root/radiance/ray/src/util/SConscript
Revision: 1.19
Committed: Sat Mar 5 00:29:28 2016 UTC (9 years, 5 months ago) by schorsch
Changes since 1.18: +5 -8 lines
update SCons
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = ['$RAD_MLIB']
6 progs = []
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
11
12 Version = env.Object(source='#src/rt/Version.c')
13
14 # standard targets
15 PROGS = [
16 ('findglare', Split('findglare.c glareval.c glaresrc.c setscan.c'),
17 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']),
18 ('glarendx', Split('glarendx.c'), ['rtpic','rtargs','rtio','rtmath']),
19 ('vwright', Split('vwright.c'), ['rtpic','rtargs','rtio','rtmath']),
20 ('vwrays', Split('vwrays.c'), ['rtpic','rtargs','rtio','rtmath']),
21 ('rad', Split('rad.c'),
22 ['rtpic','rtproc','rtpath','rtmath','rtargs','rtio','rtcont','rtmem','rterror']),
23 ('rpiece', Split('rpiece.c') + [Version],
24 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']),
25 ('ranimate', ['ranimate.c', '$RAD_NETCOMPAT'],
26 ['rtpic','rtargs','rtio','rtproc','rtcont','rtmem','rtpath','rtmath',
27 'rtnet','rterror','$RAD_SOCKETLIB']),
28 ('dctimestep', Split('dctimestep.c cmbsdf.c cmatrix.c'),
29 ['rtall'])
30 ]
31
32 for p in PROGS:
33 prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
34 progs.append(prog)
35
36 #if os.name != 'nt': # XXX pending Windows version of raypcalls.c
37 if True: # experimental raypwin.c
38 # targets with different includes/libs
39 rs = Split('ranimove.c ranimove1.c ranimove2.c')
40 ranimove = env.Program(target=radbin('ranimove'), source=rs,
41 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
42 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtmath',
43 'rtnet','rtcont','rtmem','rtargs','rtio','rtproc','rtpath','rterror']
44 + mlib)
45 progs.append(ranimove)
46 rsensor = env.Program(target=radbin('rsensor'), source='rsensor.c',
47 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
48 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtmath',
49 'rtcont','rtmem','rtargs','rtio','rtpath','rterror','rtproc',
50 'rtnet','rtlamps'] + mlib)
51 progs.append(rsensor)
52
53 getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c',
54 LIBS=['rtio'])
55 progs.append(getinfo)
56
57
58 # X11 targets
59 if env.has_key('X11LIB'):
60 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
61 xlibp = env.get('LIBPATH', []) + ['$X11LIB']
62 xglaresrc = env.Program(target=radbin('xglaresrc'),
63 source=Split('xglaresrc.c') + [env.x11findwind], # XXX remote magic
64 LIBPATH=xlibp, CPPPATH=xincl,
65 LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib)
66 progs.append(xglaresrc)
67
68 # OpenGL targets that also depend on X11
69 if env.has_key('OGL'):
70 glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'),
71 CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'],
72 LIBPATH=xlibp, CPPPATH=xincl,
73 LIBS=['rgl','rtpic','rtscene','rtproc','rtpath','rtargs','rtio',
74 'rtmath','rtcont','rtmem','rterror','rtdummy',
75 'GL', 'GLU','X11'] + mlib,)
76 progs.append(glrad)
77
78 if os.name == 'posix': # XXX ignoring trad.wsh
79 for s in Split('''objview objline objpict glare dayfact
80 debugcal rlux raddepend compamb vinfo genambpos fieldcomb'''):
81 Default(env.InstallScript(radbin(s), s + '.csh'))
82 # Those don't really work yet
83 #else:
84 # for s in Split('''objview glare rlux '''):
85 # prog = env.Program(target=radbin(s), source=s+'.c')
86 # progs.append(prog)
87
88 Default('#src/util')
89 env.Install('$RAD_BINDIR', progs)
90
