root/radiance/ray/src/util/bsdfview.pl
Wed Jan 26 18:01:41 2022 UTC (3 years, 3 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.7: +6 -1 lines
feat(bsdfview): Added call to checkBSDF for XML input
Fri Jul 20 00:50:40 2018 UTC (6 years, 9 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 2.6: +7 -3 lines
Added "-r" option to bsdf2rad and bsdfview to fix plotting range
Wed Oct 18 19:30:48 2017 UTC (7 years, 6 months ago) by greg
Added note about "-v 0" and made start-up with "-t" option more reliable.
Wed Sep 6 23:57:56 2017 UTC (7 years, 8 months ago) by greg
Fixed issue with trad introduced in last change
Sat Aug 26 16:07:22 2017 UTC (7 years, 8 months ago) by greg
Thu Aug 17 21:32:29 2017 UTC (7 years, 8 months ago) by greg
Changes since 2.2: +20 -7 lines
Final check-ins to get evalglare working and addition of bsdfview -t option
Sat Aug 12 01:31:29 2017 UTC (7 years, 8 months ago) by greg
Changes since 2.1: +7 -2 lines
Improved handling of repeat runs
Fri Aug 11 21:39:52 2017 UTC (7 years, 8 months ago) by greg
Diff to selected 2.4
