root/radiance/ray/src/util/SConscript
Revision: 1.13
Committed: Mon Sep 19 12:59:49 2005 UTC (19 years, 7 months ago) by schorsch
Added fieldcomb.csh to SCons install.
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = ['$RAD_MLIB']
6 progs = []
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
11
12 Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice
13
14 # standard targets
15 PROGS = [
16 ('findglare', Split('findglare.c glareval.c glaresrc.c setscan.c'),
17 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']),
18 ('glarendx', Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']),
19 ('vwright', Split('vwright.c'), ['rtpic','rtio','rtargs','rtmath']),
20 ('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']),
21 ('rad', Split('rad.c'),
22 ['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']),
23 ('rpiece', Split('rpiece.c') + [Version],
24 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']),
25 ('ranimate', ['ranimate.c', '$RAD_NETCOMPAT'],
26 ['rtpic','rtargs','rtio','rtproc','rtcont','rtmem','rtpath','rtmath',
27 'rtnet','rterror','$RAD_SOCKETLIB']),
28 ('rtcontrib', ['rtcontrib.c', Version],
29 ['rtpic','rtargs','rtfunc','rtio','rtproc','rtcont','rtmem','rtpath',
30 'rtmath','rtnet','rterror','$RAD_SOCKETLIB'])
31 ]
32
33 for p in PROGS:
34 prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
35 progs.append(prog)
36
37 if os.name != 'nt': # XXX pending Windows version of raypcalls.c
38 # targets with different includes/libs
39 rs = Split('ranimove.c ranimove1.c ranimove2.c')
40 ranimove = env.Program(target=radbin('ranimove'), source=rs,
41 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
42 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio',
43 'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib)
44 progs.append(ranimove)
45
46 getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c',
47 LIBS=['rtio'])
48 progs.append(getinfo)
49
50
51 # X11 targets
52 if env.has_key('X11LIB'):
53 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
54 xlibp = env.get('LIBPATH', []) + ['$X11LIB']
55 x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice
56 CPPPATH=xincl)
57 xglaresrc = env.Program(target=radbin('xglaresrc'),
58 source=Split('xglaresrc.c') + [x11findwind],
59 LIBPATH=xlibp, CPPPATH=xincl,
60 LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib)
61 progs.append(xglaresrc)
62
63 # OpenGL targets that also depend on X11
64 if env.has_key('OGL'):
65 glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'),
66 CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'],
67 LIBPATH=xlibp, CPPPATH=xincl,
68 LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs',
69 'rtmath','rtcont','rtmem','rterror',
70 'GL', 'GLU','X11'],)
71 progs.append(glrad)
72
73 if os.name == 'posix': # XXX ignoring trad.wsh
74 for s in Split('''objview objline objpict glare dayfact
75 debugcal rlux raddepend compamb vinfo genambpos fieldcomb'''):
76 Default(env.InstallCsh(radbin(s), s + '.csh'))
77 # Those don't really work yet
78 #else:
79 # for s in Split('''objview glare rlux '''):
80 # prog = env.Program(target=radbin(s), source=s+'.c')
81 # progs.append(prog)
82
83 Default('#src/util')
84 env.Install('$RAD_BINDIR', progs)
85
