root/Development/ray/src/util/cmatrix.c
Revision: 2.20
Committed: Thu Aug 2 18:33:49 2018 UTC (7 years, 3 months ago) by greg
2 static const char RCSid[] = "$Id: cmatrix.c,v 2.19 2018/04/10 22:11:30 greg Exp $";
5 * Color matrix routines.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "platform.h"
12 #include "standard.h"
13 #include "cmatrix.h"
14 #include "platform.h"
15 #include "paths.h"
16 #include "resolu.h"
17
18 const char *cm_fmt_id[] = {
19 "unknown", "ascii", COLRFMT, CIEFMT,
20 "float", "double"
21 };
22
23 const int cm_elem_size[] = {
24 0, 0, 4, 4, 3*sizeof(float), 3*sizeof(double)
25 };
26
27 /* Allocate a color coefficient matrix */
28 CMATRIX *
29 cm_alloc(int nrows, int ncols)
30 {
31 CMATRIX *cm;
32
33 if ((nrows <= 0) | (ncols <= 0))
34 error(USER, "attempt to create empty matrix");
35 cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
36 sizeof(COLOR)*(nrows*ncols - 1));
37 if (cm == NULL)
38 error(SYSTEM, "out of memory in cm_alloc()");
39 cm->nrows = nrows;
40 cm->ncols = ncols;
41 return(cm);
42 }
43
44 static void
45 adjacent_ra_sizes(size_t bounds[2], size_t target)
46 {
47 bounds[0] = 0; bounds[1] = 2048;
48 while (bounds[1] < target) {
49 bounds[0] = bounds[1];
50 bounds[1] += bounds[1]>>1;
51 }
52 }
53
54 /* Resize color coefficient matrix */
55 CMATRIX *
56 cm_resize(CMATRIX *cm, int nrows)
57 {
58 size_t old_size, new_size, ra_bounds[2];
59
60 if (nrows == cm->nrows)
61 return(cm);
62 if (nrows <= 0) {
63 cm_free(cm);
64 return(NULL);
65 }
66 old_size = sizeof(CMATRIX) + sizeof(COLOR)*(cm->nrows*cm->ncols - 1);
67 adjacent_ra_sizes(ra_bounds, old_size);
68 new_size = sizeof(CMATRIX) + sizeof(COLOR)*(nrows*cm->ncols - 1);
69 if (nrows < cm->nrows ? new_size <= ra_bounds[0] :
70 new_size > ra_bounds[1]) {
71 adjacent_ra_sizes(ra_bounds, new_size);
72 cm = (CMATRIX *)realloc(cm, ra_bounds[1]);
73 if (cm == NULL)
74 error(SYSTEM, "out of memory in cm_resize()");
75 }
76 cm->nrows = nrows;
77 return(cm);
78 }
79
80 typedef struct {
81 int dtype; /* data type */
82 int nrows, ncols; /* matrix size */
83 char *err; /* error message */
84 } CMINFO; /* header info record */
85
86 static int
87 get_cminfo(char *s, void *p)
88 {
89 CMINFO *ip = (CMINFO *)p;
90 char fmt[MAXFMTLEN];
91 int i;
92
93 if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) {
94 ip->err = "unexpected # components (must be 3)";
95 return(-1);
96 }
97 if (!strncmp(s, "NROWS=", 6)) {
98 ip->nrows = atoi(s+6);
99 return(0);
100 }
101 if (!strncmp(s, "NCOLS=", 6)) {
102 ip->ncols = atoi(s+6);
103 return(0);
104 }
105 if (!formatval(fmt, s))
106 return(0);
107 for (i = 1; i < DTend; i++)
108 if (!strcmp(fmt, cm_fmt_id[i]))
109 ip->dtype = i;
110 return(0);
111 }
112
113 /* Load header to obtain/check data type and number of columns */
114 char *
115 cm_getheader(int *dt, int *nr, int *nc, FILE *fp)
116 {
117 CMINFO cmi;
118 /* read header */
119 cmi.dtype = DTfromHeader;
120 cmi.nrows = cmi.ncols = 0;
121 cmi.err = "unexpected EOF in header";
122 if (getheader(fp, get_cminfo, &cmi) < 0)
123 return(cmi.err);
124 if (dt != NULL) { /* get/check data type? */
125 if (cmi.dtype == DTfromHeader) {
126 if (*dt == DTfromHeader)
127 return("missing/unknown data format in header");
128 } else if (*dt == DTfromHeader)
129 *dt = cmi.dtype;
130 else if (*dt != cmi.dtype)
131 return("unexpected data format in header");
132 }
133 if (nr != NULL) { /* get/check #rows? */
134 if (*nr <= 0)
135 *nr = cmi.nrows;
136 else if ((cmi.nrows > 0) & (*nr != cmi.nrows))
137 return("unexpected row count in header");
138 }
139 if (nc != NULL) { /* get/check #columns? */
140 if (*nc <= 0)
141 *nc = cmi.ncols;
142 else if ((cmi.ncols > 0) & (*nc != cmi.ncols))
143 return("unexpected column count in header");
144 }
145 return(NULL);
146 }
147
148 /* Allocate and load a matrix from the given input (or stdin if NULL) */
149 CMATRIX *
150 cm_load(const char *inspec, int nrows, int ncols, int dtype)
151 {
152 const int ROWINC = 2048;
153 FILE *fp = stdin;
154 CMATRIX *cm;
155
156 if (inspec == NULL)
157 inspec = "<stdin>";
158 else if (inspec[0] == '!') {
159 fp = popen(inspec+1, "r");
160 if (fp == NULL) {
161 sprintf(errmsg, "cannot start command '%s'", inspec);
162 error(SYSTEM, errmsg);
163 }
164 } else if ((fp = fopen(inspec, "r")) == NULL) {
165 sprintf(errmsg, "cannot open file '%s'", inspec);
166 error(SYSTEM, errmsg);
167 }
168 #ifdef getc_unlocked
169 flockfile(fp);
170 #endif
171 if (dtype != DTascii)
172 SET_FILE_BINARY(fp); /* doesn't really work */
173 if (!dtype | !ncols) { /* expecting header? */
174 char *err = cm_getheader(&dtype, &nrows, &ncols, fp);
175 if (err != NULL)
176 error(USER, err);
177 if (ncols <= 0)
178 error(USER, "unspecified number of columns");
179 }
180 switch (dtype) {
181 case DTascii:
182 case DTfloat:
183 case DTdouble:
184 break;
185 default:
186 error(USER, "unexpected data type in cm_load()");
187 }
188 if (nrows <= 0) { /* don't know length? */
189 int guessrows = 147; /* usually big enough */
190 if ((dtype != DTascii) & (fp != stdin) & (inspec[0] != '!')) {
191 long startpos = ftell(fp);
192 if (fseek(fp, 0L, SEEK_END) == 0) {
193 long endpos = ftell(fp);
194 long elemsiz = 3*(dtype==DTfloat ?
195 sizeof(float) : sizeof(double));
196
197 if ((endpos - startpos) % (ncols*elemsiz)) {
198 sprintf(errmsg,
199 "improper length for binary file '%s'",
200 inspec);
201 error(USER, errmsg);
202 }
203 guessrows = (endpos - startpos)/(ncols*elemsiz);
204 if (fseek(fp, startpos, SEEK_SET) < 0) {
205 sprintf(errmsg,
206 "fseek() error on file '%s'",
207 inspec);
208 error(SYSTEM, errmsg);
209 }
210 nrows = guessrows; /* we're confident */
211 }
212 }
213 cm = cm_alloc(guessrows, ncols);
214 } else
215 cm = cm_alloc(nrows, ncols);
216 if (cm == NULL) /* XXX never happens */
217 return(NULL);
218 if (dtype == DTascii) { /* read text file */
219 int maxrow = (nrows > 0 ? nrows : 32000);
220 int r, c;
221 for (r = 0; r < maxrow; r++) {
222 if (r >= cm->nrows) /* need more space? */
223 cm = cm_resize(cm, cm->nrows+ROWINC);
224 for (c = 0; c < ncols; c++) {
225 COLORV *cv = cm_lval(cm,r,c);
226 if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) {
227 if ((nrows <= 0) & (r > 0) & !c) {
228 cm = cm_resize(cm, maxrow=r);
229 break;
230 } else
231 goto EOFerror;
232 }
233 }
234 }
235 while ((c = getc(fp)) != EOF)
236 if (!isspace(c)) {
237 sprintf(errmsg,
238 "unexpected data at end of ascii input '%s'",
239 inspec);
240 error(WARNING, errmsg);
241 break;
242 }
243 } else { /* read binary file */
244 if (sizeof(COLOR) == cm_elem_size[dtype]) {
245 int nread = 0;
246 do { /* read all we can */
247 nread += getbinary(cm->cmem + 3*nread,
248 sizeof(COLOR),
249 cm->nrows*cm->ncols - nread,
250 fp);
251 if (nrows <= 0) { /* unknown length */
252 if (nread == cm->nrows*cm->ncols)
253 /* need more space? */
254 cm = cm_resize(cm, cm->nrows+ROWINC);
255 else if (nread && !(nread % cm->ncols))
256 /* seem to be done */
257 cm = cm_resize(cm, nread/cm->ncols);
258 else /* ended mid-row */
259 goto EOFerror;
260 } else if (nread < cm->nrows*cm->ncols)
261 goto EOFerror;
262 } while (nread < cm->nrows*cm->ncols);
263
264 } else if (dtype == DTdouble) {
265 double dc[3]; /* load from double */
266 COLORV *cvp = cm->cmem;
267 int n = nrows*ncols;
268
269 if (n <= 0)
270 goto not_handled;
271 while (n--) {
272 if (getbinary(dc, sizeof(double), 3, fp) != 3)
273 goto EOFerror;
274 copycolor(cvp, dc);
275 cvp += 3;
276 }
277 } else /* dtype == DTfloat */ {
278 float fc[3]; /* load from float */
279 COLORV *cvp = cm->cmem;
280 int n = nrows*ncols;
281
282 if (n <= 0)
283 goto not_handled;
284 while (n--) {
285 if (getbinary(fc, sizeof(float), 3, fp) != 3)
286 goto EOFerror;
287 copycolor(cvp, fc);
288 cvp += 3;
289 }
290 }
291 if (fgetc(fp) != EOF) {
292 sprintf(errmsg,
293 "unexpected data at end of binary input '%s'",
294 inspec);
295 error(WARNING, errmsg);
296 }
297 }
298 if (fp != stdin) {
299 if (inspec[0] != '!')
300 fclose(fp);
301 else if (pclose(fp)) {
302 sprintf(errmsg, "error running command '%s'", inspec);
303 error(WARNING, errmsg);
304 }
305 }
306 #ifdef getc_unlocked
307 else
308 funlockfile(fp);
309 #endif
310 return(cm);
311 EOFerror:
312 sprintf(errmsg, "unexpected EOF reading %s", inspec);
313 error(USER, errmsg);
314 not_handled:
315 error(INTERNAL, "unhandled data size or length in cm_load()");
316 return(NULL); /* gratis return */
317 }
318
319 /* Extract a column vector from a matrix */
320 CMATRIX *
321 cm_column(const CMATRIX *cm, int c)
322 {
323 CMATRIX *cvr;
324 int dr;
325
326 if ((c < 0) | (c >= cm->ncols))
327 error(INTERNAL, "column requested outside matrix");
328 cvr = cm_alloc(cm->nrows, 1);
329 if (cvr == NULL)
330 return(NULL);
331 for (dr = 0; dr < cm->nrows; dr++) {
332 const COLORV *sp = cm_lval(cm,dr,c);
333 COLORV *dp = cv_lval(cvr,dr);
334 dp[0] = sp[0];
335 dp[1] = sp[1];
336 dp[2] = sp[2];
337 }
338 return(cvr);
339 }
340
341 /* Scale a matrix by a single value */
342 CMATRIX *
343 cm_scale(const CMATRIX *cm1, const COLOR sca)
344 {
345 CMATRIX *cmr;
346 int dr, dc;
347
348 cmr = cm_alloc(cm1->nrows, cm1->ncols);
349 if (cmr == NULL)
350 return(NULL);
351 for (dr = 0; dr < cmr->nrows; dr++)
352 for (dc = 0; dc < cmr->ncols; dc++) {
353 const COLORV *sp = cm_lval(cm1,dr,dc);
354 COLORV *dp = cm_lval(cmr,dr,dc);
355 dp[0] = sp[0] * sca[0];
356 dp[1] = sp[1] * sca[1];
357 dp[2] = sp[2] * sca[2];
358 }
359 return(cmr);
360 }
361
362 /* Multiply two matrices (or a matrix and a vector) and allocate the result */
363 CMATRIX *
364 cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
365 {
366 char *rowcheck=NULL, *colcheck=NULL;
367 CMATRIX *cmr;
368 int dr, dc, i;
369
370 if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
371 error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
372 cmr = cm_alloc(cm1->nrows, cm2->ncols);
373 if (cmr == NULL)
374 return(NULL);
375 /* optimization: check for zero rows & cols */
376 if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
377 static const COLOR czero;
378 rowcheck = (char *)calloc(cmr->nrows, 1);
379 for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
380 for (dc = cm1->ncols; dc--; )
381 if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
382 rowcheck[dr] = 1;
383 break;
384 }
385 colcheck = (char *)calloc(cmr->ncols, 1);
386 for (dc = cm2->ncols*(colcheck != NULL); dc--; )
387 for (dr = cm2->nrows; dr--; )
388 if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
389 colcheck[dc] = 1;
390 break;
391 }
392 }
393 for (dr = 0; dr < cmr->nrows; dr++)
394 for (dc = 0; dc < cmr->ncols; dc++) {
395 COLORV *dp = cm_lval(cmr,dr,dc);
396 double res[3];
397 dp[0] = dp[1] = dp[2] = 0;
398 if (rowcheck != NULL && !rowcheck[dr])
399 continue;
400 if (colcheck != NULL && !colcheck[dc])
401 continue;
402 res[0] = res[1] = res[2] = 0;
403 for (i = 0; i < cm1->ncols; i++) {
404 const COLORV *cp1 = cm_lval(cm1,dr,i);
405 const COLORV *cp2 = cm_lval(cm2,i,dc);
406 res[0] += (double)cp1[0] * cp2[0];
407 res[1] += (double)cp1[1] * cp2[1];
408 res[2] += (double)cp1[2] * cp2[2];
409 }
410 copycolor(dp, res);
411 }
412 if (rowcheck != NULL) free(rowcheck);
413 if (colcheck != NULL) free(colcheck);
414 return(cmr);
415 }
416
417 /* write out matrix to file (precede by resolution string if picture) */
418 int
419 cm_write(const CMATRIX *cm, int dtype, FILE *fp)
420 {
421 static const char tabEOL[2] = {'\t','\n'};
422 const COLORV *mp = cm->cmem;
423 int r, c;
424
425 switch (dtype) {
426 case DTascii:
427 for (r = 0; r < cm->nrows; r++)
428 for (c = 0; c < cm->ncols; c++, mp += 3)
429 fprintf(fp, "%.6e %.6e %.6e%c",
430 mp[0], mp[1], mp[2],
431 tabEOL[c >= cm->ncols-1]);
432 break;
433 case DTfloat:
434 case DTdouble:
435 if (sizeof(COLOR) == cm_elem_size[dtype]) {
436 r = cm->ncols*cm->nrows;
437 while (r > 0) {
438 c = putbinary(mp, sizeof(COLOR), r, fp);
439 if (c <= 0)
440 return(0);
441 mp += 3*c;
442 r -= c;
443 }
444 } else if (dtype == DTdouble) {
445 double dc[3];
446 r = cm->ncols*cm->nrows;
447 while (r--) {
448 copycolor(dc, mp);
449 if (putbinary(dc, sizeof(double), 3, fp) != 3)
450 return(0);
451 mp += 3;
452 }
453 } else /* dtype == DTfloat */ {
454 float fc[3];
455 r = cm->ncols*cm->nrows;
456 while (r--) {
457 copycolor(fc, mp);
458 if (putbinary(fc, sizeof(float), 3, fp) != 3)
459 return(0);
460 mp += 3;
461 }
462 }
463 break;
464 case DTrgbe:
465 case DTxyze:
466 fprtresolu(cm->ncols, cm->nrows, fp);
467 for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols)
468 if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0)
469 return(0);
470 break;
471 default:
472 fputs("Unsupported data type in cm_write()!\n", stderr);
473 return(0);
474 }
475 return(fflush(fp) == 0);
476 }
