--- ray/src/util/SConscript 2003/10/21 19:27:29 1.1 +++ ray/src/util/SConscript 2004/11/05 22:15:44 1.9 @@ -2,69 +2,88 @@ import os Import('env') # inherit from parent -# make a modified local copy -util = env.Copy(LIBS=['rt'] + env['RAD_MLIB']) +mlib = ['$RAD_MLIB'] +progs = [] # compose paths -def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) -def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) +def radbin(name): return os.path.join('$RAD_BUILDBIN', name) +def radlib(name): return os.path.join('$RAD_BUILDLIB', name) +setscan = env.Object(source='setscan.c') +Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice + # standard targets PROGS = [ -('findglare', Split('findglare.c glareval.c glaresrc.c setscan.c')), -('glarendx', Split('glarendx.c')), -('vwright', Split('vwright.c')), -('vwrays', Split('vwrays.c')), -('rad', Split('rad.c')), -('rpiece', Split('rpiece.c Version.c')), +('findglare', Split('findglare.c glareval.c glaresrc.c')+[setscan], + ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']), +#('contour', Split('contour.c'), ['rtmath']), # XXX what is this? +('glarendx', Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']), +('vwright', Split('vwright.c'), ['rtpic','rtio','rtargs','rtmath']), +('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']), +('rad', Split('rad.c'), + ['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']), +('rpiece', Split('rpiece.c') + [Version], + ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']), ] -if os.name != 'nt': # XXX pending Windows version of netproc.c - PROGS.append(('ranimate', Split('ranimate.c netproc.c'))) +if os.name == 'nt': # XXX should be set in a *.cfg file + netproc = 'win_netproc.c' + netlib = ['ws2_32'] +else: + netproc = 'netproc.c' + netlib = [] + +PROGS.append(('ranimate', ['ranimate.c', netproc], + ['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath','rtnet','rterror'] + netlib)) for p in PROGS: - prog = util.Program(target=radbin(p[0]), source=p[1]) - Default(prog) - env.Append(RAD_BININSTALL=[util.Install(util['RAD_BINDIR'], prog)]) + prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib) + progs.append(prog) -if os.name != 'nt': # XXX pending resolution of free_os() conflict +if os.name != 'nt': # XXX pending Windows version of raypcalls.c # targets with different includes/libs rs = Split('ranimove.c ranimove1.c ranimove2.c') - for l in ['raycalls', 'radiance']: # XXX ugly - rs.append(radlib(util['LIBPREFIX'] + l + util['LIBSUFFIX'])) - ranimove = util.Program(target=radbin('ranimove'), source=rs, - CPPPATH=util.get('CPPPATH', []) + ['#src/rt']) - Default(ranimove) - env.Append(RAD_BININSTALL=[util.Install(util['RAD_BINDIR'], ranimove)]) + ranimove = env.Program(target=radbin('ranimove'), source=rs, + CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], + LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio', + 'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib) + progs.append(ranimove) -getinfo = util.Program(target=radbin('getinfo'), source='getinfo.c', - LIBS=['rt']) -Default(getinfo) -env.Append(RAD_BININSTALL=[util.Install(util['RAD_BINDIR'], getinfo)]) +getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c', + LIBS=['rtio']) +progs.append(getinfo) -# special targets not normally built -scanner = util.Program(target=radbin('scanner'), source='scanner.c', LIBS=['m']) -makedist = util.Program(target=radbin('makedist'), - source=Split('makedist.c setscan.c')) -scanner_i = util.Install(util['RAD_BINDIR'], scanner) -makedist_i = util.Install(util['RAD_BINDIR'], makedist) -util.Alias('util_special', [scanner, makedist]) -util.Alias('util_special_install', [scanner_i, makedist_i]) # X11 targets -if util.has_key('X11LIB'): - util.Append(CPPPATH=util['X11INCLUDE']) - util.Append(LIBS='X11') - util.Append(LIBPATH=util['X11LIB']) - xglaresrc = util.Program(target=radbin('xglaresrc'), - source=Split('xglaresrc.c x11findwind.c'),) - Default(xglaresrc) - env.Append(RAD_BININSTALL=[util.Install(util['RAD_BINDIR'], xglaresrc)]) +if env.has_key('X11LIB'): + xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] + xlibp = env.get('LIBPATH', []) + ['$X11LIB'] + x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice + CPPPATH=xincl) + xglaresrc = env.Program(target=radbin('xglaresrc'), + source=Split('xglaresrc.c') + [x11findwind], + LIBPATH=xlibp, CPPPATH=xincl, + LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib) + progs.append(xglaresrc) - # OpenGL targets that also depend on X11 - if util.has_key('OGL'): - glrad = util.Program(target=radbin('glrad'), source=Split('glrad.c'), - CPPFLAGS=util.get('CPPFLAGS', []) + [util['RAD_STEREO']], - LIBS=['rgl', 'GL', 'GLU']+util['LIBS'],) - Default(glrad) - env.Append(RAD_BININSTALL=[util.Install(util['RAD_BINDIR'], glrad)]) + # OpenGL targets that also depend on X11 + if env.has_key('OGL'): + glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'), + CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'], + LIBPATH=xlibp, CPPPATH=xincl, + LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs', + 'rtmath','rtcont','rtmem','rterror', + 'GL', 'GLU','X11'],) + progs.append(glrad) +if os.name == 'posix': # XXX ignoring trad.wsh + for s in Split('''objview objline objpict + glare dayfact debugcal rlux raddepend compamb vinfo genambpos'''): + Default(env.InstallCsh(radbin(s), s + '.csh')) +# Those don't really work yet +#else: +# for s in Split('''objview glare rlux '''): +# prog = env.Program(target=radbin(s), source=s+'.c') +# progs.append(prog) + +Default('#src/util') +env.Install('$RAD_BINDIR', progs)
