Fixed issues loading resolution string when NCOLS= not in header
Minor changes should not affect operation
Fixed important bugs in RGBE and XYZE file loading and byte-swapping
Fixed priority of output formats
Made error checking more consistent and eliminated unused function call
Fixed inconsistency introduced in 2014 (rev. 2.8)
Force double promotion
Made realloc() calls less aggressive to avoid memory errors
Reduced precision of multiplies in favor of time when little differ found
Improved matrix multiplication accuracy by forcing promotions to double
Added rtprocess.h needed for popen() under Windows
Removed unnecessary address operators from function ids.
Hopeful fix to performance issue for gendaymtx under Windows
Improved accuracy of matrix multiplication by using double accumulator
Removed tab before first column
