| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: cmatrix.c,v 2.9 2015/05/04 20:53:21 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Color matrix routines.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#include <ctype.h>
| 11 |
#include "standard.h"
| 12 |
#include "cmatrix.h"
| 13 |
#include "platform.h"
| 14 |
#include "rtprocess.h"
| 15 |
#include "resolu.h"
| 16 |
| 17 |
const char *cm_fmt_id[] = {
| 18 |
"unknown", "ascii", COLRFMT, CIEFMT,
| 19 |
"float", "double"
| 20 |
| 21 |
| 22 |
const int cm_elem_size[] = {
| 23 |
0, 0, 3*sizeof(float), 3*sizeof(double), 4, 4
| 24 |
| 25 |
| 26 |
/* Allocate a color coefficient matrix */
| 27 |
CMATRIX *
| 28 |
cm_alloc(int nrows, int ncols)
| 29 |
| 30 |
CMATRIX *cm;
| 31 |
| 32 |
if ((nrows <= 0) | (ncols <= 0))
| 33 |
error(USER, "attempt to create empty matrix");
| 34 |
cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
| 35 |
sizeof(COLOR)*(nrows*ncols - 1));
| 36 |
if (cm == NULL)
| 37 |
error(SYSTEM, "out of memory in cm_alloc()");
| 38 |
cm->nrows = nrows;
| 39 |
cm->ncols = ncols;
| 40 |
return(cm);
| 41 |
| 42 |
| 43 |
static void
| 44 |
adjacent_ra_sizes(size_t bounds[2], size_t target)
| 45 |
| 46 |
bounds[0] = 0; bounds[1] = 2048;
| 47 |
while (bounds[1] < target) {
| 48 |
bounds[0] = bounds[1];
| 49 |
bounds[1] += bounds[1]>>1;
| 50 |
| 51 |
| 52 |
| 53 |
/* Resize color coefficient matrix */
| 54 |
CMATRIX *
| 55 |
cm_resize(CMATRIX *cm, int nrows)
| 56 |
| 57 |
size_t old_size, new_size, ra_bounds[2];
| 58 |
| 59 |
if (nrows == cm->nrows)
| 60 |
return(cm);
| 61 |
if (nrows <= 0) {
| 62 |
cm_free(cm);
| 63 |
return(NULL);
| 64 |
| 65 |
old_size = sizeof(CMATRIX) + sizeof(COLOR)*(cm->nrows*cm->ncols - 1);
| 66 |
adjacent_ra_sizes(ra_bounds, old_size);
| 67 |
new_size = sizeof(CMATRIX) + sizeof(COLOR)*(nrows*cm->ncols - 1);
| 68 |
if (nrows < cm->nrows ? new_size <= ra_bounds[0] :
| 69 |
new_size > ra_bounds[1]) {
| 70 |
adjacent_ra_sizes(ra_bounds, new_size);
| 71 |
cm = (CMATRIX *)realloc(cm, ra_bounds[1]);
| 72 |
if (cm == NULL)
| 73 |
error(SYSTEM, "out of memory in cm_resize()");
| 74 |
| 75 |
cm->nrows = nrows;
| 76 |
return(cm);
| 77 |
| 78 |
| 79 |
typedef struct {
| 80 |
int dtype; /* data type */
| 81 |
int nrows, ncols; /* matrix size */
| 82 |
char *err; /* error message */
| 83 |
} CMINFO; /* header info record */
| 84 |
| 85 |
static int
| 86 |
get_cminfo(char *s, void *p)
| 87 |
| 88 |
CMINFO *ip = (CMINFO *)p;
| 89 |
char fmt[32];
| 90 |
int i;
| 91 |
| 92 |
if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) {
| 93 |
ip->err = "unexpected # components (must be 3)";
| 94 |
return(-1);
| 95 |
| 96 |
if (!strncmp(s, "NROWS=", 6)) {
| 97 |
ip->nrows = atoi(s+6);
| 98 |
return(0);
| 99 |
| 100 |
if (!strncmp(s, "NCOLS=", 6)) {
| 101 |
ip->ncols = atoi(s+6);
| 102 |
return(0);
| 103 |
| 104 |
if (!formatval(fmt, s))
| 105 |
return(0);
| 106 |
for (i = 1; i < DTend; i++)
| 107 |
if (!strcmp(fmt, cm_fmt_id[i]))
| 108 |
ip->dtype = i;
| 109 |
return(0);
| 110 |
| 111 |
| 112 |
/* Load header to obtain/check data type and number of columns */
| 113 |
char *
| 114 |
cm_getheader(int *dt, int *nr, int *nc, FILE *fp)
| 115 |
| 116 |
CMINFO cmi;
| 117 |
/* read header */
| 118 |
cmi.dtype = DTfromHeader;
| 119 |
cmi.nrows = cmi.ncols = 0;
| 120 |
cmi.err = "unexpected EOF in header";
| 121 |
if (getheader(fp, get_cminfo, &cmi) < 0)
| 122 |
return(cmi.err);
| 123 |
if (dt != NULL) { /* get/check data type? */
| 124 |
if (cmi.dtype == DTfromHeader) {
| 125 |
if (*dt == DTfromHeader)
| 126 |
return("missing/unknown data format in header");
| 127 |
} else if (*dt == DTfromHeader)
| 128 |
*dt = cmi.dtype;
| 129 |
else if (*dt != cmi.dtype)
| 130 |
return("unexpected data format in header");
| 131 |
| 132 |
if (nr != NULL) { /* get/check #rows? */
| 133 |
if (*nr <= 0)
| 134 |
*nr = cmi.nrows;
| 135 |
else if ((cmi.nrows > 0) & (*nr != cmi.nrows))
| 136 |
return("unexpected row count in header");
| 137 |
| 138 |
if (nc != NULL) { /* get/check #columns? */
| 139 |
if (*nc <= 0)
| 140 |
*nc = cmi.ncols;
| 141 |
else if ((cmi.ncols > 0) & (*nc != cmi.ncols))
| 142 |
return("unexpected column count in header");
| 143 |
| 144 |
return(NULL);
| 145 |
| 146 |
| 147 |
/* Allocate and load a matrix from the given input (or stdin if NULL) */
| 148 |
CMATRIX *
| 149 |
cm_load(const char *inspec, int nrows, int ncols, int dtype)
| 150 |
| 151 |
FILE *fp = stdin;
| 152 |
CMATRIX *cm;
| 153 |
| 154 |
if (inspec == NULL)
| 155 |
inspec = "<stdin>";
| 156 |
else if (inspec[0] == '!') {
| 157 |
fp = popen(inspec+1, "r");
| 158 |
if (fp == NULL) {
| 159 |
sprintf(errmsg, "cannot start command '%s'", inspec);
| 160 |
error(SYSTEM, errmsg);
| 161 |
| 162 |
} else if ((fp = fopen(inspec, "r")) == NULL) {
| 163 |
sprintf(errmsg, "cannot open file '%s'", inspec);
| 164 |
| 165 |
| 166 |
#ifdef getc_unlocked
| 167 |
flockfile(fp);
| 168 |
#endif
| 169 |
if (dtype != DTascii)
| 170 |
SET_FILE_BINARY(fp); /* doesn't really work */
| 171 |
if (!dtype | !ncols) { /* expecting header? */
| 172 |
char *err = cm_getheader(&dtype, &nrows, &ncols, fp);
| 173 |
if (err != NULL)
| 174 |
error(USER, err);
| 175 |
if (ncols <= 0)
| 176 |
error(USER, "unspecified number of columns");
| 177 |
| 178 |
switch (dtype) {
| 179 |
case DTascii:
| 180 |
case DTfloat:
| 181 |
case DTdouble:
| 182 |
break;
| 183 |
default:
| 184 |
error(USER, "unexpected data type in cm_load()");
| 185 |
| 186 |
if (nrows <= 0) { /* don't know length? */
| 187 |
int guessrows = 147; /* usually big enough */
| 188 |
if ((dtype != DTascii) & (fp != stdin) & (inspec[0] != '!')) {
| 189 |
long startpos = ftell(fp);
| 190 |
if (fseek(fp, 0L, SEEK_END) == 0) {
| 191 |
long endpos = ftell(fp);
| 192 |
long elemsiz = 3*(dtype==DTfloat ?
| 193 |
sizeof(float) : sizeof(double));
| 194 |
| 195 |
if ((endpos - startpos) % (ncols*elemsiz)) {
| 196 |
sprintf(errmsg,
| 197 |
"improper length for binary file '%s'",
| 198 |
inspec);
| 199 |
error(USER, errmsg);
| 200 |
| 201 |
guessrows = (endpos - startpos)/(ncols*elemsiz);
| 202 |
if (fseek(fp, startpos, SEEK_SET) < 0) {
| 203 |
sprintf(errmsg,
| 204 |
"fseek() error on file '%s'",
| 205 |
inspec);
| 206 |
| 207 |
| 208 |
nrows = guessrows; /* we're confident */
| 209 |
| 210 |
| 211 |
cm = cm_alloc(guessrows, ncols);
| 212 |
} else
| 213 |
cm = cm_alloc(nrows, ncols);
| 214 |
if (cm == NULL) /* XXX never happens */
| 215 |
return(NULL);
| 216 |
if (dtype == DTascii) { /* read text file */
| 217 |
int maxrow = (nrows > 0 ? nrows : 32000);
| 218 |
int r, c;
| 219 |
for (r = 0; r < maxrow; r++) {
| 220 |
if (r >= cm->nrows) /* need more space? */
| 221 |
cm = cm_resize(cm, 2*cm->nrows);
| 222 |
for (c = 0; c < ncols; c++) {
| 223 |
COLORV *cv = cm_lval(cm,r,c);
| 224 |
if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3)
| 225 |
if ((nrows <= 0) & (r > 0) & !c) {
| 226 |
cm = cm_resize(cm, maxrow=r);
| 227 |
break;
| 228 |
} else
| 229 |
goto EOFerror;
| 230 |
| 231 |
| 232 |
while ((c = getc(fp)) != EOF)
| 233 |
if (!isspace(c)) {
| 234 |
sprintf(errmsg,
| 235 |
"unexpected data at end of ascii input '%s'",
| 236 |
inspec);
| 237 |
error(WARNING, errmsg);
| 238 |
break;
| 239 |
| 240 |
} else { /* read binary file */
| 241 |
if (sizeof(COLOR) == cm_elem_size[dtype]) {
| 242 |
int nread = 0;
| 243 |
do { /* read all we can */
| 244 |
nread += fread(cm->cmem + 3*nread,
| 245 |
sizeof(COLOR),
| 246 |
cm->nrows*cm->ncols - nread,
| 247 |
fp);
| 248 |
if (nrows <= 0) { /* unknown length */
| 249 |
if (nread == cm->nrows*cm->ncols)
| 250 |
| 251 |
| 252 |
else if (nread && !(nread % cm->ncols))
| 253 |
/* seem to be done */
| 254 |
cm = cm_resize(cm, nread/cm->ncols);
| 255 |
else /* ended mid-row */
| 256 |
goto EOFerror;
| 257 |
} else if (nread < cm->nrows*cm->ncols)
| 258 |
goto EOFerror;
| 259 |
} while (nread < cm->nrows*cm->ncols);
| 260 |
| 261 |
} else if (dtype == DTdouble) {
| 262 |
double dc[3]; /* load from double */
| 263 |
COLORV *cvp = cm->cmem;
| 264 |
int n = nrows*ncols;
| 265 |
| 266 |
if (n <= 0)
| 267 |
goto not_handled;
| 268 |
while (n--) {
| 269 |
if (fread(dc, sizeof(double), 3, fp) != 3)
| 270 |
goto EOFerror;
| 271 |
copycolor(cvp, dc);
| 272 |
cvp += 3;
| 273 |
| 274 |
} else /* dtype == DTfloat */ {
| 275 |
float fc[3]; /* load from float */
| 276 |
| 277 |
| 278 |
| 279 |
if (n <= 0)
| 280 |
goto not_handled;
| 281 |
while (n--) {
| 282 |
if (fread(fc, sizeof(float), 3, fp) != 3)
| 283 |
goto EOFerror;
| 284 |
copycolor(cvp, fc);
| 285 |
cvp += 3;
| 286 |
| 287 |
| 288 |
if (fgetc(fp) != EOF) {
| 289 |
sprintf(errmsg,
| 290 |
"unexpected data at end of binary input '%s'",
| 291 |
inspec);
| 292 |
| 293 |
| 294 |
| 295 |
if (fp != stdin) {
| 296 |
if (inspec[0] != '!')
| 297 |
fclose(fp);
| 298 |
else if (pclose(fp)) {
| 299 |
sprintf(errmsg, "error running command '%s'", inspec);
| 300 |
| 301 |
| 302 |
| 303 |
| 304 |
else
| 305 |
funlockfile(fp);
| 306 |
#endif
| 307 |
return(cm);
| 308 |
EOFerror:
| 309 |
sprintf(errmsg, "unexpected EOF reading %s", inspec);
| 310 |
| 311 |
not_handled:
| 312 |
error(INTERNAL, "unhandled data size or length in cm_load()");
| 313 |
return(NULL); /* gratis return */
| 314 |
| 315 |
| 316 |
/* Extract a column vector from a matrix */
| 317 |
CMATRIX *
| 318 |
cm_column(const CMATRIX *cm, int c)
| 319 |
| 320 |
CMATRIX *cvr;
| 321 |
int dr;
| 322 |
| 323 |
if ((c < 0) | (c >= cm->ncols))
| 324 |
error(INTERNAL, "column requested outside matrix");
| 325 |
cvr = cm_alloc(cm->nrows, 1);
| 326 |
if (cvr == NULL)
| 327 |
return(NULL);
| 328 |
for (dr = 0; dr < cm->nrows; dr++) {
| 329 |
const COLORV *sp = cm_lval(cm,dr,c);
| 330 |
COLORV *dp = cv_lval(cvr,dr);
| 331 |
dp[0] = sp[0];
| 332 |
dp[1] = sp[1];
| 333 |
dp[2] = sp[2];
| 334 |
| 335 |
return(cvr);
| 336 |
| 337 |
| 338 |
/* Scale a matrix by a single value */
| 339 |
CMATRIX *
| 340 |
cm_scale(const CMATRIX *cm1, const COLOR sca)
| 341 |
| 342 |
CMATRIX *cmr;
| 343 |
int dr, dc;
| 344 |
| 345 |
cmr = cm_alloc(cm1->nrows, cm1->ncols);
| 346 |
if (cmr == NULL)
| 347 |
return(NULL);
| 348 |
for (dr = 0; dr < cmr->nrows; dr++)
| 349 |
for (dc = 0; dc < cmr->ncols; dc++) {
| 350 |
const COLORV *sp = cm_lval(cm1,dr,dc);
| 351 |
COLORV *dp = cm_lval(cmr,dr,dc);
| 352 |
dp[0] = sp[0] * sca[0];
| 353 |
dp[1] = sp[1] * sca[1];
| 354 |
dp[2] = sp[2] * sca[2];
| 355 |
| 356 |
return(cmr);
| 357 |
| 358 |
| 359 |
/* Multiply two matrices (or a matrix and a vector) and allocate the result */
| 360 |
CMATRIX *
| 361 |
cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
| 362 |
| 363 |
char *rowcheck=NULL, *colcheck=NULL;
| 364 |
CMATRIX *cmr;
| 365 |
int dr, dc, i;
| 366 |
| 367 |
if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
| 368 |
error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
| 369 |
cmr = cm_alloc(cm1->nrows, cm2->ncols);
| 370 |
if (cmr == NULL)
| 371 |
return(NULL);
| 372 |
/* optimization: check for zero rows & cols */
| 373 |
if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
| 374 |
static const COLOR czero;
| 375 |
rowcheck = (char *)calloc(cmr->nrows, 1);
| 376 |
for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
| 377 |
for (dc = cm1->ncols; dc--; )
| 378 |
if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
| 379 |
rowcheck[dr] = 1;
| 380 |
break;
| 381 |
| 382 |
colcheck = (char *)calloc(cmr->ncols, 1);
| 383 |
for (dc = cm2->ncols*(colcheck != NULL); dc--; )
| 384 |
for (dr = cm2->nrows; dr--; )
| 385 |
if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
| 386 |
colcheck[dc] = 1;
| 387 |
break;
| 388 |
| 389 |
| 390 |
| 391 |
| 392 |
| 393 |
double res[3];
| 394 |
dp[0] = dp[1] = dp[2] = 0;
| 395 |
if (rowcheck != NULL && !rowcheck[dr])
| 396 |
continue;
| 397 |
if (colcheck != NULL && !colcheck[dc])
| 398 |
continue;
| 399 |
res[0] = res[1] = res[2] = 0;
| 400 |
for (i = 0; i < cm1->ncols; i++) {
| 401 |
const COLORV *cp1 = cm_lval(cm1,dr,i);
| 402 |
const COLORV *cp2 = cm_lval(cm2,i,dc);
| 403 |
res[0] += cp1[0] * cp2[0];
| 404 |
res[1] += cp1[1] * cp2[1];
| 405 |
res[2] += cp1[2] * cp2[2];
| 406 |
| 407 |
copycolor(dp, res);
| 408 |
| 409 |
if (rowcheck != NULL) free(rowcheck);
| 410 |
if (colcheck != NULL) free(colcheck);
| 411 |
return(cmr);
| 412 |
| 413 |
| 414 |
/* write out matrix to file (precede by resolution string if picture) */
| 415 |
int
| 416 |
cm_write(const CMATRIX *cm, int dtype, FILE *fp)
| 417 |
| 418 |
static const char tabEOL[2] = {'\t','\n'};
| 419 |
const COLORV *mp = cm->cmem;
| 420 |
int r, c;
| 421 |
| 422 |
switch (dtype) {
| 423 |
case DTascii:
| 424 |
for (r = 0; r < cm->nrows; r++)
| 425 |
for (c = 0; c < cm->ncols; c++, mp += 3)
| 426 |
fprintf(fp, "%.6e %.6e %.6e%c",
| 427 |
mp[0], mp[1], mp[2],
| 428 |
tabEOL[c >= cm->ncols-1]);
| 429 |
break;
| 430 |
case DTfloat:
| 431 |
case DTdouble:
| 432 |
| 433 |
r = cm->ncols*cm->nrows;
| 434 |
while (r > 0) {
| 435 |
c = fwrite(mp, sizeof(COLOR), r, fp);
| 436 |
if (c <= 0)
| 437 |
return(0);
| 438 |
mp += 3*c;
| 439 |
r -= c;
| 440 |
| 441 |
| 442 |
double dc[3];
| 443 |
| 444 |
while (r--) {
| 445 |
copycolor(dc, mp);
| 446 |
if (fwrite(dc, sizeof(double), 3, fp) != 3)
| 447 |
return(0);
| 448 |
mp += 3;
| 449 |
| 450 |
| 451 |
float fc[3];
| 452 |
| 453 |
while (r--) {
| 454 |
copycolor(fc, mp);
| 455 |
if (fwrite(fc, sizeof(float), 3, fp) != 3)
| 456 |
return(0);
| 457 |
mp += 3;
| 458 |
| 459 |
| 460 |
break;
| 461 |
case DTrgbe:
| 462 |
case DTxyze:
| 463 |
fprtresolu(cm->ncols, cm->nrows, fp);
| 464 |
for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols)
| 465 |
if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0)
| 466 |
return(0);
| 467 |
break;
| 468 |
default:
| 469 |
fputs("Unsupported data type in cm_write()!\n", stderr);
| 470 |
return(0);
| 471 |
| 472 |
return(fflush(fp) == 0);
| 473 |
