root/Development/ray/src/util/SConscript
Mon Jan 8 13:38:37 2018 UTC (7 years, 11 months ago) by schorsch
Changes since 1.22: +12 -8 lines
Diff to previous 1.22 , to selected 1.10
Sat Mar 19 12:53:19 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.21: +6 -4 lines
Diff to previous 1.21 , to selected 1.10
better solution for addobjnotify
Thu Mar 10 21:43:23 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.20: +20 -31 lines
Diff to previous 1.20 , to selected 1.10
Sat Mar 5 13:24:58 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.19: +38 -22 lines
Diff to previous 1.19 , to selected 1.10
Sat Mar 5 00:29:28 2016 UTC (9 years, 10 months ago) by schorsch
Changes since 1.18: +5 -8 lines
Diff to previous 1.18 , to selected 1.10
update SCons
Wed Dec 15 01:40:11 2010 UTC (15 years ago) by greg
Diff to previous 1.17 , to selected 1.10
Updated SConscript files for compiling under MINGW
Fri Jul 9 15:24:45 2010 UTC (15 years, 5 months ago) by greg
Changes since 1.16: +3 -1 lines
Diff to previous 1.16 , to selected 1.10
Removed duplicate installs and added dctimestep
Tue Dec 23 15:04:01 2008 UTC (17 years ago) by schorsch
Changes since 1.15: +2 -3 lines
Diff to previous 1.15 , to selected 1.10
Thu Apr 24 10:28:25 2008 UTC (17 years, 8 months ago) by schorsch
Changes since 1.14: +2 -3 lines
Diff to previous 1.14 , to selected 1.10
Mon Apr 21 07:31:30 2008 UTC (17 years, 8 months ago) by schorsch
Changes since 1.13: +16 -8 lines
Diff to previous 1.13 , to selected 1.10
Scons update for mingw.
Mon Sep 19 12:59:49 2005 UTC (20 years, 3 months ago) by schorsch
Diff to previous 1.12 , to selected 1.10
Added fieldcomb.csh to SCons install.
Mon Sep 19 11:30:11 2005 UTC (20 years, 3 months ago) by schorsch
Changes since 1.11: +7 -10 lines
Diff to previous 1.11 , to selected 1.10
Wed Sep 14 09:28:35 2005 UTC (20 years, 3 months ago) by schorsch
Changes since 1.10: +2 -1 lines
Diff to previous 1.10
Revision 1.10 - (view) (download) (annotate) - [selected]
Mon Nov 8 19:24:46 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 1.9: +1 -3 lines
Diff to previous 1.9
Fri Nov 5 22:15:44 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 1.8: +0 -11 lines
Diff to previous 1.8 , to selected 1.10
Sat Oct 23 18:55:53 2004 UTC (21 years, 2 months ago) by schorsch
CVS Tags: rad3R6P1
Changes since 1.7: +5 -0 lines
Diff to previous 1.7 , to selected 1.10
Thu Oct 21 15:47:13 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 1.6: +21 -18 lines
Diff to previous 1.6 , to selected 1.10
SCons build simplifications.
Tue Jul 6 11:49:10 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 1.5: +2 -1 lines
Diff to previous 1.5 , to selected 1.10
Sun Jul 4 12:08:48 2004 UTC (21 years, 6 months ago) by schorsch
Diff to previous 1.4 , to selected 1.10
Sun Mar 28 20:33:14 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 1.3: +2 -1 lines
Diff to previous 1.3 , to selected 1.10
Fri Mar 26 23:34:23 2004 UTC (21 years, 9 months ago) by schorsch
Diff to previous 1.2 , to selected 1.10
Continued ANSIfication.
Mon Oct 27 10:35:43 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 1.1: +62 -45 lines
Diff to previous 1.1 , to selected 1.10
Tue Oct 21 19:27:29 2003 UTC (22 years, 2 months ago) by schorsch
Diff to selected 1.10
