root/Development/ray/src/util/SConscript
Revision: 1.11
Committed: Wed Sep 14 09:28:35 2005 UTC (20 years, 3 months ago) by schorsch
Changes since 1.10: +2 -1 lines
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = ['$RAD_MLIB']
6 progs = []
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
11
12 Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice
13
14 # standard targets
15 PROGS = [
16 ('findglare', Split('findglare.c glareval.c glaresrc.c setscan.c'),
17 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']),
18 ('glarendx', Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']),
19 ('vwright', Split('vwright.c'), ['rtpic','rtio','rtargs','rtmath']),
20 ('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']),
21 ('rad', Split('rad.c'),
22 ['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']),
23 ('rpiece', Split('rpiece.c') + [Version],
24 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']),
25 ]
26 if os.name == 'nt': # XXX should be set in a *.cfg file
27 netproc = 'win_netproc.c'
28 netlib = ['ws2_32']
29 else:
30 netproc = 'netproc.c'
31 netlib = []
32
33 PROGS.append(('ranimate', ['ranimate.c', netproc],
34 ['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath',
35 'rtnet','$RAD_SOCKETLIB','rterror'] + netlib))
36 for p in PROGS:
37 prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
38 progs.append(prog)
39
40 if os.name != 'nt': # XXX pending Windows version of raypcalls.c
41 # targets with different includes/libs
42 rs = Split('ranimove.c ranimove1.c ranimove2.c')
43 ranimove = env.Program(target=radbin('ranimove'), source=rs,
44 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
45 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio',
46 'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib)
47 progs.append(ranimove)
48
49 getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c',
50 LIBS=['rtio'])
51 progs.append(getinfo)
52
53
54 # X11 targets
55 if env.has_key('X11LIB'):
56 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
57 xlibp = env.get('LIBPATH', []) + ['$X11LIB']
58 x11findwind = env.Object(source='../common/x11findwind.c', # XXX ../not/nice
59 CPPPATH=xincl)
60 xglaresrc = env.Program(target=radbin('xglaresrc'),
61 source=Split('xglaresrc.c') + [x11findwind],
62 LIBPATH=xlibp, CPPPATH=xincl,
63 LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib)
64 progs.append(xglaresrc)
65
66 # OpenGL targets that also depend on X11
67 if env.has_key('OGL'):
68 glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'),
69 CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'],
70 LIBPATH=xlibp, CPPPATH=xincl,
71 LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs',
72 'rtmath','rtcont','rtmem','rterror',
73 'GL', 'GLU','X11'],)
74 progs.append(glrad)
75
76 if os.name == 'posix': # XXX ignoring trad.wsh
77 for s in Split('''objview objline objpict
78 glare dayfact debugcal rlux raddepend compamb vinfo genambpos'''):
79 Default(env.InstallCsh(radbin(s), s + '.csh'))
80 # Those don't really work yet
81 #else:
82 # for s in Split('''objview glare rlux '''):
83 # prog = env.Program(target=radbin(s), source=s+'.c')
84 # progs.append(prog)
85
86 Default('#src/util')
87 env.Install('$RAD_BINDIR', progs)
88
