root/radiance/ray/src/util/SConscript
Revision: 1.1
Committed: Tue Oct 21 19:27:29 2003 UTC (21 years, 9 months ago) by schorsch
1 import os
2
3 Import('env') # inherit from parent
4
5 # make a modified local copy
6 util = env.Copy(LIBS=['rt'] + env['RAD_MLIB'])
7
8 # compose paths
9 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
11
12 # standard targets
13 PROGS = [
14 ('findglare', Split('findglare.c glareval.c glaresrc.c setscan.c')),
15 ('glarendx', Split('glarendx.c')),
16 ('vwright', Split('vwright.c')),
17 ('vwrays', Split('vwrays.c')),
18 ('rad', Split('rad.c')),
19 ('rpiece', Split('rpiece.c Version.c')),
20 ]
21 if os.name != 'nt': # XXX pending Windows version of netproc.c
22 PROGS.append(('ranimate', Split('ranimate.c netproc.c')))
23 for p in PROGS:
24 prog = util.Program(target=radbin(p[0]), source=p[1])
25 Default(prog)
26 env.Append(RAD_BININSTALL=[util.Install(util['RAD_BINDIR'], prog)])
27
28 if os.name != 'nt': # XXX pending resolution of free_os() conflict
29 # targets with different includes/libs
30 rs = Split('ranimove.c ranimove1.c ranimove2.c')
31 for l in ['raycalls', 'radiance']: # XXX ugly
32 rs.append(radlib(util['LIBPREFIX'] + l + util['LIBSUFFIX']))
33 ranimove = util.Program(target=radbin('ranimove'), source=rs,
34 CPPPATH=util.get('CPPPATH', []) + ['#src/rt'])
35 Default(ranimove)
36 env.Append(RAD_BININSTALL=[util.Install(util['RAD_BINDIR'], ranimove)])
37
38 getinfo = util.Program(target=radbin('getinfo'), source='getinfo.c',
39 LIBS=['rt'])
40 Default(getinfo)
41 env.Append(RAD_BININSTALL=[util.Install(util['RAD_BINDIR'], getinfo)])
42
43 # special targets not normally built
44 scanner = util.Program(target=radbin('scanner'), source='scanner.c', LIBS=['m'])
45 makedist = util.Program(target=radbin('makedist'),
46 source=Split('makedist.c setscan.c'))
47 scanner_i = util.Install(util['RAD_BINDIR'], scanner)
48 makedist_i = util.Install(util['RAD_BINDIR'], makedist)
49 util.Alias('util_special', [scanner, makedist])
50 util.Alias('util_special_install', [scanner_i, makedist_i])
51
52 # X11 targets
53 if util.has_key('X11LIB'):
54 util.Append(CPPPATH=util['X11INCLUDE'])
55 util.Append(LIBS='X11')
56 util.Append(LIBPATH=util['X11LIB'])
57 xglaresrc = util.Program(target=radbin('xglaresrc'),
58 source=Split('xglaresrc.c x11findwind.c'),)
59 Default(xglaresrc)
60 env.Append(RAD_BININSTALL=[util.Install(util['RAD_BINDIR'], xglaresrc)])
61
62 # OpenGL targets that also depend on X11
63 if util.has_key('OGL'):
64 glrad = util.Program(target=radbin('glrad'), source=Split('glrad.c'),
65 CPPFLAGS=util.get('CPPFLAGS', []) + [util['RAD_STEREO']],
66 LIBS=['rgl', 'GL', 'GLU']+util['LIBS'],)
67 Default(glrad)
68 env.Append(RAD_BININSTALL=[util.Install(util['RAD_BINDIR'], glrad)])
69
70
