--- ray/src/util/cmatrix.c 2014/01/20 21:29:04 2.1 +++ ray/src/util/cmatrix.c 2016/03/06 01:13:18 2.16 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: cmatrix.c,v 2.1 2014/01/20 21:29:04 greg Exp $"; +static const char RCSid[] = "$Id: cmatrix.c,v 2.16 2016/03/06 01:13:18 schorsch Exp $"; #endif /* * Color matrix routines. @@ -8,10 +8,22 @@ static const char RCSid[] = "$Id: cmatrix.c,v 2.1 2014 */ #include +#include "platform.h" #include "standard.h" #include "cmatrix.h" #include "platform.h" +#include "paths.h" +#include "resolu.h" +const char *cm_fmt_id[] = { + "unknown", "ascii", COLRFMT, CIEFMT, + "float", "double" + }; + +const int cm_elem_size[] = { + 0, 0, 3*sizeof(float), 3*sizeof(double), 4, 4 + }; + /* Allocate a color coefficient matrix */ CMATRIX * cm_alloc(int nrows, int ncols) @@ -21,7 +33,7 @@ cm_alloc(int nrows, int ncols) if ((nrows <= 0) | (ncols <= 0)) error(USER, "attempt to create empty matrix"); cm = (CMATRIX *)malloc(sizeof(CMATRIX) + - 3*sizeof(COLORV)*(nrows*ncols - 1)); + sizeof(COLOR)*(nrows*ncols - 1)); if (cm == NULL) error(SYSTEM, "out of memory in cm_alloc()"); cm->nrows = nrows; @@ -29,70 +41,128 @@ cm_alloc(int nrows, int ncols) return(cm); } +static void +adjacent_ra_sizes(size_t bounds[2], size_t target) +{ + bounds[0] = 0; bounds[1] = 2048; + while (bounds[1] < target) { + bounds[0] = bounds[1]; + bounds[1] += bounds[1]>>1; + } +} + /* Resize color coefficient matrix */ CMATRIX * cm_resize(CMATRIX *cm, int nrows) { + size_t old_size, new_size, ra_bounds[2]; + if (nrows == cm->nrows) return(cm); if (nrows <= 0) { cm_free(cm); return(NULL); } - cm = (CMATRIX *)realloc(cm, sizeof(CMATRIX) + - 3*sizeof(COLORV)*(nrows*cm->ncols - 1)); - if (cm == NULL) - error(SYSTEM, "out of memory in cm_resize()"); + old_size = sizeof(CMATRIX) + sizeof(COLOR)*(cm->nrows*cm->ncols - 1); + adjacent_ra_sizes(ra_bounds, old_size); + new_size = sizeof(CMATRIX) + sizeof(COLOR)*(nrows*cm->ncols - 1); + if (nrows < cm->nrows ? new_size <= ra_bounds[0] : + new_size > ra_bounds[1]) { + adjacent_ra_sizes(ra_bounds, new_size); + cm = (CMATRIX *)realloc(cm, ra_bounds[1]); + if (cm == NULL) + error(SYSTEM, "out of memory in cm_resize()"); + } cm->nrows = nrows; return(cm); } +typedef struct { + int dtype; /* data type */ + int nrows, ncols; /* matrix size */ + char *err; /* error message */ +} CMINFO; /* header info record */ + static int -getDT(char *s, void *p) +get_cminfo(char *s, void *p) { + CMINFO *ip = (CMINFO *)p; char fmt[32]; - - if (formatval(fmt, s)) { - if (!strcmp(fmt, "ascii")) - *((int *)p) = DTascii; - else if (!strcmp(fmt, "float")) - *((int *)p) = DTfloat; - else if (!strcmp(fmt, "double")) - *((int *)p) = DTdouble; - else if (!strcmp(fmt, COLRFMT)) - *((int *)p) = DTrgbe; - else if (!strcmp(fmt, CIEFMT)) - *((int *)p) = DTxyze; + int i; + + if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) { + ip->err = "unexpected # components (must be 3)"; + return(-1); } + if (!strncmp(s, "NROWS=", 6)) { + ip->nrows = atoi(s+6); + return(0); + } + if (!strncmp(s, "NCOLS=", 6)) { + ip->ncols = atoi(s+6); + return(0); + } + if (!formatval(fmt, s)) + return(0); + for (i = 1; i < DTend; i++) + if (!strcmp(fmt, cm_fmt_id[i])) + ip->dtype = i; return(0); } -/* Load header to obtain data type */ -int -getDTfromHeader(FILE *fp) +/* Load header to obtain/check data type and number of columns */ +char * +cm_getheader(int *dt, int *nr, int *nc, FILE *fp) { - int dt = DTfromHeader; - - if (getheader(fp, getDT, &dt) < 0) - error(SYSTEM, "header read error"); - if (dt == DTfromHeader) - error(USER, "missing data format in header"); - return(dt); + CMINFO cmi; + /* read header */ + cmi.dtype = DTfromHeader; + cmi.nrows = cmi.ncols = 0; + cmi.err = "unexpected EOF in header"; + if (getheader(fp, get_cminfo, &cmi) < 0) + return(cmi.err); + if (dt != NULL) { /* get/check data type? */ + if (cmi.dtype == DTfromHeader) { + if (*dt == DTfromHeader) + return("missing/unknown data format in header"); + } else if (*dt == DTfromHeader) + *dt = cmi.dtype; + else if (*dt != cmi.dtype) + return("unexpected data format in header"); + } + if (nr != NULL) { /* get/check #rows? */ + if (*nr <= 0) + *nr = cmi.nrows; + else if ((cmi.nrows > 0) & (*nr != cmi.nrows)) + return("unexpected row count in header"); + } + if (nc != NULL) { /* get/check #columns? */ + if (*nc <= 0) + *nc = cmi.ncols; + else if ((cmi.ncols > 0) & (*nc != cmi.ncols)) + return("unexpected column count in header"); + } + return(NULL); } -/* Allocate and load a matrix from the given file (or stdin if NULL) */ +/* Allocate and load a matrix from the given input (or stdin if NULL) */ CMATRIX * -cm_load(const char *fname, int nrows, int ncols, int dtype) +cm_load(const char *inspec, int nrows, int ncols, int dtype) { - FILE *fp = stdin; - CMATRIX *cm; + const int ROWINC = 2048; + FILE *fp = stdin; + CMATRIX *cm; - if (ncols <= 0) - error(USER, "Non-positive number of columns"); - if (fname == NULL) - fname = ""; - else if ((fp = fopen(fname, "r")) == NULL) { - sprintf(errmsg, "cannot open file '%s'", fname); + if (inspec == NULL) + inspec = ""; + else if (inspec[0] == '!') { + fp = popen(inspec+1, "r"); + if (fp == NULL) { + sprintf(errmsg, "cannot start command '%s'", inspec); + error(SYSTEM, errmsg); + } + } else if ((fp = fopen(inspec, "r")) == NULL) { + sprintf(errmsg, "cannot open file '%s'", inspec); error(SYSTEM, errmsg); } #ifdef getc_unlocked @@ -100,8 +170,13 @@ cm_load(const char *fname, int nrows, int ncols, int d #endif if (dtype != DTascii) SET_FILE_BINARY(fp); /* doesn't really work */ - if (dtype == DTfromHeader) - dtype = getDTfromHeader(fp); + if (!dtype | !ncols) { /* expecting header? */ + char *err = cm_getheader(&dtype, &nrows, &ncols, fp); + if (err != NULL) + error(USER, err); + if (ncols <= 0) + error(USER, "unspecified number of columns"); + } switch (dtype) { case DTascii: case DTfloat: @@ -112,7 +187,7 @@ cm_load(const char *fname, int nrows, int ncols, int d } if (nrows <= 0) { /* don't know length? */ int guessrows = 147; /* usually big enough */ - if ((dtype != DTascii) & (fp != stdin)) { + if ((dtype != DTascii) & (fp != stdin) & (inspec[0] != '!')) { long startpos = ftell(fp); if (fseek(fp, 0L, SEEK_END) == 0) { long endpos = ftell(fp); @@ -122,14 +197,14 @@ cm_load(const char *fname, int nrows, int ncols, int d if ((endpos - startpos) % (ncols*elemsiz)) { sprintf(errmsg, "improper length for binary file '%s'", - fname); + inspec); error(USER, errmsg); } guessrows = (endpos - startpos)/(ncols*elemsiz); if (fseek(fp, startpos, SEEK_SET) < 0) { sprintf(errmsg, "fseek() error on file '%s'", - fname); + inspec); error(SYSTEM, errmsg); } nrows = guessrows; /* we're confident */ @@ -145,38 +220,38 @@ cm_load(const char *fname, int nrows, int ncols, int d int r, c; for (r = 0; r < maxrow; r++) { if (r >= cm->nrows) /* need more space? */ - cm = cm_resize(cm, 2*cm->nrows); + cm = cm_resize(cm, cm->nrows+ROWINC); for (c = 0; c < ncols; c++) { COLORV *cv = cm_lval(cm,r,c); - if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) + if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) { if ((nrows <= 0) & (r > 0) & !c) { cm = cm_resize(cm, maxrow=r); break; } else goto EOFerror; + } } } while ((c = getc(fp)) != EOF) if (!isspace(c)) { sprintf(errmsg, - "unexpected data at end of ascii file %s", - fname); + "unexpected data at end of ascii input '%s'", + inspec); error(WARNING, errmsg); break; } } else { /* read binary file */ - if (sizeof(COLORV) == (dtype==DTfloat ? sizeof(float) : - sizeof(double))) { + if (sizeof(COLOR) == cm_elem_size[dtype]) { int nread = 0; do { /* read all we can */ nread += fread(cm->cmem + 3*nread, - 3*sizeof(COLORV), + sizeof(COLOR), cm->nrows*cm->ncols - nread, fp); if (nrows <= 0) { /* unknown length */ if (nread == cm->nrows*cm->ncols) /* need more space? */ - cm = cm_resize(cm, 2*cm->nrows); + cm = cm_resize(cm, cm->nrows+ROWINC); else if (nread && !(nread % cm->ncols)) /* seem to be done */ cm = cm_resize(cm, nread/cm->ncols); @@ -215,20 +290,26 @@ cm_load(const char *fname, int nrows, int ncols, int d } if (fgetc(fp) != EOF) { sprintf(errmsg, - "unexpected data at end of binary file %s", - fname); + "unexpected data at end of binary input '%s'", + inspec); error(WARNING, errmsg); } } - if (fp != stdin) - fclose(fp); + if (fp != stdin) { + if (inspec[0] != '!') + fclose(fp); + else if (pclose(fp)) { + sprintf(errmsg, "error running command '%s'", inspec); + error(WARNING, errmsg); + } + } #ifdef getc_unlocked else funlockfile(fp); #endif return(cm); EOFerror: - sprintf(errmsg, "unexpected EOF reading %s", fname); + sprintf(errmsg, "unexpected EOF reading %s", inspec); error(USER, errmsg); not_handled: error(INTERNAL, "unhandled data size or length in cm_load()"); @@ -312,34 +393,84 @@ cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2) for (dr = 0; dr < cmr->nrows; dr++) for (dc = 0; dc < cmr->ncols; dc++) { COLORV *dp = cm_lval(cmr,dr,dc); + double res[3]; dp[0] = dp[1] = dp[2] = 0; if (rowcheck != NULL && !rowcheck[dr]) continue; if (colcheck != NULL && !colcheck[dc]) continue; + res[0] = res[1] = res[2] = 0; for (i = 0; i < cm1->ncols; i++) { const COLORV *cp1 = cm_lval(cm1,dr,i); const COLORV *cp2 = cm_lval(cm2,i,dc); - dp[0] += cp1[0] * cp2[0]; - dp[1] += cp1[1] * cp2[1]; - dp[2] += cp1[2] * cp2[2]; + res[0] += cp1[0] * cp2[0]; + res[1] += cp1[1] * cp2[1]; + res[2] += cp1[2] * cp2[2]; } + copycolor(dp, res); } if (rowcheck != NULL) free(rowcheck); if (colcheck != NULL) free(colcheck); return(cmr); } -/* print out matrix as ASCII text -- no header */ -void -cm_print(const CMATRIX *cm, FILE *fp) +/* write out matrix to file (precede by resolution string if picture) */ +int +cm_write(const CMATRIX *cm, int dtype, FILE *fp) { - int r, c; - const COLORV *mp = cm->cmem; - - for (r = 0; r < cm->nrows; r++) { - for (c = 0; c < cm->ncols; c++, mp += 3) - fprintf(fp, "\t%.6e %.6e %.6e", mp[0], mp[1], mp[2]); - fputc('\n', fp); + static const char tabEOL[2] = {'\t','\n'}; + const COLORV *mp = cm->cmem; + int r, c; + + switch (dtype) { + case DTascii: + for (r = 0; r < cm->nrows; r++) + for (c = 0; c < cm->ncols; c++, mp += 3) + fprintf(fp, "%.6e %.6e %.6e%c", + mp[0], mp[1], mp[2], + tabEOL[c >= cm->ncols-1]); + break; + case DTfloat: + case DTdouble: + if (sizeof(COLOR) == cm_elem_size[dtype]) { + r = cm->ncols*cm->nrows; + while (r > 0) { + c = fwrite(mp, sizeof(COLOR), r, fp); + if (c <= 0) + return(0); + mp += 3*c; + r -= c; + } + } else if (dtype == DTdouble) { + double dc[3]; + r = cm->ncols*cm->nrows; + while (r--) { + copycolor(dc, mp); + if (fwrite(dc, sizeof(double), 3, fp) != 3) + return(0); + mp += 3; + } + } else /* dtype == DTfloat */ { + float fc[3]; + r = cm->ncols*cm->nrows; + while (r--) { + copycolor(fc, mp); + if (fwrite(fc, sizeof(float), 3, fp) != 3) + return(0); + mp += 3; + } + } + break; + case DTrgbe: + case DTxyze: + fprtresolu(cm->ncols, cm->nrows, fp); + for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols) + if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0) + return(0); + break; + default: + fputs("Unsupported data type in cm_write()!\n", stderr); + return(0); } + return(fflush(fp) == 0); }
