root/Development/ray/src/util/SConscript
Revision: 1.5
Committed: Sun Jul 4 12:08:48 2004 UTC (21 years, 6 months ago) by schorsch
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = env['RAD_MLIB']
6
7 # compose paths
8 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
9 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
10
11 setscan = env.Object(source='setscan.c')
12 Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice
13
14 # standard targets
15 PROGS = [
16 ('findglare', Split('findglare.c glareval.c glaresrc.c')+[setscan],
17 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']),
18 #('contour', Split('contour.c'), ['rtmath']), # XXX what is this?
19 ('glarendx', Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']),
20 ('vwright', Split('vwright.c'), ['rtpic','rtio','rtargs','rtmath']),
21 ('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']),
22 ('rad', Split('rad.c'),
23 ['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']),
24 ('rpiece', Split('rpiece.c') + [Version],
25 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']),
26 ]
27 if os.name == 'nt': # XXX should be set in a *.cfg file
28 netproc = 'win_netproc.c'
29 netlib = ['ws2_32']
30 else:
31 netproc = 'netproc.c'
32 netlib = []
33
34 PROGS.append(('ranimate', ['ranimate.c', netproc],
35 ['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath','rtnet','rterror'] + netlib))
36 for p in PROGS:
37 prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
38 Default(prog)
39 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
40
41 if os.name != 'nt': # XXX pending Windows version of raypcalls.c
42 # targets with different includes/libs
43 rs = Split('ranimove.c ranimove1.c ranimove2.c')
44 ranimove = env.Program(target=radbin('ranimove'), source=rs,
45 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
46 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio',
47 'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib)
48 Default(ranimove)
49 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], ranimove)])
50
51 getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c',
52 LIBS=['rtio'])
53 Default(getinfo)
54 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], getinfo)])
55
56 # special targets not normally built
57 if os.name != 'nt': # XXX pending replacement of fork() and friends
58 scanner = env.Program(target=radbin('scanner'), source='scanner.c',
59 LIBS=mlib)
60 scanner_i = env.Install(env['RAD_BINDIR'], scanner)
61 makedist = env.Program(target=radbin('makedist'),
62 source=Split('makedist.c')+[setscan],
63 LIBS=['rtmath']+mlib)
64 makedist_i = env.Install(env['RAD_BINDIR'], makedist)
65 env.Alias('util_special', [scanner, makedist])
66 env.Alias('util_special_install', [scanner_i, makedist_i])
67
68 # X11 targets
69 if env.has_key('X11LIB'):
70 xlibp = env.get('LIBPATH',[]) + [env['X11LIB']]
71 xincl = env.get('CPPPATH',[]) + [env['X11INCLUDE']]
72 x11findwind = env.Object(source='../common/x11findwind.c') # XXX ../
73 xglaresrc = env.Program(target=radbin('xglaresrc'),
74 source=Split('xglaresrc.c') + [x11findwind],
75 LIBPATH=xlibp, CPPPATH=xincl,
76 LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib)
77 Default(xglaresrc)
78 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], xglaresrc)])
79
80 # OpenGL targets that also depend on X11
81 if env.has_key('OGL'):
82 glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'),
83 CPPFLAGS=env.get('CPPFLAGS', []) + [env['RAD_STEREO']],
84 LIBPATH=xlibp, CPPPATH=xincl,
85 LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs',
86 'rtmath','rtcont','rtmem','rterror',
87 'GL', 'GLU','X11'],)
88 Default(glrad)
89 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], glrad)])
90
91
