--- ray/src/util/cmatrix.c 2014/01/20 21:29:04 2.1 +++ ray/src/util/cmatrix.c 2020/03/25 01:51:09 2.25 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: cmatrix.c,v 2.1 2014/01/20 21:29:04 greg Exp $"; +static const char RCSid[] = "$Id: cmatrix.c,v 2.25 2020/03/25 01:51:09 greg Exp $"; #endif /* * Color matrix routines. @@ -8,10 +8,22 @@ static const char RCSid[] = "$Id: cmatrix.c,v 2.1 2014 */ #include +#include "platform.h" #include "standard.h" #include "cmatrix.h" #include "platform.h" +#include "paths.h" +#include "resolu.h" +const char *cm_fmt_id[] = { + "unknown", COLRFMT, CIEFMT, + "float", "ascii", "double" + }; + +const int cm_elem_size[] = { + 0, 0, 4, 4, 3*sizeof(float), 3*sizeof(double) + }; + /* Allocate a color coefficient matrix */ CMATRIX * cm_alloc(int nrows, int ncols) @@ -21,78 +33,204 @@ cm_alloc(int nrows, int ncols) if ((nrows <= 0) | (ncols <= 0)) error(USER, "attempt to create empty matrix"); cm = (CMATRIX *)malloc(sizeof(CMATRIX) + - 3*sizeof(COLORV)*(nrows*ncols - 1)); - if (cm == NULL) + sizeof(COLOR)*(nrows*ncols - 1)); + if (!cm) error(SYSTEM, "out of memory in cm_alloc()"); cm->nrows = nrows; cm->ncols = ncols; return(cm); } +static void +adjacent_ra_sizes(size_t bounds[2], size_t target) +{ + bounds[0] = 0; bounds[1] = 2048; + while (bounds[1] < target) { + bounds[0] = bounds[1]; + bounds[1] += bounds[1]>>1; + } +} + /* Resize color coefficient matrix */ CMATRIX * cm_resize(CMATRIX *cm, int nrows) { + size_t old_size, new_size, ra_bounds[2]; + + if (!cm) + return(NULL); if (nrows == cm->nrows) return(cm); if (nrows <= 0) { cm_free(cm); return(NULL); } - cm = (CMATRIX *)realloc(cm, sizeof(CMATRIX) + - 3*sizeof(COLORV)*(nrows*cm->ncols - 1)); - if (cm == NULL) - error(SYSTEM, "out of memory in cm_resize()"); + old_size = sizeof(CMATRIX) + sizeof(COLOR)*(cm->nrows*cm->ncols - 1); + adjacent_ra_sizes(ra_bounds, old_size); + new_size = sizeof(CMATRIX) + sizeof(COLOR)*(nrows*cm->ncols - 1); + if (nrows < cm->nrows ? new_size <= ra_bounds[0] : + new_size > ra_bounds[1]) { + adjacent_ra_sizes(ra_bounds, new_size); + cm = (CMATRIX *)realloc(cm, ra_bounds[1]); + if (!cm) + error(SYSTEM, "out of memory in cm_resize()"); + } cm->nrows = nrows; return(cm); } +typedef struct { + int dtype; /* data type */ + int need2swap; /* need byte swap? */ + int nrows, ncols; /* matrix size */ + COLOR expos; /* exposure value */ + char *err; /* error message */ +} CMINFO; /* header info record */ + static int -getDT(char *s, void *p) +get_cminfo(char *s, void *p) { - char fmt[32]; - - if (formatval(fmt, s)) { - if (!strcmp(fmt, "ascii")) - *((int *)p) = DTascii; - else if (!strcmp(fmt, "float")) - *((int *)p) = DTfloat; - else if (!strcmp(fmt, "double")) - *((int *)p) = DTdouble; - else if (!strcmp(fmt, COLRFMT)) - *((int *)p) = DTrgbe; - else if (!strcmp(fmt, CIEFMT)) - *((int *)p) = DTxyze; + CMINFO *ip = (CMINFO *)p; + char fmt[MAXFMTLEN]; + int i; + + if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) { + ip->err = "unexpected # components (must be 3)"; + return(-1); } + if (!strncmp(s, "NROWS=", 6)) { + ip->nrows = atoi(s+6); + return(0); + } + if (!strncmp(s, "NCOLS=", 6)) { + ip->ncols = atoi(s+6); + return(0); + } + if ((i = isbigendian(s)) >= 0) { + ip->need2swap = (nativebigendian() != i); + return(0); + } + if (isexpos(s)) { + double d = exposval(s); + scalecolor(ip->expos, d); + return(0); + } + if (iscolcor(s)) { + COLOR ctmp; + colcorval(ctmp, s); + multcolor(ip->expos, ctmp); + return(0); + } + if (!formatval(fmt, s)) + return(0); + for (i = 1; i < DTend; i++) + if (!strcmp(fmt, cm_fmt_id[i])) + ip->dtype = i; return(0); } -/* Load header to obtain data type */ -int -getDTfromHeader(FILE *fp) +/* Load header to obtain/check data type and number of columns */ +char * +cm_getheader(int *dt, int *nr, int *nc, int *swp, COLOR scale, FILE *fp) { - int dt = DTfromHeader; - - if (getheader(fp, getDT, &dt) < 0) - error(SYSTEM, "header read error"); - if (dt == DTfromHeader) - error(USER, "missing data format in header"); - return(dt); + CMINFO cmi; + /* read header */ + cmi.dtype = DTfromHeader; + cmi.need2swap = 0; + cmi.expos[0] = cmi.expos[1] = cmi.expos[2] = 1.f; + cmi.nrows = cmi.ncols = 0; + cmi.err = "unexpected EOF in header"; + if (getheader(fp, get_cminfo, &cmi) < 0) + return(cmi.err); + if (dt) { /* get/check data type? */ + if (cmi.dtype == DTfromHeader) { + if (*dt == DTfromHeader) + return("missing/unknown data format in header"); + } else if (*dt == DTfromHeader) + *dt = cmi.dtype; + else if (*dt != cmi.dtype) + return("unexpected data format in header"); + } + if (nr) { /* get/check #rows? */ + if (*nr <= 0) + *nr = cmi.nrows; + else if ((cmi.nrows > 0) & (*nr != cmi.nrows)) + return("unexpected row count in header"); + } + if (nc) { /* get/check #columns? */ + if (*nc <= 0) + *nc = cmi.ncols; + else if ((cmi.ncols > 0) & (*nc != cmi.ncols)) + return("unexpected column count in header"); + } + if (swp) /* get/check swap? */ + *swp = cmi.need2swap; + if (scale) { /* transfer exposure comp. */ + scale[0] = 1.f/cmi.expos[0]; + scale[1] = 1.f/cmi.expos[1]; + scale[2] = 1.f/cmi.expos[2]; + } + return(NULL); } -/* Allocate and load a matrix from the given file (or stdin if NULL) */ -CMATRIX * -cm_load(const char *fname, int nrows, int ncols, int dtype) +/* Allocate and load image data into matrix */ +static CMATRIX * +cm_load_rgbe(FILE *fp, int nrows, int ncols, COLOR scale) { - FILE *fp = stdin; + int doscale; CMATRIX *cm; + COLORV *mp; + /* header already loaded */ + if ((nrows <= 0) | (ncols <= 0) && !fscnresolu(&ncols, &nrows, fp)) { + error(USER, "bad picture resolution string"); + return(NULL); + } + cm = cm_alloc(nrows, ncols); + if (!cm) + return(NULL); + doscale = (scale[0] < .99) | (scale[0] > 1.01) | + (scale[1] < .99) | (scale[1] > 1.01) | + (scale[2] < .99) | (scale[2] > 1.01) ; + mp = cm->cmem; + while (nrows--) { + if (freadscan((COLOR *)mp, ncols, fp) < 0) { + error(USER, "error reading color picture as matrix"); + cm_free(cm); + return(NULL); + } + if (doscale) { + int i = ncols; + while (i--) { + *mp++ *= scale[0]; + *mp++ *= scale[1]; + *mp++ *= scale[2]; + } + } else + mp += 3*ncols; + } /* caller closes stream */ + return(cm); +} - if (ncols <= 0) - error(USER, "Non-positive number of columns"); - if (fname == NULL) - fname = ""; - else if ((fp = fopen(fname, "r")) == NULL) { - sprintf(errmsg, "cannot open file '%s'", fname); +/* Allocate and load a matrix from the given input (or stdin if NULL) */ +CMATRIX * +cm_load(const char *inspec, int nrows, int ncols, int dtype) +{ + const int ROWINC = 2048; + FILE *fp = stdin; + int swap = 0; + COLOR scale; + CMATRIX *cm; + + if (!inspec) + inspec = ""; + else if (inspec[0] == '!') { + fp = popen(inspec+1, "r"); + if (!fp) { + sprintf(errmsg, "cannot start command '%s'", inspec); + error(SYSTEM, errmsg); + } + } else if (!(fp = fopen(inspec, "r"))) { + sprintf(errmsg, "cannot open file '%s'", inspec); error(SYSTEM, errmsg); } #ifdef getc_unlocked @@ -100,19 +238,28 @@ cm_load(const char *fname, int nrows, int ncols, int d #endif if (dtype != DTascii) SET_FILE_BINARY(fp); /* doesn't really work */ - if (dtype == DTfromHeader) - dtype = getDTfromHeader(fp); + if (!dtype | !ncols) { /* expecting header? */ + char *err = cm_getheader(&dtype, &nrows, &ncols, &swap, scale, fp); + if (err) + error(USER, err); + if (ncols <= 0) + error(USER, "unspecified number of columns"); + } switch (dtype) { case DTascii: case DTfloat: case DTdouble: break; + case DTrgbe: + case DTxyze: + cm = cm_load_rgbe(fp, nrows, ncols, scale); + goto cleanup; default: error(USER, "unexpected data type in cm_load()"); } if (nrows <= 0) { /* don't know length? */ int guessrows = 147; /* usually big enough */ - if ((dtype != DTascii) & (fp != stdin)) { + if ((dtype != DTascii) & (fp != stdin) & (inspec[0] != '!')) { long startpos = ftell(fp); if (fseek(fp, 0L, SEEK_END) == 0) { long endpos = ftell(fp); @@ -122,14 +269,14 @@ cm_load(const char *fname, int nrows, int ncols, int d if ((endpos - startpos) % (ncols*elemsiz)) { sprintf(errmsg, "improper length for binary file '%s'", - fname); + inspec); error(USER, errmsg); } guessrows = (endpos - startpos)/(ncols*elemsiz); if (fseek(fp, startpos, SEEK_SET) < 0) { sprintf(errmsg, "fseek() error on file '%s'", - fname); + inspec); error(SYSTEM, errmsg); } nrows = guessrows; /* we're confident */ @@ -138,45 +285,45 @@ cm_load(const char *fname, int nrows, int ncols, int d cm = cm_alloc(guessrows, ncols); } else cm = cm_alloc(nrows, ncols); - if (cm == NULL) /* XXX never happens */ + if (!cm) /* XXX never happens */ return(NULL); if (dtype == DTascii) { /* read text file */ int maxrow = (nrows > 0 ? nrows : 32000); int r, c; for (r = 0; r < maxrow; r++) { if (r >= cm->nrows) /* need more space? */ - cm = cm_resize(cm, 2*cm->nrows); + cm = cm_resize(cm, cm->nrows+ROWINC); for (c = 0; c < ncols; c++) { COLORV *cv = cm_lval(cm,r,c); - if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) + if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) { if ((nrows <= 0) & (r > 0) & !c) { cm = cm_resize(cm, maxrow=r); break; } else goto EOFerror; + } } } while ((c = getc(fp)) != EOF) if (!isspace(c)) { sprintf(errmsg, - "unexpected data at end of ascii file %s", - fname); + "unexpected data at end of ascii input '%s'", + inspec); error(WARNING, errmsg); break; } } else { /* read binary file */ - if (sizeof(COLORV) == (dtype==DTfloat ? sizeof(float) : - sizeof(double))) { + if (sizeof(COLOR) == cm_elem_size[dtype]) { int nread = 0; do { /* read all we can */ - nread += fread(cm->cmem + 3*nread, - 3*sizeof(COLORV), + nread += getbinary(cm->cmem + 3*nread, + sizeof(COLOR), cm->nrows*cm->ncols - nread, fp); if (nrows <= 0) { /* unknown length */ if (nread == cm->nrows*cm->ncols) /* need more space? */ - cm = cm_resize(cm, 2*cm->nrows); + cm = cm_resize(cm, cm->nrows+ROWINC); else if (nread && !(nread % cm->ncols)) /* seem to be done */ cm = cm_resize(cm, nread/cm->ncols); @@ -194,7 +341,7 @@ cm_load(const char *fname, int nrows, int ncols, int d if (n <= 0) goto not_handled; while (n--) { - if (fread(dc, sizeof(double), 3, fp) != 3) + if (getbinary(dc, sizeof(double), 3, fp) != 3) goto EOFerror; copycolor(cvp, dc); cvp += 3; @@ -207,7 +354,7 @@ cm_load(const char *fname, int nrows, int ncols, int d if (n <= 0) goto not_handled; while (n--) { - if (fread(fc, sizeof(float), 3, fp) != 3) + if (getbinary(fc, sizeof(float), 3, fp) != 3) goto EOFerror; copycolor(cvp, fc); cvp += 3; @@ -215,21 +362,35 @@ cm_load(const char *fname, int nrows, int ncols, int d } if (fgetc(fp) != EOF) { sprintf(errmsg, - "unexpected data at end of binary file %s", - fname); + "unexpected data at end of binary input '%s'", + inspec); error(WARNING, errmsg); } } - if (fp != stdin) - fclose(fp); + if (swap) { + if (dtype == DTfloat) + swap32((char *)cm->cmem, 3*cm->nrows*cm->ncols); + else if (dtype == DTdouble) + swap64((char *)cm->cmem, 3*cm->nrows*cm->ncols); + } +cleanup: + if (fp != stdin) { + if (inspec[0] != '!') + fclose(fp); + else if (pclose(fp)) { + sprintf(errmsg, "error running command '%s'", inspec); + error(WARNING, errmsg); + } + } #ifdef getc_unlocked else funlockfile(fp); #endif return(cm); EOFerror: - sprintf(errmsg, "unexpected EOF reading %s", fname); + sprintf(errmsg, "unexpected EOF reading %s", inspec); error(USER, errmsg); + return(NULL); not_handled: error(INTERNAL, "unhandled data size or length in cm_load()"); return(NULL); /* gratis return */ @@ -242,10 +403,12 @@ cm_column(const CMATRIX *cm, int c) CMATRIX *cvr; int dr; + if (!cm) + return(NULL); if ((c < 0) | (c >= cm->ncols)) error(INTERNAL, "column requested outside matrix"); cvr = cm_alloc(cm->nrows, 1); - if (cvr == NULL) + if (!cvr) return(NULL); for (dr = 0; dr < cm->nrows; dr++) { const COLORV *sp = cm_lval(cm,dr,c); @@ -257,27 +420,6 @@ cm_column(const CMATRIX *cm, int c) return(cvr); } -/* Scale a matrix by a single value */ -CMATRIX * -cm_scale(const CMATRIX *cm1, const COLOR sca) -{ - CMATRIX *cmr; - int dr, dc; - - cmr = cm_alloc(cm1->nrows, cm1->ncols); - if (cmr == NULL) - return(NULL); - for (dr = 0; dr < cmr->nrows; dr++) - for (dc = 0; dc < cmr->ncols; dc++) { - const COLORV *sp = cm_lval(cm1,dr,dc); - COLORV *dp = cm_lval(cmr,dr,dc); - dp[0] = sp[0] * sca[0]; - dp[1] = sp[1] * sca[1]; - dp[2] = sp[2] * sca[2]; - } - return(cmr); -} - /* Multiply two matrices (or a matrix and a vector) and allocate the result */ CMATRIX * cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2) @@ -286,10 +428,12 @@ cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2) CMATRIX *cmr; int dr, dc, i; + if (!cm1 | !cm2) + return(NULL); if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows)) error(INTERNAL, "matrix dimension mismatch in cm_multiply()"); cmr = cm_alloc(cm1->nrows, cm2->ncols); - if (cmr == NULL) + if (!cmr) return(NULL); /* optimization: check for zero rows & cols */ if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) { @@ -312,34 +456,87 @@ cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2) for (dr = 0; dr < cmr->nrows; dr++) for (dc = 0; dc < cmr->ncols; dc++) { COLORV *dp = cm_lval(cmr,dr,dc); + double res[3]; dp[0] = dp[1] = dp[2] = 0; - if (rowcheck != NULL && !rowcheck[dr]) + if (rowcheck && !rowcheck[dr]) continue; - if (colcheck != NULL && !colcheck[dc]) + if (colcheck && !colcheck[dc]) continue; + res[0] = res[1] = res[2] = 0; for (i = 0; i < cm1->ncols; i++) { const COLORV *cp1 = cm_lval(cm1,dr,i); const COLORV *cp2 = cm_lval(cm2,i,dc); - dp[0] += cp1[0] * cp2[0]; - dp[1] += cp1[1] * cp2[1]; - dp[2] += cp1[2] * cp2[2]; + res[0] += (double)cp1[0] * cp2[0]; + res[1] += (double)cp1[1] * cp2[1]; + res[2] += (double)cp1[2] * cp2[2]; } + copycolor(dp, res); } - if (rowcheck != NULL) free(rowcheck); - if (colcheck != NULL) free(colcheck); + if (rowcheck) free(rowcheck); + if (colcheck) free(colcheck); return(cmr); } -/* print out matrix as ASCII text -- no header */ -void -cm_print(const CMATRIX *cm, FILE *fp) +/* write out matrix to file (precede by resolution string if picture) */ +int +cm_write(const CMATRIX *cm, int dtype, FILE *fp) { - int r, c; - const COLORV *mp = cm->cmem; - - for (r = 0; r < cm->nrows; r++) { - for (c = 0; c < cm->ncols; c++, mp += 3) - fprintf(fp, "\t%.6e %.6e %.6e", mp[0], mp[1], mp[2]); - fputc('\n', fp); + static const char tabEOL[2] = {'\t','\n'}; + const COLORV *mp; + int r, c; + + if (!cm) + return(0); + mp = cm->cmem; + switch (dtype) { + case DTascii: + for (r = 0; r < cm->nrows; r++) + for (c = 0; c < cm->ncols; c++, mp += 3) + fprintf(fp, "%.6e %.6e %.6e%c", + mp[0], mp[1], mp[2], + tabEOL[c >= cm->ncols-1]); + break; + case DTfloat: + case DTdouble: + if (sizeof(COLOR) == cm_elem_size[dtype]) { + r = cm->ncols*cm->nrows; + while (r > 0) { + c = putbinary(mp, sizeof(COLOR), r, fp); + if (c <= 0) + return(0); + mp += 3*c; + r -= c; + } + } else if (dtype == DTdouble) { + double dc[3]; + r = cm->ncols*cm->nrows; + while (r--) { + copycolor(dc, mp); + if (putbinary(dc, sizeof(double), 3, fp) != 3) + return(0); + mp += 3; + } + } else /* dtype == DTfloat */ { + float fc[3]; + r = cm->ncols*cm->nrows; + while (r--) { + copycolor(fc, mp); + if (putbinary(fc, sizeof(float), 3, fp) != 3) + return(0); + mp += 3; + } + } + break; + case DTrgbe: + case DTxyze: + fprtresolu(cm->ncols, cm->nrows, fp); + for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols) + if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0) + return(0); + break; + default: + fputs("Unsupported data type in cm_write()!\n", stderr); + return(0); } + return(fflush(fp) == 0); }
