root/radiance/ray/src/util/bsdfview.pl
Revision: 2.2
Committed: Sat Aug 12 01:31:29 2017 UTC (7 years, 8 months ago) by greg
Changes since 2.1: +7 -2 lines
Improved handling of repeat runs
1 #!/usr/bin/perl
2 # RCSid $Id: bsdfview.pl,v 2.1 2017/08/11 21:39:52 greg Exp $
3 #
4 # Call bsdf2rad to render BSDF and start viewing it.
5 # Arguments are BSDF XML or SIR file(s)
6 #
7 use strict;
8 use warnings;
9 use File::Temp qw/ tempdir /;
10
11 my $td = tempdir( CLEANUP => 0 );
12 my $octree = "$td/bv$$.oct";
13 my $ambf = "$td/af$$.amb";
14 my $raddev = "x11"; # default output device. Overwrite with -o
15 my $qual = "Low";
16 my $vw = "def";
17
18 my $opts = ""; # Options common to rad
19 my $rendopts = "-w-"; # For render= line in rif file
20
21 while (@ARGV) {
22 $_ = $ARGV[0];
23 if ((m/^-s\b/) or (m/^-w/)) { # silent, no warnings
24 $opts .= " $_";
25 } elsif (m/^-v\b/) { # standard view
26 # Let rad do any error handling...
27 $vw = $ARGV[1];
28 shift @ARGV;
29 } elsif (m/^-[nN]\b/) { # No. of parallel processes
30 $opts .= ' -N ' . $ARGV[1];
31 shift @ARGV;
32 } elsif (m/^-o\b/) { # output device (rvu -devices)
33 $raddev = $ARGV[1];
34 shift @ARGV;
35 } elsif (m/^-q/) { # quality setting
36 $qual = $ARGV[1];
37 shift @ARGV;
38 } elsif ((m/^-V\b/) or (m/^-e\b/)) { # print view, explicate variables
39 # Think of those two as '-verbose'.
40 $opts .= " $_";
41 } elsif (m/^-\w/) {
42 die("bsdfview: Bad option: $_\n");
43 } else {
44 last;
45 }
46 shift @ARGV;
47 }
48
49 # We need at least one XML or SIR file
50 if ($#ARGV < 0) {
51 die("Missing input XML or SIR file(s)\n");
52 }
53
54 my @objects = @ARGV;
55
56 # Make this work under Windoze
57 if ( $^O =~ /MSWin32/ ) {
58 for my $i (0 .. $#objects) {
59 # rad doesn't like Windows-style backslashes.
60 $objects[$i] =~ s{\\}{/}g;
61 }
62 $octree =~ s{\\}{/}g;
63 $ambf =~ s{\\}{/}g;
64 $raddev = "qt";
65 }
66
67 my $name = $objects[0];
68 $name =~ s{.*/}{}; # remove leading path
69 $name =~ s{\.[^.]+$}{}; # remove file extension
70
71 my $rif = "$name.rif";
72
73 if (-e $rif) { # RIF already exists?
74 print "Attempting to run with existing rad input file '$rif'\n";
75 system "rad -o $raddev -w -v $vw $opts $rif QUA=$qual";
76 die("\nTry removing '$rif' and starting again\n\n") if $?;
77 exit;
78 }
79
80 print "bsdfview: creating rad input file '$rif'\n";
81
82 my $scene = qq("!bsdf2rad @objects"); # let bsdf2rad do complaining
83
84 my $objects = join(' ', @objects);
85 open(FH, ">$rif") or
86 die("bsdfview: Can't write to temporary file $rif\n");
87 print FH <<EndOfRif;
88 scene= $scene
89 objects= $objects
90 ZONE= E -35 35 -20 15 -5 15
91 PICTURE= $name
92 RESOLU= 1024
93 EXPOSURE= 1
94 UP= +Z
95 OCTREE= $octree
96 oconv= -w -f
97 AMBF= $ambf
98 QUAL = $qual
99 render= $rendopts
100 view= def -vp 0 -50 50 -vd 0 50 -50 -vh 45 -vv 30
101 view= fr -vp 15 -30 30 -vd 0 30 -30
102 view= br -vp -15 -30 30 -vd 0 30 -30
103 view= ft -vta -vp 15 0 0 -vd 0 0 1 -vu 0 1 0 -vh 200 -vv 200
104 view= bt -vta -vp -15 0 0 -vd 0 0 1 -vu 0 1 0 -vh 200 -vv 200
105 view= pr -vtl -vp 0 0 20 -vd 0 0 -1 -vu 0 1 0 -vv 35 -vh 65
106 view= pt -vtl -vp 0 0 -10 -vd 0 0 1 -vu 0 1 0 -vv 35 -vh 65
107 EndOfRif
108 close(FH);
109
110 system "rad -o $raddev -v $vw $opts $rif";
111
112 #EOF
