1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: cmatrix.c,v 2.10 2015/05/08 18:25:03 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Color matrix routines. |
6 |
7 |
* G. Ward |
8 |
9 |
10 |
#include <ctype.h> |
11 |
#include "standard.h" |
12 |
#include "cmatrix.h" |
13 |
#include "platform.h" |
14 |
#include "rtprocess.h" |
15 |
#include "resolu.h" |
16 |
17 |
const char *cm_fmt_id[] = { |
18 |
"unknown", "ascii", COLRFMT, CIEFMT, |
19 |
"float", "double" |
20 |
21 |
22 |
const int cm_elem_size[] = { |
23 |
0, 0, 3*sizeof(float), 3*sizeof(double), 4, 4 |
24 |
25 |
26 |
/* Allocate a color coefficient matrix */ |
27 |
CMATRIX * |
28 |
cm_alloc(int nrows, int ncols) |
29 |
30 |
CMATRIX *cm; |
31 |
32 |
if ((nrows <= 0) | (ncols <= 0)) |
33 |
error(USER, "attempt to create empty matrix"); |
34 |
cm = (CMATRIX *)malloc(sizeof(CMATRIX) + |
35 |
sizeof(COLOR)*(nrows*ncols - 1)); |
36 |
if (cm == NULL) |
37 |
error(SYSTEM, "out of memory in cm_alloc()"); |
38 |
cm->nrows = nrows; |
39 |
cm->ncols = ncols; |
40 |
return(cm); |
41 |
42 |
43 |
static void |
44 |
adjacent_ra_sizes(size_t bounds[2], size_t target) |
45 |
46 |
bounds[0] = 0; bounds[1] = 2048; |
47 |
while (bounds[1] < target) { |
48 |
bounds[0] = bounds[1]; |
49 |
bounds[1] += bounds[1]>>1; |
50 |
51 |
52 |
53 |
/* Resize color coefficient matrix */ |
54 |
CMATRIX * |
55 |
cm_resize(CMATRIX *cm, int nrows) |
56 |
57 |
size_t old_size, new_size, ra_bounds[2]; |
58 |
59 |
if (nrows == cm->nrows) |
60 |
return(cm); |
61 |
if (nrows <= 0) { |
62 |
cm_free(cm); |
63 |
return(NULL); |
64 |
65 |
old_size = sizeof(CMATRIX) + sizeof(COLOR)*(cm->nrows*cm->ncols - 1); |
66 |
adjacent_ra_sizes(ra_bounds, old_size); |
67 |
new_size = sizeof(CMATRIX) + sizeof(COLOR)*(nrows*cm->ncols - 1); |
68 |
if (nrows < cm->nrows ? new_size <= ra_bounds[0] : |
69 |
new_size > ra_bounds[1]) { |
70 |
adjacent_ra_sizes(ra_bounds, new_size); |
71 |
cm = (CMATRIX *)realloc(cm, ra_bounds[1]); |
72 |
if (cm == NULL) |
73 |
error(SYSTEM, "out of memory in cm_resize()"); |
74 |
75 |
76 |
return(cm); |
77 |
78 |
79 |
typedef struct { |
80 |
int dtype; /* data type */ |
81 |
int nrows, ncols; /* matrix size */ |
82 |
char *err; /* error message */ |
83 |
} CMINFO; /* header info record */ |
84 |
85 |
static int |
86 |
get_cminfo(char *s, void *p) |
87 |
88 |
CMINFO *ip = (CMINFO *)p; |
89 |
char fmt[32]; |
90 |
int i; |
91 |
92 |
if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) { |
93 |
ip->err = "unexpected # components (must be 3)"; |
94 |
return(-1); |
95 |
96 |
if (!strncmp(s, "NROWS=", 6)) { |
97 |
ip->nrows = atoi(s+6); |
98 |
return(0); |
99 |
100 |
if (!strncmp(s, "NCOLS=", 6)) { |
101 |
ip->ncols = atoi(s+6); |
102 |
return(0); |
103 |
104 |
if (!formatval(fmt, s)) |
105 |
return(0); |
106 |
for (i = 1; i < DTend; i++) |
107 |
if (!strcmp(fmt, cm_fmt_id[i])) |
108 |
ip->dtype = i; |
109 |
return(0); |
110 |
111 |
112 |
/* Load header to obtain/check data type and number of columns */ |
113 |
char * |
114 |
cm_getheader(int *dt, int *nr, int *nc, FILE *fp) |
115 |
116 |
CMINFO cmi; |
117 |
/* read header */ |
118 |
cmi.dtype = DTfromHeader; |
119 |
cmi.nrows = cmi.ncols = 0; |
120 |
cmi.err = "unexpected EOF in header"; |
121 |
if (getheader(fp, get_cminfo, &cmi) < 0) |
122 |
return(cmi.err); |
123 |
if (dt != NULL) { /* get/check data type? */ |
124 |
if (cmi.dtype == DTfromHeader) { |
125 |
if (*dt == DTfromHeader) |
126 |
return("missing/unknown data format in header"); |
127 |
} else if (*dt == DTfromHeader) |
128 |
*dt = cmi.dtype; |
129 |
else if (*dt != cmi.dtype) |
130 |
return("unexpected data format in header"); |
131 |
132 |
if (nr != NULL) { /* get/check #rows? */ |
133 |
if (*nr <= 0) |
134 |
*nr = cmi.nrows; |
135 |
else if ((cmi.nrows > 0) & (*nr != cmi.nrows)) |
136 |
return("unexpected row count in header"); |
137 |
138 |
if (nc != NULL) { /* get/check #columns? */ |
139 |
if (*nc <= 0) |
140 |
*nc = cmi.ncols; |
141 |
else if ((cmi.ncols > 0) & (*nc != cmi.ncols)) |
142 |
return("unexpected column count in header"); |
143 |
144 |
return(NULL); |
145 |
146 |
147 |
/* Allocate and load a matrix from the given input (or stdin if NULL) */ |
148 |
CMATRIX * |
149 |
cm_load(const char *inspec, int nrows, int ncols, int dtype) |
150 |
151 |
FILE *fp = stdin; |
152 |
CMATRIX *cm; |
153 |
154 |
if (inspec == NULL) |
155 |
inspec = "<stdin>"; |
156 |
else if (inspec[0] == '!') { |
157 |
fp = popen(inspec+1, "r"); |
158 |
if (fp == NULL) { |
159 |
sprintf(errmsg, "cannot start command '%s'", inspec); |
160 |
error(SYSTEM, errmsg); |
161 |
162 |
} else if ((fp = fopen(inspec, "r")) == NULL) { |
163 |
sprintf(errmsg, "cannot open file '%s'", inspec); |
164 |
165 |
166 |
#ifdef getc_unlocked |
167 |
flockfile(fp); |
168 |
#endif |
169 |
if (dtype != DTascii) |
170 |
SET_FILE_BINARY(fp); /* doesn't really work */ |
171 |
if (!dtype | !ncols) { /* expecting header? */ |
172 |
char *err = cm_getheader(&dtype, &nrows, &ncols, fp); |
173 |
if (err != NULL) |
174 |
error(USER, err); |
175 |
if (ncols <= 0) |
176 |
error(USER, "unspecified number of columns"); |
177 |
178 |
switch (dtype) { |
179 |
case DTascii: |
180 |
case DTfloat: |
181 |
case DTdouble: |
182 |
break; |
183 |
default: |
184 |
error(USER, "unexpected data type in cm_load()"); |
185 |
186 |
if (nrows <= 0) { /* don't know length? */ |
187 |
int guessrows = 147; /* usually big enough */ |
188 |
if ((dtype != DTascii) & (fp != stdin) & (inspec[0] != '!')) { |
189 |
long startpos = ftell(fp); |
190 |
if (fseek(fp, 0L, SEEK_END) == 0) { |
191 |
long endpos = ftell(fp); |
192 |
long elemsiz = 3*(dtype==DTfloat ? |
193 |
sizeof(float) : sizeof(double)); |
194 |
195 |
if ((endpos - startpos) % (ncols*elemsiz)) { |
196 |
sprintf(errmsg, |
197 |
"improper length for binary file '%s'", |
198 |
inspec); |
199 |
error(USER, errmsg); |
200 |
201 |
guessrows = (endpos - startpos)/(ncols*elemsiz); |
202 |
if (fseek(fp, startpos, SEEK_SET) < 0) { |
203 |
sprintf(errmsg, |
204 |
"fseek() error on file '%s'", |
205 |
inspec); |
206 |
207 |
208 |
nrows = guessrows; /* we're confident */ |
209 |
210 |
211 |
cm = cm_alloc(guessrows, ncols); |
212 |
} else |
213 |
cm = cm_alloc(nrows, ncols); |
214 |
if (cm == NULL) /* XXX never happens */ |
215 |
return(NULL); |
216 |
if (dtype == DTascii) { /* read text file */ |
217 |
int maxrow = (nrows > 0 ? nrows : 32000); |
218 |
int r, c; |
219 |
for (r = 0; r < maxrow; r++) { |
220 |
if (r >= cm->nrows) /* need more space? */ |
221 |
cm = cm_resize(cm, 2*cm->nrows); |
222 |
for (c = 0; c < ncols; c++) { |
223 |
COLORV *cv = cm_lval(cm,r,c); |
224 |
if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) |
225 |
if ((nrows <= 0) & (r > 0) & !c) { |
226 |
cm = cm_resize(cm, maxrow=r); |
227 |
break; |
228 |
} else |
229 |
goto EOFerror; |
230 |
231 |
232 |
while ((c = getc(fp)) != EOF) |
233 |
if (!isspace(c)) { |
234 |
sprintf(errmsg, |
235 |
"unexpected data at end of ascii input '%s'", |
236 |
inspec); |
237 |
error(WARNING, errmsg); |
238 |
break; |
239 |
240 |
} else { /* read binary file */ |
241 |
if (sizeof(COLOR) == cm_elem_size[dtype]) { |
242 |
int nread = 0; |
243 |
do { /* read all we can */ |
244 |
nread += fread(cm->cmem + 3*nread, |
245 |
sizeof(COLOR), |
246 |
cm->nrows*cm->ncols - nread, |
247 |
fp); |
248 |
if (nrows <= 0) { /* unknown length */ |
249 |
if (nread == cm->nrows*cm->ncols) |
250 |
251 |
252 |
else if (nread && !(nread % cm->ncols)) |
253 |
/* seem to be done */ |
254 |
cm = cm_resize(cm, nread/cm->ncols); |
255 |
else /* ended mid-row */ |
256 |
goto EOFerror; |
257 |
} else if (nread < cm->nrows*cm->ncols) |
258 |
goto EOFerror; |
259 |
} while (nread < cm->nrows*cm->ncols); |
260 |
261 |
} else if (dtype == DTdouble) { |
262 |
double dc[3]; /* load from double */ |
263 |
COLORV *cvp = cm->cmem; |
264 |
int n = nrows*ncols; |
265 |
266 |
if (n <= 0) |
267 |
goto not_handled; |
268 |
while (n--) { |
269 |
if (fread(dc, sizeof(double), 3, fp) != 3) |
270 |
goto EOFerror; |
271 |
copycolor(cvp, dc); |
272 |
cvp += 3; |
273 |
274 |
} else /* dtype == DTfloat */ { |
275 |
float fc[3]; /* load from float */ |
276 |
277 |
278 |
279 |
if (n <= 0) |
280 |
goto not_handled; |
281 |
while (n--) { |
282 |
if (fread(fc, sizeof(float), 3, fp) != 3) |
283 |
goto EOFerror; |
284 |
copycolor(cvp, fc); |
285 |
cvp += 3; |
286 |
287 |
288 |
if (fgetc(fp) != EOF) { |
289 |
sprintf(errmsg, |
290 |
"unexpected data at end of binary input '%s'", |
291 |
inspec); |
292 |
293 |
294 |
295 |
if (fp != stdin) { |
296 |
if (inspec[0] != '!') |
297 |
fclose(fp); |
298 |
else if (pclose(fp)) { |
299 |
sprintf(errmsg, "error running command '%s'", inspec); |
300 |
301 |
302 |
303 |
304 |
else |
305 |
funlockfile(fp); |
306 |
#endif |
307 |
return(cm); |
308 |
EOFerror: |
309 |
sprintf(errmsg, "unexpected EOF reading %s", inspec); |
310 |
311 |
not_handled: |
312 |
error(INTERNAL, "unhandled data size or length in cm_load()"); |
313 |
return(NULL); /* gratis return */ |
314 |
315 |
316 |
/* Extract a column vector from a matrix */ |
317 |
CMATRIX * |
318 |
cm_column(const CMATRIX *cm, int c) |
319 |
320 |
CMATRIX *cvr; |
321 |
int dr; |
322 |
323 |
if ((c < 0) | (c >= cm->ncols)) |
324 |
error(INTERNAL, "column requested outside matrix"); |
325 |
cvr = cm_alloc(cm->nrows, 1); |
326 |
if (cvr == NULL) |
327 |
return(NULL); |
328 |
for (dr = 0; dr < cm->nrows; dr++) { |
329 |
const COLORV *sp = cm_lval(cm,dr,c); |
330 |
COLORV *dp = cv_lval(cvr,dr); |
331 |
dp[0] = sp[0]; |
332 |
dp[1] = sp[1]; |
333 |
dp[2] = sp[2]; |
334 |
335 |
return(cvr); |
336 |
337 |
338 |
/* Scale a matrix by a single value */ |
339 |
CMATRIX * |
340 |
cm_scale(const CMATRIX *cm1, const COLOR sca) |
341 |
342 |
CMATRIX *cmr; |
343 |
int dr, dc; |
344 |
345 |
cmr = cm_alloc(cm1->nrows, cm1->ncols); |
346 |
if (cmr == NULL) |
347 |
return(NULL); |
348 |
for (dr = 0; dr < cmr->nrows; dr++) |
349 |
for (dc = 0; dc < cmr->ncols; dc++) { |
350 |
const COLORV *sp = cm_lval(cm1,dr,dc); |
351 |
COLORV *dp = cm_lval(cmr,dr,dc); |
352 |
dp[0] = sp[0] * sca[0]; |
353 |
dp[1] = sp[1] * sca[1]; |
354 |
dp[2] = sp[2] * sca[2]; |
355 |
356 |
return(cmr); |
357 |
358 |
359 |
/* Multiply two matrices (or a matrix and a vector) and allocate the result */ |
360 |
CMATRIX * |
361 |
cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2) |
362 |
363 |
char *rowcheck=NULL, *colcheck=NULL; |
364 |
CMATRIX *cmr; |
365 |
int dr, dc, i; |
366 |
367 |
if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows)) |
368 |
error(INTERNAL, "matrix dimension mismatch in cm_multiply()"); |
369 |
cmr = cm_alloc(cm1->nrows, cm2->ncols); |
370 |
if (cmr == NULL) |
371 |
return(NULL); |
372 |
/* optimization: check for zero rows & cols */ |
373 |
if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) { |
374 |
static const COLOR czero; |
375 |
rowcheck = (char *)calloc(cmr->nrows, 1); |
376 |
for (dr = cm1->nrows*(rowcheck != NULL); dr--; ) |
377 |
for (dc = cm1->ncols; dc--; ) |
378 |
if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) { |
379 |
rowcheck[dr] = 1; |
380 |
break; |
381 |
382 |
colcheck = (char *)calloc(cmr->ncols, 1); |
383 |
for (dc = cm2->ncols*(colcheck != NULL); dc--; ) |
384 |
for (dr = cm2->nrows; dr--; ) |
385 |
if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) { |
386 |
colcheck[dc] = 1; |
387 |
break; |
388 |
389 |
390 |
391 |
392 |
393 |
double res[3]; |
394 |
dp[0] = dp[1] = dp[2] = 0; |
395 |
if (rowcheck != NULL && !rowcheck[dr]) |
396 |
continue; |
397 |
if (colcheck != NULL && !colcheck[dc]) |
398 |
continue; |
399 |
res[0] = res[1] = res[2] = 0; |
400 |
for (i = 0; i < cm1->ncols; i++) { |
401 |
const COLORV *cp1 = cm_lval(cm1,dr,i); |
402 |
const COLORV *cp2 = cm_lval(cm2,i,dc); |
403 |
res[0] += (double)cp1[0] * (double)cp2[0]; |
404 |
res[1] += (double)cp1[1] * (double)cp2[1]; |
405 |
res[2] += (double)cp1[2] * (double)cp2[2]; |
406 |
407 |
copycolor(dp, res); |
408 |
409 |
if (rowcheck != NULL) free(rowcheck); |
410 |
if (colcheck != NULL) free(colcheck); |
411 |
return(cmr); |
412 |
413 |
414 |
/* write out matrix to file (precede by resolution string if picture) */ |
415 |
int |
416 |
cm_write(const CMATRIX *cm, int dtype, FILE *fp) |
417 |
418 |
static const char tabEOL[2] = {'\t','\n'}; |
419 |
const COLORV *mp = cm->cmem; |
420 |
int r, c; |
421 |
422 |
switch (dtype) { |
423 |
case DTascii: |
424 |
for (r = 0; r < cm->nrows; r++) |
425 |
for (c = 0; c < cm->ncols; c++, mp += 3) |
426 |
fprintf(fp, "%.6e %.6e %.6e%c", |
427 |
mp[0], mp[1], mp[2], |
428 |
tabEOL[c >= cm->ncols-1]); |
429 |
break; |
430 |
case DTfloat: |
431 |
case DTdouble: |
432 |
433 |
r = cm->ncols*cm->nrows; |
434 |
while (r > 0) { |
435 |
c = fwrite(mp, sizeof(COLOR), r, fp); |
436 |
if (c <= 0) |
437 |
return(0); |
438 |
mp += 3*c; |
439 |
r -= c; |
440 |
441 |
442 |
double dc[3]; |
443 |
444 |
while (r--) { |
445 |
copycolor(dc, mp); |
446 |
if (fwrite(dc, sizeof(double), 3, fp) != 3) |
447 |
return(0); |
448 |
mp += 3; |
449 |
450 |
451 |
float fc[3]; |
452 |
453 |
while (r--) { |
454 |
copycolor(fc, mp); |
455 |
if (fwrite(fc, sizeof(float), 3, fp) != 3) |
456 |
return(0); |
457 |
mp += 3; |
458 |
459 |
460 |
break; |
461 |
case DTrgbe: |
462 |
case DTxyze: |
463 |
fprtresolu(cm->ncols, cm->nrows, fp); |
464 |
for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols) |
465 |
if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0) |
466 |
return(0); |
467 |
break; |
468 |
default: |
469 |
fputs("Unsupported data type in cm_write()!\n", stderr); |
470 |
return(0); |
471 |
472 |
return(fflush(fp) == 0); |
473 |
