--- ray/src/util/SConscript 2004/03/26 23:34:23 1.3 +++ ray/src/util/SConscript 2008/12/23 15:04:01 1.16 @@ -2,87 +2,90 @@ import os Import('env') # inherit from parent -mlib = env['RAD_MLIB'] +mlib = ['$RAD_MLIB'] +progs = [] # compose paths -def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) -def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) +def radbin(name): return os.path.join('$RAD_BUILDBIN', name) +def radlib(name): return os.path.join('$RAD_BUILDLIB', name) -setscan = env.Object(source='setscan.c') +Version = env.Object(source='#src/rt/Version.c') # standard targets PROGS = [ -('findglare', Split('findglare.c glareval.c glaresrc.c')+[setscan], +('findglare', Split('findglare.c glareval.c glaresrc.c setscan.c'), ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']), -#('contour', Split('contour.c'), ['rtmath']), # XXX what is this? -('glarendx', Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']), -('vwright', Split('vwright.c'), ['rtpic','rtio','rtargs','rtmath']), -('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']), +('glarendx', Split('glarendx.c'), ['rtpic','rtargs','rtio','rtmath']), +('vwright', Split('vwright.c'), ['rtpic','rtargs','rtio','rtmath']), +('vwrays', Split('vwrays.c'), ['rtpic','rtargs','rtio','rtmath']), ('rad', Split('rad.c'), - ['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']), -('rpiece', Split('rpiece.c Version.c'), + ['rtpic','rtproc','rtpath','rtmath','rtargs','rtio','rtcont','rtmem','rterror']), +('rpiece', Split('rpiece.c') + [Version], ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']), +('ranimate', ['ranimate.c', '$RAD_NETCOMPAT'], + ['rtpic','rtargs','rtio','rtproc','rtcont','rtmem','rtpath','rtmath', + 'rtnet','rterror','$RAD_SOCKETLIB']), +('rtcontrib', ['rtcontrib.c', Version], + ['rtpic','rtargs','rtfunc','rtio','rtproc','rtcont','rtmem','rtpath', + 'rtmath','rtnet','rterror','$RAD_SOCKETLIB']) ] -if os.name == 'nt': # XXX should be set in a *.cfg file - netproc = 'win_netproc.c' - netlib = ['ws2_32'] -else: - netproc = 'netproc.c' - netlib = [] -PROGS.append(('ranimate', ['ranimate.c', netproc], - ['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath','rtnet','rterror'] + netlib)) for p in PROGS: prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib) - Default(prog) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) + progs.append(prog) -if os.name != 'nt': # XXX pending Windows version of raypcalls.c +#if os.name != 'nt': # XXX pending Windows version of raypcalls.c +if True: # experimental raypwin.c # targets with different includes/libs rs = Split('ranimove.c ranimove1.c ranimove2.c') ranimove = env.Program(target=radbin('ranimove'), source=rs, CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], - LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio', - 'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib) - Default(ranimove) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], ranimove)]) + LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtmath', + 'rtcont','rtmem','rtargs','rtio','rtproc','rtpath','rterror'] + + mlib) + progs.append(ranimove) + rsensor = env.Program(target=radbin('rsensor'), source='rsensor.c', + CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], + LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtmath', + 'rtcont','rtmem','rtargs','rtio','rtpath','rterror','rtproc', + 'rtlamps'] + mlib) + progs.append(rsensor) getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c', LIBS=['rtio']) -Default(getinfo) -env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], getinfo)]) +progs.append(getinfo) -# special targets not normally built -if os.name != 'nt': # XXX pending replacement of fork() and friends - scanner = env.Program(target=radbin('scanner'), source='scanner.c', - LIBS=mlib) - scanner_i = env.Install(env['RAD_BINDIR'], scanner) - makedist = env.Program(target=radbin('makedist'), - source=Split('makedist.c')+[setscan]) - makedist_i = env.Install(env['RAD_BINDIR'], makedist) - env.Alias('util_special', [scanner, makedist]) - env.Alias('util_special_install', [scanner_i, makedist_i]) # X11 targets if env.has_key('X11LIB'): - xlibp = env.get('LIBPATH',[]) + [env['X11LIB']] - xincl = env.get('CPPPATH',[]) + [env['X11INCLUDE']] + xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] + xlibp = env.get('LIBPATH', []) + ['$X11LIB'] xglaresrc = env.Program(target=radbin('xglaresrc'), - source=Split('xglaresrc.c x11findwind.c'), + source=Split('xglaresrc.c') + [env.x11findwind], # XXX remote magic LIBPATH=xlibp, CPPPATH=xincl, LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib) - Default(xglaresrc) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], xglaresrc)]) + progs.append(xglaresrc) # OpenGL targets that also depend on X11 if env.has_key('OGL'): glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'), - CPPFLAGS=env.get('CPPFLAGS', []) + [env['RAD_STEREO']], + CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'], LIBPATH=xlibp, CPPPATH=xincl, - LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs', - 'rtmath','rtcont','rtmem','rterror', + LIBS=['rgl','rtpic','rtscene','rtproc','rtpath','rtargs','rtio', + 'rtmath','rtcont','rtmem','rterror','rtdummy', 'GL', 'GLU','X11'],) - Default(glrad) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], glrad)]) + progs.append(glrad) +if os.name == 'posix': # XXX ignoring trad.wsh + for s in Split('''objview objline objpict glare dayfact + debugcal rlux raddepend compamb vinfo genambpos fieldcomb'''): + Default(env.InstallCsh(radbin(s), s + '.csh')) +# Those don't really work yet +#else: +# for s in Split('''objview glare rlux '''): +# prog = env.Program(target=radbin(s), source=s+'.c') +# progs.append(prog) + +Default('#src/util') +env.Install('$RAD_BINDIR', progs)
