root/radiance/ray/src/util/SConscript
Revision: 1.16
Committed: Tue Dec 23 15:04:01 2008 UTC (16 years, 5 months ago) by schorsch
Changes since 1.15: +2 -3 lines
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = ['$RAD_MLIB']
6 progs = []
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
11
12 Version = env.Object(source='#src/rt/Version.c')
13
14 # standard targets
15 PROGS = [
16 ('findglare', Split('findglare.c glareval.c glaresrc.c setscan.c'),
17 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']),
18 ('glarendx', Split('glarendx.c'), ['rtpic','rtargs','rtio','rtmath']),
19 ('vwright', Split('vwright.c'), ['rtpic','rtargs','rtio','rtmath']),
20 ('vwrays', Split('vwrays.c'), ['rtpic','rtargs','rtio','rtmath']),
21 ('rad', Split('rad.c'),
22 ['rtpic','rtproc','rtpath','rtmath','rtargs','rtio','rtcont','rtmem','rterror']),
23 ('rpiece', Split('rpiece.c') + [Version],
24 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']),
25 ('ranimate', ['ranimate.c', '$RAD_NETCOMPAT'],
26 ['rtpic','rtargs','rtio','rtproc','rtcont','rtmem','rtpath','rtmath',
27 'rtnet','rterror','$RAD_SOCKETLIB']),
28 ('rtcontrib', ['rtcontrib.c', Version],
29 ['rtpic','rtargs','rtfunc','rtio','rtproc','rtcont','rtmem','rtpath',
30 'rtmath','rtnet','rterror','$RAD_SOCKETLIB'])
31 ]
32
33 for p in PROGS:
34 prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
35 progs.append(prog)
36
37 #if os.name != 'nt': # XXX pending Windows version of raypcalls.c
38 if True: # experimental raypwin.c
39 # targets with different includes/libs
40 rs = Split('ranimove.c ranimove1.c ranimove2.c')
41 ranimove = env.Program(target=radbin('ranimove'), source=rs,
42 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
43 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtmath',
44 'rtcont','rtmem','rtargs','rtio','rtproc','rtpath','rterror']
45 + mlib)
46 progs.append(ranimove)
47 rsensor = env.Program(target=radbin('rsensor'), source='rsensor.c',
48 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
49 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtmath',
50 'rtcont','rtmem','rtargs','rtio','rtpath','rterror','rtproc',
51 'rtlamps'] + mlib)
52 progs.append(rsensor)
53
54 getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c',
55 LIBS=['rtio'])
56 progs.append(getinfo)
57
58
59 # X11 targets
60 if env.has_key('X11LIB'):
61 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
62 xlibp = env.get('LIBPATH', []) + ['$X11LIB']
63 xglaresrc = env.Program(target=radbin('xglaresrc'),
64 source=Split('xglaresrc.c') + [env.x11findwind], # XXX remote magic
65 LIBPATH=xlibp, CPPPATH=xincl,
66 LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib)
67 progs.append(xglaresrc)
68
69 # OpenGL targets that also depend on X11
70 if env.has_key('OGL'):
71 glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'),
72 CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'],
73 LIBPATH=xlibp, CPPPATH=xincl,
74 LIBS=['rgl','rtpic','rtscene','rtproc','rtpath','rtargs','rtio',
75 'rtmath','rtcont','rtmem','rterror','rtdummy',
76 'GL', 'GLU','X11'],)
77 progs.append(glrad)
78
79 if os.name == 'posix': # XXX ignoring trad.wsh
80 for s in Split('''objview objline objpict glare dayfact
81 debugcal rlux raddepend compamb vinfo genambpos fieldcomb'''):
82 Default(env.InstallCsh(radbin(s), s + '.csh'))
83 # Those don't really work yet
84 #else:
85 # for s in Split('''objview glare rlux '''):
86 # prog = env.Program(target=radbin(s), source=s+'.c')
87 # progs.append(prog)
88
89 Default('#src/util')
90 env.Install('$RAD_BINDIR', progs)
91
