1 |
import os |
2 |
3 |
Import('env') # inherit from parent |
4 |
5 |
mlib = ['$RAD_MLIB'] |
6 |
progs = [] |
7 |
8 |
# compose paths |
9 |
def radbin(name): return os.path.join('$RAD_BUILDBIN', name) |
10 |
def radlib(name): return os.path.join('$RAD_BUILDLIB', name) |
11 |
12 |
setscan = env.Object(source='setscan.c') |
13 |
Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice |
14 |
15 |
# standard targets |
16 |
PROGS = [ |
17 |
('findglare', Split('findglare.c glareval.c glaresrc.c')+[setscan], |
18 |
['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']), |
19 |
#('contour', Split('contour.c'), ['rtmath']), # XXX what is this? |
20 |
('glarendx', Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']), |
21 |
('vwright', Split('vwright.c'), ['rtpic','rtio','rtargs','rtmath']), |
22 |
('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']), |
23 |
('rad', Split('rad.c'), |
24 |
['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']), |
25 |
('rpiece', Split('rpiece.c') + [Version], |
26 |
['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']), |
27 |
28 |
if os.name == 'nt': # XXX should be set in a *.cfg file |
29 |
netproc = 'win_netproc.c' |
30 |
netlib = ['ws2_32'] |
31 |
else: |
32 |
netproc = 'netproc.c' |
33 |
netlib = [] |
34 |
35 |
PROGS.append(('ranimate', ['ranimate.c', netproc], |
36 |
['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath','rtnet','rterror'] + netlib)) |
37 |
for p in PROGS: |
38 |
prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib) |
39 |
progs.append(prog) |
40 |
41 |
if os.name != 'nt': # XXX pending Windows version of raypcalls.c |
42 |
# targets with different includes/libs |
43 |
rs = Split('ranimove.c ranimove1.c ranimove2.c') |
44 |
ranimove = env.Program(target=radbin('ranimove'), source=rs, |
45 |
CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], |
46 |
LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio', |
47 |
'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib) |
48 |
progs.append(ranimove) |
49 |
50 |
getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c', |
51 |
LIBS=['rtio']) |
52 |
progs.append(getinfo) |
53 |
54 |
# special targets not normally built |
55 |
if os.name != 'nt': # XXX pending replacement of fork() and friends |
56 |
scanner = env.Program(target=radbin('scanner'), source='scanner.c', |
57 |
LIBS=mlib) |
58 |
scanner_i = env.Install('$RAD_BINDIR', scanner) |
59 |
makedist = env.Program(target=radbin('makedist'), |
60 |
source=Split('makedist.c')+[setscan], |
61 |
LIBS=['rtmath']+mlib) |
62 |
makedist_i = env.Install('$RAD_BINDIR', makedist) |
63 |
env.Alias('util_special', [scanner, makedist]) |
64 |
env.Alias('util_special_install', [scanner_i, makedist_i]) |
65 |
66 |
# X11 targets |
67 |
if env.has_key('X11LIB'): |
68 |
xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] |
69 |
xlibp = env.get('LIBPATH', []) + ['$X11LIB'] |
70 |
x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice |
71 |
CPPPATH=xincl) |
72 |
xglaresrc = env.Program(target=radbin('xglaresrc'), |
73 |
source=Split('xglaresrc.c') + [x11findwind], |
74 |
LIBPATH=xlibp, CPPPATH=xincl, |
75 |
LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib) |
76 |
progs.append(xglaresrc) |
77 |
78 |
# OpenGL targets that also depend on X11 |
79 |
if env.has_key('OGL'): |
80 |
glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'), |
81 |
CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'], |
82 |
83 |
LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs', |
84 |
'rtmath','rtcont','rtmem','rterror', |
85 |
'GL', 'GLU','X11'],) |
86 |
progs.append(glrad) |
87 |
88 |
if os.name == 'posix': # XXX ignoring trad.wsh |
89 |
for s in Split('''objview objline objpict |
90 |
glare dayfact debugcal rlux raddepend compamb vinfo genambpos'''): |
91 |
Default(env.InstallCsh(radbin(s), s + '.csh')) |
92 |
93 |
Default('#src/util') |
94 |
env.Install('$RAD_BINDIR', progs) |
95 |
