root/Development/ray/src/util/cmatrix.c
Revision: 2.9
Committed: Mon May 4 20:53:21 2015 UTC (10 years, 7 months ago) by greg
Changes since 2.8: +29 -17 lines
2 static const char RCSid[] = "$Id: cmatrix.c,v 2.8 2014/08/02 17:10:43 greg Exp $";
5 * Color matrix routines.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "standard.h"
12 #include "cmatrix.h"
13 #include "platform.h"
14 #include "resolu.h"
15
16 const char *cm_fmt_id[] = {
17 "unknown", "ascii", COLRFMT, CIEFMT,
18 "float", "double"
19 };
20
21 const int cm_elem_size[] = {
22 0, 0, 3*sizeof(float), 3*sizeof(double), 4, 4
23 };
24
25 /* Allocate a color coefficient matrix */
26 CMATRIX *
27 cm_alloc(int nrows, int ncols)
28 {
29 CMATRIX *cm;
30
31 if ((nrows <= 0) | (ncols <= 0))
32 error(USER, "attempt to create empty matrix");
33 cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
34 sizeof(COLOR)*(nrows*ncols - 1));
35 if (cm == NULL)
36 error(SYSTEM, "out of memory in cm_alloc()");
37 cm->nrows = nrows;
38 cm->ncols = ncols;
39 return(cm);
40 }
41
42 static void
43 adjacent_ra_sizes(size_t bounds[2], size_t target)
44 {
45 bounds[0] = 0; bounds[1] = 2048;
46 while (bounds[1] < target) {
47 bounds[0] = bounds[1];
48 bounds[1] += bounds[1]>>1;
49 }
50 }
51
52 /* Resize color coefficient matrix */
53 CMATRIX *
54 cm_resize(CMATRIX *cm, int nrows)
55 {
56 size_t old_size, new_size, ra_bounds[2];
57
58 if (nrows == cm->nrows)
59 return(cm);
60 if (nrows <= 0) {
61 cm_free(cm);
62 return(NULL);
63 }
64 old_size = sizeof(CMATRIX) + sizeof(COLOR)*(cm->nrows*cm->ncols - 1);
65 adjacent_ra_sizes(ra_bounds, old_size);
66 new_size = sizeof(CMATRIX) + sizeof(COLOR)*(nrows*cm->ncols - 1);
67 if (nrows < cm->nrows ? new_size <= ra_bounds[0] :
68 new_size > ra_bounds[1]) {
69 adjacent_ra_sizes(ra_bounds, new_size);
70 cm = (CMATRIX *)realloc(cm, ra_bounds[1]);
71 if (cm == NULL)
72 error(SYSTEM, "out of memory in cm_resize()");
73 }
74 cm->nrows = nrows;
75 return(cm);
76 }
77
78 typedef struct {
79 int dtype; /* data type */
80 int nrows, ncols; /* matrix size */
81 char *err; /* error message */
82 } CMINFO; /* header info record */
83
84 static int
85 get_cminfo(char *s, void *p)
86 {
87 CMINFO *ip = (CMINFO *)p;
88 char fmt[32];
89 int i;
90
91 if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) {
92 ip->err = "unexpected # components (must be 3)";
93 return(-1);
94 }
95 if (!strncmp(s, "NROWS=", 6)) {
96 ip->nrows = atoi(s+6);
97 return(0);
98 }
99 if (!strncmp(s, "NCOLS=", 6)) {
100 ip->ncols = atoi(s+6);
101 return(0);
102 }
103 if (!formatval(fmt, s))
104 return(0);
105 for (i = 1; i < DTend; i++)
106 if (!strcmp(fmt, cm_fmt_id[i]))
107 ip->dtype = i;
108 return(0);
109 }
110
111 /* Load header to obtain/check data type and number of columns */
112 char *
113 cm_getheader(int *dt, int *nr, int *nc, FILE *fp)
114 {
115 CMINFO cmi;
116 /* read header */
117 cmi.dtype = DTfromHeader;
118 cmi.nrows = cmi.ncols = 0;
119 cmi.err = "unexpected EOF in header";
120 if (getheader(fp, get_cminfo, &cmi) < 0)
121 return(cmi.err);
122 if (dt != NULL) { /* get/check data type? */
123 if (cmi.dtype == DTfromHeader) {
124 if (*dt == DTfromHeader)
125 return("missing/unknown data format in header");
126 } else if (*dt == DTfromHeader)
127 *dt = cmi.dtype;
128 else if (*dt != cmi.dtype)
129 return("unexpected data format in header");
130 }
131 if (nr != NULL) { /* get/check #rows? */
132 if (*nr <= 0)
133 *nr = cmi.nrows;
134 else if ((cmi.nrows > 0) & (*nr != cmi.nrows))
135 return("unexpected row count in header");
136 }
137 if (nc != NULL) { /* get/check #columns? */
138 if (*nc <= 0)
139 *nc = cmi.ncols;
140 else if ((cmi.ncols > 0) & (*nc != cmi.ncols))
141 return("unexpected column count in header");
142 }
143 return(NULL);
144 }
145
146 /* Allocate and load a matrix from the given input (or stdin if NULL) */
147 CMATRIX *
148 cm_load(const char *inspec, int nrows, int ncols, int dtype)
149 {
150 FILE *fp = stdin;
151 CMATRIX *cm;
152
153 if (inspec == NULL)
154 inspec = "<stdin>";
155 else if (inspec[0] == '!') {
156 fp = popen(inspec+1, "r");
157 if (fp == NULL) {
158 sprintf(errmsg, "cannot start command '%s'", inspec);
159 error(SYSTEM, errmsg);
160 }
161 } else if ((fp = fopen(inspec, "r")) == NULL) {
162 sprintf(errmsg, "cannot open file '%s'", inspec);
163 error(SYSTEM, errmsg);
164 }
165 #ifdef getc_unlocked
166 flockfile(fp);
167 #endif
168 if (dtype != DTascii)
169 SET_FILE_BINARY(fp); /* doesn't really work */
170 if (!dtype | !ncols) { /* expecting header? */
171 char *err = cm_getheader(&dtype, &nrows, &ncols, fp);
172 if (err != NULL)
173 error(USER, err);
174 if (ncols <= 0)
175 error(USER, "unspecified number of columns");
176 }
177 switch (dtype) {
178 case DTascii:
179 case DTfloat:
180 case DTdouble:
181 break;
182 default:
183 error(USER, "unexpected data type in cm_load()");
184 }
185 if (nrows <= 0) { /* don't know length? */
186 int guessrows = 147; /* usually big enough */
187 if ((dtype != DTascii) & (fp != stdin) & (inspec[0] != '!')) {
188 long startpos = ftell(fp);
189 if (fseek(fp, 0L, SEEK_END) == 0) {
190 long endpos = ftell(fp);
191 long elemsiz = 3*(dtype==DTfloat ?
192 sizeof(float) : sizeof(double));
193
194 if ((endpos - startpos) % (ncols*elemsiz)) {
195 sprintf(errmsg,
196 "improper length for binary file '%s'",
197 inspec);
198 error(USER, errmsg);
199 }
200 guessrows = (endpos - startpos)/(ncols*elemsiz);
201 if (fseek(fp, startpos, SEEK_SET) < 0) {
202 sprintf(errmsg,
203 "fseek() error on file '%s'",
204 inspec);
205 error(SYSTEM, errmsg);
206 }
207 nrows = guessrows; /* we're confident */
208 }
209 }
210 cm = cm_alloc(guessrows, ncols);
211 } else
212 cm = cm_alloc(nrows, ncols);
213 if (cm == NULL) /* XXX never happens */
214 return(NULL);
215 if (dtype == DTascii) { /* read text file */
216 int maxrow = (nrows > 0 ? nrows : 32000);
217 int r, c;
218 for (r = 0; r < maxrow; r++) {
219 if (r >= cm->nrows) /* need more space? */
220 cm = cm_resize(cm, 2*cm->nrows);
221 for (c = 0; c < ncols; c++) {
222 COLORV *cv = cm_lval(cm,r,c);
223 if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3)
224 if ((nrows <= 0) & (r > 0) & !c) {
225 cm = cm_resize(cm, maxrow=r);
226 break;
227 } else
228 goto EOFerror;
229 }
230 }
231 while ((c = getc(fp)) != EOF)
232 if (!isspace(c)) {
233 sprintf(errmsg,
234 "unexpected data at end of ascii input '%s'",
235 inspec);
236 error(WARNING, errmsg);
237 break;
238 }
239 } else { /* read binary file */
240 if (sizeof(COLOR) == cm_elem_size[dtype]) {
241 int nread = 0;
242 do { /* read all we can */
243 nread += fread(cm->cmem + 3*nread,
244 sizeof(COLOR),
245 cm->nrows*cm->ncols - nread,
246 fp);
247 if (nrows <= 0) { /* unknown length */
248 if (nread == cm->nrows*cm->ncols)
249 /* need more space? */
250 cm = cm_resize(cm, 2*cm->nrows);
251 else if (nread && !(nread % cm->ncols))
252 /* seem to be done */
253 cm = cm_resize(cm, nread/cm->ncols);
254 else /* ended mid-row */
255 goto EOFerror;
256 } else if (nread < cm->nrows*cm->ncols)
257 goto EOFerror;
258 } while (nread < cm->nrows*cm->ncols);
259
260 } else if (dtype == DTdouble) {
261 double dc[3]; /* load from double */
262 COLORV *cvp = cm->cmem;
263 int n = nrows*ncols;
264
265 if (n <= 0)
266 goto not_handled;
267 while (n--) {
268 if (fread(dc, sizeof(double), 3, fp) != 3)
269 goto EOFerror;
270 copycolor(cvp, dc);
271 cvp += 3;
272 }
273 } else /* dtype == DTfloat */ {
274 float fc[3]; /* load from float */
275 COLORV *cvp = cm->cmem;
276 int n = nrows*ncols;
277
278 if (n <= 0)
279 goto not_handled;
280 while (n--) {
281 if (fread(fc, sizeof(float), 3, fp) != 3)
282 goto EOFerror;
283 copycolor(cvp, fc);
284 cvp += 3;
285 }
286 }
287 if (fgetc(fp) != EOF) {
288 sprintf(errmsg,
289 "unexpected data at end of binary input '%s'",
290 inspec);
291 error(WARNING, errmsg);
292 }
293 }
294 if (fp != stdin) {
295 if (inspec[0] != '!')
296 fclose(fp);
297 else if (pclose(fp)) {
298 sprintf(errmsg, "error running command '%s'", inspec);
299 error(WARNING, errmsg);
300 }
301 }
302 #ifdef getc_unlocked
303 else
304 funlockfile(fp);
305 #endif
306 return(cm);
307 EOFerror:
308 sprintf(errmsg, "unexpected EOF reading %s", inspec);
309 error(USER, errmsg);
310 not_handled:
311 error(INTERNAL, "unhandled data size or length in cm_load()");
312 return(NULL); /* gratis return */
313 }
314
315 /* Extract a column vector from a matrix */
316 CMATRIX *
317 cm_column(const CMATRIX *cm, int c)
318 {
319 CMATRIX *cvr;
320 int dr;
321
322 if ((c < 0) | (c >= cm->ncols))
323 error(INTERNAL, "column requested outside matrix");
324 cvr = cm_alloc(cm->nrows, 1);
325 if (cvr == NULL)
326 return(NULL);
327 for (dr = 0; dr < cm->nrows; dr++) {
328 const COLORV *sp = cm_lval(cm,dr,c);
329 COLORV *dp = cv_lval(cvr,dr);
330 dp[0] = sp[0];
331 dp[1] = sp[1];
332 dp[2] = sp[2];
333 }
334 return(cvr);
335 }
336
337 /* Scale a matrix by a single value */
338 CMATRIX *
339 cm_scale(const CMATRIX *cm1, const COLOR sca)
340 {
341 CMATRIX *cmr;
342 int dr, dc;
343
344 cmr = cm_alloc(cm1->nrows, cm1->ncols);
345 if (cmr == NULL)
346 return(NULL);
347 for (dr = 0; dr < cmr->nrows; dr++)
348 for (dc = 0; dc < cmr->ncols; dc++) {
349 const COLORV *sp = cm_lval(cm1,dr,dc);
350 COLORV *dp = cm_lval(cmr,dr,dc);
351 dp[0] = sp[0] * sca[0];
352 dp[1] = sp[1] * sca[1];
353 dp[2] = sp[2] * sca[2];
354 }
355 return(cmr);
356 }
357
358 /* Multiply two matrices (or a matrix and a vector) and allocate the result */
359 CMATRIX *
360 cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
361 {
362 char *rowcheck=NULL, *colcheck=NULL;
363 CMATRIX *cmr;
364 int dr, dc, i;
365
366 if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
367 error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
368 cmr = cm_alloc(cm1->nrows, cm2->ncols);
369 if (cmr == NULL)
370 return(NULL);
371 /* optimization: check for zero rows & cols */
372 if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
373 static const COLOR czero;
374 rowcheck = (char *)calloc(cmr->nrows, 1);
375 for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
376 for (dc = cm1->ncols; dc--; )
377 if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
378 rowcheck[dr] = 1;
379 break;
380 }
381 colcheck = (char *)calloc(cmr->ncols, 1);
382 for (dc = cm2->ncols*(colcheck != NULL); dc--; )
383 for (dr = cm2->nrows; dr--; )
384 if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
385 colcheck[dc] = 1;
386 break;
387 }
388 }
389 for (dr = 0; dr < cmr->nrows; dr++)
390 for (dc = 0; dc < cmr->ncols; dc++) {
391 COLORV *dp = cm_lval(cmr,dr,dc);
392 double res[3];
393 dp[0] = dp[1] = dp[2] = 0;
394 if (rowcheck != NULL && !rowcheck[dr])
395 continue;
396 if (colcheck != NULL && !colcheck[dc])
397 continue;
398 res[0] = res[1] = res[2] = 0;
399 for (i = 0; i < cm1->ncols; i++) {
400 const COLORV *cp1 = cm_lval(cm1,dr,i);
401 const COLORV *cp2 = cm_lval(cm2,i,dc);
402 res[0] += cp1[0] * cp2[0];
403 res[1] += cp1[1] * cp2[1];
404 res[2] += cp1[2] * cp2[2];
405 }
406 copycolor(dp, res);
407 }
408 if (rowcheck != NULL) free(rowcheck);
409 if (colcheck != NULL) free(colcheck);
410 return(cmr);
411 }
412
413 /* write out matrix to file (precede by resolution string if picture) */
414 int
415 cm_write(const CMATRIX *cm, int dtype, FILE *fp)
416 {
417 static const char tabEOL[2] = {'\t','\n'};
418 const COLORV *mp = cm->cmem;
419 int r, c;
420
421 switch (dtype) {
422 case DTascii:
423 for (r = 0; r < cm->nrows; r++)
424 for (c = 0; c < cm->ncols; c++, mp += 3)
425 fprintf(fp, "%.6e %.6e %.6e%c",
426 mp[0], mp[1], mp[2],
427 tabEOL[c >= cm->ncols-1]);
428 break;
429 case DTfloat:
430 case DTdouble:
431 if (sizeof(COLOR) == cm_elem_size[dtype]) {
432 r = cm->ncols*cm->nrows;
433 while (r > 0) {
434 c = fwrite(mp, sizeof(COLOR), r, fp);
435 if (c <= 0)
436 return(0);
437 mp += 3*c;
438 r -= c;
439 }
440 } else if (dtype == DTdouble) {
441 double dc[3];
442 r = cm->ncols*cm->nrows;
443 while (r--) {
444 copycolor(dc, mp);
445 if (fwrite(dc, sizeof(double), 3, fp) != 3)
446 return(0);
447 mp += 3;
448 }
449 } else /* dtype == DTfloat */ {
450 float fc[3];
451 r = cm->ncols*cm->nrows;
452 while (r--) {
453 copycolor(fc, mp);
454 if (fwrite(fc, sizeof(float), 3, fp) != 3)
455 return(0);
456 mp += 3;
457 }
458 }
459 break;
460 case DTrgbe:
461 case DTxyze:
462 fprtresolu(cm->ncols, cm->nrows, fp);
463 for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols)
464 if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0)
465 return(0);
466 break;
467 default:
468 fputs("Unsupported data type in cm_write()!\n", stderr);
469 return(0);
470 }
471 return(fflush(fp) == 0);
472 }
