root/radiance/ray/src/util/SConscript
Revision: 1.2
Committed: Mon Oct 27 10:35:43 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 1.1: +62 -45 lines
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = env['RAD_MLIB']
6
7 # compose paths
8 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
9 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
10
11 setscan = env.Object(source='setscan.c')
12
13 # standard targets
14 PROGS = [
15 ('findglare', Split('findglare.c glareval.c glaresrc.c')+[setscan],
16 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem','rterror']),
17 ('glarendx', Split('glarendx.c'), ['rtpic','rtio','rtargs','rtmath']),
18 ('vwright', Split('vwright.c'), ['rtpic','rtio','rtargs','rtmath']),
19 ('vwrays', Split('vwrays.c'), ['rtpic','rtio','rtargs','rtmath']),
20 ('rad', Split('rad.c'),
21 ['rtpic','rtproc','rtpath','rtio','rtmath','rtargs','rtcont','rtmem','rterror']),
22 ('rpiece', Split('rpiece.c Version.c'),
23 ['rtpic','rtargs','rtio','rtproc','rtmath','rtpath','rtmem']),
24 ]
25 if os.name == 'nt': # XXX should be set in a *.cfg file
26 netproc = 'win_netproc.c'
27 netlib = ['ws2_32']
28 else:
29 netproc = 'netproc.c'
30 netlib = []
31
32 PROGS.append(('ranimate', ['ranimate.c', netproc],
33 ['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath','rtnet','rterror'] + netlib))
34 for p in PROGS:
35 prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
36 Default(prog)
37 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
38
39 if os.name != 'nt': # XXX pending Windows version of raypcalls.c
40 # targets with different includes/libs
41 rs = Split('ranimove.c ranimove1.c ranimove2.c')
42 ranimove = env.Program(target=radbin('ranimove'), source=rs,
43 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
44 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio',
45 'rtmath','rtcont','rtmem','rtargs','rtproc','rtpath','rterror'] + mlib)
46 Default(ranimove)
47 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], ranimove)])
48
49 getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c',
50 LIBS=['rtio'])
51 Default(getinfo)
52 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], getinfo)])
53
54 # special targets not normally built
55 if os.name != 'nt': # XXX pending replacement of fork() and friends
56 scanner = env.Program(target=radbin('scanner'), source='scanner.c',
57 LIBS=mlib)
58 scanner_i = env.Install(env['RAD_BINDIR'], scanner)
59 makedist = env.Program(target=radbin('makedist'),
60 source=Split('makedist.c')+[setscan])
61 makedist_i = env.Install(env['RAD_BINDIR'], makedist)
62 env.Alias('util_special', [scanner, makedist])
63 env.Alias('util_special_install', [scanner_i, makedist_i])
64
65 # X11 targets
66 if env.has_key('X11LIB'):
67 xlibp = env.get('LIBPATH',[]) + [env['X11LIB']]
68 xincl = env.get('CPPPATH',[]) + [env['X11INCLUDE']]
69 xglaresrc = env.Program(target=radbin('xglaresrc'),
70 source=Split('xglaresrc.c x11findwind.c'),
71 LIBPATH=xlibp, CPPPATH=xincl,
72 LIBS=['rtpic','rtmath','rtargs','rtio','X11']+ mlib)
73 Default(xglaresrc)
74 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], xglaresrc)])
75
76 # OpenGL targets that also depend on X11
77 if env.has_key('OGL'):
78 glrad = env.Program(target=radbin('glrad'), source=Split('glrad.c'),
79 CPPFLAGS=env.get('CPPFLAGS', []) + [env['RAD_STEREO']],
80 LIBPATH=xlibp, CPPPATH=xincl,
81 LIBS=['rgl','rtpic','rtscene','rtio','rtproc','rtpath','rtargs',
82 'rtmath','rtcont','rtmem','rterror',
83 'GL', 'GLU','X11'],)
84 Default(glrad)
85 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], glrad)])
86
87
