root/radiance/ray/src/util/cmatrix.c
Thu Aug 2 18:33:49 2018 UTC (5 years, 10 months ago) by greg
Diff to previous 2.19 , to selected 2.3
Tue Apr 10 22:11:30 2018 UTC (6 years, 1 month ago) by greg
Diff to previous 2.18 , to selected 2.3
Fixed inconsistency introduced in 2014 (rev. 2.8)
Tue Aug 30 14:52:46 2016 UTC (7 years, 9 months ago) by greg
Diff to previous 2.17 , to selected 2.3
Force double promotion
Thu Aug 18 00:52:48 2016 UTC (7 years, 9 months ago) by greg
Diff to previous 2.16 , to selected 2.3
Changes since 2.15: +2 -1 lines
Diff to previous 2.15 , to selected 2.3
Wed Feb 17 23:26:06 2016 UTC (8 years, 3 months ago) by greg
Changes since 2.14: +6 -5 lines
Diff to previous 2.14 , to selected 2.3
Made realloc() calls less aggressive to avoid memory errors
Tue Feb 2 18:02:32 2016 UTC (8 years, 3 months ago) by greg
Diff to previous 2.13 , to selected 2.3
Sat Aug 1 23:27:04 2015 UTC (8 years, 10 months ago) by greg
Diff to previous 2.12 , to selected 2.3
Wed Jul 22 04:29:56 2015 UTC (8 years, 10 months ago) by greg
Diff to previous 2.11 , to selected 2.3
Reduced precision of multiplies in favor of time when little differ found
Wed Jul 22 04:23:27 2015 UTC (8 years, 10 months ago) by greg
Diff to previous 2.10 , to selected 2.3
Improved matrix multiplication accuracy by forcing promotions to double
Fri May 8 18:25:03 2015 UTC (9 years ago) by greg
Diff to previous 2.9 , to selected 2.3
Added rtprocess.h needed for popen() under Windows
Mon May 4 20:53:21 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.8: +29 -17 lines
Sat Aug 2 17:10:43 2014 UTC (9 years, 10 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Tue Jul 8 16:39:41 2014 UTC (9 years, 10 months ago) by greg
CVS Tags: rad4R2
Removed unnecessary address operators from function ids.
Tue Jun 17 18:03:48 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.5: +23 -5 lines
Hopeful fix to performance issue for gendaymtx under Windows
Fri May 30 00:00:54 2014 UTC (10 years ago) by greg
Changes since 2.4: +62 -18 lines
Thu May 29 17:28:09 2014 UTC (10 years ago) by greg
Changes since 2.3: +10 -7 lines
Improved accuracy of matrix multiplication by using double accumulator
Tue Apr 8 23:45:33 2014 UTC (10 years, 1 month ago) by greg
Removed tab before first column
Sat Feb 8 01:28:06 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.1: +74 -24 lines
Mon Jan 20 21:29:04 2014 UTC (10 years, 4 months ago) by greg
Diff to selected 2.3
