| 1 | import os |
| 2 |  |
| 3 | Import('env') # inherit from parent |
| 4 |  |
| 5 | mlib = ['$RAD_MLIB'] |
| 6 | progs = [] |
| 7 |  |
| 8 | # compose paths |
| 9 | def radbin(name): return os.path.join('$RAD_BUILDBIN', name) |
| 10 | def radlib(name): return os.path.join('$RAD_BUILDLIB', name) |
| 11 |  |
| 12 | setscan = env.Object(source='setscan.c') |
| 13 | Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice |
| 14 |  |
| 15 | # standard targets |
| 16 | PROGS = [ |
| 17 | ('findglare', Split('findglare.c glareval.c glaresrc.c')+[setscan], |
| 18 | ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']), |
| 19 | #('contour',   Split('contour.c'),  ['rtmath']), # XXX what is this? |
| 20 | ('glarendx',  Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']), |
| 21 | ('vwright',   Split('vwright.c'),  ['rtpic','rtio','rtargs','rtmath']), |
| 22 | ('vwrays',    Split('vwrays.c'),   ['rtpic','rtio','rtargs','rtmath']), |
| 23 | ('rad',       Split('rad.c'), |
| 24 | ['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']), |
| 25 | ('rpiece',    Split('rpiece.c') + [Version], |
| 26 | ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']), |
| 27 | ] |
| 28 | if os.name == 'nt': # XXX should be set in a *.cfg file |
| 29 | netproc = 'win_netproc.c' |
| 30 | netlib = ['ws2_32'] |
| 31 | else: |
| 32 | netproc = 'netproc.c' |
| 33 | netlib = [] |
| 34 |  |
| 35 | PROGS.append(('ranimate',  ['ranimate.c', netproc], |
| 36 | ['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath','rtnet','rterror'] + netlib)) |
| 37 | for p in PROGS: |
| 38 | prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib) |
| 39 | progs.append(prog) |
| 40 |  |
| 41 | if os.name != 'nt': # XXX pending Windows version of raypcalls.c |
| 42 | # targets with different includes/libs |
| 43 | rs = Split('ranimove.c ranimove1.c ranimove2.c') |
| 44 | ranimove = env.Program(target=radbin('ranimove'), source=rs, |
| 45 | CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], |
| 46 | LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio', |
| 47 | 'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib) |
| 48 | progs.append(ranimove) |
| 49 |  |
| 50 | getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c', |
| 51 | LIBS=['rtio']) |
| 52 | progs.append(getinfo) |
| 53 |  |
| 54 | # special targets not normally built |
| 55 | if os.name != 'nt': # XXX pending replacement of fork() and friends |
| 56 | scanner = env.Program(target=radbin('scanner'), source='scanner.c', |
| 57 | LIBS=mlib) |
| 58 | scanner_i = env.Install('$RAD_BINDIR', scanner) |
| 59 | makedist = env.Program(target=radbin('makedist'), |
| 60 | source=Split('makedist.c')+[setscan], |
| 61 | LIBS=['rtmath']+mlib) |
| 62 | makedist_i = env.Install('$RAD_BINDIR', makedist) |
| 63 | env.Alias('util_special', [scanner, makedist]) |
| 64 | env.Alias('util_special_install', [scanner_i, makedist_i]) |
| 65 |  |
| 66 | # X11 targets |
| 67 | if env.has_key('X11LIB'): |
| 68 | xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] |
| 69 | xlibp = env.get('LIBPATH', []) + ['$X11LIB'] |
| 70 | x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice |
| 71 | CPPPATH=xincl) |
| 72 | xglaresrc = env.Program(target=radbin('xglaresrc'), |
| 73 | source=Split('xglaresrc.c') + [x11findwind], |
| 74 | LIBPATH=xlibp, CPPPATH=xincl, |
| 75 | LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib) |
| 76 | progs.append(xglaresrc) |
| 77 |  |
| 78 | # OpenGL targets that also depend on X11 |
| 79 | if env.has_key('OGL'): |
| 80 | glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'), |
| 81 | CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'], |
| 82 | LIBPATH=xlibp, CPPPATH=xincl, |
| 83 | LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs', |
| 84 | 'rtmath','rtcont','rtmem','rterror', |
| 85 | 'GL', 'GLU','X11'],) |
| 86 | progs.append(glrad) |
| 87 |  |
| 88 | if os.name == 'posix': # XXX ignoring trad.wsh |
| 89 | for s in Split('''objview objline objpict |
| 90 | glare dayfact debugcal rlux raddepend compamb vinfo genambpos'''): |
| 91 | Default(env.InstallCsh(radbin(s), s + '.csh')) |
| 92 |  |
| 93 | Default('#src/util') |
| 94 | env.Install('$RAD_BINDIR', progs) |
| 95 |  |
