--- ray/src/util/SConscript 2004/03/26 23:34:23 1.3 +++ ray/src/util/SConscript 2004/10/21 15:47:13 1.7 @@ -2,13 +2,15 @@ import os Import('env') # inherit from parent -mlib = env['RAD_MLIB'] +mlib = ['$RAD_MLIB'] +progs = [] # compose paths -def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) -def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) +def radbin(name): return os.path.join('$RAD_BUILDBIN', name) +def radlib(name): return os.path.join('$RAD_BUILDLIB', name) setscan = env.Object(source='setscan.c') +Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice # standard targets PROGS = [ @@ -20,7 +22,7 @@ PROGS = [ ('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']), ('rad', Split('rad.c'), ['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']), -('rpiece', Split('rpiece.c Version.c'), +('rpiece', Split('rpiece.c') + [Version], ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']), ] if os.name == 'nt': # XXX should be set in a *.cfg file @@ -34,8 +36,7 @@ PROGS.append(('ranimate', ['ranimate.c', netproc], ['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath','rtnet','rterror'] + netlib)) for p in PROGS: prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib) - Default(prog) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) + progs.append(prog) if os.name != 'nt': # XXX pending Windows version of raypcalls.c # targets with different includes/libs @@ -44,45 +45,51 @@ if os.name != 'nt': # XXX pending Windows version of r CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'], LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio', 'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib) - Default(ranimove) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], ranimove)]) + progs.append(ranimove) getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c', LIBS=['rtio']) -Default(getinfo) -env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], getinfo)]) +progs.append(getinfo) # special targets not normally built if os.name != 'nt': # XXX pending replacement of fork() and friends scanner = env.Program(target=radbin('scanner'), source='scanner.c', LIBS=mlib) - scanner_i = env.Install(env['RAD_BINDIR'], scanner) + scanner_i = env.Install('$RAD_BINDIR', scanner) makedist = env.Program(target=radbin('makedist'), - source=Split('makedist.c')+[setscan]) - makedist_i = env.Install(env['RAD_BINDIR'], makedist) + source=Split('makedist.c')+[setscan], + LIBS=['rtmath']+mlib) + makedist_i = env.Install('$RAD_BINDIR', makedist) env.Alias('util_special', [scanner, makedist]) env.Alias('util_special_install', [scanner_i, makedist_i]) # X11 targets if env.has_key('X11LIB'): - xlibp = env.get('LIBPATH',[]) + [env['X11LIB']] - xincl = env.get('CPPPATH',[]) + [env['X11INCLUDE']] + xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] + xlibp = env.get('LIBPATH', []) + ['$X11LIB'] + x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice + CPPPATH=xincl) xglaresrc = env.Program(target=radbin('xglaresrc'), - source=Split('xglaresrc.c x11findwind.c'), + source=Split('xglaresrc.c') + [x11findwind], LIBPATH=xlibp, CPPPATH=xincl, LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib) - Default(xglaresrc) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], xglaresrc)]) + progs.append(xglaresrc) # OpenGL targets that also depend on X11 if env.has_key('OGL'): glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'), - CPPFLAGS=env.get('CPPFLAGS', []) + [env['RAD_STEREO']], + CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'], LIBPATH=xlibp, CPPPATH=xincl, LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs', 'rtmath','rtcont','rtmem','rterror', 'GL', 'GLU','X11'],) - Default(glrad) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], glrad)]) + progs.append(glrad) +if os.name == 'posix': # XXX ignoring trad.wsh + for s in Split('''objview objline objpict + glare dayfact debugcal rlux raddepend compamb vinfo genambpos'''): + Default(env.InstallCsh(radbin(s), s + '.csh')) + +Default('#src/util') +env.Install('$RAD_BINDIR', progs)
