root/radiance/ray/src/util/cmatrix.c
Sat Aug 2 17:10:43 2014 UTC (9 years, 10 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Tue Jul 8 16:39:41 2014 UTC (9 years, 11 months ago) by greg
CVS Tags: rad4R2
Removed unnecessary address operators from function ids.
Tue Jun 17 18:03:48 2014 UTC (10 years ago) by greg
Changes since 2.5: +23 -5 lines
Hopeful fix to performance issue for gendaymtx under Windows
Fri May 30 00:00:54 2014 UTC (10 years ago) by greg
Changes since 2.4: +62 -18 lines
Thu May 29 17:28:09 2014 UTC (10 years ago) by greg
Changes since 2.3: +10 -7 lines
Improved accuracy of matrix multiplication by using double accumulator
Tue Apr 8 23:45:33 2014 UTC (10 years, 2 months ago) by greg
Removed tab before first column
Sat Feb 8 01:28:06 2014 UTC (10 years, 4 months ago) by greg
Changes since 2.1: +74 -24 lines
Mon Jan 20 21:29:04 2014 UTC (10 years, 5 months ago) by greg
Diff to selected 2.5
