| 1 |
import os |
| 2 |
| 3 |
Import('env') # inherit from parent |
| 4 |
| 5 |
mlib = ['$RAD_MLIB'] |
| 6 |
progs = [] |
| 7 |
| 8 |
# compose paths |
| 9 |
def radbin(name): return os.path.join('$RAD_BUILDBIN', name) |
| 10 |
def radlib(name): return os.path.join('$RAD_BUILDLIB', name) |
| 11 |
| 12 |
setscan = env.Object(source='setscan.c') |
| 13 |
Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice |
| 14 |
| 15 |
# standard targets |
| 16 |
PROGS = [ |
| 17 |
('findglare', Split('findglare.c glareval.c glaresrc.c')+[setscan], |
| 18 |
['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']), |
| 19 |
#('contour', Split('contour.c'), ['rtmath']), # XXX what is this? |
| 20 |
('glarendx', Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']), |
| 21 |
('vwright', Split('vwright.c'), ['rtpic','rtio','rtargs','rtmath']), |
| 22 |
('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']), |
| 23 |
('rad', Split('rad.c'), |
| 24 |
['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']), |
| 25 |
('rpiece', Split('rpiece.c') + [Version], |
| 26 |
['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']), |
| 27 |
| 28 |
if os.name == 'nt': # XXX should be set in a *.cfg file |
| 29 |
netproc = 'win_netproc.c' |
| 30 |
netlib = ['ws2_32'] |
| 31 |
else: |
| 32 |
netproc = 'netproc.c' |
| 33 |
netlib = [] |
| 34 |
| 35 |
PROGS.append(('ranimate', ['ranimate.c', netproc], |
| 36 |
['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath','rtnet','rterror'] + netlib)) |
| 37 |
for p in PROGS: |
| 38 |
prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib) |
| 39 |
progs.append(prog) |
| 40 |
| 41 |
if os.name != 'nt': # XXX pending Windows version of raypcalls.c |
| 42 |
# targets with different includes/libs |
| 43 |
rs = Split('ranimove.c ranimove1.c ranimove2.c') |
| 44 |
ranimove = env.Program(target=radbin('ranimove'), source=rs, |
| 45 |
CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], |
| 46 |
LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio', |
| 47 |
'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib) |
| 48 |
progs.append(ranimove) |
| 49 |
| 50 |
getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c', |
| 51 |
LIBS=['rtio']) |
| 52 |
progs.append(getinfo) |
| 53 |
| 54 |
# special targets not normally built |
| 55 |
if os.name != 'nt': # XXX pending replacement of fork() and friends |
| 56 |
scanner = env.Program(target=radbin('scanner'), source='scanner.c', |
| 57 |
LIBS=mlib) |
| 58 |
scanner_i = env.Install('$RAD_BINDIR', scanner) |
| 59 |
makedist = env.Program(target=radbin('makedist'), |
| 60 |
source=Split('makedist.c')+[setscan], |
| 61 |
LIBS=['rtmath']+mlib) |
| 62 |
makedist_i = env.Install('$RAD_BINDIR', makedist) |
| 63 |
env.Alias('util_special', [scanner, makedist]) |
| 64 |
env.Alias('util_special_install', [scanner_i, makedist_i]) |
| 65 |
| 66 |
# X11 targets |
| 67 |
if env.has_key('X11LIB'): |
| 68 |
xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] |
| 69 |
xlibp = env.get('LIBPATH', []) + ['$X11LIB'] |
| 70 |
x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice |
| 71 |
CPPPATH=xincl) |
| 72 |
xglaresrc = env.Program(target=radbin('xglaresrc'), |
| 73 |
source=Split('xglaresrc.c') + [x11findwind], |
| 74 |
LIBPATH=xlibp, CPPPATH=xincl, |
| 75 |
LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib) |
| 76 |
progs.append(xglaresrc) |
| 77 |
| 78 |
# OpenGL targets that also depend on X11 |
| 79 |
if env.has_key('OGL'): |
| 80 |
glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'), |
| 81 |
CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'], |
| 82 |
| 83 |
LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs', |
| 84 |
'rtmath','rtcont','rtmem','rterror', |
| 85 |
'GL', 'GLU','X11'],) |
| 86 |
progs.append(glrad) |
| 87 |
| 88 |
if os.name == 'posix': # XXX ignoring trad.wsh |
| 89 |
for s in Split('''objview objline objpict |
| 90 |
glare dayfact debugcal rlux raddepend compamb vinfo genambpos'''): |
| 91 |
Default(env.InstallCsh(radbin(s), s + '.csh')) |
| 92 |
# Those don't really work yet |
| 93 |
#else: |
| 94 |
# for s in Split('''objview glare rlux '''): |
| 95 |
# prog = env.Program(target=radbin(s), source=s+'.c') |
| 96 |
# progs.append(prog) |
| 97 |
| 98 |
Default('#src/util') |
| 99 |
env.Install('$RAD_BINDIR', progs) |
| 100 |
