root/radiance/ray/src/util/cmatrix.c
Revision: 2.33
Committed: Fri Jan 22 16:19:15 2021 UTC (4 years, 5 months ago) by greg
Changes since 2.32: +6 -4 lines
fix: reinstated interpretation of NULL file name as stdin, so dctimestep works
2 static const char RCSid[] = "$Id: cmatrix.c,v 2.32 2021/01/19 23:32:00 greg Exp $";
5 * Color matrix routines.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "platform.h"
12 #include "standard.h"
13 #include "cmatrix.h"
14 #include "platform.h"
15 #include "paths.h"
16 #include "resolu.h"
17
18 const char stdin_name[] = "<stdin>";
19
20 const char *cm_fmt_id[] = {
21 "unknown", COLRFMT, CIEFMT,
22 "float", "ascii", "double"
23 };
24
25 const int cm_elem_size[] = {
26 0, 4, 4, 3*sizeof(float), 0, 3*sizeof(double)
27 };
28
29 /* Allocate a color coefficient matrix */
30 CMATRIX *
31 cm_alloc(int nrows, int ncols)
32 {
33 CMATRIX *cm;
34
35 if ((nrows <= 0) | (ncols <= 0))
36 error(USER, "attempt to create empty matrix");
37 cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
38 sizeof(COLOR)*((size_t)nrows*ncols - 1));
39 if (!cm)
40 error(SYSTEM, "out of memory in cm_alloc()");
41 cm->nrows = nrows;
42 cm->ncols = ncols;
43 return(cm);
44 }
45
46 static void
47 adjacent_ra_sizes(size_t bounds[2], size_t target)
48 {
49 bounds[0] = 0; bounds[1] = 2048;
50 while (bounds[1] < target) {
51 bounds[0] = bounds[1];
52 bounds[1] += bounds[1]>>1;
53 }
54 }
55
56 /* Resize color coefficient matrix */
57 CMATRIX *
58 cm_resize(CMATRIX *cm, int nrows)
59 {
60 size_t old_size, new_size, ra_bounds[2];
61
62 if (!cm)
63 return(NULL);
64 if (nrows == cm->nrows)
65 return(cm);
66 if (nrows <= 0) {
67 cm_free(cm);
68 return(NULL);
69 }
70 old_size = sizeof(CMATRIX) + sizeof(COLOR)*((size_t)cm->nrows*cm->ncols - 1);
71 adjacent_ra_sizes(ra_bounds, old_size);
72 new_size = sizeof(CMATRIX) + sizeof(COLOR)*((size_t)nrows*cm->ncols - 1);
73 if (nrows < cm->nrows ? new_size <= ra_bounds[0] :
74 new_size > ra_bounds[1]) {
75 adjacent_ra_sizes(ra_bounds, new_size);
76 cm = (CMATRIX *)realloc(cm, ra_bounds[1]);
77 if (!cm)
78 error(SYSTEM, "out of memory in cm_resize()");
79 }
80 cm->nrows = nrows;
81 return(cm);
82 }
83
84 typedef struct {
85 int dtype; /* data type */
86 int need2swap; /* need byte swap? */
87 int nrows, ncols; /* matrix size */
88 COLOR expos; /* exposure value */
89 char *err; /* error message */
90 } CMINFO; /* header info record */
91
92 static int
93 get_cminfo(char *s, void *p)
94 {
95 CMINFO *ip = (CMINFO *)p;
96 char fmt[MAXFMTLEN];
97 int i;
98
99 if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) {
100 ip->err = "unexpected # components (must be 3)";
101 return(-1);
102 }
103 if (!strncmp(s, "NROWS=", 6)) {
104 ip->nrows = atoi(s+6);
105 return(0);
106 }
107 if (!strncmp(s, "NCOLS=", 6)) {
108 ip->ncols = atoi(s+6);
109 return(0);
110 }
111 if ((i = isbigendian(s)) >= 0) {
112 ip->need2swap = (nativebigendian() != i);
113 return(0);
114 }
115 if (isexpos(s)) {
116 double d = exposval(s);
117 scalecolor(ip->expos, d);
118 return(0);
119 }
120 if (iscolcor(s)) {
121 COLOR ctmp;
122 colcorval(ctmp, s);
123 multcolor(ip->expos, ctmp);
124 return(0);
125 }
126 if (!formatval(fmt, s))
127 return(0);
128 for (i = 1; i < DTend; i++)
129 if (!strcmp(fmt, cm_fmt_id[i]))
130 ip->dtype = i;
131 return(0);
132 }
133
134 /* Load header to obtain/check data type and number of columns */
135 char *
136 cm_getheader(int *dt, int *nr, int *nc, int *swp, COLOR scale, FILE *fp)
137 {
138 CMINFO cmi;
139 /* read header */
140 cmi.dtype = DTfromHeader;
141 cmi.need2swap = 0;
142 cmi.expos[0] = cmi.expos[1] = cmi.expos[2] = 1.f;
143 cmi.nrows = cmi.ncols = 0;
144 cmi.err = "unexpected EOF in header";
145 if (getheader(fp, get_cminfo, &cmi) < 0)
146 return(cmi.err);
147 if (dt) { /* get/check data type? */
148 if (cmi.dtype == DTfromHeader) {
149 if (*dt == DTfromHeader)
150 return("missing/unknown data format in header");
151 } else if (*dt == DTfromHeader)
152 *dt = cmi.dtype;
153 else if (*dt != cmi.dtype)
154 return("unexpected data format in header");
155 }
156 if (nr) { /* get/check #rows? */
157 if (*nr <= 0)
158 *nr = cmi.nrows;
159 else if ((cmi.nrows > 0) & (*nr != cmi.nrows))
160 return("unexpected row count in header");
161 }
162 if (nc) { /* get/check #columns? */
163 if (*nc <= 0)
164 *nc = cmi.ncols;
165 else if ((cmi.ncols > 0) & (*nc != cmi.ncols))
166 return("unexpected column count in header");
167 }
168 if (swp) /* get/check swap? */
169 *swp = cmi.need2swap;
170 if (scale) { /* transfer exposure comp. */
171 scale[0] = 1.f/cmi.expos[0];
172 scale[1] = 1.f/cmi.expos[1];
173 scale[2] = 1.f/cmi.expos[2];
174 }
175 return(NULL);
176 }
177
178 /* Allocate and load image data into matrix */
179 static CMATRIX *
180 cm_load_rgbe(FILE *fp, int nrows, int ncols, COLOR scale)
181 {
182 int doscale;
183 CMATRIX *cm;
184 COLORV *mp;
185 /* header already loaded */
186 cm = cm_alloc(nrows, ncols);
187 if (!cm)
188 return(NULL);
189 doscale = (scale[0] < .99) | (scale[0] > 1.01) |
190 (scale[1] < .99) | (scale[1] > 1.01) |
191 (scale[2] < .99) | (scale[2] > 1.01) ;
192 mp = cm->cmem;
193 while (nrows--) {
194 if (freadscan((COLOR *)mp, ncols, fp) < 0) {
195 error(USER, "error reading color picture as matrix");
196 cm_free(cm);
197 return(NULL);
198 }
199 if (doscale) {
200 int i = ncols;
201 while (i--) {
202 *mp++ *= scale[0];
203 *mp++ *= scale[1];
204 *mp++ *= scale[2];
205 }
206 } else
207 mp += 3*ncols;
208 } /* caller closes stream */
209 return(cm);
210 }
211
212 /* Allocate and load a matrix from the given input (or stdin if NULL) */
213 CMATRIX *
214 cm_load(const char *inspec, int nrows, int ncols, int dtype)
215 {
216 const int ROWINC = 2048;
217 int swap = 0;
218 FILE *fp;
219 COLOR scale;
220 CMATRIX *cm;
221
222 if (!inspec)
223 inspec = stdin_name;
224 else if (!*inspec)
225 return(NULL);
226 if (inspec == stdin_name) { /* reading from stdin? */
227 fp = stdin;
228 } else if (inspec[0] == '!') {
229 fp = popen(inspec+1, "r");
230 if (!fp) {
231 sprintf(errmsg, "cannot start command '%s'", inspec);
232 error(SYSTEM, errmsg);
233 }
234 } else if (!(fp = fopen(inspec, "r"))) {
235 sprintf(errmsg, "cannot open file '%s'", inspec);
236 error(SYSTEM, errmsg);
237 }
238 #ifdef getc_unlocked
239 flockfile(fp);
240 #endif
241 if (dtype != DTascii)
242 SET_FILE_BINARY(fp); /* doesn't really work */
243 if (!dtype | !ncols) { /* expecting header? */
244 char *err = cm_getheader(&dtype, &nrows, &ncols, &swap, scale, fp);
245 if (err)
246 error(USER, err);
247 }
248 if (ncols <= 0 && !fscnresolu(&ncols, &nrows, fp))
249 error(USER, "unspecified number of columns");
250 switch (dtype) {
251 case DTascii:
252 case DTfloat:
253 case DTdouble:
254 break;
255 case DTrgbe:
256 case DTxyze:
257 cm = cm_load_rgbe(fp, nrows, ncols, scale);
258 goto cleanup;
259 default:
260 error(USER, "unexpected data type in cm_load()");
261 }
262 if (nrows <= 0) { /* don't know length? */
263 int guessrows = 147; /* usually big enough */
264 if (cm_elem_size[dtype] && (fp != stdin) & (inspec[0] != '!')) {
265 long startpos = ftell(fp);
266 if (fseek(fp, 0L, SEEK_END) == 0) {
267 long rowsiz = (long)ncols*cm_elem_size[dtype];
268 long endpos = ftell(fp);
269
270 if ((endpos - startpos) % rowsiz) {
271 sprintf(errmsg,
272 "improper length for binary file '%s'",
273 inspec);
274 error(USER, errmsg);
275 }
276 guessrows = (endpos - startpos)/rowsiz;
277 if (fseek(fp, startpos, SEEK_SET) < 0) {
278 sprintf(errmsg,
279 "fseek() error on file '%s'",
280 inspec);
281 error(SYSTEM, errmsg);
282 }
283 nrows = guessrows; /* we're confident */
284 }
285 }
286 cm = cm_alloc(guessrows, ncols);
287 } else
288 cm = cm_alloc(nrows, ncols);
289 if (!cm) /* XXX never happens */
290 return(NULL);
291 if (dtype == DTascii) { /* read text file */
292 int maxrow = (nrows > 0 ? nrows : 32000);
293 int r, c;
294 for (r = 0; r < maxrow; r++) {
295 if (r >= cm->nrows) /* need more space? */
296 cm = cm_resize(cm, cm->nrows+ROWINC);
297 for (c = 0; c < ncols; c++) {
298 COLORV *cv = cm_lval(cm,r,c);
299 if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) {
300 if ((nrows <= 0) & (r > 0) & !c) {
301 cm = cm_resize(cm, maxrow=r);
302 break;
303 } else
304 goto EOFerror;
305 }
306 }
307 }
308 while ((c = getc(fp)) != EOF)
309 if (!isspace(c)) {
310 sprintf(errmsg,
311 "unexpected data at end of ascii input '%s'",
312 inspec);
313 error(WARNING, errmsg);
314 break;
315 }
316 } else { /* read binary file */
317 if (sizeof(COLOR) == cm_elem_size[dtype]) {
318 size_t nread = 0;
319 do { /* read all we can */
320 nread += getbinary(cm->cmem + 3*nread,
321 sizeof(COLOR),
322 (size_t)cm->nrows*cm->ncols - nread,
323 fp);
324 if (nrows <= 0) { /* unknown length */
325 if (nread == (size_t)cm->nrows*cm->ncols)
326 /* need more space? */
327 cm = cm_resize(cm, cm->nrows+ROWINC);
328 else if (nread && !(nread % cm->ncols))
329 /* seem to be done */
330 cm = cm_resize(cm, nread/cm->ncols);
331 else /* ended mid-row */
332 goto EOFerror;
333 } else if (nread < (size_t)cm->nrows*cm->ncols)
334 goto EOFerror;
335 } while (nread < (size_t)cm->nrows*cm->ncols);
336
337 if (swap) {
338 if (sizeof(COLORV) == 4)
339 swap32((char *)cm->cmem,
340 3*(size_t)cm->nrows*cm->ncols);
341 else /* sizeof(COLORV) == 8 */
342 swap64((char *)cm->cmem,
343 3*(size_t)cm->nrows*cm->ncols);
344 }
345 } else if (dtype == DTdouble) {
346 double dc[3]; /* load from double */
347 COLORV *cvp = cm->cmem;
348 size_t n = (size_t)nrows*ncols;
349
350 if (n <= 0)
351 goto not_handled;
352 while (n--) {
353 if (getbinary(dc, sizeof(double), 3, fp) != 3)
354 goto EOFerror;
355 if (swap) swap64((char *)dc, 3);
356 copycolor(cvp, dc);
357 cvp += 3;
358 }
359 } else /* dtype == DTfloat */ {
360 float fc[3]; /* load from float */
361 COLORV *cvp = cm->cmem;
362 size_t n = (size_t)nrows*ncols;
363
364 if (n <= 0)
365 goto not_handled;
366 while (n--) {
367 if (getbinary(fc, sizeof(float), 3, fp) != 3)
368 goto EOFerror;
369 if (swap) swap32((char *)fc, 3);
370 copycolor(cvp, fc);
371 cvp += 3;
372 }
373 }
374 if (fgetc(fp) != EOF) {
375 sprintf(errmsg,
376 "unexpected data at end of binary input '%s'",
377 inspec);
378 error(WARNING, errmsg);
379 }
380 }
381 cleanup:
382 if (fp != stdin) {
383 if (inspec[0] != '!')
384 fclose(fp);
385 else if (pclose(fp)) {
386 sprintf(errmsg, "error running command '%s'", inspec);
387 error(WARNING, errmsg);
388 }
389 }
390 #ifdef getc_unlocked
391 else
392 funlockfile(fp);
393 #endif
394 return(cm);
395 EOFerror:
396 sprintf(errmsg, "unexpected EOF reading %s", inspec);
397 error(USER, errmsg);
398 return(NULL);
399 not_handled:
400 error(INTERNAL, "unhandled data size or length in cm_load()");
401 return(NULL); /* gratis return */
402 }
403
404 /* Extract a column vector from a matrix */
405 CMATRIX *
406 cm_column(const CMATRIX *cm, int c)
407 {
408 CMATRIX *cvr;
409 int dr;
410
411 if (!cm)
412 return(NULL);
413 if ((c < 0) | (c >= cm->ncols))
414 error(INTERNAL, "column requested outside matrix");
415 cvr = cm_alloc(cm->nrows, 1);
416 if (!cvr)
417 return(NULL);
418 for (dr = 0; dr < cm->nrows; dr++) {
419 const COLORV *sp = cm_lval(cm,dr,c);
420 COLORV *dp = cv_lval(cvr,dr);
421 dp[0] = sp[0];
422 dp[1] = sp[1];
423 dp[2] = sp[2];
424 }
425 return(cvr);
426 }
427
428 /* Multiply two matrices (or a matrix and a vector) and allocate the result */
429 CMATRIX *
430 cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
431 {
432 char *rowcheck=NULL, *colcheck=NULL;
433 CMATRIX *cmr;
434 int dr, dc, i;
435
436 if (!cm1 | !cm2)
437 return(NULL);
438 if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
439 error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
440 cmr = cm_alloc(cm1->nrows, cm2->ncols);
441 if (!cmr)
442 return(NULL);
443 /* optimization: check for zero rows & cols */
444 if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
445 static const COLOR czero;
446 rowcheck = (char *)calloc(cmr->nrows, 1);
447 for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
448 for (dc = cm1->ncols; dc--; )
449 if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
450 rowcheck[dr] = 1;
451 break;
452 }
453 colcheck = (char *)calloc(cmr->ncols, 1);
454 for (dc = cm2->ncols*(colcheck != NULL); dc--; )
455 for (dr = cm2->nrows; dr--; )
456 if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
457 colcheck[dc] = 1;
458 break;
459 }
460 }
461 for (dr = 0; dr < cmr->nrows; dr++)
462 for (dc = 0; dc < cmr->ncols; dc++) {
463 COLORV *dp = cm_lval(cmr,dr,dc);
464 double res[3];
465 dp[0] = dp[1] = dp[2] = 0;
466 if (rowcheck && !rowcheck[dr])
467 continue;
468 if (colcheck && !colcheck[dc])
469 continue;
470 res[0] = res[1] = res[2] = 0;
471 for (i = 0; i < cm1->ncols; i++) {
472 const COLORV *cp1 = cm_lval(cm1,dr,i);
473 const COLORV *cp2 = cm_lval(cm2,i,dc);
474 res[0] += (double)cp1[0] * cp2[0];
475 res[1] += (double)cp1[1] * cp2[1];
476 res[2] += (double)cp1[2] * cp2[2];
477 }
478 copycolor(dp, res);
479 }
480 if (rowcheck) free(rowcheck);
481 if (colcheck) free(colcheck);
482 return(cmr);
483 }
484
485 /* write out matrix to file (precede by resolution string if picture) */
486 int
487 cm_write(const CMATRIX *cm, int dtype, FILE *fp)
488 {
489 static const char tabEOL[2] = {'\t','\n'};
490 const COLORV *mp;
491 int r, c;
492 size_t n, rv;
493
494 if (!cm)
495 return(0);
496 mp = cm->cmem;
497 switch (dtype) {
498 case DTascii:
499 for (r = 0; r < cm->nrows; r++)
500 for (c = 0; c < cm->ncols; c++, mp += 3)
501 fprintf(fp, "%.6e %.6e %.6e%c",
502 mp[0], mp[1], mp[2],
503 tabEOL[c >= cm->ncols-1]);
504 break;
505 case DTfloat:
506 case DTdouble:
507 if (sizeof(COLOR) == cm_elem_size[dtype]) {
508 n = (size_t)cm->ncols*cm->nrows;
509 while (n > 0) {
510 rv = fwrite(mp, sizeof(COLOR), n, fp);
511 if (rv <= 0)
512 return(0);
513 mp += 3*rv;
514 n -= rv;
515 }
516 } else if (dtype == DTdouble) {
517 double dc[3];
518 n = (size_t)cm->ncols*cm->nrows;
519 while (n--) {
520 copycolor(dc, mp);
521 if (putbinary(dc, sizeof(double), 3, fp) != 3)
522 return(0);
523 mp += 3;
524 }
525 } else /* dtype == DTfloat */ {
526 float fc[3];
527 n = (size_t)cm->ncols*cm->nrows;
528 while (n--) {
529 copycolor(fc, mp);
530 if (putbinary(fc, sizeof(float), 3, fp) != 3)
531 return(0);
532 mp += 3;
533 }
534 }
535 break;
536 case DTrgbe:
537 case DTxyze:
538 fprtresolu(cm->ncols, cm->nrows, fp);
539 for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols)
540 if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0)
541 return(0);
542 break;
543 default:
544 fputs("Unsupported data type in cm_write()!\n", stderr);
545 return(0);
546 }
547 return(fflush(fp) == 0);
548 }
