root/radiance/ray/src/util/SConscript
Revision: 1.21
Committed: Thu Mar 10 21:43:23 2016 UTC (9 years, 2 months ago) by schorsch
Changes since 1.20: +20 -31 lines
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = ['$RAD_MLIB']
6 progs = []
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
11 def tclscr(name): return os.path.join('$RAD_BUILDRLIB', 'tcl', name)
12
13 cmatrix = env.Object(source='cmatrix.c')
14 cmbsdf = env.Object(source='cmbsdf.c')
15
16 # standard targets
17 PROGS = [
18 ('findglare', Split('findglare.c glareval.c glaresrc.c setscan.c'), ['rtrad']),
19 ('glarendx', Split('glarendx.c'), ['rtrad']),
20 ('vwright', Split('vwright.c'), ['rtrad']),
21 ('vwrays', Split('vwrays.c'), ['rtrad']),
22 ('rad', Split('rad.c'), ['rtrad']),
23 ('rpiece', Split('rpiece.c') + [env.version], ['rtrad']),
24 ('ranimate', ['ranimate.c', '$RAD_NETCOMPAT'], ['rtrad', '$RAD_SOCKETLIB']),
25 ('dctimestep', Split('dctimestep.c')+[cmatrix, cmbsdf], ['rtrad']),
26 ('rttree_reduce', Split('rttree_reduce.c'), ['rtrad']),
27 ('rcollate', Split('rcollate.c'), ['rtrad']),
28 ('eplus_adduvf', Split('eplus_adduvf.c eplus_idf.c'), ['rtrad']),
29 ('rfluxmtx', Split('rfluxmtx.c'), ['rtrad']),
30 ('rmtxop', Split('rmtxop.c rmatrix.c')+[cmatrix, cmbsdf], ['rtrad']),
31 ('wrapBSDF', Split('wrapBSDF.c'), ['rtrad']),
32 ('evalglare', Split('evalglare.c pictool.c'), ['rtrad', 'reetz']),
33 ]
34
35 for p in PROGS:
36 prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
37 progs.append(prog)
38
39 # targets with different includes/libs
40 rs = Split('ranimove.c ranimove1.c ranimove2.c')
41 ranimove = env.Program(target=radbin('ranimove'), source=rs,
42 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
43 LIBS=['raycalls','rttrace','rtrad'] + mlib)
44 progs.append(ranimove)
45 rsensor = env.Program(target=radbin('rsensor'), source='rsensor.c',
46 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
47 LIBS=['raycalls','rttrace','rtrad'] + mlib)
48 progs.append(rsensor)
49
50 getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c',
51 LIBS=['rtrad'])
52 progs.append(getinfo)
53
54
55 # X11 targets
56 if env.has_key('X11LIB'):
57 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
58 xlibp = env.get('LIBPATH', []) + ['$X11LIB']
59 xglaresrc = env.Program(target=radbin('xglaresrc'),
60 source=Split('xglaresrc.c') + [env.x11findwind], # XXX remote magic
61 LIBPATH=xlibp, CPPPATH=xincl,
62 LIBS=['rtrad', 'X11']+ mlib)
63 progs.append(xglaresrc)
64
65 # OpenGL targets that also depend on X11
66 if env.has_key('OGL'):
67 glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'),
68 CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'],
69 LIBPATH=xlibp, CPPPATH=xincl,
70 LIBS=['rgl','rtrad','rtdummy', 'GL', 'GLU','X11'] + mlib,)
71 progs.append(glrad)
72
73 if os.name == 'posix': # XXX ignoring trad.wsh
74 for s in Split('''objline glare dayfact
75 debugcal rlux raddepend compamb vinfo fieldcomb'''):
76 Default(env.InstallScript(radbin(s), s + '.csh'))
77 for s in Split('''objview objpict
78 genambpos genklemsamp genskyvec genBSDF ltview ltpict'''):
79 Default(env.InstallScript(radbin(s), s + '.pl'))
80 for s in Split('''do_action.tcl do_file.tcl do_options.tcl do_results.tcl
81 do_scene.tcl do_views.tcl do_zone.tcl file.hlp getfile.tcl gethelp.tcl
82 help.hlp tclIndex trad.hlp trad.icon util.tcl'''):
83 Default(env.InstallScript(tclscr(s), s))
84 Default(env.InstallTCLScript(radbin('trad'), 'trad.wsh'))
85
86 # Those don't really work yet
87 #else:
88 # for s in Split('''objview glare rlux '''):
89 # prog = env.Program(target=radbin(s), source=s+'.c')
90 # progs.append(prog)
91
92 Default('#src/util')
93 env.Install('$RAD_BINDIR', progs)
94
95 # vim: set syntax=python:
