1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: cmatrix.c,v 2.33 2021/01/22 16:19:15 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Color matrix routines. |
6 |
7 |
* G. Ward |
8 |
9 |
10 |
#include <ctype.h> |
11 |
#include "platform.h" |
12 |
#include "standard.h" |
13 |
#include "cmatrix.h" |
14 |
15 |
#include "paths.h" |
16 |
#include "resolu.h" |
17 |
18 |
const char stdin_name[] = "<stdin>"; |
19 |
20 |
const char *cm_fmt_id[] = { |
21 |
"unknown", COLRFMT, CIEFMT, |
22 |
"float", "ascii", "double" |
23 |
24 |
25 |
const int cm_elem_size[] = { |
26 |
0, 4, 4, 3*sizeof(float), 0, 3*sizeof(double) |
27 |
28 |
29 |
/* Allocate a color coefficient matrix */ |
30 |
CMATRIX * |
31 |
cm_alloc(int nrows, int ncols) |
32 |
33 |
CMATRIX *cm; |
34 |
35 |
if ((nrows <= 0) | (ncols <= 0)) |
36 |
error(USER, "attempt to create empty matrix"); |
37 |
cm = (CMATRIX *)malloc(sizeof(CMATRIX) + |
38 |
sizeof(COLOR)*((size_t)nrows*ncols - 1)); |
39 |
if (!cm) |
40 |
error(SYSTEM, "out of memory in cm_alloc()"); |
41 |
cm->nrows = nrows; |
42 |
cm->ncols = ncols; |
43 |
return(cm); |
44 |
45 |
46 |
static void |
47 |
adjacent_ra_sizes(size_t bounds[2], size_t target) |
48 |
49 |
bounds[0] = 0; bounds[1] = 2048; |
50 |
while (bounds[1] < target) { |
51 |
bounds[0] = bounds[1]; |
52 |
bounds[1] += bounds[1]>>1; |
53 |
54 |
55 |
56 |
/* Resize color coefficient matrix */ |
57 |
CMATRIX * |
58 |
cm_resize(CMATRIX *cm, int nrows) |
59 |
60 |
size_t old_size, new_size, ra_bounds[2]; |
61 |
62 |
if (!cm) |
63 |
return(NULL); |
64 |
if (nrows == cm->nrows) |
65 |
return(cm); |
66 |
if (nrows <= 0) { |
67 |
cm_free(cm); |
68 |
return(NULL); |
69 |
70 |
old_size = sizeof(CMATRIX) + sizeof(COLOR)*((size_t)cm->nrows*cm->ncols - 1); |
71 |
adjacent_ra_sizes(ra_bounds, old_size); |
72 |
new_size = sizeof(CMATRIX) + sizeof(COLOR)*((size_t)nrows*cm->ncols - 1); |
73 |
if (nrows < cm->nrows ? new_size <= ra_bounds[0] : |
74 |
new_size > ra_bounds[1]) { |
75 |
adjacent_ra_sizes(ra_bounds, new_size); |
76 |
cm = (CMATRIX *)realloc(cm, ra_bounds[1]); |
77 |
if (!cm) |
78 |
error(SYSTEM, "out of memory in cm_resize()"); |
79 |
80 |
81 |
return(cm); |
82 |
83 |
84 |
typedef struct { |
85 |
int dtype; /* data type */ |
86 |
int need2swap; /* need byte swap? */ |
87 |
int nrows, ncols; /* matrix size */ |
88 |
COLOR expos; /* exposure value */ |
89 |
char *err; /* error message */ |
90 |
} CMINFO; /* header info record */ |
91 |
92 |
static int |
93 |
get_cminfo(char *s, void *p) |
94 |
95 |
CMINFO *ip = (CMINFO *)p; |
96 |
char fmt[MAXFMTLEN]; |
97 |
int i; |
98 |
99 |
if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) { |
100 |
ip->err = "unexpected # components (must be 3)"; |
101 |
return(-1); |
102 |
103 |
if (!strncmp(s, "NROWS=", 6)) { |
104 |
ip->nrows = atoi(s+6); |
105 |
return(0); |
106 |
107 |
if (!strncmp(s, "NCOLS=", 6)) { |
108 |
ip->ncols = atoi(s+6); |
109 |
return(0); |
110 |
111 |
if ((i = isbigendian(s)) >= 0) { |
112 |
ip->need2swap = (nativebigendian() != i); |
113 |
return(0); |
114 |
115 |
if (isexpos(s)) { |
116 |
double d = exposval(s); |
117 |
scalecolor(ip->expos, d); |
118 |
return(0); |
119 |
120 |
if (iscolcor(s)) { |
121 |
COLOR ctmp; |
122 |
colcorval(ctmp, s); |
123 |
multcolor(ip->expos, ctmp); |
124 |
return(0); |
125 |
126 |
if (!formatval(fmt, s)) |
127 |
return(0); |
128 |
for (i = 1; i < DTend; i++) |
129 |
if (!strcmp(fmt, cm_fmt_id[i])) |
130 |
ip->dtype = i; |
131 |
return(0); |
132 |
133 |
134 |
/* Load header to obtain/check data type and number of columns */ |
135 |
char * |
136 |
cm_getheader(int *dt, int *nr, int *nc, int *swp, COLOR scale, FILE *fp) |
137 |
138 |
CMINFO cmi; |
139 |
/* read header */ |
140 |
cmi.dtype = DTfromHeader; |
141 |
cmi.need2swap = 0; |
142 |
cmi.expos[0] = cmi.expos[1] = cmi.expos[2] = 1.f; |
143 |
cmi.nrows = cmi.ncols = 0; |
144 |
cmi.err = "unexpected EOF in header"; |
145 |
if (getheader(fp, get_cminfo, &cmi) < 0) |
146 |
return(cmi.err); |
147 |
if (dt) { /* get/check data type? */ |
148 |
if (cmi.dtype == DTfromHeader) { |
149 |
if (*dt == DTfromHeader) |
150 |
return("missing/unknown data format in header"); |
151 |
} else if (*dt == DTfromHeader) |
152 |
*dt = cmi.dtype; |
153 |
else if (*dt != cmi.dtype) |
154 |
return("unexpected data format in header"); |
155 |
156 |
if (nr) { /* get/check #rows? */ |
157 |
if (*nr <= 0) |
158 |
*nr = cmi.nrows; |
159 |
else if ((cmi.nrows > 0) & (*nr != cmi.nrows)) |
160 |
return("unexpected row count in header"); |
161 |
162 |
if (nc) { /* get/check #columns? */ |
163 |
if (*nc <= 0) |
164 |
*nc = cmi.ncols; |
165 |
else if ((cmi.ncols > 0) & (*nc != cmi.ncols)) |
166 |
return("unexpected column count in header"); |
167 |
168 |
if (swp) /* get/check swap? */ |
169 |
*swp = cmi.need2swap; |
170 |
if (scale) { /* transfer exposure comp. */ |
171 |
scale[0] = 1.f/cmi.expos[0]; |
172 |
scale[1] = 1.f/cmi.expos[1]; |
173 |
scale[2] = 1.f/cmi.expos[2]; |
174 |
175 |
return(NULL); |
176 |
177 |
178 |
/* Allocate and load image data into matrix */ |
179 |
static CMATRIX * |
180 |
cm_load_rgbe(FILE *fp, int nrows, int ncols, COLOR scale) |
181 |
182 |
int doscale; |
183 |
CMATRIX *cm; |
184 |
COLORV *mp; |
185 |
/* header already loaded */ |
186 |
cm = cm_alloc(nrows, ncols); |
187 |
if (!cm) |
188 |
return(NULL); |
189 |
doscale = (scale[0] < .99) | (scale[0] > 1.01) | |
190 |
(scale[1] < .99) | (scale[1] > 1.01) | |
191 |
(scale[2] < .99) | (scale[2] > 1.01) ; |
192 |
mp = cm->cmem; |
193 |
while (nrows--) { |
194 |
if (freadscan((COLOR *)mp, ncols, fp) < 0) { |
195 |
error(USER, "error reading color picture as matrix"); |
196 |
cm_free(cm); |
197 |
return(NULL); |
198 |
199 |
if (doscale) { |
200 |
int i = ncols; |
201 |
while (i--) { |
202 |
*mp++ *= scale[0]; |
203 |
*mp++ *= scale[1]; |
204 |
*mp++ *= scale[2]; |
205 |
206 |
} else |
207 |
mp += 3*ncols; |
208 |
} /* caller closes stream */ |
209 |
return(cm); |
210 |
211 |
212 |
/* Allocate and load a matrix from the given input (or stdin if NULL) */ |
213 |
CMATRIX * |
214 |
cm_load(const char *inspec, int nrows, int ncols, int dtype) |
215 |
216 |
const int ROWINC = 2048; |
217 |
int swap = 0; |
218 |
FILE *fp; |
219 |
COLOR scale; |
220 |
CMATRIX *cm; |
221 |
222 |
if (!inspec) |
223 |
inspec = stdin_name; |
224 |
else if (!*inspec) |
225 |
return(NULL); |
226 |
if (inspec == stdin_name) { /* reading from stdin? */ |
227 |
fp = stdin; |
228 |
} else if (inspec[0] == '!') { |
229 |
fp = popen(inspec+1, "r"); |
230 |
if (!fp) { |
231 |
sprintf(errmsg, "cannot start command '%s'", inspec); |
232 |
error(SYSTEM, errmsg); |
233 |
234 |
} else if (!(fp = fopen(inspec, "r"))) { |
235 |
sprintf(errmsg, "cannot open file '%s'", inspec); |
236 |
237 |
238 |
#ifdef getc_unlocked |
239 |
flockfile(fp); |
240 |
#endif |
241 |
if (dtype != DTascii) |
242 |
SET_FILE_BINARY(fp); /* doesn't really work */ |
243 |
if (!dtype | !nrows | !ncols) { /* expecting header? */ |
244 |
char *err = cm_getheader(&dtype, &nrows, &ncols, &swap, scale, fp); |
245 |
if (err) |
246 |
error(USER, err); |
247 |
248 |
if (!nrows | !ncols && !fscnresolu(&ncols, &nrows, fp)) |
249 |
error(USER, "unspecified matrix size"); |
250 |
switch (dtype) { |
251 |
case DTascii: |
252 |
case DTfloat: |
253 |
case DTdouble: |
254 |
break; |
255 |
case DTrgbe: |
256 |
case DTxyze: |
257 |
cm = cm_load_rgbe(fp, nrows, ncols, scale); |
258 |
goto cleanup; |
259 |
default: |
260 |
error(USER, "unexpected data type in cm_load()"); |
261 |
262 |
if (nrows <= 0) { /* don't know length? */ |
263 |
int guessrows = 147; /* usually big enough */ |
264 |
if (cm_elem_size[dtype] && (fp != stdin) & (inspec[0] != '!')) { |
265 |
long startpos = ftell(fp); |
266 |
if (fseek(fp, 0L, SEEK_END) == 0) { |
267 |
long rowsiz = (long)ncols*cm_elem_size[dtype]; |
268 |
long endpos = ftell(fp); |
269 |
270 |
if ((endpos - startpos) % rowsiz) { |
271 |
sprintf(errmsg, |
272 |
"improper length for binary file '%s'", |
273 |
inspec); |
274 |
error(USER, errmsg); |
275 |
276 |
guessrows = (endpos - startpos)/rowsiz; |
277 |
if (fseek(fp, startpos, SEEK_SET) < 0) { |
278 |
sprintf(errmsg, |
279 |
"fseek() error on file '%s'", |
280 |
inspec); |
281 |
282 |
283 |
nrows = guessrows; /* we're confident */ |
284 |
285 |
286 |
cm = cm_alloc(guessrows, ncols); |
287 |
} else |
288 |
289 |
if (!cm) /* XXX never happens */ |
290 |
return(NULL); |
291 |
if (dtype == DTascii) { /* read text file */ |
292 |
int maxrow = (nrows > 0 ? nrows : 32000); |
293 |
int r, c; |
294 |
for (r = 0; r < maxrow; r++) { |
295 |
if (r >= cm->nrows) /* need more space? */ |
296 |
cm = cm_resize(cm, cm->nrows+ROWINC); |
297 |
for (c = 0; c < ncols; c++) { |
298 |
COLORV *cv = cm_lval(cm,r,c); |
299 |
if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) { |
300 |
if ((nrows <= 0) & (r > 0) & !c) { |
301 |
cm = cm_resize(cm, maxrow=r); |
302 |
break; |
303 |
} else |
304 |
goto EOFerror; |
305 |
306 |
307 |
308 |
while ((c = getc(fp)) != EOF) |
309 |
if (!isspace(c)) { |
310 |
sprintf(errmsg, |
311 |
"unexpected data at end of ascii input '%s'", |
312 |
inspec); |
313 |
error(WARNING, errmsg); |
314 |
break; |
315 |
316 |
} else { /* read binary file */ |
317 |
if (sizeof(COLOR) == cm_elem_size[dtype]) { |
318 |
size_t nread = 0; |
319 |
do { /* read all we can */ |
320 |
nread += getbinary(cm->cmem + 3*nread, |
321 |
sizeof(COLOR), |
322 |
(size_t)cm->nrows*cm->ncols - nread, |
323 |
fp); |
324 |
if (nrows <= 0) { /* unknown length */ |
325 |
if (nread == (size_t)cm->nrows*cm->ncols) |
326 |
327 |
328 |
else if (nread && !(nread % cm->ncols)) |
329 |
/* seem to be done */ |
330 |
cm = cm_resize(cm, nread/cm->ncols); |
331 |
else /* ended mid-row */ |
332 |
goto EOFerror; |
333 |
} else if (nread < (size_t)cm->nrows*cm->ncols) |
334 |
goto EOFerror; |
335 |
} while (nread < (size_t)cm->nrows*cm->ncols); |
336 |
337 |
if (swap) { |
338 |
if (sizeof(COLORV) == 4) |
339 |
swap32((char *)cm->cmem, |
340 |
3*(size_t)cm->nrows*cm->ncols); |
341 |
else /* sizeof(COLORV) == 8 */ |
342 |
swap64((char *)cm->cmem, |
343 |
344 |
345 |
} else if (dtype == DTdouble) { |
346 |
double dc[3]; /* load from double */ |
347 |
COLORV *cvp = cm->cmem; |
348 |
size_t n = (size_t)nrows*ncols; |
349 |
350 |
if (n <= 0) |
351 |
goto not_handled; |
352 |
while (n--) { |
353 |
if (getbinary(dc, sizeof(double), 3, fp) != 3) |
354 |
goto EOFerror; |
355 |
if (swap) swap64((char *)dc, 3); |
356 |
copycolor(cvp, dc); |
357 |
cvp += 3; |
358 |
359 |
} else /* dtype == DTfloat */ { |
360 |
float fc[3]; /* load from float */ |
361 |
362 |
363 |
364 |
if (n <= 0) |
365 |
goto not_handled; |
366 |
while (n--) { |
367 |
if (getbinary(fc, sizeof(float), 3, fp) != 3) |
368 |
goto EOFerror; |
369 |
if (swap) swap32((char *)fc, 3); |
370 |
copycolor(cvp, fc); |
371 |
cvp += 3; |
372 |
373 |
374 |
if (fgetc(fp) != EOF) { |
375 |
sprintf(errmsg, |
376 |
"unexpected data at end of binary input '%s'", |
377 |
inspec); |
378 |
379 |
380 |
381 |
cleanup: |
382 |
if (fp != stdin) { |
383 |
if (inspec[0] != '!') |
384 |
fclose(fp); |
385 |
else if (pclose(fp)) { |
386 |
sprintf(errmsg, "error running command '%s'", inspec); |
387 |
388 |
389 |
390 |
391 |
else |
392 |
funlockfile(fp); |
393 |
#endif |
394 |
return(cm); |
395 |
EOFerror: |
396 |
sprintf(errmsg, "unexpected EOF reading %s", inspec); |
397 |
398 |
return(NULL); |
399 |
not_handled: |
400 |
error(INTERNAL, "unhandled data size or length in cm_load()"); |
401 |
return(NULL); /* gratis return */ |
402 |
403 |
404 |
/* Extract a column vector from a matrix */ |
405 |
CMATRIX * |
406 |
cm_column(const CMATRIX *cm, int c) |
407 |
408 |
CMATRIX *cvr; |
409 |
int dr; |
410 |
411 |
if (!cm) |
412 |
return(NULL); |
413 |
if ((c < 0) | (c >= cm->ncols)) |
414 |
error(INTERNAL, "column requested outside matrix"); |
415 |
cvr = cm_alloc(cm->nrows, 1); |
416 |
if (!cvr) |
417 |
return(NULL); |
418 |
for (dr = 0; dr < cm->nrows; dr++) { |
419 |
const COLORV *sp = cm_lval(cm,dr,c); |
420 |
COLORV *dp = cv_lval(cvr,dr); |
421 |
dp[0] = sp[0]; |
422 |
dp[1] = sp[1]; |
423 |
dp[2] = sp[2]; |
424 |
425 |
return(cvr); |
426 |
427 |
428 |
/* Multiply two matrices (or a matrix and a vector) and allocate the result */ |
429 |
CMATRIX * |
430 |
cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2) |
431 |
432 |
char *rowcheck=NULL, *colcheck=NULL; |
433 |
CMATRIX *cmr; |
434 |
int dr, dc, i; |
435 |
436 |
if (!cm1 | !cm2) |
437 |
return(NULL); |
438 |
if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows)) |
439 |
error(INTERNAL, "matrix dimension mismatch in cm_multiply()"); |
440 |
cmr = cm_alloc(cm1->nrows, cm2->ncols); |
441 |
if (!cmr) |
442 |
return(NULL); |
443 |
/* optimization: check for zero rows & cols */ |
444 |
if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) { |
445 |
static const COLOR czero; |
446 |
rowcheck = (char *)calloc(cmr->nrows, 1); |
447 |
for (dr = cm1->nrows*(rowcheck != NULL); dr--; ) |
448 |
for (dc = cm1->ncols; dc--; ) |
449 |
if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) { |
450 |
rowcheck[dr] = 1; |
451 |
break; |
452 |
453 |
colcheck = (char *)calloc(cmr->ncols, 1); |
454 |
for (dc = cm2->ncols*(colcheck != NULL); dc--; ) |
455 |
for (dr = cm2->nrows; dr--; ) |
456 |
if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) { |
457 |
colcheck[dc] = 1; |
458 |
break; |
459 |
460 |
461 |
for (dr = 0; dr < cmr->nrows; dr++) |
462 |
for (dc = 0; dc < cmr->ncols; dc++) { |
463 |
COLORV *dp = cm_lval(cmr,dr,dc); |
464 |
double res[3]; |
465 |
dp[0] = dp[1] = dp[2] = 0; |
466 |
if (rowcheck && !rowcheck[dr]) |
467 |
continue; |
468 |
if (colcheck && !colcheck[dc]) |
469 |
continue; |
470 |
res[0] = res[1] = res[2] = 0; |
471 |
for (i = 0; i < cm1->ncols; i++) { |
472 |
const COLORV *cp1 = cm_lval(cm1,dr,i); |
473 |
const COLORV *cp2 = cm_lval(cm2,i,dc); |
474 |
res[0] += (double)cp1[0] * cp2[0]; |
475 |
res[1] += (double)cp1[1] * cp2[1]; |
476 |
res[2] += (double)cp1[2] * cp2[2]; |
477 |
478 |
copycolor(dp, res); |
479 |
480 |
if (rowcheck) free(rowcheck); |
481 |
if (colcheck) free(colcheck); |
482 |
return(cmr); |
483 |
484 |
485 |
/* write out matrix to file (precede by resolution string if picture) */ |
486 |
int |
487 |
cm_write(const CMATRIX *cm, int dtype, FILE *fp) |
488 |
489 |
static const char tabEOL[2] = {'\t','\n'}; |
490 |
const COLORV *mp; |
491 |
int r, c; |
492 |
size_t n, rv; |
493 |
494 |
if (!cm) |
495 |
return(0); |
496 |
mp = cm->cmem; |
497 |
switch (dtype) { |
498 |
case DTascii: |
499 |
for (r = 0; r < cm->nrows; r++) |
500 |
for (c = 0; c < cm->ncols; c++, mp += 3) |
501 |
fprintf(fp, "%.6e %.6e %.6e%c", |
502 |
mp[0], mp[1], mp[2], |
503 |
tabEOL[c >= cm->ncols-1]); |
504 |
break; |
505 |
case DTfloat: |
506 |
case DTdouble: |
507 |
508 |
n = (size_t)cm->ncols*cm->nrows; |
509 |
while (n > 0) { |
510 |
rv = fwrite(mp, sizeof(COLOR), n, fp); |
511 |
if (rv <= 0) |
512 |
return(0); |
513 |
mp += 3*rv; |
514 |
n -= rv; |
515 |
516 |
517 |
double dc[3]; |
518 |
519 |
while (n--) { |
520 |
copycolor(dc, mp); |
521 |
if (putbinary(dc, sizeof(double), 3, fp) != 3) |
522 |
return(0); |
523 |
mp += 3; |
524 |
525 |
526 |
float fc[3]; |
527 |
528 |
while (n--) { |
529 |
copycolor(fc, mp); |
530 |
if (putbinary(fc, sizeof(float), 3, fp) != 3) |
531 |
return(0); |
532 |
mp += 3; |
533 |
534 |
535 |
break; |
536 |
case DTrgbe: |
537 |
case DTxyze: |
538 |
fprtresolu(cm->ncols, cm->nrows, fp); |
539 |
for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols) |
540 |
if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0) |
541 |
return(0); |
542 |
break; |
543 |
default: |
544 |
fputs("Unsupported data type in cm_write()!\n", stderr); |
545 |
return(0); |
546 |
547 |
return(fflush(fp) == 0); |
548 |
