--- ray/src/util/SConscript 2004/07/06 11:49:10 1.6 +++ ray/src/util/SConscript 2004/11/08 19:24:46 1.10 @@ -2,20 +2,19 @@ import os Import('env') # inherit from parent -mlib = env['RAD_MLIB'] +mlib = ['$RAD_MLIB'] +progs = [] # compose paths -def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) -def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) +def radbin(name): return os.path.join('$RAD_BUILDBIN', name) +def radlib(name): return os.path.join('$RAD_BUILDLIB', name) -setscan = env.Object(source='setscan.c') Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice # standard targets PROGS = [ -('findglare', Split('findglare.c glareval.c glaresrc.c')+[setscan], +('findglare', Split('findglare.c glareval.c glaresrc.c setscan.c'), ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']), -#('contour', Split('contour.c'), ['rtmath']), # XXX what is this? ('glarendx', Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']), ('vwright', Split('vwright.c'), ['rtpic','rtio','rtargs','rtmath']), ('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']), @@ -35,8 +34,7 @@ PROGS.append(('ranimate', ['ranimate.c', netproc], ['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath','rtnet','rterror'] + netlib)) for p in PROGS: prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib) - Default(prog) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) + progs.append(prog) if os.name != 'nt': # XXX pending Windows version of raypcalls.c # targets with different includes/libs @@ -45,48 +43,45 @@ if os.name != 'nt': # XXX pending Windows version of r CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio', 'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib) - Default(ranimove) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], ranimove)]) + progs.append(ranimove) getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c', LIBS=['rtio']) -Default(getinfo) -env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], getinfo)]) +progs.append(getinfo) -# special targets not normally built -if os.name != 'nt': # XXX pending replacement of fork() and friends - scanner = env.Program(target=radbin('scanner'), source='scanner.c', - LIBS=mlib) - scanner_i = env.Install(env['RAD_BINDIR'], scanner) - makedist = env.Program(target=radbin('makedist'), - source=Split('makedist.c')+[setscan], - LIBS=['rtmath']+mlib) - makedist_i = env.Install(env['RAD_BINDIR'], makedist) - env.Alias('util_special', [scanner, makedist]) - env.Alias('util_special_install', [scanner_i, makedist_i]) # X11 targets if env.has_key('X11LIB'): - xlibp = env.get('LIBPATH',[]) + [env['X11LIB']] - xincl = env.get('CPPPATH',[]) + [env['X11INCLUDE']] + xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] + xlibp = env.get('LIBPATH', []) + ['$X11LIB'] x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice CPPPATH=xincl) xglaresrc = env.Program(target=radbin('xglaresrc'), source=Split('xglaresrc.c') + [x11findwind], LIBPATH=xlibp, CPPPATH=xincl, LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib) - Default(xglaresrc) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], xglaresrc)]) + progs.append(xglaresrc) # OpenGL targets that also depend on X11 if env.has_key('OGL'): glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'), - CPPFLAGS=env.get('CPPFLAGS', []) + [env['RAD_STEREO']], + CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'], LIBPATH=xlibp, CPPPATH=xincl, LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs', 'rtmath','rtcont','rtmem','rterror', 'GL', 'GLU','X11'],) - Default(glrad) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], glrad)]) + progs.append(glrad) +if os.name == 'posix': # XXX ignoring trad.wsh + for s in Split('''objview objline objpict + glare dayfact debugcal rlux raddepend compamb vinfo genambpos'''): + Default(env.InstallCsh(radbin(s), s + '.csh')) +# Those don't really work yet +#else: +# for s in Split('''objview glare rlux '''): +# prog = env.Program(target=radbin(s), source=s+'.c') +# progs.append(prog) + +Default('#src/util') +env.Install('$RAD_BINDIR', progs)
