root/radiance/ray/src/util/cmatrix.c
Mon Mar 30 20:41:47 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.27: +3 -7 lines
Diff to previous 2.27 , to selected 2.16
Fixed issues loading resolution string when NCOLS= not in header
Thu Mar 26 16:56:10 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.26: +5 -6 lines
Diff to previous 2.26 , to selected 2.16
Minor changes should not affect operation
Thu Mar 26 02:48:31 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.25: +12 -8 lines
Diff to previous 2.25 , to selected 2.16
Fixed important bugs in RGBE and XYZE file loading and byte-swapping
Wed Mar 25 01:51:09 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.24: +37 -6 lines
Diff to previous 2.24 , to selected 2.16
Thu Nov 7 23:10:18 2019 UTC (4 years, 5 months ago) by greg
Diff to previous 2.23 , to selected 2.16
Fixed priority of output formats
Wed Oct 23 17:00:14 2019 UTC (4 years, 6 months ago) by greg
Changes since 2.22: +33 -1 lines
Diff to previous 2.22 , to selected 2.16
Wed Aug 14 18:20:02 2019 UTC (4 years, 8 months ago) by greg
Changes since 2.21: +18 -3 lines
Diff to previous 2.21 , to selected 2.16
Mon Aug 12 18:28:37 2019 UTC (4 years, 8 months ago) by greg
Changes since 2.20: +27 -39 lines
Diff to previous 2.20 , to selected 2.16
Made error checking more consistent and eliminated unused function call
Thu Aug 2 18:33:49 2018 UTC (5 years, 8 months ago) by greg
Diff to previous 2.19 , to selected 2.16
Tue Apr 10 22:11:30 2018 UTC (6 years ago) by greg
Diff to previous 2.18 , to selected 2.16
Fixed inconsistency introduced in 2014 (rev. 2.8)
Tue Aug 30 14:52:46 2016 UTC (7 years, 8 months ago) by greg
Diff to previous 2.17 , to selected 2.16
Force double promotion
Thu Aug 18 00:52:48 2016 UTC (7 years, 8 months ago) by greg
Diff to previous 2.16
Revision 2.16 - (view) (download) (annotate) - [selected]
Sun Mar 6 01:13:18 2016 UTC (8 years, 1 month ago) by schorsch
Changes since 2.15: +2 -1 lines
Diff to previous 2.15
Wed Feb 17 23:26:06 2016 UTC (8 years, 2 months ago) by greg
Changes since 2.14: +6 -5 lines
Diff to previous 2.14 , to selected 2.16
Made realloc() calls less aggressive to avoid memory errors
Tue Feb 2 18:02:32 2016 UTC (8 years, 2 months ago) by greg
Diff to previous 2.13 , to selected 2.16
Sat Aug 1 23:27:04 2015 UTC (8 years, 9 months ago) by greg
Diff to previous 2.12 , to selected 2.16
Wed Jul 22 04:29:56 2015 UTC (8 years, 9 months ago) by greg
Diff to previous 2.11 , to selected 2.16
Reduced precision of multiplies in favor of time when little differ found
Wed Jul 22 04:23:27 2015 UTC (8 years, 9 months ago) by greg
Diff to previous 2.10 , to selected 2.16
Improved matrix multiplication accuracy by forcing promotions to double
Fri May 8 18:25:03 2015 UTC (8 years, 11 months ago) by greg
Diff to previous 2.9 , to selected 2.16
Added rtprocess.h needed for popen() under Windows
Mon May 4 20:53:21 2015 UTC (8 years, 11 months ago) by greg
Changes since 2.8: +29 -17 lines
Diff to previous 2.8 , to selected 2.16
Sat Aug 2 17:10:43 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Diff to previous 2.7 , to selected 2.16
Tue Jul 8 16:39:41 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2
Diff to previous 2.6 , to selected 2.16
Removed unnecessary address operators from function ids.
Tue Jun 17 18:03:48 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.5: +23 -5 lines
Diff to previous 2.5 , to selected 2.16
Hopeful fix to performance issue for gendaymtx under Windows
Fri May 30 00:00:54 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.4: +62 -18 lines
Diff to previous 2.4 , to selected 2.16
Thu May 29 17:28:09 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.3: +10 -7 lines
Diff to previous 2.3 , to selected 2.16
Improved accuracy of matrix multiplication by using double accumulator
Tue Apr 8 23:45:33 2014 UTC (10 years ago) by greg
Diff to previous 2.2 , to selected 2.16
Removed tab before first column
Sat Feb 8 01:28:06 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.1: +74 -24 lines
Diff to previous 2.1 , to selected 2.16
Mon Jan 20 21:29:04 2014 UTC (10 years, 3 months ago) by greg
Diff to selected 2.16
