| 1 |
import os
| 2 |
| 3 |
Import('env') # inherit from parent
| 4 |
| 5 |
mlib = ['$RAD_MLIB']
| 6 |
progs = []
| 7 |
| 8 |
# compose paths
| 9 |
def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
| 10 |
def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
| 11 |
def tclscr(name): return os.path.join('$RAD_BUILDRLIB', 'tcl', name)
| 12 |
| 13 |
cmatrix = env.Object(source='cmatrix.c')
| 14 |
cmbsdf = env.Object(source='cmbsdf.c')
| 15 |
| 16 |
# standard targets
| 17 |
PROGS = [
| 18 |
('findglare', Split('findglare.c glareval.c glaresrc.c setscan.c'), ['rtrad']),
| 19 |
('glarendx', Split('glarendx.c'), ['rtrad']),
| 20 |
('vwright', Split('vwright.c'), ['rtrad']),
| 21 |
('vwrays', Split('vwrays.c'), ['rtrad']),
| 22 |
('rad', Split('rad.c'), ['rtrad']),
| 23 |
('rpiece', Split('rpiece.c') + [env.version], ['rtrad']),
| 24 |
('ranimate', ['ranimate.c', '$RAD_NETCOMPAT'], ['rtrad', '$RAD_SOCKETLIB']),
| 25 |
('dctimestep', Split('dctimestep.c')+[cmatrix, cmbsdf], ['rtrad']),
| 26 |
('rttree_reduce', Split('rttree_reduce.c'), ['rtrad']),
| 27 |
('rcollate', Split('rcollate.c'), ['rtrad']),
| 28 |
('eplus_adduvf', Split('eplus_adduvf.c eplus_idf.c'), ['rtrad']),
| 29 |
('rfluxmtx', Split('rfluxmtx.c'), ['rtrad']),
| 30 |
('rmtxop', Split('rmtxop.c rmatrix.c')+[cmatrix, cmbsdf], ['rtrad']),
| 31 |
('wrapBSDF', Split('wrapBSDF.c'), ['rtrad']),
| 32 |
('evalglare', Split('evalglare.c pictool.c'), ['rtrad', 'reetz']),
| 33 |
| 34 |
| 35 |
for p in PROGS:
| 36 |
prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
| 37 |
progs.append(prog)
| 38 |
| 39 |
# targets with different includes/libs
| 40 |
rs = Split('ranimove.c ranimove1.c ranimove2.c')
| 41 |
ranimove = env.Program(target=radbin('ranimove'), source=rs,
| 42 |
CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
| 43 |
LIBS=['raycalls','rttrace','rtrad'] + mlib)
| 44 |
progs.append(ranimove)
| 45 |
rsensor = env.Program(target=radbin('rsensor'), source='rsensor.c',
| 46 |
| 47 |
| 48 |
progs.append(rsensor)
| 49 |
| 50 |
getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c',
| 51 |
LIBS=['rtrad'])
| 52 |
progs.append(getinfo)
| 53 |
| 54 |
| 55 |
# X11 targets
| 56 |
if env.has_key('X11LIB'):
| 57 |
addobj = env.get('ADDOBJNOTIFY')
| 58 |
xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
| 59 |
xlibp = env.get('LIBPATH', []) + ['$X11LIB']
| 60 |
xglaresrc = env.Program(target=radbin('xglaresrc'),
| 61 |
source=Split('xglaresrc.c') + [env.x11findwind], # XXX remote magic
| 62 |
LIBPATH=xlibp, CPPPATH=xincl,
| 63 |
LIBS=['rtrad', 'X11']+ mlib)
| 64 |
progs.append(xglaresrc)
| 65 |
| 66 |
# OpenGL targets that also depend on X11
| 67 |
if env.has_key('OGL'):
| 68 |
glrad = env.Program(target=radbin('glrad'),
| 69 |
source=['glrad.c', addobj],
| 70 |
CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'],
| 71 |
| 72 |
LIBS=['rgl','rtrad','GL', 'GLU','X11'] + mlib,)
| 73 |
progs.append(glrad)
| 74 |
| 75 |
if os.name == 'posix': # XXX ignoring trad.wsh
| 76 |
for s in Split('''objline glare dayfact
| 77 |
debugcal rlux raddepend compamb vinfo fieldcomb'''):
| 78 |
Default(env.InstallScript(radbin(s), s + '.csh'))
| 79 |
for s in Split('''objview objpict
| 80 |
genambpos genklemsamp genskyvec genBSDF ltview ltpict'''):
| 81 |
Default(env.InstallScript(radbin(s), s + '.pl'))
| 82 |
for s in Split('''do_action.tcl do_file.tcl do_options.tcl do_results.tcl
| 83 |
do_scene.tcl do_views.tcl do_zone.tcl file.hlp getfile.tcl gethelp.tcl
| 84 |
help.hlp tclIndex trad.hlp trad.icon util.tcl'''):
| 85 |
Default(env.InstallScript(tclscr(s), s))
| 86 |
Default(env.InstallTCLScript(radbin('trad'), 'trad.wsh'))
| 87 |
| 88 |
# Those don't really work yet
| 89 |
#else:
| 90 |
# for s in Split('''objview glare rlux '''):
| 91 |
# prog = env.Program(target=radbin(s), source=s+'.c')
| 92 |
# progs.append(prog)
| 93 |
| 94 |
Default('#src/util')
| 95 |
env.Install('$RAD_BINDIR', progs)
| 96 |
| 97 |
# vim: set syntax=python:
