root/radiance/ray/src/util/Rmakefile
Revision: 2.98
Committed: Mon Mar 2 22:00:05 2020 UTC (4 years ago) by greg
Changes since 2.97: +3 -2 lines
Switched pipe output to use open_process() call on Unix
1 # RCSid: $Id: Rmakefile,v 2.97 2019/09/10 17:25:02 greg Exp $
2 #
3 # Radiance makefile for utility programs
4 #
5
6 MACH = -DBSD
7
8 OPT = -O
9
10 CFLAGS = -I../common -I../rt -L../lib $(OPT) $(MACH)
11
12 MLIB = -lm
13
14 CC = cc
15
16 SPECIAL =
17
18 INSTDIR = /usr/local/bin
19
20 LIBDIR = /usr/local/lib/ray
21
22 PROGS = findglare glarendx rpiece rad ranimate ranimove vwright getinfo \
23 vwrays xglaresrc rsensor dctimestep rttree_reduce rcollate \
24 eplus_adduvf rfluxmtx rmtxop wrapBSDF evalglare radcompare \
25 rcode_depth rcode_norm rcode_ident dcglare
26
27 LIBFILES = rambpos.cal ambpos.cal tregsamp.dat reinhartb.cal \
28 klems_full.cal klems_half.cal klems_quarter.cal disk2square.cal \
29 minimalBSDFt.xml WINDOW6BSDFt.xml
30
31 all: $(PROGS)
32
33 install: all $(SPECIAL) objview.pl objpict.pl glare.csh dayfact.csh \
34 rlux.csh raddepend.csh trad.wsh objline.csh compamb.csh vinfo.csh \
35 ltview.pl ltpict.pl genambpos.pl fieldcomb.csh genklemsamp.pl \
36 genskyvec.pl genBSDF.pl bsdfview.pl rtpict.pl rcode2bmp.pl $(LIBFILES)
37 cp $(PROGS) $(INSTDIR)
38 cp objview.pl $(INSTDIR)/objview
39 cp objline.csh $(INSTDIR)/objline
40 cp objpict.pl $(INSTDIR)/objpict
41 cp glare.csh $(INSTDIR)/glare
42 cp dayfact.csh $(INSTDIR)/dayfact
43 cp debugcal.csh $(INSTDIR)/debugcal
44 cp rlux.csh $(INSTDIR)/rlux
45 cp raddepend.csh $(INSTDIR)/raddepend
46 cp compamb.csh $(INSTDIR)/compamb
47 cp vinfo.csh $(INSTDIR)/vinfo
48 cp genambpos.pl $(INSTDIR)/genambpos
49 cp fieldcomb.csh $(INSTDIR)/fieldcomb
50 cp genklemsamp.pl $(INSTDIR)/genklemsamp
51 cp genskyvec.pl $(INSTDIR)/genskyvec
52 cp genBSDF.pl $(INSTDIR)/genBSDF
53 cp bsdfview.pl $(INSTDIR)/bsdfview
54 cp ltview.pl $(INSTDIR)/ltview
55 cp ltpict.pl $(INSTDIR)/ltpict
56 cp rtpict.pl $(INSTDIR)/rtpict
57 cp rcode2bmp.pl $(INSTDIR)/rcode2bmp
58 cd $(INSTDIR) ; chmod 755 objview objpict \
59 glare dayfact debugcal rlux raddepend objline \
60 compamb vinfo genambpos fieldcomb genklemsamp \
61 genskyvec genBSDF rtpict rcode2bmp
62 cd $(LIBDIR) && rm -f $(LIBFILES)
63 cp $(LIBFILES) $(LIBDIR)
64 csh -f tradinstall.csh $(INSTDIR) $(LIBDIR)/tcl
65
66 clean:
67 set nonomatch; rm -f *.o $(PROGS) glrad Version.c x11findwind.c
68
69 ogl: glrad
70 cp glrad $(INSTDIR)
71
72 sgi:
73
74 sun:
75
76 findglare: findglare.o glareval.o glaresrc.o setscan.o
77 $(CC) $(CFLAGS) -o findglare findglare.o glareval.o glaresrc.o \
78 setscan.o -lrtrad $(MLIB)
79
80 glarendx: glarendx.o
81 $(CC) $(CFLAGS) -o glarendx glarendx.o -lrtrad $(MLIB)
82
83 xglaresrc: xglaresrc.o x11findwind.o
84 $(CC) $(CFLAGS) -o xglaresrc xglaresrc.o \
85 x11findwind.o -lrtrad -lX11 $(MLIB)
86
87 rad: rad.o
88 $(CC) $(CFLAGS) -o rad rad.o -lrtrad $(MLIB)
89
90 ranimate: ranimate.o netproc.o
91 $(CC) $(CFLAGS) -o ranimate ranimate.o netproc.o -lrtrad $(MLIB)
92
93 ranimove: ranimove.o ranimove1.o ranimove2.o
94 $(CC) $(CFLAGS) -o ranimove ranimove.o ranimove1.o ranimove2.o \
95 -lraycalls -lradiance -lrtrad $(MLIB)
96
97 rsensor: rsensor.o
98 $(CC) $(CFLAGS) -o rsensor rsensor.o \
99 -lraycalls -lradiance -lrtrad $(MLIB)
100
101 rpiece: rpiece.o Version.o
102 $(CC) $(CFLAGS) -o rpiece rpiece.o Version.o -lrtrad $(MLIB)
103
104 vwright: vwright.o
105 $(CC) $(CFLAGS) -o vwright vwright.o -lrtrad $(MLIB)
106
107 vwrays: vwrays.o
108 $(CC) $(CFLAGS) -o vwrays vwrays.o -lrtrad $(MLIB)
109
110 getinfo: getinfo.o
111 $(CC) $(CFLAGS) -o getinfo getinfo.o -lrtrad
112
113 glrad: glrad.o
114 $(CC) $(CFLAGS) -o glrad glrad.o -lrgl -lrtrad -lGLU -lGL \
115 -lX11 -lXext $(MLIB)
116
117 dctimestep: dctimestep.o cmbsdf.o cmatrix.o
118 $(CC) $(CFLAGS) -o dctimestep dctimestep.o cmbsdf.o cmatrix.o \
119 -lrtrad $(MLIB)
120
121 rttree_reduce: rttree_reduce.o
122 $(CC) $(CFLAGS) -o rttree_reduce rttree_reduce.o -lrtrad $(MLIB)
123
124 rcollate: rcollate.o
125 $(CC) $(CFLAGS) -o rcollate rcollate.o -lrtrad
126
127 eplus_adduvf: eplus_adduvf.o eplus_idf.o
128 $(CC) $(CFLAGS) -o eplus_adduvf eplus_adduvf.o eplus_idf.o \
129 -lrtrad $(MLIB)
130
131 rfluxmtx: rfluxmtx.o
132 $(CC) $(CFLAGS) -o rfluxmtx rfluxmtx.o -lrtrad $(MLIB)
133
134 rmtxop: rmtxop.o rmatrix.o cmatrix.o cmbsdf.o
135 $(CC) $(CFLAGS) -o rmtxop rmtxop.o rmatrix.o cmatrix.o cmbsdf.o \
136 -lrtrad $(MLIB)
137
138 wrapBSDF: wrapBSDF.o
139 $(CC) $(CFLAGS) -o wrapBSDF wrapBSDF.o -lrtrad $(MLIB)
140
141 evalglare: evalglare.o pictool.o
142 $(CC) $(CFLAGS) -o evalglare evalglare.o pictool.o -lreetz -lrtrad $(MLIB)
143
144 radcompare: radcompare.o
145 $(CC) $(CFLAGS) -o radcompare radcompare.o -lrtrad $(MLIB)
146
147 setscan.o: setscan.h
148
149 rcode_depth: rcode_depth.o
150 $(CC) $(CFLAGS) -o rcode_depth rcode_depth.o \
151 -lrtrad $(MLIB)
152
153 rcode_norm: rcode_norm.o
154 $(CC) $(CFLAGS) -o rcode_norm rcode_norm.o \
155 -lrtrad $(MLIB)
156
157 rcode_ident: rcode_ident.o
158 $(CC) $(CFLAGS) -o rcode_ident rcode_ident.o -lrtrad
159
160 dcglare: dcglare.o cmbsdf.o cmatrix.o cmglare.o
161 $(CC) $(CFLAGS) -o dcglare dcglare.o cmbsdf.o cmatrix.o cmglare.o \
162 -lrtrad $(MLIB)
163
164 eplus_adduvf.o: ../common/triangulate.h ../common/rtprocess.h \
165 ../common/paths.h ../common/rtio.h ../common/random.h \
166 ../common/rtmath.h ../common/mat4.h ../common/fvect.h
167
168 eplus_adduvf.o eplus_idf.o: eplus_idf.h \
169 ../common/lookup.h
170
171 findglare.o glareval.o \
172 glaresrc.o: glare.h ../common/standard.h \
173 ../common/rtmisc.h ../common/rtio.h \
174 ../common/rtmath.h ../common/mat4.h ../common/fvect.h \
175 ../common/rterror.h ../common/view.h ../common/color.h setscan.h
176
177 glaresrc.o: ../common/linregr.h
178
179 rpiece.o: ../common/color.h ../common/view.h ../common/resolu.h
180
181 dctimestep.o: ../common/standard.h \
182 ../common/rtmisc.h ../common/rtio.h \
183 ../common/rtmath.h ../common/mat4.h ../common/fvect.h \
184 ../common/rterror.h ../common/resolu.h
185
186 dctimestep.o cmatrix.o cmbsdf.o: cmatrix.h ../common/color.h
187
188 cmatrix.o cmbsdf.o: ../common/standard.h \
189 ../common/rtmisc.h ../common/rtio.h \
190 ../common/rtmath.h ../common/mat4.h ../common/fvect.h \
191 ../common/rterror.h
192
193 cmbsdf.o: ../common/paths.h ../common/bsdf.h ../common/bsdf_m.h
194
195 rfluxmtx.o: ../common/rtio.h ../common/random.h ../common/triangulate.h \
196 ../common/rtmath.h ../common/fvect.h ../common/mat4.h ../common/tiff.h \
197 ../common/platform.h ../common/bsdf.h ../common/bsdf_m.h \
198 ../common/paths.h ../common/rtprocess.h
199
200 rmtxop.o dctimestep.o cmatrix.o: ../common/platform.h
201
202 dcglare.o rad.o ranimate.o rpiece.o xglaresrc.o: ../common/standard.h \
203 ../common/rtmisc.h ../common/rtio.h \
204 ../common/rtmath.h ../common/mat4.h ../common/fvect.h \
205 ../common/rterror.h
206
207 xglaresrc.o: ../common/view.h
208
209 glareval.o xglaresrc.o: ../common/resolu.h
210
211 glareval.o: ../common/platform.h ../common/rtprocess.h
212
213 rad.o ranimate.o: ../common/vars.h
214
215 ranimove1.o ranimove2.o vwrays.o: ../common/random.h
216
217 rad.o: ../common/paths.h
218
219 ranimate.o netproc.o: netproc.h
220
221 ranimove1.o: ../common/otypes.h ../rt/otspecial.h ../rt/source.h
222
223 netproc.o: ../common/paths.h
224
225 rad.o ranimate.o ranimove.o: ../common/view.h ../common/resolu.h
226
227 glrad.o: ../common/radogl.h \
228 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
229 ../common/rtmath.h ../common/mat4.h ../common/fvect.h ../common/rterror.h \
230 ../common/color.h ../common/object.h ../common/otypes.h ../common/lookup.h
231
232 glrad.o: glradicon.h ../common/view.h ../common/paths.h
233
234 ranimove.o ranimove1.o ranimove2.o: ranimove.h \
235 ../common/vars.h ../common/view.h \
236 ../rt/ray.h ../common/octree.h \
237 ../common/object.h ../common/color.h \
238 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
239 ../common/rtmath.h ../common/mat4.h ../common/fvect.h \
240 ../common/rterror.h
241
242 rsensor.o: ../rt/ray.h ../common/octree.h \
243 ../common/object.h ../common/color.h \
244 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
245 ../common/rtmath.h ../common/mat4.h ../common/fvect.h \
246 ../common/rterror.h
247
248 rsensor.o: ../common/view.h ../common/resolu.h ../rt/source.h
249
250 rcollate.o: ../common/platform.h \
251 ../common/rtio.h ../common/resolu.h
252
253 Version.c: ../rt/Version.c
254 cp ../rt/Version.c .
255
256 x11findwind.c: ../common/x11findwind.c
257 cp ../common/x11findwind.c .
258
259 rttree_reduce.o: ../common/rtio.h ../common/rterror.h
260
261 rmatrix.o: rmatrix.h cmatrix.h ../common/resolu.h
262
263 rmtxop.o: rmatrix.h cmatrix.h ../common/rtio.h ../common/resolu.h
264
265 wrapBSDF.o: ../common/rtio.h ../common/rtprocess.h ../common/ezxml.h \
266 ../common/bsdf.h ../common/bsdf_m.h ../common/fvect.h ../common/ccolor.h
267
268 pictool.o evalglare.o: pictool.h ../common/g3vector.h ../common/g3affine.h \
269 ../common/g3flist.h ../common/fvect.h ../common/gbasic.h
270
271 evalglare.o: ../common/rtio.h
272
273 radcompare.o: ../common/rtio.h ../common/color.h ../common/lookup.h \
274 ../common/platform.h ../common/normcodec.h ../common/depthcodec.h \
275 ../common/rtmath.h ../common/view.h
276
277 pictool.o: ../common/view.h ../common/color.h
278
279 getinfo.o: ../common/rtprocess.h ../common/platform.h ../common/resolu.h
280
281 rcode_depth.o: ../common/depthcodec.h \
282 ../common/view.h ../common/fvect.h ../common/resolu.h ../common/rtio.h \
283 ../common/platform.h
284
285 rcode_norm.o: ../common/normcodec.h \
286 ../common/rtmath.h ../common/mat4.h ../common/fvect.h \
287 ../common/resolu.h ../common/rtio.h ../common/platform.h
288
289 rcode_ident.o: ../common/idmap.h ../common/resolu.h \
290 ../common/platform.h ../common/rtio.h ../common/lookup.h
291
292 dcglare.o: ../common/platform.h ../common/resolu.h cmglare.h
