root/Development/ray/src/util/SConscript
Revision: 1.4
Committed: Sun Mar 28 20:33:14 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 1.3: +2 -1 lines
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = env['RAD_MLIB']
6
7 # compose paths
8 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
9 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
10
11 setscan = env.Object(source='setscan.c')
12
13 # standard targets
14 PROGS = [
15 ('findglare', Split('findglare.c glareval.c glaresrc.c')+[setscan],
16 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']),
17 #('contour', Split('contour.c'), ['rtmath']), # XXX what is this?
18 ('glarendx', Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']),
19 ('vwright', Split('vwright.c'), ['rtpic','rtio','rtargs','rtmath']),
20 ('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']),
21 ('rad', Split('rad.c'),
22 ['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']),
23 ('rpiece', Split('rpiece.c Version.c'),
24 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']),
25 ]
26 if os.name == 'nt': # XXX should be set in a *.cfg file
27 netproc = 'win_netproc.c'
28 netlib = ['ws2_32']
29 else:
30 netproc = 'netproc.c'
31 netlib = []
32
33 PROGS.append(('ranimate', ['ranimate.c', netproc],
34 ['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath','rtnet','rterror'] + netlib))
35 for p in PROGS:
36 prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
37 Default(prog)
38 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
39
40 if os.name != 'nt': # XXX pending Windows version of raypcalls.c
41 # targets with different includes/libs
42 rs = Split('ranimove.c ranimove1.c ranimove2.c')
43 ranimove = env.Program(target=radbin('ranimove'), source=rs,
44 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
45 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio',
46 'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib)
47 Default(ranimove)
48 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], ranimove)])
49
50 getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c',
51 LIBS=['rtio'])
52 Default(getinfo)
53 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], getinfo)])
54
55 # special targets not normally built
56 if os.name != 'nt': # XXX pending replacement of fork() and friends
57 scanner = env.Program(target=radbin('scanner'), source='scanner.c',
58 LIBS=mlib)
59 scanner_i = env.Install(env['RAD_BINDIR'], scanner)
60 makedist = env.Program(target=radbin('makedist'),
61 source=Split('makedist.c')+[setscan],
62 LIBS=['rtmath']+mlib)
63 makedist_i = env.Install(env['RAD_BINDIR'], makedist)
64 env.Alias('util_special', [scanner, makedist])
65 env.Alias('util_special_install', [scanner_i, makedist_i])
66
67 # X11 targets
68 if env.has_key('X11LIB'):
69 xlibp = env.get('LIBPATH',[]) + [env['X11LIB']]
70 xincl = env.get('CPPPATH',[]) + [env['X11INCLUDE']]
71 xglaresrc = env.Program(target=radbin('xglaresrc'),
72 source=Split('xglaresrc.c x11findwind.c'),
73 LIBPATH=xlibp, CPPPATH=xincl,
74 LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib)
75 Default(xglaresrc)
76 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], xglaresrc)])
77
78 # OpenGL targets that also depend on X11
79 if env.has_key('OGL'):
80 glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'),
81 CPPFLAGS=env.get('CPPFLAGS', []) + [env['RAD_STEREO']],
82 LIBPATH=xlibp, CPPPATH=xincl,
83 LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs',
84 'rtmath','rtcont','rtmem','rterror',
85 'GL', 'GLU','X11'],)
86 Default(glrad)
87 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], glrad)])
88
89
