root/radiance/ray/src/util/SConscript
Revision: 1.9
Committed: Fri Nov 5 22:15:44 2004 UTC (20 years, 6 months ago) by schorsch
Changes since 1.8: +0 -11 lines
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = ['$RAD_MLIB']
6 progs = []
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
11
12 setscan = env.Object(source='setscan.c')
13 Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice
14
15 # standard targets
16 PROGS = [
17 ('findglare', Split('findglare.c glareval.c glaresrc.c')+[setscan],
18 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']),
19 #('contour', Split('contour.c'), ['rtmath']), # XXX what is this?
20 ('glarendx', Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']),
21 ('vwright', Split('vwright.c'), ['rtpic','rtio','rtargs','rtmath']),
22 ('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']),
23 ('rad', Split('rad.c'),
24 ['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']),
25 ('rpiece', Split('rpiece.c') + [Version],
26 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']),
27 ]
28 if os.name == 'nt': # XXX should be set in a *.cfg file
29 netproc = 'win_netproc.c'
30 netlib = ['ws2_32']
31 else:
32 netproc = 'netproc.c'
33 netlib = []
34
35 PROGS.append(('ranimate', ['ranimate.c', netproc],
36 ['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath','rtnet','rterror'] + netlib))
37 for p in PROGS:
38 prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
39 progs.append(prog)
40
41 if os.name != 'nt': # XXX pending Windows version of raypcalls.c
42 # targets with different includes/libs
43 rs = Split('ranimove.c ranimove1.c ranimove2.c')
44 ranimove = env.Program(target=radbin('ranimove'), source=rs,
45 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
46 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio',
47 'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib)
48 progs.append(ranimove)
49
50 getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c',
51 LIBS=['rtio'])
52 progs.append(getinfo)
53
54
55 # X11 targets
56 if env.has_key('X11LIB'):
57 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
58 xlibp = env.get('LIBPATH', []) + ['$X11LIB']
59 x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice
60 CPPPATH=xincl)
61 xglaresrc = env.Program(target=radbin('xglaresrc'),
62 source=Split('xglaresrc.c') + [x11findwind],
63 LIBPATH=xlibp, CPPPATH=xincl,
64 LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib)
65 progs.append(xglaresrc)
66
67 # OpenGL targets that also depend on X11
68 if env.has_key('OGL'):
69 glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'),
70 CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'],
71 LIBPATH=xlibp, CPPPATH=xincl,
72 LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs',
73 'rtmath','rtcont','rtmem','rterror',
74 'GL', 'GLU','X11'],)
75 progs.append(glrad)
76
77 if os.name == 'posix': # XXX ignoring trad.wsh
78 for s in Split('''objview objline objpict
79 glare dayfact debugcal rlux raddepend compamb vinfo genambpos'''):
80 Default(env.InstallCsh(radbin(s), s + '.csh'))
81 # Those don't really work yet
82 #else:
83 # for s in Split('''objview glare rlux '''):
84 # prog = env.Program(target=radbin(s), source=s+'.c')
85 # progs.append(prog)
86
87 Default('#src/util')
88 env.Install('$RAD_BINDIR', progs)
89
