root/radiance/ray/src/util/cmatrix.c
Revision: 2.21
Committed: Mon Aug 12 18:28:37 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.20: +27 -39 lines
Made error checking more consistent and eliminated unused function call
2 static const char RCSid[] = "$Id: cmatrix.c,v 2.20 2018/08/02 18:33:49 greg Exp $";
5 * Color matrix routines.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "platform.h"
12 #include "standard.h"
13 #include "cmatrix.h"
14 #include "platform.h"
15 #include "paths.h"
16 #include "resolu.h"
17
18 const char *cm_fmt_id[] = {
19 "unknown", "ascii", COLRFMT, CIEFMT,
20 "float", "double"
21 };
22
23 const int cm_elem_size[] = {
24 0, 0, 4, 4, 3*sizeof(float), 3*sizeof(double)
25 };
26
27 /* Allocate a color coefficient matrix */
28 CMATRIX *
29 cm_alloc(int nrows, int ncols)
30 {
31 CMATRIX *cm;
32
33 if ((nrows <= 0) | (ncols <= 0))
34 error(USER, "attempt to create empty matrix");
35 cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
36 sizeof(COLOR)*(nrows*ncols - 1));
37 if (!cm)
38 error(SYSTEM, "out of memory in cm_alloc()");
39 cm->nrows = nrows;
40 cm->ncols = ncols;
41 return(cm);
42 }
43
44 static void
45 adjacent_ra_sizes(size_t bounds[2], size_t target)
46 {
47 bounds[0] = 0; bounds[1] = 2048;
48 while (bounds[1] < target) {
49 bounds[0] = bounds[1];
50 bounds[1] += bounds[1]>>1;
51 }
52 }
53
54 /* Resize color coefficient matrix */
55 CMATRIX *
56 cm_resize(CMATRIX *cm, int nrows)
57 {
58 size_t old_size, new_size, ra_bounds[2];
59
60 if (!cm)
61 return(NULL);
62 if (nrows == cm->nrows)
63 return(cm);
64 if (nrows <= 0) {
65 cm_free(cm);
66 return(NULL);
67 }
68 old_size = sizeof(CMATRIX) + sizeof(COLOR)*(cm->nrows*cm->ncols - 1);
69 adjacent_ra_sizes(ra_bounds, old_size);
70 new_size = sizeof(CMATRIX) + sizeof(COLOR)*(nrows*cm->ncols - 1);
71 if (nrows < cm->nrows ? new_size <= ra_bounds[0] :
72 new_size > ra_bounds[1]) {
73 adjacent_ra_sizes(ra_bounds, new_size);
74 cm = (CMATRIX *)realloc(cm, ra_bounds[1]);
75 if (!cm)
76 error(SYSTEM, "out of memory in cm_resize()");
77 }
78 cm->nrows = nrows;
79 return(cm);
80 }
81
82 typedef struct {
83 int dtype; /* data type */
84 int nrows, ncols; /* matrix size */
85 char *err; /* error message */
86 } CMINFO; /* header info record */
87
88 static int
89 get_cminfo(char *s, void *p)
90 {
91 CMINFO *ip = (CMINFO *)p;
92 char fmt[MAXFMTLEN];
93 int i;
94
95 if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) {
96 ip->err = "unexpected # components (must be 3)";
97 return(-1);
98 }
99 if (!strncmp(s, "NROWS=", 6)) {
100 ip->nrows = atoi(s+6);
101 return(0);
102 }
103 if (!strncmp(s, "NCOLS=", 6)) {
104 ip->ncols = atoi(s+6);
105 return(0);
106 }
107 if (!formatval(fmt, s))
108 return(0);
109 for (i = 1; i < DTend; i++)
110 if (!strcmp(fmt, cm_fmt_id[i]))
111 ip->dtype = i;
112 return(0);
113 }
114
115 /* Load header to obtain/check data type and number of columns */
116 char *
117 cm_getheader(int *dt, int *nr, int *nc, FILE *fp)
118 {
119 CMINFO cmi;
120 /* read header */
121 cmi.dtype = DTfromHeader;
122 cmi.nrows = cmi.ncols = 0;
123 cmi.err = "unexpected EOF in header";
124 if (getheader(fp, get_cminfo, &cmi) < 0)
125 return(cmi.err);
126 if (dt) { /* get/check data type? */
127 if (cmi.dtype == DTfromHeader) {
128 if (*dt == DTfromHeader)
129 return("missing/unknown data format in header");
130 } else if (*dt == DTfromHeader)
131 *dt = cmi.dtype;
132 else if (*dt != cmi.dtype)
133 return("unexpected data format in header");
134 }
135 if (nr) { /* get/check #rows? */
136 if (*nr <= 0)
137 *nr = cmi.nrows;
138 else if ((cmi.nrows > 0) & (*nr != cmi.nrows))
139 return("unexpected row count in header");
140 }
141 if (nc) { /* get/check #columns? */
142 if (*nc <= 0)
143 *nc = cmi.ncols;
144 else if ((cmi.ncols > 0) & (*nc != cmi.ncols))
145 return("unexpected column count in header");
146 }
147 return(NULL);
148 }
149
150 /* Allocate and load a matrix from the given input (or stdin if NULL) */
151 CMATRIX *
152 cm_load(const char *inspec, int nrows, int ncols, int dtype)
153 {
154 const int ROWINC = 2048;
155 FILE *fp = stdin;
156 CMATRIX *cm;
157
158 if (!inspec)
159 inspec = "<stdin>";
160 else if (inspec[0] == '!') {
161 fp = popen(inspec+1, "r");
162 if (!fp) {
163 sprintf(errmsg, "cannot start command '%s'", inspec);
164 error(SYSTEM, errmsg);
165 }
166 } else if (!(fp = fopen(inspec, "r"))) {
167 sprintf(errmsg, "cannot open file '%s'", inspec);
168 error(SYSTEM, errmsg);
169 }
170 #ifdef getc_unlocked
171 flockfile(fp);
172 #endif
173 if (dtype != DTascii)
174 SET_FILE_BINARY(fp); /* doesn't really work */
175 if (!dtype | !ncols) { /* expecting header? */
176 char *err = cm_getheader(&dtype, &nrows, &ncols, fp);
177 if (err)
178 error(USER, err);
179 if (ncols <= 0)
180 error(USER, "unspecified number of columns");
181 }
182 switch (dtype) {
183 case DTascii:
184 case DTfloat:
185 case DTdouble:
186 break;
187 default:
188 error(USER, "unexpected data type in cm_load()");
189 }
190 if (nrows <= 0) { /* don't know length? */
191 int guessrows = 147; /* usually big enough */
192 if ((dtype != DTascii) & (fp != stdin) & (inspec[0] != '!')) {
193 long startpos = ftell(fp);
194 if (fseek(fp, 0L, SEEK_END) == 0) {
195 long endpos = ftell(fp);
196 long elemsiz = 3*(dtype==DTfloat ?
197 sizeof(float) : sizeof(double));
198
199 if ((endpos - startpos) % (ncols*elemsiz)) {
200 sprintf(errmsg,
201 "improper length for binary file '%s'",
202 inspec);
203 error(USER, errmsg);
204 }
205 guessrows = (endpos - startpos)/(ncols*elemsiz);
206 if (fseek(fp, startpos, SEEK_SET) < 0) {
207 sprintf(errmsg,
208 "fseek() error on file '%s'",
209 inspec);
210 error(SYSTEM, errmsg);
211 }
212 nrows = guessrows; /* we're confident */
213 }
214 }
215 cm = cm_alloc(guessrows, ncols);
216 } else
217 cm = cm_alloc(nrows, ncols);
218 if (!cm) /* XXX never happens */
219 return(NULL);
220 if (dtype == DTascii) { /* read text file */
221 int maxrow = (nrows > 0 ? nrows : 32000);
222 int r, c;
223 for (r = 0; r < maxrow; r++) {
224 if (r >= cm->nrows) /* need more space? */
225 cm = cm_resize(cm, cm->nrows+ROWINC);
226 for (c = 0; c < ncols; c++) {
227 COLORV *cv = cm_lval(cm,r,c);
228 if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) {
229 if ((nrows <= 0) & (r > 0) & !c) {
230 cm = cm_resize(cm, maxrow=r);
231 break;
232 } else
233 goto EOFerror;
234 }
235 }
236 }
237 while ((c = getc(fp)) != EOF)
238 if (!isspace(c)) {
239 sprintf(errmsg,
240 "unexpected data at end of ascii input '%s'",
241 inspec);
242 error(WARNING, errmsg);
243 break;
244 }
245 } else { /* read binary file */
246 if (sizeof(COLOR) == cm_elem_size[dtype]) {
247 int nread = 0;
248 do { /* read all we can */
249 nread += getbinary(cm->cmem + 3*nread,
250 sizeof(COLOR),
251 cm->nrows*cm->ncols - nread,
252 fp);
253 if (nrows <= 0) { /* unknown length */
254 if (nread == cm->nrows*cm->ncols)
255 /* need more space? */
256 cm = cm_resize(cm, cm->nrows+ROWINC);
257 else if (nread && !(nread % cm->ncols))
258 /* seem to be done */
259 cm = cm_resize(cm, nread/cm->ncols);
260 else /* ended mid-row */
261 goto EOFerror;
262 } else if (nread < cm->nrows*cm->ncols)
263 goto EOFerror;
264 } while (nread < cm->nrows*cm->ncols);
265
266 } else if (dtype == DTdouble) {
267 double dc[3]; /* load from double */
268 COLORV *cvp = cm->cmem;
269 int n = nrows*ncols;
270
271 if (n <= 0)
272 goto not_handled;
273 while (n--) {
274 if (getbinary(dc, sizeof(double), 3, fp) != 3)
275 goto EOFerror;
276 copycolor(cvp, dc);
277 cvp += 3;
278 }
279 } else /* dtype == DTfloat */ {
280 float fc[3]; /* load from float */
281 COLORV *cvp = cm->cmem;
282 int n = nrows*ncols;
283
284 if (n <= 0)
285 goto not_handled;
286 while (n--) {
287 if (getbinary(fc, sizeof(float), 3, fp) != 3)
288 goto EOFerror;
289 copycolor(cvp, fc);
290 cvp += 3;
291 }
292 }
293 if (fgetc(fp) != EOF) {
294 sprintf(errmsg,
295 "unexpected data at end of binary input '%s'",
296 inspec);
297 error(WARNING, errmsg);
298 }
299 }
300 if (fp != stdin) {
301 if (inspec[0] != '!')
302 fclose(fp);
303 else if (pclose(fp)) {
304 sprintf(errmsg, "error running command '%s'", inspec);
305 error(WARNING, errmsg);
306 }
307 }
308 #ifdef getc_unlocked
309 else
310 funlockfile(fp);
311 #endif
312 return(cm);
313 EOFerror:
314 sprintf(errmsg, "unexpected EOF reading %s", inspec);
315 error(USER, errmsg);
316 not_handled:
317 error(INTERNAL, "unhandled data size or length in cm_load()");
318 return(NULL); /* gratis return */
319 }
320
321 /* Extract a column vector from a matrix */
322 CMATRIX *
323 cm_column(const CMATRIX *cm, int c)
324 {
325 CMATRIX *cvr;
326 int dr;
327
328 if (!cm)
329 return(NULL);
330 if ((c < 0) | (c >= cm->ncols))
331 error(INTERNAL, "column requested outside matrix");
332 cvr = cm_alloc(cm->nrows, 1);
333 if (!cvr)
334 return(NULL);
335 for (dr = 0; dr < cm->nrows; dr++) {
336 const COLORV *sp = cm_lval(cm,dr,c);
337 COLORV *dp = cv_lval(cvr,dr);
338 dp[0] = sp[0];
339 dp[1] = sp[1];
340 dp[2] = sp[2];
341 }
342 return(cvr);
343 }
344
345 /* Multiply two matrices (or a matrix and a vector) and allocate the result */
346 CMATRIX *
347 cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
348 {
349 char *rowcheck=NULL, *colcheck=NULL;
350 CMATRIX *cmr;
351 int dr, dc, i;
352
353 if (!cm1 | !cm2)
354 return(NULL);
355 if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
356 error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
357 cmr = cm_alloc(cm1->nrows, cm2->ncols);
358 if (!cmr)
359 return(NULL);
360 /* optimization: check for zero rows & cols */
361 if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
362 static const COLOR czero;
363 rowcheck = (char *)calloc(cmr->nrows, 1);
364 for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
365 for (dc = cm1->ncols; dc--; )
366 if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
367 rowcheck[dr] = 1;
368 break;
369 }
370 colcheck = (char *)calloc(cmr->ncols, 1);
371 for (dc = cm2->ncols*(colcheck != NULL); dc--; )
372 for (dr = cm2->nrows; dr--; )
373 if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
374 colcheck[dc] = 1;
375 break;
376 }
377 }
378 for (dr = 0; dr < cmr->nrows; dr++)
379 for (dc = 0; dc < cmr->ncols; dc++) {
380 COLORV *dp = cm_lval(cmr,dr,dc);
381 double res[3];
382 dp[0] = dp[1] = dp[2] = 0;
383 if (rowcheck && !rowcheck[dr])
384 continue;
385 if (colcheck && !colcheck[dc])
386 continue;
387 res[0] = res[1] = res[2] = 0;
388 for (i = 0; i < cm1->ncols; i++) {
389 const COLORV *cp1 = cm_lval(cm1,dr,i);
390 const COLORV *cp2 = cm_lval(cm2,i,dc);
391 res[0] += (double)cp1[0] * cp2[0];
392 res[1] += (double)cp1[1] * cp2[1];
393 res[2] += (double)cp1[2] * cp2[2];
394 }
395 copycolor(dp, res);
396 }
397 if (rowcheck) free(rowcheck);
398 if (colcheck) free(colcheck);
399 return(cmr);
400 }
401
402 /* write out matrix to file (precede by resolution string if picture) */
403 int
404 cm_write(const CMATRIX *cm, int dtype, FILE *fp)
405 {
406 static const char tabEOL[2] = {'\t','\n'};
407 const COLORV *mp;
408 int r, c;
409
410 if (!cm)
411 return(0);
412 mp = cm->cmem;
413 switch (dtype) {
414 case DTascii:
415 for (r = 0; r < cm->nrows; r++)
416 for (c = 0; c < cm->ncols; c++, mp += 3)
417 fprintf(fp, "%.6e %.6e %.6e%c",
418 mp[0], mp[1], mp[2],
419 tabEOL[c >= cm->ncols-1]);
420 break;
421 case DTfloat:
422 case DTdouble:
423 if (sizeof(COLOR) == cm_elem_size[dtype]) {
424 r = cm->ncols*cm->nrows;
425 while (r > 0) {
426 c = putbinary(mp, sizeof(COLOR), r, fp);
427 if (c <= 0)
428 return(0);
429 mp += 3*c;
430 r -= c;
431 }
432 } else if (dtype == DTdouble) {
433 double dc[3];
434 r = cm->ncols*cm->nrows;
435 while (r--) {
436 copycolor(dc, mp);
437 if (putbinary(dc, sizeof(double), 3, fp) != 3)
438 return(0);
439 mp += 3;
440 }
441 } else /* dtype == DTfloat */ {
442 float fc[3];
443 r = cm->ncols*cm->nrows;
444 while (r--) {
445 copycolor(fc, mp);
446 if (putbinary(fc, sizeof(float), 3, fp) != 3)
447 return(0);
448 mp += 3;
449 }
450 }
451 break;
452 case DTrgbe:
453 case DTxyze:
454 fprtresolu(cm->ncols, cm->nrows, fp);
455 for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols)
456 if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0)
457 return(0);
458 break;
459 default:
460 fputs("Unsupported data type in cm_write()!\n", stderr);
461 return(0);
462 }
463 return(fflush(fp) == 0);
464 }
