--- ray/src/util/bsdfview.pl 2017/08/26 16:07:22 2.4 +++ ray/src/util/bsdfview.pl 2022/01/26 18:01:41 2.8 @@ -1,5 +1,5 @@ #!/usr/bin/perl -# RCSid $Id: bsdfview.pl,v 2.4 2017/08/26 16:07:22 greg Exp $ +# RCSid $Id: bsdfview.pl,v 2.8 2022/01/26 18:01:41 greg Exp $ # # Call bsdf2rad to render BSDF and start viewing it. # Arguments are BSDF XML or SIR file(s) @@ -12,10 +12,11 @@ my $td = tempdir( CLEANUP => 0 ); my $octree = "$td/bv$$.oct"; my $ambf = "$td/af$$.amb"; my $raddev = "x11"; # default output device. Overwrite with -o -my $qual = "Low"; +my $qual = "Med"; my $usetrad = 0; -my $opts = ""; # Options common to rad +my @range; # BSDF min and max range +my $opts = ""; # Options common to rad my $rendopts = "-w-"; # For render= line in rif file while (@ARGV) { @@ -40,6 +41,9 @@ while (@ARGV) { $opts .= " $_"; } elsif (m/^-t\b/) { # start trad instead of rad $usetrad = 1; + } elsif (m/^-r/) { # specified range for BSDF + @range = ("-r", $ARGV[1], $ARGV[2]); + shift @ARGV; shift @ARGV; } elsif (m/^-\w/) { die("bsdfview: Bad option: $_\n"); } else { @@ -87,9 +91,14 @@ if (-e $rif) { # RIF already exists? exit; } +if ($objects[0] =~ /\.xml$/i) { + system "checkBSDF $objects[0]"; + die "Bad XML input\n" if ( $? ); +} + print "bsdfview: creating rad input file '$rif'\n"; -my $scene = qq("!bsdf2rad @objects"); # let bsdf2rad do complaining +my $scene = qq("!bsdf2rad @range @objects"); # let bsdf2rad do complaining my $objects = join(' ', @objects); open(FH, ">$rif") or @@ -118,7 +127,7 @@ EndOfRif close(FH); if ($usetrad) { - system "trad $rif"; + system "rad -v 0 $rif ; trad $rif"; } else { system "rad -o $raddev $opts $rif"; }
