Force double promotion
Made realloc() calls less aggressive to avoid memory errors
Reduced precision of multiplies in favor of time when little differ found
Improved matrix multiplication accuracy by forcing promotions to double
Added rtprocess.h needed for popen() under Windows
Removed unnecessary address operators from function ids.
Hopeful fix to performance issue for gendaymtx under Windows
Improved accuracy of matrix multiplication by using double accumulator
Removed tab before first column
