root/radiance/ray/src/util/cmatrix.c
Revision: 2.22
Committed: Wed Aug 14 18:20:02 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.21: +18 -3 lines
2 static const char RCSid[] = "$Id: cmatrix.c,v 2.21 2019/08/12 18:28:37 greg Exp $";
5 * Color matrix routines.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "platform.h"
12 #include "standard.h"
13 #include "cmatrix.h"
14 #include "platform.h"
15 #include "paths.h"
16 #include "resolu.h"
17
18 const char *cm_fmt_id[] = {
19 "unknown", "ascii", COLRFMT, CIEFMT,
20 "float", "double"
21 };
22
23 const int cm_elem_size[] = {
24 0, 0, 4, 4, 3*sizeof(float), 3*sizeof(double)
25 };
26
27 /* Allocate a color coefficient matrix */
28 CMATRIX *
29 cm_alloc(int nrows, int ncols)
30 {
31 CMATRIX *cm;
32
33 if ((nrows <= 0) | (ncols <= 0))
34 error(USER, "attempt to create empty matrix");
35 cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
36 sizeof(COLOR)*(nrows*ncols - 1));
37 if (!cm)
38 error(SYSTEM, "out of memory in cm_alloc()");
39 cm->nrows = nrows;
40 cm->ncols = ncols;
41 return(cm);
42 }
43
44 static void
45 adjacent_ra_sizes(size_t bounds[2], size_t target)
46 {
47 bounds[0] = 0; bounds[1] = 2048;
48 while (bounds[1] < target) {
49 bounds[0] = bounds[1];
50 bounds[1] += bounds[1]>>1;
51 }
52 }
53
54 /* Resize color coefficient matrix */
55 CMATRIX *
56 cm_resize(CMATRIX *cm, int nrows)
57 {
58 size_t old_size, new_size, ra_bounds[2];
59
60 if (!cm)
61 return(NULL);
62 if (nrows == cm->nrows)
63 return(cm);
64 if (nrows <= 0) {
65 cm_free(cm);
66 return(NULL);
67 }
68 old_size = sizeof(CMATRIX) + sizeof(COLOR)*(cm->nrows*cm->ncols - 1);
69 adjacent_ra_sizes(ra_bounds, old_size);
70 new_size = sizeof(CMATRIX) + sizeof(COLOR)*(nrows*cm->ncols - 1);
71 if (nrows < cm->nrows ? new_size <= ra_bounds[0] :
72 new_size > ra_bounds[1]) {
73 adjacent_ra_sizes(ra_bounds, new_size);
74 cm = (CMATRIX *)realloc(cm, ra_bounds[1]);
75 if (!cm)
76 error(SYSTEM, "out of memory in cm_resize()");
77 }
78 cm->nrows = nrows;
79 return(cm);
80 }
81
82 typedef struct {
83 int dtype; /* data type */
84 int need2swap; /* need byte swap? */
85 int nrows, ncols; /* matrix size */
86 char *err; /* error message */
87 } CMINFO; /* header info record */
88
89 static int
90 get_cminfo(char *s, void *p)
91 {
92 CMINFO *ip = (CMINFO *)p;
93 char fmt[MAXFMTLEN];
94 int i;
95
96 if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) {
97 ip->err = "unexpected # components (must be 3)";
98 return(-1);
99 }
100 if (!strncmp(s, "NROWS=", 6)) {
101 ip->nrows = atoi(s+6);
102 return(0);
103 }
104 if (!strncmp(s, "NCOLS=", 6)) {
105 ip->ncols = atoi(s+6);
106 return(0);
107 }
108 if ((i = isbigendian(s)) >= 0) {
109 ip->need2swap = (nativebigendian() != i);
110 return(0);
111 }
112 if (!formatval(fmt, s))
113 return(0);
114 for (i = 1; i < DTend; i++)
115 if (!strcmp(fmt, cm_fmt_id[i]))
116 ip->dtype = i;
117 return(0);
118 }
119
120 /* Load header to obtain/check data type and number of columns */
121 char *
122 cm_getheader(int *dt, int *nr, int *nc, int *swp, FILE *fp)
123 {
124 CMINFO cmi;
125 /* read header */
126 cmi.dtype = DTfromHeader;
127 cmi.need2swap = 0;
128 cmi.nrows = cmi.ncols = 0;
129 cmi.err = "unexpected EOF in header";
130 if (getheader(fp, get_cminfo, &cmi) < 0)
131 return(cmi.err);
132 if (dt) { /* get/check data type? */
133 if (cmi.dtype == DTfromHeader) {
134 if (*dt == DTfromHeader)
135 return("missing/unknown data format in header");
136 } else if (*dt == DTfromHeader)
137 *dt = cmi.dtype;
138 else if (*dt != cmi.dtype)
139 return("unexpected data format in header");
140 }
141 if (nr) { /* get/check #rows? */
142 if (*nr <= 0)
143 *nr = cmi.nrows;
144 else if ((cmi.nrows > 0) & (*nr != cmi.nrows))
145 return("unexpected row count in header");
146 }
147 if (nc) { /* get/check #columns? */
148 if (*nc <= 0)
149 *nc = cmi.ncols;
150 else if ((cmi.ncols > 0) & (*nc != cmi.ncols))
151 return("unexpected column count in header");
152 }
153 if (swp) /* get/check swap? */
154 *swp = cmi.need2swap;
155 return(NULL);
156 }
157
158 /* Allocate and load a matrix from the given input (or stdin if NULL) */
159 CMATRIX *
160 cm_load(const char *inspec, int nrows, int ncols, int dtype)
161 {
162 const int ROWINC = 2048;
163 FILE *fp = stdin;
164 int swap = 0;
165 CMATRIX *cm;
166
167 if (!inspec)
168 inspec = "<stdin>";
169 else if (inspec[0] == '!') {
170 fp = popen(inspec+1, "r");
171 if (!fp) {
172 sprintf(errmsg, "cannot start command '%s'", inspec);
173 error(SYSTEM, errmsg);
174 }
175 } else if (!(fp = fopen(inspec, "r"))) {
176 sprintf(errmsg, "cannot open file '%s'", inspec);
177 error(SYSTEM, errmsg);
178 }
179 #ifdef getc_unlocked
180 flockfile(fp);
181 #endif
182 if (dtype != DTascii)
183 SET_FILE_BINARY(fp); /* doesn't really work */
184 if (!dtype | !ncols) { /* expecting header? */
185 char *err = cm_getheader(&dtype, &nrows, &ncols, &swap, fp);
186 if (err)
187 error(USER, err);
188 if (ncols <= 0)
189 error(USER, "unspecified number of columns");
190 }
191 switch (dtype) {
192 case DTascii:
193 case DTfloat:
194 case DTdouble:
195 break;
196 default:
197 error(USER, "unexpected data type in cm_load()");
198 }
199 if (nrows <= 0) { /* don't know length? */
200 int guessrows = 147; /* usually big enough */
201 if ((dtype != DTascii) & (fp != stdin) & (inspec[0] != '!')) {
202 long startpos = ftell(fp);
203 if (fseek(fp, 0L, SEEK_END) == 0) {
204 long endpos = ftell(fp);
205 long elemsiz = 3*(dtype==DTfloat ?
206 sizeof(float) : sizeof(double));
207
208 if ((endpos - startpos) % (ncols*elemsiz)) {
209 sprintf(errmsg,
210 "improper length for binary file '%s'",
211 inspec);
212 error(USER, errmsg);
213 }
214 guessrows = (endpos - startpos)/(ncols*elemsiz);
215 if (fseek(fp, startpos, SEEK_SET) < 0) {
216 sprintf(errmsg,
217 "fseek() error on file '%s'",
218 inspec);
219 error(SYSTEM, errmsg);
220 }
221 nrows = guessrows; /* we're confident */
222 }
223 }
224 cm = cm_alloc(guessrows, ncols);
225 } else
226 cm = cm_alloc(nrows, ncols);
227 if (!cm) /* XXX never happens */
228 return(NULL);
229 if (dtype == DTascii) { /* read text file */
230 int maxrow = (nrows > 0 ? nrows : 32000);
231 int r, c;
232 for (r = 0; r < maxrow; r++) {
233 if (r >= cm->nrows) /* need more space? */
234 cm = cm_resize(cm, cm->nrows+ROWINC);
235 for (c = 0; c < ncols; c++) {
236 COLORV *cv = cm_lval(cm,r,c);
237 if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) {
238 if ((nrows <= 0) & (r > 0) & !c) {
239 cm = cm_resize(cm, maxrow=r);
240 break;
241 } else
242 goto EOFerror;
243 }
244 }
245 }
246 while ((c = getc(fp)) != EOF)
247 if (!isspace(c)) {
248 sprintf(errmsg,
249 "unexpected data at end of ascii input '%s'",
250 inspec);
251 error(WARNING, errmsg);
252 break;
253 }
254 } else { /* read binary file */
255 if (sizeof(COLOR) == cm_elem_size[dtype]) {
256 int nread = 0;
257 do { /* read all we can */
258 nread += getbinary(cm->cmem + 3*nread,
259 sizeof(COLOR),
260 cm->nrows*cm->ncols - nread,
261 fp);
262 if (nrows <= 0) { /* unknown length */
263 if (nread == cm->nrows*cm->ncols)
264 /* need more space? */
265 cm = cm_resize(cm, cm->nrows+ROWINC);
266 else if (nread && !(nread % cm->ncols))
267 /* seem to be done */
268 cm = cm_resize(cm, nread/cm->ncols);
269 else /* ended mid-row */
270 goto EOFerror;
271 } else if (nread < cm->nrows*cm->ncols)
272 goto EOFerror;
273 } while (nread < cm->nrows*cm->ncols);
274
275 } else if (dtype == DTdouble) {
276 double dc[3]; /* load from double */
277 COLORV *cvp = cm->cmem;
278 int n = nrows*ncols;
279
280 if (n <= 0)
281 goto not_handled;
282 while (n--) {
283 if (getbinary(dc, sizeof(double), 3, fp) != 3)
284 goto EOFerror;
285 copycolor(cvp, dc);
286 cvp += 3;
287 }
288 } else /* dtype == DTfloat */ {
289 float fc[3]; /* load from float */
290 COLORV *cvp = cm->cmem;
291 int n = nrows*ncols;
292
293 if (n <= 0)
294 goto not_handled;
295 while (n--) {
296 if (getbinary(fc, sizeof(float), 3, fp) != 3)
297 goto EOFerror;
298 copycolor(cvp, fc);
299 cvp += 3;
300 }
301 }
302 if (fgetc(fp) != EOF) {
303 sprintf(errmsg,
304 "unexpected data at end of binary input '%s'",
305 inspec);
306 error(WARNING, errmsg);
307 }
308 }
309 if (swap) {
310 if (dtype == DTfloat)
311 swap32((char *)cm->cmem, 3*cm->nrows*cm->ncols);
312 else if (dtype == DTdouble)
313 swap64((char *)cm->cmem, 3*cm->nrows*cm->ncols);
314 }
315 if (fp != stdin) {
316 if (inspec[0] != '!')
317 fclose(fp);
318 else if (pclose(fp)) {
319 sprintf(errmsg, "error running command '%s'", inspec);
320 error(WARNING, errmsg);
321 }
322 }
323 #ifdef getc_unlocked
324 else
325 funlockfile(fp);
326 #endif
327 return(cm);
328 EOFerror:
329 sprintf(errmsg, "unexpected EOF reading %s", inspec);
330 error(USER, errmsg);
331 not_handled:
332 error(INTERNAL, "unhandled data size or length in cm_load()");
333 return(NULL); /* gratis return */
334 }
335
336 /* Extract a column vector from a matrix */
337 CMATRIX *
338 cm_column(const CMATRIX *cm, int c)
339 {
340 CMATRIX *cvr;
341 int dr;
342
343 if (!cm)
344 return(NULL);
345 if ((c < 0) | (c >= cm->ncols))
346 error(INTERNAL, "column requested outside matrix");
347 cvr = cm_alloc(cm->nrows, 1);
348 if (!cvr)
349 return(NULL);
350 for (dr = 0; dr < cm->nrows; dr++) {
351 const COLORV *sp = cm_lval(cm,dr,c);
352 COLORV *dp = cv_lval(cvr,dr);
353 dp[0] = sp[0];
354 dp[1] = sp[1];
355 dp[2] = sp[2];
356 }
357 return(cvr);
358 }
359
360 /* Multiply two matrices (or a matrix and a vector) and allocate the result */
361 CMATRIX *
362 cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
363 {
364 char *rowcheck=NULL, *colcheck=NULL;
365 CMATRIX *cmr;
366 int dr, dc, i;
367
368 if (!cm1 | !cm2)
369 return(NULL);
370 if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
371 error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
372 cmr = cm_alloc(cm1->nrows, cm2->ncols);
373 if (!cmr)
374 return(NULL);
375 /* optimization: check for zero rows & cols */
376 if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
377 static const COLOR czero;
378 rowcheck = (char *)calloc(cmr->nrows, 1);
379 for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
380 for (dc = cm1->ncols; dc--; )
381 if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
382 rowcheck[dr] = 1;
383 break;
384 }
385 colcheck = (char *)calloc(cmr->ncols, 1);
386 for (dc = cm2->ncols*(colcheck != NULL); dc--; )
387 for (dr = cm2->nrows; dr--; )
388 if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
389 colcheck[dc] = 1;
390 break;
391 }
392 }
393 for (dr = 0; dr < cmr->nrows; dr++)
394 for (dc = 0; dc < cmr->ncols; dc++) {
395 COLORV *dp = cm_lval(cmr,dr,dc);
396 double res[3];
397 dp[0] = dp[1] = dp[2] = 0;
398 if (rowcheck && !rowcheck[dr])
399 continue;
400 if (colcheck && !colcheck[dc])
401 continue;
402 res[0] = res[1] = res[2] = 0;
403 for (i = 0; i < cm1->ncols; i++) {
404 const COLORV *cp1 = cm_lval(cm1,dr,i);
405 const COLORV *cp2 = cm_lval(cm2,i,dc);
406 res[0] += (double)cp1[0] * cp2[0];
407 res[1] += (double)cp1[1] * cp2[1];
408 res[2] += (double)cp1[2] * cp2[2];
409 }
410 copycolor(dp, res);
411 }
412 if (rowcheck) free(rowcheck);
413 if (colcheck) free(colcheck);
414 return(cmr);
415 }
416
417 /* write out matrix to file (precede by resolution string if picture) */
418 int
419 cm_write(const CMATRIX *cm, int dtype, FILE *fp)
420 {
421 static const char tabEOL[2] = {'\t','\n'};
422 const COLORV *mp;
423 int r, c;
424
425 if (!cm)
426 return(0);
427 mp = cm->cmem;
428 switch (dtype) {
429 case DTascii:
430 for (r = 0; r < cm->nrows; r++)
431 for (c = 0; c < cm->ncols; c++, mp += 3)
432 fprintf(fp, "%.6e %.6e %.6e%c",
433 mp[0], mp[1], mp[2],
434 tabEOL[c >= cm->ncols-1]);
435 break;
436 case DTfloat:
437 case DTdouble:
438 if (sizeof(COLOR) == cm_elem_size[dtype]) {
439 r = cm->ncols*cm->nrows;
440 while (r > 0) {
441 c = putbinary(mp, sizeof(COLOR), r, fp);
442 if (c <= 0)
443 return(0);
444 mp += 3*c;
445 r -= c;
446 }
447 } else if (dtype == DTdouble) {
448 double dc[3];
449 r = cm->ncols*cm->nrows;
450 while (r--) {
451 copycolor(dc, mp);
452 if (putbinary(dc, sizeof(double), 3, fp) != 3)
453 return(0);
454 mp += 3;
455 }
456 } else /* dtype == DTfloat */ {
457 float fc[3];
458 r = cm->ncols*cm->nrows;
459 while (r--) {
460 copycolor(fc, mp);
461 if (putbinary(fc, sizeof(float), 3, fp) != 3)
462 return(0);
463 mp += 3;
464 }
465 }
466 break;
467 case DTrgbe:
468 case DTxyze:
469 fprtresolu(cm->ncols, cm->nrows, fp);
470 for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols)
471 if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0)
472 return(0);
473 break;
474 default:
475 fputs("Unsupported data type in cm_write()!\n", stderr);
476 return(0);
477 }
478 return(fflush(fp) == 0);
479 }
