root/radiance/ray/src/util/bsdfview.pl
Revision: 2.7
Committed: Fri Jul 20 00:50:40 2018 UTC (6 years, 9 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 2.6: +7 -3 lines
Added "-r" option to bsdf2rad and bsdfview to fix plotting range
# User Rev Content
1 greg 2.1 #!/usr/bin/perl
2 greg 2.7 # RCSid $Id: bsdfview.pl,v 2.6 2017/10/18 19:30:48 greg Exp $
3 greg 2.1 #
4     # Call bsdf2rad to render BSDF and start viewing it.
5     # Arguments are BSDF XML or SIR file(s)
6     #
7     use strict;
8     use warnings;
9     use File::Temp qw/ tempdir /;
10
11     my $td = tempdir( CLEANUP => 0 );
12     my $octree = "$td/bv$$.oct";
13     my $ambf = "$td/af$$.amb";
14     my $raddev = "x11"; # default output device. Overwrite with -o
15 greg 2.5 my $qual = "Med";
16 greg 2.3 my $usetrad = 0;
17 greg 2.1
18 greg 2.7 my @range; # BSDF min and max range
19     my $opts = ""; # Options common to rad
20 greg 2.1 my $rendopts = "-w-"; # For render= line in rif file
21
22     while (@ARGV) {
23     $_ = $ARGV[0];
24     if ((m/^-s\b/) or (m/^-w/)) { # silent, no warnings
25     $opts .= " $_";
26     } elsif (m/^-v\b/) { # standard view
27     # Let rad do any error handling...
28 greg 2.3 $opts .= qq( -v "$ARGV[1]");
29 greg 2.1 shift @ARGV;
30     } elsif (m/^-[nN]\b/) { # No. of parallel processes
31     $opts .= ' -N ' . $ARGV[1];
32     shift @ARGV;
33     } elsif (m/^-o\b/) { # output device (rvu -devices)
34     $raddev = $ARGV[1];
35     shift @ARGV;
36     } elsif (m/^-q/) { # quality setting
37     $qual = $ARGV[1];
38     shift @ARGV;
39     } elsif ((m/^-V\b/) or (m/^-e\b/)) { # print view, explicate variables
40     # Think of those two as '-verbose'.
41     $opts .= " $_";
42 greg 2.3 } elsif (m/^-t\b/) { # start trad instead of rad
43     $usetrad = 1;
44 greg 2.7 } elsif (m/^-r/) { # specified range for BSDF
45     @range = ("-r", $ARGV[1], $ARGV[2]);
46     shift @ARGV; shift @ARGV;
47 greg 2.1 } elsif (m/^-\w/) {
48     die("bsdfview: Bad option: $_\n");
49     } else {
50     last;
51     }
52     shift @ARGV;
53     }
54
55     # We need at least one XML or SIR file
56     if ($#ARGV < 0) {
57 greg 2.3 die("bsdfview: missing input XML or SIR file(s)\n");
58     }
59
60     if (length($opts) and $usetrad) {
61     die("bsdfview: rad options not supported when calling trad (-t)\n");
62 greg 2.1 }
63
64     my @objects = @ARGV;
65
66     # Make this work under Windoze
67     if ( $^O =~ /MSWin32/ ) {
68     for my $i (0 .. $#objects) {
69     # rad doesn't like Windows-style backslashes.
70     $objects[$i] =~ s{\\}{/}g;
71     }
72     $octree =~ s{\\}{/}g;
73     $ambf =~ s{\\}{/}g;
74     $raddev = "qt";
75     }
76
77     my $name = $objects[0];
78     $name =~ s{.*/}{}; # remove leading path
79     $name =~ s{\.[^.]+$}{}; # remove file extension
80
81     my $rif = "$name.rif";
82
83 greg 2.2 if (-e $rif) { # RIF already exists?
84     print "Attempting to run with existing rad input file '$rif'\n";
85 greg 2.3 if ($usetrad) {
86     system "trad $rif";
87     } else {
88     system "rad -o $raddev -w $opts $rif QUA=$qual";
89     }
90 greg 2.2 die("\nTry removing '$rif' and starting again\n\n") if $?;
91     exit;
92     }
93 greg 2.1
94     print "bsdfview: creating rad input file '$rif'\n";
95
96 greg 2.7 my $scene = qq("!bsdf2rad @range @objects"); # let bsdf2rad do complaining
97 greg 2.1
98     my $objects = join(' ', @objects);
99     open(FH, ">$rif") or
100     die("bsdfview: Can't write to temporary file $rif\n");
101     print FH <<EndOfRif;
102     scene= $scene
103     objects= $objects
104     ZONE= E -35 35 -20 15 -5 15
105     PICTURE= $name
106     RESOLU= 1024
107     EXPOSURE= 1
108     UP= +Z
109     OCTREE= $octree
110     oconv= -w -f
111     AMBF= $ambf
112 greg 2.4 QUAL= $qual
113 greg 2.1 render= $rendopts
114     view= def -vp 0 -50 50 -vd 0 50 -50 -vh 45 -vv 30
115     view= fr -vp 15 -30 30 -vd 0 30 -30
116     view= br -vp -15 -30 30 -vd 0 30 -30
117     view= ft -vta -vp 15 0 0 -vd 0 0 1 -vu 0 1 0 -vh 200 -vv 200
118     view= bt -vta -vp -15 0 0 -vd 0 0 1 -vu 0 1 0 -vh 200 -vv 200
119     view= pr -vtl -vp 0 0 20 -vd 0 0 -1 -vu 0 1 0 -vv 35 -vh 65
120     view= pt -vtl -vp 0 0 -10 -vd 0 0 1 -vu 0 1 0 -vv 35 -vh 65
121     EndOfRif
122     close(FH);
123
124 greg 2.3 if ($usetrad) {
125 greg 2.6 system "rad -v 0 $rif ; trad $rif";
126 greg 2.3 } else {
127     system "rad -o $raddev $opts $rif";
128     }
129 greg 2.1 #EOF
