--- ray/src/util/cmatrix.c 2019/10/23 17:00:14 2.23 +++ ray/src/util/cmatrix.c 2021/01/19 23:32:00 2.32 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: cmatrix.c,v 2.23 2019/10/23 17:00:14 greg Exp $"; +static const char RCSid[] = "$Id: cmatrix.c,v 2.32 2021/01/19 23:32:00 greg Exp $"; #endif /* * Color matrix routines. @@ -15,13 +15,15 @@ static const char RCSid[] = "$Id: cmatrix.c,v 2.23 201 #include "paths.h" #include "resolu.h" +const char stdin_name[] = ""; + const char *cm_fmt_id[] = { - "unknown", "ascii", COLRFMT, CIEFMT, - "float", "double" + "unknown", COLRFMT, CIEFMT, + "float", "ascii", "double" }; const int cm_elem_size[] = { - 0, 0, 4, 4, 3*sizeof(float), 3*sizeof(double) + 0, 4, 4, 3*sizeof(float), 0, 3*sizeof(double) }; /* Allocate a color coefficient matrix */ @@ -33,7 +35,7 @@ cm_alloc(int nrows, int ncols) if ((nrows <= 0) | (ncols <= 0)) error(USER, "attempt to create empty matrix"); cm = (CMATRIX *)malloc(sizeof(CMATRIX) + - sizeof(COLOR)*(nrows*ncols - 1)); + sizeof(COLOR)*((size_t)nrows*ncols - 1)); if (!cm) error(SYSTEM, "out of memory in cm_alloc()"); cm->nrows = nrows; @@ -65,9 +67,9 @@ cm_resize(CMATRIX *cm, int nrows) cm_free(cm); return(NULL); } - old_size = sizeof(CMATRIX) + sizeof(COLOR)*(cm->nrows*cm->ncols - 1); + old_size = sizeof(CMATRIX) + sizeof(COLOR)*((size_t)cm->nrows*cm->ncols - 1); adjacent_ra_sizes(ra_bounds, old_size); - new_size = sizeof(CMATRIX) + sizeof(COLOR)*(nrows*cm->ncols - 1); + new_size = sizeof(CMATRIX) + sizeof(COLOR)*((size_t)nrows*cm->ncols - 1); if (nrows < cm->nrows ? new_size <= ra_bounds[0] : new_size > ra_bounds[1]) { adjacent_ra_sizes(ra_bounds, new_size); @@ -83,6 +85,7 @@ typedef struct { int dtype; /* data type */ int need2swap; /* need byte swap? */ int nrows, ncols; /* matrix size */ + COLOR expos; /* exposure value */ char *err; /* error message */ } CMINFO; /* header info record */ @@ -109,6 +112,17 @@ get_cminfo(char *s, void *p) ip->need2swap = (nativebigendian() != i); return(0); } + if (isexpos(s)) { + double d = exposval(s); + scalecolor(ip->expos, d); + return(0); + } + if (iscolcor(s)) { + COLOR ctmp; + colcorval(ctmp, s); + multcolor(ip->expos, ctmp); + return(0); + } if (!formatval(fmt, s)) return(0); for (i = 1; i < DTend; i++) @@ -119,12 +133,13 @@ get_cminfo(char *s, void *p) /* Load header to obtain/check data type and number of columns */ char * -cm_getheader(int *dt, int *nr, int *nc, int *swp, FILE *fp) +cm_getheader(int *dt, int *nr, int *nc, int *swp, COLOR scale, FILE *fp) { CMINFO cmi; /* read header */ cmi.dtype = DTfromHeader; cmi.need2swap = 0; + cmi.expos[0] = cmi.expos[1] = cmi.expos[2] = 1.f; cmi.nrows = cmi.ncols = 0; cmi.err = "unexpected EOF in header"; if (getheader(fp, get_cminfo, &cmi) < 0) @@ -152,23 +167,28 @@ cm_getheader(int *dt, int *nr, int *nc, int *swp, FILE } if (swp) /* get/check swap? */ *swp = cmi.need2swap; + if (scale) { /* transfer exposure comp. */ + scale[0] = 1.f/cmi.expos[0]; + scale[1] = 1.f/cmi.expos[1]; + scale[2] = 1.f/cmi.expos[2]; + } return(NULL); } /* Allocate and load image data into matrix */ static CMATRIX * -cm_load_rgbe(FILE *fp, int nrows, int ncols) +cm_load_rgbe(FILE *fp, int nrows, int ncols, COLOR scale) { + int doscale; CMATRIX *cm; COLORV *mp; /* header already loaded */ - if ((nrows <= 0) | (ncols <= 0) && !fscnresolu(&ncols, &nrows, fp)) { - error(USER, "bad picture resolution string"); - return(NULL); - } cm = cm_alloc(nrows, ncols); if (!cm) return(NULL); + doscale = (scale[0] < .99) | (scale[0] > 1.01) | + (scale[1] < .99) | (scale[1] > 1.01) | + (scale[2] < .99) | (scale[2] > 1.01) ; mp = cm->cmem; while (nrows--) { if (freadscan((COLOR *)mp, ncols, fp) < 0) { @@ -176,7 +196,15 @@ cm_load_rgbe(FILE *fp, int nrows, int ncols) cm_free(cm); return(NULL); } - mp += 3*ncols; + if (doscale) { + int i = ncols; + while (i--) { + *mp++ *= scale[0]; + *mp++ *= scale[1]; + *mp++ *= scale[2]; + } + } else + mp += 3*ncols; } /* caller closes stream */ return(cm); } @@ -186,12 +214,15 @@ CMATRIX * cm_load(const char *inspec, int nrows, int ncols, int dtype) { const int ROWINC = 2048; - FILE *fp = stdin; int swap = 0; + FILE *fp; + COLOR scale; CMATRIX *cm; - if (!inspec) - inspec = ""; + if (!inspec || !*inspec) + return(NULL); + if (inspec == stdin_name) + fp = stdin; else if (inspec[0] == '!') { fp = popen(inspec+1, "r"); if (!fp) { @@ -208,12 +239,12 @@ cm_load(const char *inspec, int nrows, int ncols, int if (dtype != DTascii) SET_FILE_BINARY(fp); /* doesn't really work */ if (!dtype | !ncols) { /* expecting header? */ - char *err = cm_getheader(&dtype, &nrows, &ncols, &swap, fp); + char *err = cm_getheader(&dtype, &nrows, &ncols, &swap, scale, fp); if (err) error(USER, err); - if (ncols <= 0) - error(USER, "unspecified number of columns"); } + if (ncols <= 0 && !fscnresolu(&ncols, &nrows, fp)) + error(USER, "unspecified number of columns"); switch (dtype) { case DTascii: case DTfloat: @@ -221,27 +252,26 @@ cm_load(const char *inspec, int nrows, int ncols, int break; case DTrgbe: case DTxyze: - cm = cm_load_rgbe(fp, nrows, ncols); + cm = cm_load_rgbe(fp, nrows, ncols, scale); goto cleanup; default: error(USER, "unexpected data type in cm_load()"); } if (nrows <= 0) { /* don't know length? */ int guessrows = 147; /* usually big enough */ - if ((dtype != DTascii) & (fp != stdin) & (inspec[0] != '!')) { + if (cm_elem_size[dtype] && (fp != stdin) & (inspec[0] != '!')) { long startpos = ftell(fp); if (fseek(fp, 0L, SEEK_END) == 0) { + long rowsiz = (long)ncols*cm_elem_size[dtype]; long endpos = ftell(fp); - long elemsiz = 3*(dtype==DTfloat ? - sizeof(float) : sizeof(double)); - if ((endpos - startpos) % (ncols*elemsiz)) { + if ((endpos - startpos) % rowsiz) { sprintf(errmsg, "improper length for binary file '%s'", inspec); error(USER, errmsg); } - guessrows = (endpos - startpos)/(ncols*elemsiz); + guessrows = (endpos - startpos)/rowsiz; if (fseek(fp, startpos, SEEK_SET) < 0) { sprintf(errmsg, "fseek() error on file '%s'", @@ -283,14 +313,14 @@ cm_load(const char *inspec, int nrows, int ncols, int } } else { /* read binary file */ if (sizeof(COLOR) == cm_elem_size[dtype]) { - int nread = 0; + size_t nread = 0; do { /* read all we can */ nread += getbinary(cm->cmem + 3*nread, sizeof(COLOR), - cm->nrows*cm->ncols - nread, + (size_t)cm->nrows*cm->ncols - nread, fp); if (nrows <= 0) { /* unknown length */ - if (nread == cm->nrows*cm->ncols) + if (nread == (size_t)cm->nrows*cm->ncols) /* need more space? */ cm = cm_resize(cm, cm->nrows+ROWINC); else if (nread && !(nread % cm->ncols)) @@ -298,33 +328,43 @@ cm_load(const char *inspec, int nrows, int ncols, int cm = cm_resize(cm, nread/cm->ncols); else /* ended mid-row */ goto EOFerror; - } else if (nread < cm->nrows*cm->ncols) + } else if (nread < (size_t)cm->nrows*cm->ncols) goto EOFerror; - } while (nread < cm->nrows*cm->ncols); + } while (nread < (size_t)cm->nrows*cm->ncols); + if (swap) { + if (sizeof(COLORV) == 4) + swap32((char *)cm->cmem, + 3*(size_t)cm->nrows*cm->ncols); + else /* sizeof(COLORV) == 8 */ + swap64((char *)cm->cmem, + 3*(size_t)cm->nrows*cm->ncols); + } } else if (dtype == DTdouble) { double dc[3]; /* load from double */ COLORV *cvp = cm->cmem; - int n = nrows*ncols; + size_t n = (size_t)nrows*ncols; if (n <= 0) goto not_handled; while (n--) { if (getbinary(dc, sizeof(double), 3, fp) != 3) goto EOFerror; + if (swap) swap64((char *)dc, 3); copycolor(cvp, dc); cvp += 3; } } else /* dtype == DTfloat */ { float fc[3]; /* load from float */ COLORV *cvp = cm->cmem; - int n = nrows*ncols; + size_t n = (size_t)nrows*ncols; if (n <= 0) goto not_handled; while (n--) { if (getbinary(fc, sizeof(float), 3, fp) != 3) goto EOFerror; + if (swap) swap32((char *)fc, 3); copycolor(cvp, fc); cvp += 3; } @@ -336,12 +376,6 @@ cm_load(const char *inspec, int nrows, int ncols, int error(WARNING, errmsg); } } - if (swap) { - if (dtype == DTfloat) - swap32((char *)cm->cmem, 3*cm->nrows*cm->ncols); - else if (dtype == DTdouble) - swap64((char *)cm->cmem, 3*cm->nrows*cm->ncols); - } cleanup: if (fp != stdin) { if (inspec[0] != '!') @@ -453,6 +487,7 @@ cm_write(const CMATRIX *cm, int dtype, FILE *fp) static const char tabEOL[2] = {'\t','\n'}; const COLORV *mp; int r, c; + size_t n, rv; if (!cm) return(0); @@ -468,18 +503,18 @@ cm_write(const CMATRIX *cm, int dtype, FILE *fp) case DTfloat: case DTdouble: if (sizeof(COLOR) == cm_elem_size[dtype]) { - r = cm->ncols*cm->nrows; - while (r > 0) { - c = putbinary(mp, sizeof(COLOR), r, fp); - if (c <= 0) + n = (size_t)cm->ncols*cm->nrows; + while (n > 0) { + rv = fwrite(mp, sizeof(COLOR), n, fp); + if (rv <= 0) return(0); - mp += 3*c; - r -= c; + mp += 3*rv; + n -= rv; } } else if (dtype == DTdouble) { double dc[3]; - r = cm->ncols*cm->nrows; - while (r--) { + n = (size_t)cm->ncols*cm->nrows; + while (n--) { copycolor(dc, mp); if (putbinary(dc, sizeof(double), 3, fp) != 3) return(0); @@ -487,8 +522,8 @@ cm_write(const CMATRIX *cm, int dtype, FILE *fp) } } else /* dtype == DTfloat */ { float fc[3]; - r = cm->ncols*cm->nrows; - while (r--) { + n = (size_t)cm->ncols*cm->nrows; + while (n--) { copycolor(fc, mp); if (putbinary(fc, sizeof(float), 3, fp) != 3) return(0);
