |
| 81 |
| 82 |
typedef struct {
| 83 |
int dtype; /* data type */
| 84 |
int need2swap; /* need byte swap? */
| 85 |
int nrows, ncols; /* matrix size */
| 86 |
COLOR expos; /* exposure value */
| 87 |
char *err; /* error message */
| 88 |
} CMINFO; /* header info record */
| 89 |
| 90 |
static int
| 91 |
get_cminfo(char *s, void *p)
| 92 |
| 93 |
CMINFO *ip = (CMINFO *)p;
| 94 |
char fmt[MAXFMTLEN];
| 95 |
int i;
| 96 |
| 97 |
if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) {
| 98 |
ip->err = "unexpected # components (must be 3)";
| 99 |
return(-1);
| 100 |
| 101 |
if (!strncmp(s, "NROWS=", 6)) {
| 102 |
ip->nrows = atoi(s+6);
| 103 |
return(0);
| 104 |
| 105 |
if (!strncmp(s, "NCOLS=", 6)) {
| 106 |
ip->ncols = atoi(s+6);
| 107 |
return(0);
| 108 |
| 109 |
if ((i = isbigendian(s)) >= 0) {
| 110 |
ip->need2swap = (nativebigendian() != i);
| 111 |
return(0);
| 112 |
| 113 |
if (isexpos(s)) {
| 114 |
double d = exposval(s);
| 115 |
scalecolor(ip->expos, d);
| 116 |
return(0);
| 117 |
| 118 |
if (iscolcor(s)) {
| 119 |
COLOR ctmp;
| 120 |
colcorval(ctmp, s);
| 121 |
multcolor(ip->expos, ctmp);
| 122 |
return(0);
| 123 |
| 124 |
if (!formatval(fmt, s))
| 125 |
return(0);
| 126 |
for (i = 1; i < DTend; i++)
| 127 |
if (!strcmp(fmt, cm_fmt_id[i]))
| 128 |
ip->dtype = i;
| 129 |
return(0);
| 130 |
| 131 |
| 132 |
/* Load header to obtain/check data type and number of columns */
| 133 |
char *
| 134 |
cm_getheader(int *dt, int *nr, int *nc, int *swp, COLOR scale, FILE *fp)
| 135 |
| 136 |
CMINFO cmi;
| 137 |
/* read header */
| 138 |
cmi.dtype = DTfromHeader;
| 139 |
cmi.need2swap = 0;
| 140 |
cmi.expos[0] = cmi.expos[1] = cmi.expos[2] = 1.f;
| 141 |
cmi.nrows = cmi.ncols = 0;
| 142 |
cmi.err = "unexpected EOF in header";
| 143 |
if (getheader(fp, get_cminfo, &cmi) < 0)
| 144 |
return(cmi.err);
| 145 |
if (dt) { /* get/check data type? */
| 146 |
if (cmi.dtype == DTfromHeader) {
| 147 |
if (*dt == DTfromHeader)
| 148 |
return("missing/unknown data format in header");
| 149 |
} else if (*dt == DTfromHeader)
| 150 |
*dt = cmi.dtype;
| 151 |
else if (*dt != cmi.dtype)
| 152 |
return("unexpected data format in header");
| 153 |
| 154 |
if (nr) { /* get/check #rows? */
| 155 |
if (*nr <= 0)
| 156 |
*nr = cmi.nrows;
| 157 |
else if ((cmi.nrows > 0) & (*nr != cmi.nrows))
| 158 |
return("unexpected row count in header");
| 159 |
| 160 |
if (nc) { /* get/check #columns? */
| 161 |
if (*nc <= 0)
| 162 |
*nc = cmi.ncols;
| 163 |
else if ((cmi.ncols > 0) & (*nc != cmi.ncols))
| 164 |
return("unexpected column count in header");
| 165 |
| 166 |
if (swp) /* get/check swap? */
| 167 |
*swp = cmi.need2swap;
| 168 |
if (scale) { /* transfer exposure comp. */
| 169 |
scale[0] = 1.f/cmi.expos[0];
| 170 |
scale[1] = 1.f/cmi.expos[1];
| 171 |
scale[2] = 1.f/cmi.expos[2];
| 172 |
| 173 |
return(NULL);
| 174 |
| 175 |
| 176 |
/* Allocate and load image data into matrix */
| 177 |
static CMATRIX *
| 178 |
cm_load_rgbe(FILE *fp, int nrows, int ncols, COLOR scale)
| 179 |
| 180 |
int doscale;
| 181 |
CMATRIX *cm;
| 182 |
COLORV *mp;
| 183 |
/* header already loaded */
| 184 |
if ((nrows <= 0) | (ncols <= 0) && !fscnresolu(&ncols, &nrows, fp)) {
| 185 |
error(USER, "bad picture resolution string");
| 186 |
return(NULL);
| 187 |
| 188 |
cm = cm_alloc(nrows, ncols);
| 189 |
if (!cm)
| 190 |
return(NULL);
| 191 |
doscale = (scale[0] < .99) | (scale[0] > 1.01) |
| 192 |
(scale[1] < .99) | (scale[1] > 1.01) |
| 193 |
(scale[2] < .99) | (scale[2] > 1.01) ;
| 194 |
mp = cm->cmem;
| 195 |
while (nrows--) {
| 196 |
if (freadscan((COLOR *)mp, ncols, fp) < 0) {
| 197 |
error(USER, "error reading color picture as matrix");
| 198 |
cm_free(cm);
| 199 |
return(NULL);
| 200 |
| 201 |
if (doscale) {
| 202 |
int i = ncols;
| 203 |
while (i--) {
| 204 |
*mp++ *= scale[0];
| 205 |
*mp++ *= scale[1];
| 206 |
*mp++ *= scale[2];
| 207 |
| 208 |
} else
| 209 |
mp += 3*ncols;
| 210 |
} /* caller closes stream */
| 211 |
return(cm);
| 212 |
| 213 |
| 214 |
/* Allocate and load a matrix from the given input (or stdin if NULL) */
| 215 |
CMATRIX *
| 216 |
cm_load(const char *inspec, int nrows, int ncols, int dtype)
| 217 |
| 218 |
const int ROWINC = 2048;
| 219 |
FILE *fp = stdin;
| 220 |
int swap = 0;
| 221 |
COLOR scale;
| 222 |
CMATRIX *cm;
| 223 |
| 224 |
if (!inspec)
| 225 |
inspec = "<stdin>";
| 226 |
else if (inspec[0] == '!') {
| 227 |
fp = popen(inspec+1, "r");
| 228 |
if (!fp) {
| 229 |
sprintf(errmsg, "cannot start command '%s'", inspec);
| 230 |
error(SYSTEM, errmsg);
| 231 |
| 232 |
} else if (!(fp = fopen(inspec, "r"))) {
| 233 |
sprintf(errmsg, "cannot open file '%s'", inspec);
| 234 |
| 235 |
| 236 |
#ifdef getc_unlocked
| 237 |
flockfile(fp);
| 238 |
#endif
| 239 |
if (dtype != DTascii)
| 240 |
SET_FILE_BINARY(fp); /* doesn't really work */
| 241 |
if (!dtype | !ncols) { /* expecting header? */
| 242 |
char *err = cm_getheader(&dtype, &nrows, &ncols, &swap, scale, fp);
| 243 |
if (err)
| 244 |
error(USER, err);
| 245 |
if (ncols <= 0)
| 246 |
error(USER, "unspecified number of columns");
| 247 |
| 248 |
switch (dtype) {
| 249 |
case DTascii:
| 250 |
case DTfloat:
| 251 |
case DTdouble:
| 252 |
break;
| 253 |
case DTrgbe:
| 254 |
case DTxyze:
| 255 |
cm = cm_load_rgbe(fp, nrows, ncols, scale);
| 256 |
goto cleanup;
| 257 |
default:
| 258 |
error(USER, "unexpected data type in cm_load()");
| 259 |
| 260 |
if (nrows <= 0) { /* don't know length? */
| 261 |
int guessrows = 147; /* usually big enough */
| 262 |
if (cm_elem_size[dtype] && (fp != stdin) & (inspec[0] != '!')) {
| 263 |
long startpos = ftell(fp);
| 264 |
if (fseek(fp, 0L, SEEK_END) == 0) {
| 265 |
long rowsiz = (long)ncols*cm_elem_size[dtype];
| 266 |
long endpos = ftell(fp);
| 267 |
| 268 |
if ((endpos - startpos) % rowsiz) {
| 269 |
sprintf(errmsg,
| 270 |
"improper length for binary file '%s'",
| 271 |
inspec);
| 272 |
error(USER, errmsg);
| 273 |
| 274 |
guessrows = (endpos - startpos)/rowsiz;
| 275 |
if (fseek(fp, startpos, SEEK_SET) < 0) {
| 276 |
sprintf(errmsg,
| 277 |
"fseek() error on file '%s'",
| 278 |
inspec);
| 279 |
| 280 |
| 281 |
nrows = guessrows; /* we're confident */
| 282 |
| 283 |
| 284 |
cm = cm_alloc(guessrows, ncols);
| 285 |
} else
| 286 |
| 287 |
if (!cm) /* XXX never happens */
| 288 |
return(NULL);
| 289 |
if (dtype == DTascii) { /* read text file */
| 290 |
int maxrow = (nrows > 0 ? nrows : 32000);
| 291 |
int r, c;
| 292 |
for (r = 0; r < maxrow; r++) {
| 293 |
if (r >= cm->nrows) /* need more space? */
| 294 |
cm = cm_resize(cm, cm->nrows+ROWINC);
| 295 |
for (c = 0; c < ncols; c++) {
| 296 |
COLORV *cv = cm_lval(cm,r,c);
| 297 |
if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) {
| 298 |
if ((nrows <= 0) & (r > 0) & !c) {
| 299 |
cm = cm_resize(cm, maxrow=r);
| 300 |
break;
| 301 |
} else
| 302 |
goto EOFerror;
| 303 |
| 304 |
| 305 |
| 306 |
while ((c = getc(fp)) != EOF)
| 307 |
if (!isspace(c)) {
| 308 |
sprintf(errmsg,
| 309 |
"unexpected data at end of ascii input '%s'",
| 310 |
inspec);
| 311 |
error(WARNING, errmsg);
| 312 |
break;
| 313 |
| 314 |
} else { /* read binary file */
| 315 |
if (sizeof(COLOR) == cm_elem_size[dtype]) {
| 316 |
int nread = 0;
| 317 |
do { /* read all we can */
| 318 |
nread += getbinary(cm->cmem + 3*nread,
| 319 |
sizeof(COLOR),
| 320 |
cm->nrows*cm->ncols - nread,
| 321 |
fp);
| 322 |
if (nrows <= 0) { /* unknown length */
| 323 |
if (nread == cm->nrows*cm->ncols)
| 324 |
| 325 |
| 326 |
else if (nread && !(nread % cm->ncols))
| 327 |
/* seem to be done */
| 328 |
cm = cm_resize(cm, nread/cm->ncols);
| 329 |
else /* ended mid-row */
| 330 |
goto EOFerror;
| 331 |
} else if (nread < cm->nrows*cm->ncols)
| 332 |
goto EOFerror;
| 333 |
} while (nread < cm->nrows*cm->ncols);
| 334 |
| 335 |
if (swap) {
| 336 |
if (sizeof(COLORV) == 4)
| 337 |
swap32((char *)cm->cmem,
| 338 |
3*cm->nrows*cm->ncols);
| 339 |
else /* sizeof(COLORV) == 8 */
| 340 |
swap64((char *)cm->cmem,
| 341 |
| 342 |
| 343 |
} else if (dtype == DTdouble) {
| 344 |
double dc[3]; /* load from double */
| 345 |
COLORV *cvp = cm->cmem;
| 346 |
int n = nrows*ncols;
| 347 |
| 348 |
if (n <= 0)
| 349 |
goto not_handled;
| 350 |
while (n--) {
| 351 |
if (getbinary(dc, sizeof(double), 3, fp) != 3)
| 352 |
goto EOFerror;
| 353 |
if (swap) swap64((char *)dc, 3);
| 354 |
copycolor(cvp, dc);
| 355 |
cvp += 3;
| 356 |
| 357 |
} else /* dtype == DTfloat */ {
| 358 |
float fc[3]; /* load from float */
| 359 |
| 360 |
| 361 |
| 362 |
if (n <= 0)
| 363 |
goto not_handled;
| 364 |
while (n--) {
| 365 |
if (getbinary(fc, sizeof(float), 3, fp) != 3)
| 366 |
goto EOFerror;
| 367 |
if (swap) swap32((char *)fc, 3);
| 368 |
copycolor(cvp, fc);
| 369 |
cvp += 3;
| 370 |
| 371 |
| 372 |
if (fgetc(fp) != EOF) {
| 373 |
sprintf(errmsg,
| 374 |
"unexpected data at end of binary input '%s'",
| 375 |
inspec);
| 376 |
| 377 |
| 378 |
| 379 |
cleanup:
| 380 |
if (fp != stdin) {
| 381 |
if (inspec[0] != '!')
| 382 |
fclose(fp);
| 383 |
else if (pclose(fp)) {
| 384 |
sprintf(errmsg, "error running command '%s'", inspec);
| 385 |
| 386 |
| 387 |
| 388 |
| 389 |
else
| 390 |
funlockfile(fp);
| 391 |
#endif
| 392 |
return(cm);
| 393 |
EOFerror:
| 394 |
sprintf(errmsg, "unexpected EOF reading %s", inspec);
| 395 |
| 396 |
return(NULL);
| 397 |
not_handled:
| 398 |
error(INTERNAL, "unhandled data size or length in cm_load()");
| 399 |
return(NULL); /* gratis return */
| 400 |
| 401 |
| 402 |
/* Extract a column vector from a matrix */
| 403 |
CMATRIX *
| 404 |
cm_column(const CMATRIX *cm, int c)
| 405 |
| 406 |
CMATRIX *cvr;
| 407 |
int dr;
| 408 |
| 409 |
if (!cm)
| 410 |
return(NULL);
| 411 |
if ((c < 0) | (c >= cm->ncols))
| 412 |
error(INTERNAL, "column requested outside matrix");
| 413 |
cvr = cm_alloc(cm->nrows, 1);
| 414 |
if (!cvr)
| 415 |
return(NULL);
| 416 |
for (dr = 0; dr < cm->nrows; dr++) {
| 417 |
const COLORV *sp = cm_lval(cm,dr,c);
| 418 |
COLORV *dp = cv_lval(cvr,dr);
| 419 |
dp[0] = sp[0];
| 420 |
dp[1] = sp[1];
| 421 |
dp[2] = sp[2];
| 422 |
| 423 |
return(cvr);
| 424 |
| 425 |
| 426 |
/* Multiply two matrices (or a matrix and a vector) and allocate the result */
| 427 |
CMATRIX *
| 428 |
cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
| 429 |
| 430 |
char *rowcheck=NULL, *colcheck=NULL;
| 431 |
CMATRIX *cmr;
| 432 |
int dr, dc, i;
| 433 |
| 434 |
if (!cm1 | !cm2)
| 435 |
return(NULL);
| 436 |
if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
| 437 |
error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
| 438 |
cmr = cm_alloc(cm1->nrows, cm2->ncols);
| 439 |
if (!cmr)
| 440 |
return(NULL);
| 441 |
/* optimization: check for zero rows & cols */
| 442 |
if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
| 443 |
static const COLOR czero;
| 444 |
rowcheck = (char *)calloc(cmr->nrows, 1);
| 445 |
for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
| 446 |
for (dc = cm1->ncols; dc--; )
| 447 |
if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
| 448 |
rowcheck[dr] = 1;
| 449 |
break;
| 450 |
| 451 |
colcheck = (char *)calloc(cmr->ncols, 1);
| 452 |
for (dc = cm2->ncols*(colcheck != NULL); dc--; )
| 453 |
for (dr = cm2->nrows; dr--; )
| 454 |
if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
| 455 |
colcheck[dc] = 1;
| 456 |
break;
| 457 |
| 458 |
| 459 |
for (dr = 0; dr < cmr->nrows; dr++)
| 460 |
for (dc = 0; dc < cmr->ncols; dc++) {
| 461 |
COLORV *dp = cm_lval(cmr,dr,dc);
| 462 |
double res[3];
| 463 |
dp[0] = dp[1] = dp[2] = 0;
| 464 |
if (rowcheck && !rowcheck[dr])
| 465 |
continue;
| 466 |
if (colcheck && !colcheck[dc])
| 467 |
continue;
| 468 |
res[0] = res[1] = res[2] = 0;
| 469 |
for (i = 0; i < cm1->ncols; i++) {
| 470 |
const COLORV *cp1 = cm_lval(cm1,dr,i);
| 471 |
const COLORV *cp2 = cm_lval(cm2,i,dc);
| 472 |
res[0] += (double)cp1[0] * cp2[0];
| 473 |
res[1] += (double)cp1[1] * cp2[1];
| 474 |
res[2] += (double)cp1[2] * cp2[2];
| 475 |
| 476 |
copycolor(dp, res);
| 477 |
| 478 |
if (rowcheck) free(rowcheck);
| 479 |
if (colcheck) free(colcheck);
| 480 |
return(cmr);
| 481 |
| 482 |
| 483 |
/* write out matrix to file (precede by resolution string if picture) */
| 484 |
int
| 485 |
cm_write(const CMATRIX *cm, int dtype, FILE *fp)
| 486 |
| 487 |
static const char tabEOL[2] = {'\t','\n'};
| 488 |
const COLORV *mp;
| 489 |
int r, c;
| 490 |
| 491 |
if (!cm)
| 492 |
return(0);
| 493 |
mp = cm->cmem;
| 494 |
switch (dtype) {
| 495 |
case DTascii:
| 496 |
for (r = 0; r < cm->nrows; r++)
| 497 |
for (c = 0; c < cm->ncols; c++, mp += 3)
| 498 |
fprintf(fp, "%.6e %.6e %.6e%c",
| 499 |
mp[0], mp[1], mp[2],
| 500 |
tabEOL[c >= cm->ncols-1]);
| 501 |
break;
| 502 |
case DTfloat:
| 503 |
case DTdouble:
| 504 |
| 505 |
r = cm->ncols*cm->nrows;
| 506 |
while (r > 0) {
| 507 |
c = putbinary(mp, sizeof(COLOR), r, fp);
| 508 |
if (c <= 0)
| 509 |
return(0);
| 510 |
mp += 3*c;
| 511 |
r -= c;
| 512 |
| 513 |
| 514 |
double dc[3];
| 515 |
| 516 |
while (r--) {
| 517 |
copycolor(dc, mp);
| 518 |
if (putbinary(dc, sizeof(double), 3, fp) != 3)
| 519 |
return(0);
| 520 |
mp += 3;
| 521 |
| 522 |
| 523 |
float fc[3];
| 524 |
| 525 |
while (r--) {
| 526 |
copycolor(fc, mp);
| 527 |
if (putbinary(fc, sizeof(float), 3, fp) != 3)
| 528 |
return(0);
| 529 |
mp += 3;
| 530 |
| 531 |
| 532 |
break;
| 533 |
case DTrgbe:
| 534 |
case DTxyze:
| 535 |
fprtresolu(cm->ncols, cm->nrows, fp);
| 536 |
for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols)
| 537 |
if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0)
| 538 |
return(0);
| 539 |
break;
| 540 |
default:
| 541 |
fputs("Unsupported data type in cm_write()!\n", stderr);
| 542 |
return(0);
| 543 |
| 544 |
return(fflush(fp) == 0);
| 545 |
