1 |
import os |
2 |
3 |
Import('env') # inherit from parent |
4 |
5 |
mlib = ['$RAD_MLIB'] |
6 |
progs = [] |
7 |
8 |
# compose paths |
9 |
def radbin(name): return os.path.join('$RAD_BUILDBIN', name) |
10 |
def radlib(name): return os.path.join('$RAD_BUILDLIB', name) |
11 |
def tclscr(name): return os.path.join('$RAD_BUILDRLIB', 'tcl', name) |
12 |
13 |
cmatrix = env.Object(source='cmatrix.c') |
14 |
cmbsdf = env.Object(source='cmbsdf.c') |
15 |
16 |
# standard targets |
17 |
PROGS = [ |
18 |
('findglare', Split('findglare.c glareval.c glaresrc.c setscan.c'), ['rtrad']), |
19 |
('glarendx', Split('glarendx.c'), ['rtrad']), |
20 |
('vwright', Split('vwright.c'), ['rtrad']), |
21 |
('vwrays', Split('vwrays.c'), ['rtrad']), |
22 |
('rad', Split('rad.c'), ['rtrad']), |
23 |
('rpiece', Split('rpiece.c') + [env.version], ['rtrad']), |
24 |
('ranimate', ['ranimate.c', '$RAD_NETCOMPAT'], ['rtrad', '$RAD_SOCKETLIB']), |
25 |
('dctimestep', Split('dctimestep.c')+[cmatrix, cmbsdf], ['rtrad']), |
26 |
('rttree_reduce', Split('rttree_reduce.c'), ['rtrad']), |
27 |
('rcollate', Split('rcollate.c'), ['rtrad']), |
28 |
('eplus_adduvf', Split('eplus_adduvf.c eplus_idf.c'), ['rtrad']), |
29 |
('rfluxmtx', Split('rfluxmtx.c'), ['rtrad']), |
30 |
('rmtxop', Split('rmtxop.c rmatrix.c')+[cmatrix, cmbsdf], ['rtrad']), |
31 |
('wrapBSDF', Split('wrapBSDF.c'), ['rtrad']), |
32 |
('evalglare', Split('evalglare.c pictool.c'), ['rtrad', 'reetz']), |
33 |
34 |
35 |
for p in PROGS: |
36 |
prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib) |
37 |
progs.append(prog) |
38 |
39 |
# targets with different includes/libs |
40 |
rs = Split('ranimove.c ranimove1.c ranimove2.c') |
41 |
ranimove = env.Program(target=radbin('ranimove'), source=rs, |
42 |
CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], |
43 |
LIBS=['raycalls','rttrace','rtrad'] + mlib) |
44 |
progs.append(ranimove) |
45 |
rsensor = env.Program(target=radbin('rsensor'), source='rsensor.c', |
46 |
47 |
48 |
progs.append(rsensor) |
49 |
50 |
getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c', |
51 |
LIBS=['rtrad']) |
52 |
progs.append(getinfo) |
53 |
54 |
55 |
# X11 targets |
56 |
if env.has_key('X11LIB'): |
57 |
xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] |
58 |
xlibp = env.get('LIBPATH', []) + ['$X11LIB'] |
59 |
xglaresrc = env.Program(target=radbin('xglaresrc'), |
60 |
source=Split('xglaresrc.c') + [env.x11findwind], # XXX remote magic |
61 |
LIBPATH=xlibp, CPPPATH=xincl, |
62 |
LIBS=['rtrad', 'X11']+ mlib) |
63 |
progs.append(xglaresrc) |
64 |
65 |
# OpenGL targets that also depend on X11 |
66 |
if env.has_key('OGL'): |
67 |
glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'), |
68 |
CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'], |
69 |
70 |
LIBS=['rgl','rtrad','rtdummy', 'GL', 'GLU','X11'] + mlib,) |
71 |
progs.append(glrad) |
72 |
73 |
if os.name == 'posix': # XXX ignoring trad.wsh |
74 |
for s in Split('''objline glare dayfact |
75 |
debugcal rlux raddepend compamb vinfo fieldcomb'''): |
76 |
Default(env.InstallScript(radbin(s), s + '.csh')) |
77 |
for s in Split('''objview objpict |
78 |
genambpos genklemsamp genskyvec genBSDF ltview ltpict'''): |
79 |
Default(env.InstallScript(radbin(s), s + '.pl')) |
80 |
for s in Split('''do_action.tcl do_file.tcl do_options.tcl do_results.tcl |
81 |
do_scene.tcl do_views.tcl do_zone.tcl file.hlp getfile.tcl gethelp.tcl |
82 |
help.hlp tclIndex trad.hlp trad.icon util.tcl'''): |
83 |
Default(env.InstallScript(tclscr(s), s)) |
84 |
Default(env.InstallTCLScript(radbin('trad'), 'trad.wsh')) |
85 |
86 |
# Those don't really work yet |
87 |
#else: |
88 |
# for s in Split('''objview glare rlux '''): |
89 |
# prog = env.Program(target=radbin(s), source=s+'.c') |
90 |
# progs.append(prog) |
91 |
92 |
Default('#src/util') |
93 |
env.Install('$RAD_BINDIR', progs) |
94 |
95 |
# vim: set syntax=python: |
