| 1 |
import os
| 2 |
| 3 |
Import('env') # inherit from parent
| 4 |
| 5 |
mlib = env['RAD_MLIB']
| 6 |
| 7 |
# compose paths
| 8 |
def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
| 9 |
def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
| 10 |
| 11 |
setscan = env.Object(source='setscan.c')
| 12 |
| 13 |
# standard targets
| 14 |
PROGS = [
| 15 |
('findglare', Split('findglare.c glareval.c glaresrc.c')+[setscan],
| 16 |
['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']),
| 17 |
#('contour', Split('contour.c'), ['rtmath']), # XXX what is this?
| 18 |
('glarendx', Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']),
| 19 |
('vwright', Split('vwright.c'), ['rtpic','rtio','rtargs','rtmath']),
| 20 |
('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']),
| 21 |
('rad', Split('rad.c'),
| 22 |
['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']),
| 23 |
('rpiece', Split('rpiece.c Version.c'),
| 24 |
['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']),
| 25 |
| 26 |
if os.name == 'nt': # XXX should be set in a *.cfg file
| 27 |
netproc = 'win_netproc.c'
| 28 |
netlib = ['ws2_32']
| 29 |
else:
| 30 |
netproc = 'netproc.c'
| 31 |
netlib = []
| 32 |
| 33 |
PROGS.append(('ranimate', ['ranimate.c', netproc],
| 34 |
['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath','rtnet','rterror'] + netlib))
| 35 |
for p in PROGS:
| 36 |
prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
| 37 |
Default(prog)
| 38 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
| 39 |
| 40 |
if os.name != 'nt': # XXX pending Windows version of raypcalls.c
| 41 |
# targets with different includes/libs
| 42 |
rs = Split('ranimove.c ranimove1.c ranimove2.c')
| 43 |
ranimove = env.Program(target=radbin('ranimove'), source=rs,
| 44 |
CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
| 45 |
LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio',
| 46 |
'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib)
| 47 |
Default(ranimove)
| 48 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], ranimove)])
| 49 |
| 50 |
getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c',
| 51 |
LIBS=['rtio'])
| 52 |
Default(getinfo)
| 53 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], getinfo)])
| 54 |
| 55 |
# special targets not normally built
| 56 |
if os.name != 'nt': # XXX pending replacement of fork() and friends
| 57 |
scanner = env.Program(target=radbin('scanner'), source='scanner.c',
| 58 |
LIBS=mlib)
| 59 |
scanner_i = env.Install(env['RAD_BINDIR'], scanner)
| 60 |
makedist = env.Program(target=radbin('makedist'),
| 61 |
source=Split('makedist.c')+[setscan],
| 62 |
LIBS=['rtmath']+mlib)
| 63 |
makedist_i = env.Install(env['RAD_BINDIR'], makedist)
| 64 |
env.Alias('util_special', [scanner, makedist])
| 65 |
env.Alias('util_special_install', [scanner_i, makedist_i])
| 66 |
| 67 |
# X11 targets
| 68 |
if env.has_key('X11LIB'):
| 69 |
xlibp = env.get('LIBPATH',[]) + [env['X11LIB']]
| 70 |
xincl = env.get('CPPPATH',[]) + [env['X11INCLUDE']]
| 71 |
xglaresrc = env.Program(target=radbin('xglaresrc'),
| 72 |
source=Split('xglaresrc.c x11findwind.c'),
| 73 |
LIBPATH=xlibp, CPPPATH=xincl,
| 74 |
LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib)
| 75 |
Default(xglaresrc)
| 76 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], xglaresrc)])
| 77 |
| 78 |
# OpenGL targets that also depend on X11
| 79 |
if env.has_key('OGL'):
| 80 |
glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'),
| 81 |
CPPFLAGS=env.get('CPPFLAGS', []) + [env['RAD_STEREO']],
| 82 |
| 83 |
LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs',
| 84 |
'rtmath','rtcont','rtmem','rterror',
| 85 |
'GL', 'GLU','X11'],)
| 86 |
Default(glrad)
| 87 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], glrad)])
| 88 |
| 89 |
