--- ray/src/util/SConscript 2008/04/24 10:28:25 1.15 +++ ray/src/util/SConscript 2016/03/05 13:24:58 1.20 @@ -8,8 +8,10 @@ progs = [] # compose paths def radbin(name): return os.path.join('$RAD_BUILDBIN', name) def radlib(name): return os.path.join('$RAD_BUILDLIB', name) +def tclscr(name): return os.path.join('$RAD_BUILDRLIB', 'tcl', name) -Version = env.Object(source='#src/rt/Version.c') +cmatrix = env.Object(source='cmatrix.c') +cmbsdf = env.Object(source='cmbsdf.c') # standard targets PROGS = [ @@ -20,36 +22,39 @@ PROGS = [ ('vwrays', Split('vwrays.c'), ['rtpic','rtargs','rtio','rtmath']), ('rad', Split('rad.c'), ['rtpic','rtproc','rtpath','rtmath','rtargs','rtio','rtcont','rtmem','rterror']), -('rpiece', Split('rpiece.c') + [Version], +('rpiece', Split('rpiece.c') + [env.version], # remote magic ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']), ('ranimate', ['ranimate.c', '$RAD_NETCOMPAT'], ['rtpic','rtargs','rtio','rtproc','rtcont','rtmem','rtpath','rtmath', 'rtnet','rterror','$RAD_SOCKETLIB']), -('rtcontrib', ['rtcontrib.c', Version], - ['rtpic','rtargs','rtfunc','rtio','rtproc','rtcont','rtmem','rtpath', - 'rtmath','rtnet','rterror','$RAD_SOCKETLIB']) +('dctimestep', Split('dctimestep.c')+[cmatrix, cmbsdf], ['rtall']), +('rttree_reduce', Split('rttree_reduce.c'), ['rtall']), +('rcollate', Split('rcollate.c'), ['rtall']), +('eplus_adduvf', Split('eplus_adduvf.c eplus_idf.c'), ['rtall']), +('rfluxmtx', Split('rfluxmtx.c'), ['rtall']), +('rmtxop', Split('rmtxop.c rmatrix.c')+[cmatrix, cmbsdf], ['rtall']), +('wrapBSDF', Split('wrapBSDF.c'), ['rtall']), +('evalglare', Split('evalglare.c pictool.c'), ['rtall', 'reetz']), ] for p in PROGS: prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib) progs.append(prog) -#if os.name != 'nt': # XXX pending Windows version of raypcalls.c -if True: # experimental raypwin.c - # targets with different includes/libs - rs = Split('ranimove.c ranimove1.c ranimove2.c') - ranimove = env.Program(target=radbin('ranimove'), source=rs, - CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], - LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtmath', - 'rtcont','rtmem','rtargs','rtio','rtproc','rtpath','rterror'] - + mlib) - progs.append(ranimove) - rsensor = env.Program(target=radbin('rsensor'), source='rsensor.c', - CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], - LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtmath', - 'rtcont','rtmem','rtargs','rtio','rtpath','rterror','rtproc', - 'rtlamps'] + mlib) - progs.append(rsensor) +# targets with different includes/libs +rs = Split('ranimove.c ranimove1.c ranimove2.c') +ranimove = env.Program(target=radbin('ranimove'), source=rs, + CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], + LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtmath', + 'rtnet','rtcont','rtmem','rtargs','rtio','rtproc','rtpath','rterror'] + + mlib) +progs.append(ranimove) +rsensor = env.Program(target=radbin('rsensor'), source='rsensor.c', + CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], + LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtmath', + 'rtcont','rtmem','rtargs','rtio','rtpath','rterror','rtproc', + 'rtnet','rtlamps'] + mlib) +progs.append(rsensor) getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c', LIBS=['rtio']) @@ -60,9 +65,8 @@ progs.append(getinfo) if env.has_key('X11LIB'): xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] xlibp = env.get('LIBPATH', []) + ['$X11LIB'] - x11findwind = env.Object(source='#src/common/x11findwind.c', CPPPATH=xincl) xglaresrc = env.Program(target=radbin('xglaresrc'), - source=Split('xglaresrc.c') + [x11findwind], + source=Split('xglaresrc.c') + [env.x11findwind], # XXX remote magic LIBPATH=xlibp, CPPPATH=xincl, LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib) progs.append(xglaresrc) @@ -73,14 +77,23 @@ if env.has_key('X11LIB'): CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'], LIBPATH=xlibp, CPPPATH=xincl, LIBS=['rgl','rtpic','rtscene','rtproc','rtpath','rtargs','rtio', - 'rtmath','rtcont','rtmem','rterror', - 'GL', 'GLU','X11'],) + 'rtmath','rtcont','rtmem','rterror','rtdummy', + 'GL', 'GLU','X11'] + mlib,) progs.append(glrad) if os.name == 'posix': # XXX ignoring trad.wsh - for s in Split('''objview objline objpict glare dayfact - debugcal rlux raddepend compamb vinfo genambpos fieldcomb'''): - Default(env.InstallCsh(radbin(s), s + '.csh')) + for s in Split('''objline glare dayfact + debugcal rlux raddepend compamb vinfo fieldcomb'''): + Default(env.InstallScript(radbin(s), s + '.csh')) + for s in Split('''objview objpict + genambpos genklemsamp genskyvec genBSDF ltview ltpict'''): + Default(env.InstallScript(radbin(s), s + '.pl')) + for s in Split('''do_action.tcl do_file.tcl do_options.tcl do_results.tcl + do_scene.tcl do_views.tcl do_zone.tcl file.hlp getfile.tcl gethelp.tcl + help.hlp tclIndex trad.hlp trad.icon util.tcl'''): + Default(env.InstallScript(tclscr(s), s)) + Default(env.InstallTCLScript(radbin('trad'), 'trad.wsh')) + # Those don't really work yet #else: # for s in Split('''objview glare rlux '''): @@ -90,3 +103,4 @@ if os.name == 'posix': # XXX ignoring trad.wsh Default('#src/util') env.Install('$RAD_BINDIR', progs) +# vim: set syntax=python:
